Why are car-based “crossover” wagons becoming so popular? That’s simple enough. They’re roomy like SUVs, usually look rugged like an SUV – and do about as well in the rain and snow as a truck-based SUV does – but without the truck-based SUV’s typically clunky ride and handling and typically obnoxious thirst for fuel.
Almost all of them have one big downside, however.
That downside – if you’re an enthusiast driver – is that nearly all current crossover wagons are based on front-wheel-drive layouts, usually with an all-wheel-drive system of some kind available optionally. If you want rear wheel drive (with a RWD-based AWD system) and the sports car handling/balance that comes with it, you’re pretty much out of luck.* *
One of the handful of exceptions to this rule is Infiniti’s rear-drive-based EX35
The EX35 is a compact, 5-door hatchback sportwagon – aka, a “crossover” – that differs from most crossovers currently on the market in that it’s built around a rear-wheel-drive (instead of front-wheel-drive) passenger car drivetrain and chassis. As such, it offers performance/handling characteristics very much like a RWD sport sedan’s.
Main competition is the BMW X3 and the Mercedes-Benz GLK – both of which are also based on RWD layouts, but which lean more toward the SUV-like side of the aisle than the sport sedan side of the aisle.
WHAT’S NEW for 2010
The EX35 was introduced last year as an all-new model, so changes for 2010 are incremental. All trims now come standard with USB ports for the audio system and the optional GPS system has been updated with Real Time Traffic and Weather assistance.
Also new is a noticeably higher sticker price.
The base 2010 model with rear-wheel-drive starts out at $33,800 vs. $31,900 in 2009. The range-topping Journey model with AWD is priced at $37,400 – vs. $36,850 in 2009.
Runs – and corners – like the G-series sport sedan it’s based on.
Brawny (297 hp) V-6 is standard equipment.
RWD versions can do burnouts; AWD versions won’t get stuck in the snow.
Ingot-like solidity outside; beautifully crafted on the inside.
Still a deal compared to the $38,850 BMW X3.
Stronger than the 268 hp $35,500 Benz GLK.
What’s up with the mondo price increase?
Where’s the six-speed on the floor?
Drinks gas like a ’76 Eldorado.
ENGINES & PERFORMANCE
One of the EX’s standout features is its high-powered (and standard equipment) 3.5 liter V-6. It is the same basic engine as used in the G-series sport sedan, as well as the Nissan Maxima and Altima – and the 370Z. It’s just slightly smaller in displacement and tuned-down a tad to just under 300 hp.
Still, that’s power enough to launch the EX from zero to 60 mph in about 6.3-6.5 seconds seconds (RWD versions are quickest), which makes the EX one of the fastest things going in its segment.
The EX’s main competition – the 260 hp BMW X3 and the 268 hp Benz GLK – are significantly less powerful, much heavier – and not nearly as quick. The X3, for example, needs about 7.2 seconds to make it to 60 mph.
However, you can get a manual transmission in the BMW (a feature not offered with the Infiniti). BMW also has an updated version of the X3 on deck for 2011 that will likely have more power, too.
Still, the EX is near the top of the pile as far as muscularity goes. Several FWD-based competitors like the Acura RDX and VW Tiguan don’t even offer V-6 engines and their fours max out around 240 hp – not even in the same ballpark as the EX35’s close-to-300-hp V-6.
A five-speed automatic is standard in the EX. It features “sport” programming that can be accessed by pushing a button on the console. This allows driver-control of up and down gear changes. There’s also a “Snow” mode that starts the transmission out in second gear (and reduces the aggressiveness of throttle tip-in) to improve grip on slick surfaces.
The EX’s optional AWD system differs from the more common (in crossovers) set-up in that, being based on a rear-wheel-drive layout, most of the engine’s power goes to the rear wheels, most of the time. As the rear wheels begin to slip, some of the engine’s power is automatically routed to the front wheels, to maximize traction.
In front-wheel-drive-based systems, most of the engine’s output normally goes to the front wheels, until they begin to slip – at which point the system kicks back power to the rear wheels.
