2015 Scion FR-S
20
7671
Muscle cars and pony cars and exotic high-performance cars abound.'15 FR-S lead
But there aren’t many true sports cars around.
Not for less than $25k to start, at least.
Arguably, the Mazda Miata has been the only one.
It has certainly been the most successful one. For 25 years now – and still going strong.
Subaru and Toyota (an oddfellas partnership, if ever there was one) decided to have a go at this action – joining forces to produce what you might call an uber Miata.
The result of their joint effort was – is – The Twins. The Scion-badged FR-S (subject of this review) and its Subaru-skinned fraternal twin, the BRZ.'15 FR-S back seat pic
They offer a very Miata-like experience – at the same price point – but with a twist.
Unlike the two-seater-only Miata, the twins have back seats.
Brutal back seats, surely. But there, nonetheless.
Also a more macho mien.
No “chick car” issues here.
It’s a very different take on the same basic concept.
Which is cool.
After all, why should there be just one hamburger joint in town?
WHAT IT IS'15 FR-S desert
The FR-S is a compact-sized, two-door and (theoretically) four-seat sport coupe. It is mechanically identical to the Subaru BRZ, with minor exterior styling, trim/packaging and pricing differences between the two cars – which are actually built by Subaru and have Subaru-designed drivetrains, including most notably the “flat four” boxer engine used in both cars.
Base price for the Scion-ized version of the Sciobaru twins is $24,900 – vs. $25,695 for the same basic car in Subaru duds.
Interestingly, the Scion starts out less – but ends up costing more – than its twin. A top-of-the-line FR-S with the Release Series 1.0 package and the optionally available automatic transmission stickers for $31,090 while a Blue Series BRZ (top of its respective line) goes for $29,940.'15 FR-S dash pic 1
Direct competitors are few – because there simply aren’t many compact-sized/rear-wheel-drive sports coupes available at this price point.
Make that any.
Cars like the Hyundai Genesis and Ford Mustang are RWD sport coupes, too – but they’re also much larger, heavier and more expensive. Meanwhile, cars like the VW GTI and Ford Focus ST are priced in the same ballpark, but they’re front-wheel-drive.
Probably the closest-in-kind cross-shop among current new cars is the Mazda MX-5 Miata. It’s a little smaller – and only a two-seater (as well as being a roadster, with a convertible soft top standard) but it’s also RWD and offers a comparable sports car driving experience (these cars are very evenly matched in terms of acceleration and handling) and the price points match up closely.
At $23,970 to start, the Miata actually costs a few bucks less than the base FR-S.
WHAT’S NEW'15 FR-S back view
Both twins have had their suspensions slightly retuned – but this will only be noticeable to those who track-day their cars (and compare them with last year’s cars). All trims get a standard 6.1 inch LCD touchscreen screen for the audio system, with Scion’s BeSpoke upgrade available optionally.
Minor cosmetic tweaks – including new design exhaust tips – also distinguish the ’15s from the ’14s.
Like the Miata, this car is inexpensive fun. A track day car that can be driven everyday.
And unlike the Miata, this car has back seats.
Brilliant high-speed handling. A Lotus for less.
Boxer four has all kinds of potential.
WHAT’S NOT SO GOODScion FR-S interior
Back seats are literally useless for carrying passengers because there is literally no legroom. No air gap at all – unless you bunch up the front seats to create some – and then the driver and front seat passenger will be the ones suffering.
Broody/heavy – and plasticky – interior.
Horrible cupholders guaranteed to spill your coffee – and dislocate your shoulder.
Boxer engine’s potential remains untapped; automatic-equipped cars are much slower than manual-equipped versions.
UNDER THE HOOD'15 FR-S engine 2
Both twins pack the same engine as last year – and the year before.
On the plus side, it is an unusual engine. A Subaru-designed/sourced flat four, with the cylinders laid flat on their sides – one pair “boxing” the other across a common crankshaft. The major functional advantage of this layout is inherent smoothness – and that the center of gravity is lowered. Instead of the engine standing upright and with the cylinders lined up in a row – as would be the case with a conventional in-line four (as in the Miata), the engine in the FR-S and BRZ is pancaked horizontally and this naturally enhances the balance and stability of the car.
On the downside – depending on your point-of-view – the output remains unchanged: 200 hp at 7,000 RPM and 151 ft.-lbs. of torque at 6,600 RPM. Buyers who had been waiting in anticipation of a WRX’d (or even better, STi’d) version of the 2.0 engine will have to wait some more …  or do their own WRX’ing.'15 FR-S Boxer detail
Still, the twins perform well as-is. Meaning, they perform as well – or better – than the MX-5 Miata.
A manual FR-S gets to 60 in 6.4 seconds or so; the Mazda (being slightly less powerful) is just slightly less quick.
It needs about 6.6 seconds to do the same run.
