2013 Buick Verano
14
7285
The “key facts” press release that came with the 2013 Buick Verano I test-drove this week states that target competition is primarily the Lexus IS 250 and Acura TSX, which are entry-luxury (and compact-sized) sport sedans.Verano lead
Ok, sure – especially when Verano is equipped with the new-for-’13 2.0 liter, 250 hp turbo engine and (yes!) six-speed manual transmission.
In that case, it kills them both on price – and matches or beats them on straight-line performance (especially the slow-mo and way overpriced $35,065 to start Lexus, which tops out at just 204 hp and needs 8 embarrassingly long seconds to creep to 60… 8.3 if your order it with AWD).
But I think Buick is missing a marketing opportunity. While the Verano stacks up well against those relatively low-volume (and fairly high-priced) entry-luxury sport sedans, it could do some real damage if the nearly half-million people annually who buy a new Toyota Camry took the time to cross shop Verano.Verano T
Which they ought to.
They’re priced about the same ($23,080-$29,105 for the Buick vs. $22,055-$30,115 for the Toyota) and though the technically mid-sized Camry is slightly larger on the outside than the technically compact Verano, the Buick actually has almost as much interior space (more space, in at least one key area) with appreciably less space in only one area (backseat legroom).
And both cars are soft cars – Gentle Bens, with one-finger steering and ultra-cush rides. Only the Buick is cusher – and nicer.
But without being – and this is key – an old fogey’s car.
This Buick is a lot like Buicks used to be, ages ago. When they were classy, stylish, sporty – and cush. But not geezermobiles, either.
Which let’s face it, the Camry has become.
WHAT IT ISVerano inside
The Verano is Buick’s smallest model, but it actually checks out not-too-far from being mid-size if you compare its length, width and several interior measurements to the best-selling mid-size sedan on the market, Toyota’s Camry.
The models Buick mentions as target competition – the Lexus IS 250 and Acura TSX – are about the same size as the Verano – but they’re also several things the Verano’s not. For openers – and most obviously – they’re both a lot more expensive: $30,065 to start for the TSX and $35,065 to start for the Lexus.
The Verano starts at $23,080.Verano turbo engine
And for just under $30k ($29,105) you can buy a top-of-the-line turbo Verano.
That sum wouldn’t get you into the base trim versions of either the TSX or the IS250. It’s also less coin than Toyota asks for a top-line Camry V-6, which though fairly powerful is also fairly boring – and can’t be had with a stick.
So, you might consider the Verano a more youthful alternative to the dowager queen of mid-sized comfort cars (the Camry) or a steal of a deal compared with same-size entry-luxury sport sedans like the Lexus IS and Acura TSX.
Buick added Verano to the lineup in 2012 as an all-new model.
The big news for 2013 is the addition of a sporty Turbo trim to the lineup. It includes a 250 hp 2.0 liter turbo four and – wait for it – your choice of six-speed manual or six-speed automatic transmission.
Competitors like the IS 250 and Camry are automatic-only. And the Acura TSX offers a manual only with its base (low-powered) engine.
WHAT’S GOODVeranp pedals
Soft and quiet in a world of harsh and loud.
Not too soft – or too old.
Immediately comprehensible, easy-to-operate controls.
A clutch! In a Buick!
WHAT’S NOT SO GOODP1040755
Base-engined Verano’s on the slow side.
It has an absurdly tiny center console storage compartment.
The push-button start for the ignition might be made larger – and set apart from the other buttons.
Backseat’s a little tight, legroom-wise.P1040757
Last year, the Verano came with just one engine/transmission combo: A 2.4 liter four (180 hp) and six-speed automatic. It was – and still is … ok. It gets you from A to B. Not quickly – it takes about 9 seconds, which is slow in view of today’s typical average of 8-ish seconds or less – but reasonably efficiently: 21 city, 32 highway.
Still, nothing to write home about. Much less brag about.
This year, there is something to write home about: Not only has Buick put a 250 hp 2.0 liter turbo four into the mix, you can get this engine with a manual transmission – a feature not even offered in several competitors, as mentioned above.