What’s the difference – and why does it matter? The RWD-based system (with most of the engine’s power going to the rear wheels most of the time – and with the weight of the powertrain more evenly spread out from front to rear) gives better handling dynamics on dry, paved roads. A FWD-based system (with most of the engine’s power going to the front wheels most of the time – and with most of the powertrain’s weight on top of the front wheels) will give better grip on wet/slick roads, along with handling characteristics that are more forgiving of non-expert driver mistakes, such as carryinf too much speed into a decreasing radius turn. The RWD-based vehicle will tend to kick its tail out when this happens, which can be dealt with by applying more throttle and counter-steering. But this is a technique many average drivers haven’t mastered. Which is why a FWD-based vehicle – which will typically understeer, or “plow” toward the inside of the turn taken with too much speed – is more controllable and thus safer for the average driver.
But there’s a price to be paid – at the pump – for all this high-performance goodness. The EX wants premium fuel only and it wants it often. EPA rates this hawg at an impressively gas-guzzly 17 MPGs in the city and 24 MPGs on the highway. AWD versions knock it down to a suck-a-licious 16 MPGs in city driving and 23 on the highway.
In the EX’s defense, the X3 and GLK are about as bad, fuel-efficiency-wise. And they’re not nearly as powerful – nor as fun to drive (see below).
Still, Exxon-Mobil will just love you if you buy this ride.
DRIVING IMPRESSIONS
The EX may be the best handling vehicle of its type on the road.
RWD versions behave very much like a RWD sport sedan, which shouldn’t be surprising given the EX’s heritage. It is basically a wagonized version of Infiniti’s excellent G-series sport sedan – and rides and drives very much like it.
Most crossovers are either SUVs in drag – or wanna-be SUVs based on FWD passenger cars. This forces compromises in driving dynamics for the sake of off-road/poor weather bona fides. For example, the BMW X3 – which, being based on a rear-drive layout is closest to the EX in concept – is available only with full-time AWD and is set up to be more of a sporty all-weather SUV than an out and out sport wagon like the EX35.
The Benz GLK (based on the C-Class sport sedan) comes in both RWD and AWD versions, but the 30-something horsepower deficit gives the EX an obvious edge over the Benz sportwagon.
Further evidence of the EX’s tilt toward the sport side of the balance sheet is its standard/available wheel and tire packages, which include dry road-biased and very high-performance “W” (up to 168 mph) speed rated 18-inch performance tires.
The BMW X3’s standard tire is only “H” (up to 130 mph) rated.
Other factors that affect handling feel/cornering prowess are ride height and weight. The EX35 sits much lower to the pavement, with only 6.5 inches of clearance vs. the X3’s 8 inches (and nearly the same for the GLK, which has 7.9 inches of ground clearance).
That is a significant difference you really can feel in a high-speed turn.
The 3,757 lb. EX35 is also much lighter than the downright fatty 4,012 lb. X3 and the nearly two-ton (3,979 lb.) GLK. The lower unsprung mass – and the higher output engine – endow the EX35 with a much more athletic feel.
If only Infiniti offered a manual transmission, this thing would really rock. Even so, the standard five-speed automatic gives the operator much more control over gear changes (when in Sport mode) than most other automatics – which frequently won’t let you move down a gear (or up) until the computer decides you’re at an acceptable road speed or RPM.
In the EX, you can drop down to (and hold) a lower gear sooner – and for longer – which almost makes up for the absence of a clutch.
STYLING & UTILITY
The EX looks like what it is – a wagonized version of the G-series sedan. It’s much more restrained-looking than the wild-child FX (the EX’s big brother) which is even more wild-looking for 2010. The EX’s look is less dramatic, but it’s also less polarizing. You may not think the more conservatively styled EX is the most drop-dead gorgeous thing on four wheels, but it’s handsome and tasteful and even more important, neither will you (or others) point at it and say, “what the hell was that”? – as you might when an FX rolls by.
The interior layout of the EX is also similar to the way the G-series sedan’s laid out. It is much less SUV (or even crossover) like and more sport sedan-like, with a curving “double wave” dash that flows into the door panels and recessed LCD display for the GPS in the center stack. It is finished with black lacquer and aluminum trim plates or – optionally – wood veneer inserts.
One area where the EX is lacking relative to competitors like the BMW X3 and Benz GLK is cargo capacity. Behind the rear seats, there’s only about 19 cubic feet of space vs. the BMW’s 30 cubic feet and the Benz GLK’s 23.3 cubic feet.
Also, the back seat area is noticeably tighter, too. There’s just 28.5 inches of legroom for rear seat passengers vs. 35.8 in the X3 and 35.1 inches in the GLK.