But, be advised: The optional six-speed automatic really slows the car down. Zero to 60 takes nearly eight seconds when so equipped. You do, however, get a reward – or rather, compensation – in the form of significantly improved fuel economy due to the automatic’s better-than-you-can-do-it shifting. With the auto-box, an FR-S rates 25 city and 34 on the highway – vs. the manual-equipped car’s 22 city, 30 highway.  '15 FR-S automatic detail
In both cases, the Scion does better at the pump than the Miata – surprising, given the Mazda is smaller and lighter and has a less powerful (167 hp) engine. It should also be mentioned that the Miata still comes standard with a five-speed manual. A six-speed is available, but you have to pay extra to get it.
On the other hand, the FR-S requires premium fuel while the Mazda merely recommends it.
So what happens if you run regular unleaded in the Scion? You won’t hurt anything. But you may notice a slight drop in fuel economy and performance, because the engine is optimized to burn higher-octane fuel. Or put another way: You won’t save much if any money by using lower-cost regular unleaded – because your gas mileage will drop a bit from what it would otherwise have been if you’d filled up with premium.
ON THE ROAD'15 FR-S track day
There is a wise old gearhead saying: It is more fun to drive a slow car fast than it is to drive a fast car slow.
The FR-S is not slow, of course. At least, not when equipped with the six-speed manual transmission. But it is not a bullet – like a 370Z, for instance.
Or even a Hyundai Genesis.
But it is very light – as modern cars go. Just over 2,700 pounds – which is a bit heavier than the Miata (2,480 pounds) but nonetheless, a comparative featherweight compared with members of the 3,000-plus-pound club like the Genesis (3,495 lbs.) and Mustang (3,524 lbs.) and 370Z (3,278 lbs.).
Even small FWD 2-plus-2 hatchback coupes like the VW GTI (3,160 lbs.) and  Ford Focus ST (3,223 lbs.) are comparative porkers in comparison.
Nose heavy porkers, too.'15 FR-S road 2
With its boxer engine mounted low in the chassis – and the weight of its drivetrain more evenly distributed from front to rear – the Scion’s handling is inherently advantaged as compared with the FWD stuff.
In a FWD car – with most of the drivetrain’s weight located over the front axle centerline – the back end (already light) tends to get lighter as weight shifts forward mid-corner. And may the ghost of Elvis help you if you brake suddenly.
Suspension tuning can compensate for this to some extent, but the RWD layout is naturally better in terms of high-speed dynamics, especially when dancing on the razor’s edge. For example, by applying more throttle, you can effectively transfer weight rearward and use the rear wheels to help steer the car – impossible to do in a FWD car, where the back wheels are merely along for the ride.
The Scion’s grip threshold is extremely high – as is true, frankly, of almost any modern sports car. So high, in fact, that to really explore the car’s (or your own) limits it is necessary to drive at speeds that are grossly illegal in the land of the formerly free. This is both good – and extremely frustrating. Good, because the car’s limits are so high that you can drive it very fast (relative to the posted speed limit) with almost no real effort. The car does the work for you. What would have been tire-skittering/lunch-losing scary in a ’70 MG is – yawn – just loping along in a car like the FR-S.'15 FR-S road 3
To catch up to the limits of the FR-S requires track day hustling – and at that point, you are in danger of a roadside anal probing followed by a stay at your local Abu Ghraib.
Or something worse, if the car gets away from you.
Probably this is why Toyota made it so that if you select the most aggressive VSC/Sport setting, the traction control stays on. At least, just enough on to reel you back in, if you push the car beyond your limits.'15 FR-S modes pic
This year, they sent me an automatic-equipped version to test. I found it much less enjoyable to drive, even though the automatic transmission itself cannot be faulted. In Sport mode, the gear changes are speed bag brutal. The tires would chirp … if the engine made enough power to do that. The rev-matching downshifts dance in near-perfect syncopation with whatever you happen to be doing. Descending the 9 percent grade and series of sharp S turns that is Bent Mountain Road out here in The Woods, the Scion’s box admirably double downshifted and held the right gear to keep the engine on its power curve through each sweeper.
'15 FR-S road 5
But – and this is just as true of the Miata – there’s not enough horsepower (or torque) for an automatic to work well in a car like this. That is, to get the car going soon enough …  for a car like this. Losing two seconds (almost) to 60 is a tough thing to accept, even if you do get more gas mileage as part of the deal  – and because there’s so little torque at lower engine speeds (remember, the 151 ft.-lb. peak does not happen until 6,600 RPM) the car frequently feels sluggish until the revs can build (and torque is produced).
No doubt this is why Honda never offered the S2000 (RIP) with an automatic and – arguably – neither of the twins (and for that matter, the Miata) ought to be saddled with an automatic, either.