So equipped, the Verano’s zero to 60 time drops to about 6.6 seconds, which is more than just ok.
In fact, it’s exactly as quick as the V-6 equipped Camry – and nearly as quick as the much more expensive Acura TSX with its optional 3.5 liter V-6 (6.4 seconds).P1040759
And it’s much quicker than the slo-mo and even more expensive Lexus IS250, which comes only with a 204 hp 2.5 liter V-6 and automatic – which makes it feel even slower than it is.
Interestingly, the turbo Verano is also a lot quicker than than its own sibling, the Regal GS – which is heavier and only gets a 220 hp version of the 2.0 turbo four. The turbo Regal GS also costs about $5k more: $34,980 to start. Just food for thought – if you can deal with a bit less backseat legroom (more on this below).
Best part? The Verano’s turbo engine nearly matches the fuel-efficiency of the underpowered 2.4 liter non-turbo base engine: 20 city, 31 highway.
That’s also dead heat with the Camry V-6 (21 city, 30 highway), the underpowered (and $35k to start)  IS250 – also 21 city, 30 highway – and slightly better than the $39k V-6/automatic Acura TSX (19 city, 28 highway).
All Veranos are FWD. Ditto the Camry and TSX.
The Lexus IS250 is based on a RWD layout and is available with AWD – but as mentioned above, when so equipped it’s only slightly less slow than the base-engined Verano, while costing literally almost $15k more.
One caveat: An all-new IS is on deck for 2014. It may – or may not – offer more power/value for the dollar. We’ll know more by late summer 2013.
Prospects who don’t mind The Slows might also want to check out the new Acura ILX.  At $25,900 to start, it’s more affordable than the TSX – but also needs 9 seconds to reach 60. A version is available with a larger, more powerful 2.4 liter (201 hp) engine and six-speed stick, but it’s still not nearly as quick. The big draw of the ILX is its available 1.5 liter/hybrid powertrain – which can get close to 40 MPG. But at the price of 10.4 seconds to 60 – best case.
ON THE ROADVerano road
The most distinctive – the exceptional – thing about this car is that  it’s both sporty and a softie. If that sounds oxymoronic, bear with and I’ll try to explain. Buy the turbo 2.0 engine and the thing will go. The fact that you can go manual only adds to the sporty feel. But in contrast to common practice – especially when a higher-performance engine is ordered – the Verano turbo’s ride quality is still exceptionally smooth, quiet and comfortable.  Buick hasn’t forgotten how a Buick ought to behave. The best comparison I could come up with to convey the sensation is memory foam. The way the car conforms to less than perfect roads – absorbs dips  and other defects such that you hardly know you just traversed them. And it does so without the usual affliction of bounciness.P1040756
These are driving qualities not often encountered in a modern car – especially a modern turbo car. It brought memories of the early ’70s Buicks, like the old GSX – which had the muscle of the Chevy SS Chevelle, but without the Chevelle’s roughness. Also, the mid-late 1980s Regal GNs. Those also had turbos – and were fierce in a straight line. But also plush and civilized the rest of the time.
The Verano is a lot like that.
Perhaps because it – like its ancestors – is gifted with seats more befitting a luxury car than a sports car (or sport sedan). They are not the cinch-you-in heavily bolstered buckets that are typical equipment in current-era sport sedans.  These have give. Like the suspension, though, they’re not too soft. I think they’re dead-on perfect for on-street driving. This business of putting race-track seats in street-driven cars is (mostly) silly. An SS 396 Chevelle was a beast in the quarter-mile. As it was on the street. The GSX 455 was also a beast in the quarter – but it didn’t beat you up the rest of the time. Again, same here as regards this modern incarnation of Buick-style performance and everyday liveability.verano wheel
Another example: The steering. It is electrically-assisted and feather light. This is how steering used to be set up in luxury-touring cars – and even some (Buick) performance cars. The upside? It’s easy to steer – and easy is another way of saying comfortable. Which is another way – the old school way – of saying luxurious.
The whole point of owning a luxury car, once upon a time, was that it coddled you, relaxed you. This the Verano does perhaps better than any car within $20k of its maxxed-out price.