Max tow rating is 3,500 lbs. – same as the GLK and X3.
QUALITY & SAFETY
Though several Infiniti models are either based on or share major components such as platforms and engines with less prestigious Nissan-branded models, Infiniti does a very effective job of putting distance between them – and not just price-wise.
The base EX, for example, comes with a high level of standard amenities, including automatic climate control, electric sunroof, premium stereo with factory satellite radio hook-up, 17 inch alloy wheels and Infiniti’s unique self-healing paint. The finish has high-elastic resins that let it expand to fill in small scratches without ever needing to visit a body shop – or get out the buffing compound.
With a starting price point of $33,800 the EX is also considerably less expensive than its most direct competitor, the BMW X3 ($38,850 to start), even factoring in the not-small uptick in MSRP for 2010.
Lots of safety equipment – both built-in crashworthiness and active accident-avoidance features – is a given on a vehicle such as the EX35. But in addition to the things you’d find in ay other similar in price vehicle, such as high-capacity disc brakes with ABS, side-impact and curtain air bags, traction and stability control, the EX35 goes up another notch with an available full perimeter Around View camera system that gives you a 360 degree bird’s eye look around the entire vehicle, as if you were floating 10 feet above it. It works when you’re moving forward as well as backing up, too – and makes it almost impossible to not notice something that you might otherwise bump into or drive over.
The EX also offers an optional Lane Departure Warning that beeps at you if you wander too near the double yellow line in the road. And this system does more than just beep at you, too. If the driver doesn’t make a steering correction to get the vehicle back on track, the system will do that for him – automatically.
The EX may look like a crossover SUV but it’s really a sportwagon, with more power than most – and better reflexes than any (in its price range, at least).
2012 Infinity EX35 AWD
http://www.youtube.com/watch?v=HEx7Lo23yJ8
2010 Infiniti EX35 – Инфинити ЕХ35
http://www.youtube.com/watch?v=PP5A1Mh8wCY
You can’t make a RWD vehicle drive like an AWD in the snow; it just doesn’t happen. But I’ve always used BF Goodrich tires since they have an awesome rep, lots of years in the industry. I’ve never had a problem with one of their tires and you can get studded or non studded for the same price with them. I have a RWD S10 and that’s all I use in the winter and I’ve never had any issues with them – they grab hard, keep traction and they don’t flex as much at the sidewall like other brands (I’ve used Dunlop, Firestone and Avian, they all kind of sucked in the really fluffy snow that everyone gets stuck in around here.
My take on the 4WD vs. AWD debate is this:
If you live in an area subject to frequent heavy snow, or need a vehicle capable of traversing rough off-road terrain and deep mud, then a 4WD (truck-based, with a two-speed transfer case and 4WD Low range) is probably what you want.
If, on the other hand, you rarely (if ever) go off-road (or “off-road” means a grassy field) and youonly have to deal with a handful of snow days each year – then AWD is probably going to meet your needs better.
Picture a line drawn on a page, with “extreme off-road/deep snow” on the left – and “dry, paved roads/little to no off-road driving” on the right.
The more your driving needs skew to the left, the more you need truck-based “real” 4WD. The farther to the right, the less you need it.
In fact, I’d advise that FWD will suit most people whose driving skews toward the right side of the scale above.
As I see it, both 4WD and AWD have been oversold. They have been very effectively marketed as “necessary” (or at least, very desirable) by the automakers for the obvious reason that they increase profits. But for the consumer, it often just means higher prices, worse gas mileage and higher/more frequent repair/maintenance.
I’m young, and ignorant. I ablusotely had to have a nice fast car. I bought a mercedes c32 amg. Biggest mistake of my life. It was still under an 8 year federal emmisions warranty for my ECU. It went out and mercedes put the blame on everything but the ECU. and refused to fix it. The total would be over 10000 to fix the piece of shit so now it just sits in the drive way and looks pretty Im never going german agian thanks to them. I hope none of you EVER buy mercedes benz. They are crooks.
Hi Barbara,
Sorry to hear about this – I’d contest it if I were you. Take the car to an independent shop and have them evaluate the problem. If in fact it is the ECU and the failure is covered by the warranty, then you have a factual basis for demanding that Mercedes honor its warranty and fix the problem.