All these cars are not only easy-drivers with manual transmissions (thanks to hydraulic-assist clutches with light-on-the-legs action) they are better drivers with the manual.
Get the automatic if you must.
But otherwise, stick with the stick. You’ll be much happier, even if you do lose a few MPGs.
AT THE CURB'15 FR-S curb 1
The FR-S is a much more macho-looking car than the Miata, which has been accused of being a “chick” car. Which it’s not – just ask all the guys who autocross Miatas in SCCA club racing.
If anything, the more harmless-looking Miata makes it easier to run under the radar and actually use the car for its intended purpose. The week I had the FR-S (in red) I also had a Miata (in gray).
Guess which car drew less attention from the bullet-headed beat-down boys?
The FR-S is also a bigger car.'15 FR-S gauge detail
Just shy of  10 inches longer (166.7 inches vs 157.3 for the Miata), 2.2 inches wider through the hips (69.9 inches vs. 67.7) and considerably heavier (2,708 lbs. 2,480) though both cars are featherweights, by the increasingly portly new car average of 3,200-ish pounds.
Interestingly, you feel like you’re sitting lower in the FR-S, even though the Miata actually sits lower to the ground (50.6 inches for the Scion vs. 49 inches for the Mazda). This is due to the Scion’s higher door tops. In the Miata, a tall geek like me could almost rest his left elbow on the top of the door, with the window rolled down.
Wind and road noise is another big difference. There’s  a constant background whoosh in the convertible Miata, whereas the hardtop FR-S is pretty quiet, unless you’re flogging the engine.'15 FR-S door cupholder
And that’s good noise.
On the downside, the placement of the cupholders in the FR-S is torturous – and spill-certain. There are two in the center console – mounted impossibly far back, such that you either have to use your left hand to get your cup (reaching over yourself to do it) or raise your right arm up – and then back – and try to pick it up, like one of those grabber arms at a kewpie doll game of chance. There is another upholder molded into each door panel – and it’s big and in the right place. But it’s also partially obscured by the forward-canted door pulls – which makes getting your coffee out of there without sloshing it all over you a near-Olympic challenge.
The interior layout itself is business-like (which is good) but slightly broody – and a bit plasticky. I like the up-tempo look of the Miata’s dashboard more.
But this is a judgment call – and personal preferences vary.'15 FR-S back seat 3
I am not sure whether to cheer – or jeer – the layout of this allegedly 2-plus-2 sports coupe.
Theoretically, having back seats ought to make the FR-S (and BRZ) the more wife-acceptable/everyday-viable cars vs. the two-seater Miata. But in actuality, the FR-S (and BRZ) are two-seaters, too.
The back seats – while physically there – are like looking through a plate glass window at ice cream you can’t have. With the front seats in almost any position that makes sitting in them viable for either the driver or the front seat passenger, there is literally – I am not exaggerating – no space for putative back seat riders’s legs. These would need to be tucked in, fetal style, for our hypothetical people to sit back there. Now, if the FR-S/BRZ twins were hatchbacks (like the Scion tC I reviewed a few weeks back; see here) then the additional real estate could at least be used to carry cargo. But the FR-S and BRZ have conventional trunks – which are so tiny (6.9 cubic feet) as to be hardly worth having.'15 FR-S trunk
The rear seatbacks are one-piece, though – and they fold. This helps … cargo-carrying-wise.
Also, the trunk – though small – is larger than the Miata’s purse-sized 5.3 cuber.
I love the pull-up emergency brake – which is set so that you can lock up the rear wheels.
Also, the oil filter is located topside – just pop the hood. No need to crawl under the car to get at it.
THE REST'15 FR-S vents
More power would certainly be nice, but it would also make the FR-S (and BRZ) less affordable than they are – and also put them into competition with cars like the Genesis coupe and Nissan 370Z.
I think Toyota-Subaru is being smart to keep things as-is. The cars are selling well, in the way they were meant to sell – as specialty/niche vehicles. They were never meant to be high-volume cars or, for that matter, high-performance cars. They were designed to be sports cars – and affordable.
Success on both counts. Leave it alone.'15 Scion Be Spoke
Incidentals: Being a Scion, the FR-S doesn’t offer many factory options. But there are a number of dealer-installed (or over the counter and you install) options, including fog lights (look out, they’re $490), an upgrade exhaust system, various wheels and – the big one – Scion’s BeSpoke premium audio rig, which includes Internet radio and navigation. It’s an easy to use unit, with just a few buttons – but the screen is smallish and has an aftermarket look to it.
It’s nice that Subaru-Toyota didn’t just make another Miata.
Or even a better one.
Just a different one.
We depend on you to keep the wheels turning.  If you value alternatives to the MSM, please support independent mediaOur donate button is here.