Not only is it supremely composed, it is also supremely quiet – courtesy of features such as acoustically laminated glass. This is an exceedingly rare feature to find in a car whose MSRP doesn’t exceed $30k. (I had a Jaguar a few months back that had acoustic laminated glass. It also had a six figure sticker.)
I also want to mention – because it’s very much worth mentioning- the ease of use of all the Verano’s controls. Knobs and buttons – just the right size (not too small or too big) and whose functions are immediately comprehensible as well as effortlessly, immediately functional. Last week, I reviewed the Cadillac ATS. It’s a nice car, but it has the now-typical electrified whatzit controls that make luxury cars harder-to-operate cars than they ought to be. In the ATS, you have to repeatedly finger-swipe a narrow band of touch-sensitive metal – or repeatedly push a microwave oven-like flat panel – to get stuff done. In Verano, if you want to increase the volume of the stereo, you… turn a knob to the right. To reduce volume, turn it to the left. It can be done by feel, without thinking about it. Likewise changing the station or activating any other function. So… easy… effortless… calming… relaxing… .Verano stack
So luxurious.
Just one small beef: The push-button for the keyless ignition is kind of small – and mounted too close to other controls on the center stack. Usually, the Start/Stop button is off by itself someplace – for the obvious reason. You may inadvertently push the Buick’s button while the car is moving. The good news is the Buick will ask you first before actually turning off the engine while you’re running 70 MPH.
AT THE CURBVernao wide
The Verano’s a slick piece of work here as well. And I don’t mean just its looks.
Rather, look at its measurements. At 183.9 inches long overall, it is just over five inches shorter, bumper to bumper, than a Camry (189.2 inches). But the Buick gives you 42 inches of front-seat legroom – vs. 41.6 inches in Camry. Trunk space is close, too: 14.3 cubic feet for the Verano vs. 15.4 for Camry.
To be fair to the poor Toyota, you would get an extra 4.6 inches of backseat legroom (38.9 inches vs. 34.3 inches) and that’s no small thing. But if you don’t routinely carry a pair of full-size adults in the back seats, backseat legroom might be a third or fourth tier issue. Front seat space, on the other hand, is something the driver and his primary passenger must live with every time, all the time.
Incidentally, the Lexus IS has virtually nonexistent backseat legroom: 30.6 inches.
The Acura TSX does better, with a very impressive (given the size of the overall package) 42.4 inches of front seat legroom and 34.3 inches of backseat legroom. But, again, it’s hard to fairly do a direct comparison given the Acura starts out nearly $7k more than the Buick. And don’t forget: For that $30k, you get a four-cylinder (and 204 hp, 8 second to 60) TSX vs. a turbo’d four (and 250 hp and 6.6 seconds to 60) Buick… with a manual transmission.Verano backlit
And the base ($23k) Verano’s no Blue Lite Special, either – though it does come with cool-looking ice blue backlighting. Also standard: 18 inch wheels, six-speaker stereo with satellite radio, keyless ignition, automatic climate control, a seven inch LCD infotainment screen in the center stack, Bluetooth and Buick’s IntelliLink voice-controlled electronics interface. You can use this to stream podcasts through the car’s stereo as well as make hands-free phone calls.
For $23k, that’s a lot. Compare what the Verano gives you vs. what the $22k Camry does – or for that matter, the $35k Lexus IS (or $30k TSX).
You can order a Leather group, which (obviously) adds leather seat covers and trim – as well as heated seats and steering wheel, plus a Bose premium stereo. Also available is a Convenience group that adds heated outside mirrors, blind spot warning system, rear park sensors and six-way power driver’s seat.
Both options packages come standard in the Verano turbo.
THE RESTVeran backseats
I found myself liking this car – a lot. It is reasonably priced, outstandingly comfortable and sufficiently fun to drive on top of that.
Just being able to surprise people by showing them the clutch pedal is almost worth buying it. But it’s more than just that – though that is a pretty big deal all by itself (how ironic is it that it’s easier to get a manual transmission these days in a Buick than in an Acura or Lexus?)
The thing that sways me most is how vividly the Verano brought back memories – good memories – of what was best about luxury cars 20 or 30 years ago. But without the downsides of wallowy handling and Old Man Ambiance.
Buick’s doing it right.
Which is why Buick survives.
And may just thrive.
14 COMMENTS
  1. This thread is probably closed, but as an owner of a 2012 Verano it just about weaned me of American cars. Parts falling off, seat covers coming undone plus a Bose stereo that blew the back two speakers when it tried to reproduce a bass bassoon. Terrible fuel economy 16 city, driving it like a grandma. Thank God I had the foresight to lease it for two years instead of buy it. I gave Buick one more chance and bought a Korean made Encore, now on my second one. Great car, get 2-3 miles better than the EPA estimate on both, and best of all no parts have fallen off either one yet!!!!
  2. YOU ARE INCORRECT ON THE TIME OF THE VERANO TURBO TO 60 IT IS 6.2 ACCORDING TO THE BUICK BROCHURE.AND THE REGAL GS HAS 270 HP AND 295 TORQUE AT ITS INCEPTION AS A 2011 AND HAS NOT CHANGED FOR 13.AS FOR THE TIME ON THE GS TO 60 IS 6.7 AND A WEIGHT DIFFERENCE OF OF ALMOST 450 LBS.
  3. I skimmed the article and saw this fact left out. E85 would make it perform the best or even E30 with it’s high octane characteristics.
    E85 Flex Fuel Buick Verano
    First offered as a Flex Fuel Model in 2012 , it is essentially a cross between the Chvey Cruze and the Buick Regal . The Verano is expected to come with an optionla 2.0 l Turbocharged engine latter in the year (2012) as well as come in the new 2.5L engine that GM will roll out in 2013. We expect both of the engine packages will also be E85 Flex Fuel capable.
    • Hi Martin,
      True –
      But, what of vehicles not “flex-fuel” optimized?
      This is the nut of my complaint.
      I am not opposed to ethanol. I am opposed to ethanol’s being force-fed to us via government mandates.
      By all means, make ethanol (in whatever ratio) available to those who need it and wish to purchase it. But forcing everyone to buy the stuff?
      That’s where I draw the line.
      • E85 SUCKS AND DOES NOT GIVE YOU THE POWER THAT YOU THINK AND STATED HERE,THERE MAYBE A DIFFERENT VERSION I M NOT AWARE OF THAT MIGHT PERFORM NOT E85. ALSO MY BUICK REGAL TURBO MANUEL DOES NOT RECOMMEND IT FOR PERFORMANCE.
        • Ethanol has a very high anti-knock rating allowing higher compression and spark timing more suitable for higher HP. In other words the engine (and/or its management system) has to be designed for it.
  4. I went to the dealer yesterday for a test drive in the “Leather Group” trim package (no turbo). Overall it was a very nice car for the money (with a nice warranty), and the driver seat had the extra legroom that I need. However, it really felt like a compact car everywhere else: the storage areas inside the cabin were extremely limited, and legroom in the backseat was completely non-existent after adjusting the front seats. I was also pretty disappointed in the 2.4L engine, with regard to both power and fuel mileage.
  5. I was getting pretty excited about it until I realized that the gas tank is on the “wrong” side. Passenger-side tanks get me every time.. so annoying!
  6. I wish the ever-expanding dashboard growth would cease. The front seats should be my last resort, my last refuge, for sufficient legroom. The photo directly under the “At The Curb” header is not reassuring. A passenger airbag doesn’t require a over sized dashboard. I understand that they are a direct result of steeply raked windshields. Is there also a Federal safety component attached to the near-universal presence of wrap-around dashboards that intrude on my valuable knee and legroom?
    Signed,
    Someone Tall But Not Fat
    • I’m with you, James –
      In addition to ever-expanding dashboards, new cars are also afflicted with thick (and side vision impairing) B pillars. It’s common – pretty much all the 2012/2013 vehicles I’ve driven have the same problem.
  7. Is that a standard I see on a Buick no less? I’m impressed. I had an older Park Avenue that I just loved for its “geezerishness”, fuel economy, and how solid it was, but this comes as a real surprise.