20 COMMENTS
  1. I heard about this website from your interview on the Tom Woods show. I absolutely love this car. I’ve been going back and forth between keeping and upgrading my 95 Integra GS-R or getting one of these. Of course, I’d be tempted to turbo this car if I got it. If you haven’t seen the 450hp Crawford BRZ, it’s worth a look. I think I would shoot for 300hp.
  2. i am actually surprised they haven’t offered a TRD supercharger. they do it for tundras and used to offer it for the tc’s.
    i assume they don’t because it really is a subaru engine, not a toyota.
    overall i personally like the car, i recently test drove one but it does lack power, i think another 50 would be very satisfying (and why an sc offering 6-7 psi would be good). i plan on keeping it on my radar, in a couple of years the first ones won’t be under warranty and shoudl be able to be bought at a fair price used and then just stick a wrx motor in it.
    • I haven’t looked into it, but I’d bet there’s a lot of aftermarket hop up stuff available. A turbo kit that would goose the output to 260-280 or so would really wake this car up and make it a lot like one of my all-time favorites (dearly departed)… the Mazda RX-7 turbo….
  3. I own a 13 scion variant of this car. It’s not that fast. The interior is mediocre. Comfortable, supportive and with a great driving position, but plasticky, like Eric says, and with a terrible radio, and with terrible fake carbon fiber. Fit is good, but there are some rattles which seem to come from the plastic trim. With speed limits and fines being what they are, it is better to drive a slow car quickly these days. And this car begs to be driven quickly. It really doesn’t feel slow when you’re above, say, 5500rpm on a bendy mountain road. It does feel slow when you race against almost anything. More power would be nice, but is best left for after warranty, and is not really mandatory. Aftermarket parts are plentiful, with even Cosworth getting in the mix. The back seats are definitely usable for three people around town. I can’t put someone behind me and feel comfortable driving. But someone behind the front-seat passenger isn’t that big of a deal for short trips. Best car I’ve driven, and definitely the best I’ve owned.
  4. I drove one of these about a year ago. While I admit it felt sluggish due to lack of torque, everything about it feels just right. It was designed to be a drivers car. The brakes, clutch, steering and seating position just feel amazing.
    When I drive a new car the first few miles are herky-jerky as i get used to the odd brake engagement, throttle response and clutch feedback. On the FR-S I jumped in and was amazed at how great and intuitive the driving experience was.
  5. “There is a wise old gearhead saying: It is more fun to drive a slow car fast than it is to drive a fast car slow.”
    Whoever that “wise old gear head” was, he was not enlightened enough to reach logical conclusion of this line of thought, namely………
    “It is more fun to drive a fast car fast, than to drive a slow car….period!”
  6. I know one use for that useless back seat. My boss sold his Miata because his wife would not let him take his 8-yr old son anywhere. With no front passenger, he should have been able to move that seat far enough forward to fit the boy in the back. Of course the Miata was a big step down from his Z3 M-class.
  7. While arguably a 2+2 (meaning 2 people and 2 bags of groceries), the real reason that back seat being there is to make the insurance somewhat affordable for the 19-25 year-olds this car is targeted towards.
    Personally, I’d get the Subaru over the Scion. There are rumors that Scion (as a brand) hasn’t been doing all that well and that Toyota might kill it. Which would make the FR-S an orphan. Additionally, Toyota is partnering with BMW on their next sports car, so the relationship with Subaru might be on the rocks, in any case.
    • Hi Chip,
      I wonder…
      My guess/bet would be that the Miata costs less to insure – because it’s less powerful and not perceived as a “racy” car. It’d be interesting to get some quotes… .
      I wouldn’t be concerned about the Scion going away issue – even if the brand does go away. Because the FR-S is a Subaru in everything but name. And Subaru isn’t going anywhere!
      • eric, what’s up with the sorry plastic? Last time I looked at a Toy and GM pickup side by side, I got out of the Toy going cheep cheep cheep(but you could get sticker shock when looking). Really, I don’t get cheap plastic on anything but some really obscure entry-level car and even that doesn’t make much sense unless it really is cheap….to buy. 30mpg, the same as an early 90’s GM mid-size car with loads more room, a great ride, leather interior and great seats with plenty of room for four or five and cheap replacement parts. And the performance models came with 4 wheel independent suspension and disc brakes all the way around. And the front ends didn’t look like an angry catfish. Are we in a time warp?
      • I suppose that’s the other thing about the FR-S. If it’s really a Subaru under the skin, why not just buy the Subaru version? You’ll get mechanics who know how to work on the Boxer engine if you ever need work done on it.
        • I agree, Chip.
          Kind of like the now-defunct “Pontiac” Trans-Am of circa 1982-2002. It was just a reskinned Camaro, with identical (Chevy) mechanicals.
          Why bother?
          Not many did….
          • I did buy a Chevy Prizm, which was not even reskinned, just a rebadged Corolla. I did it because the price was $1k less.
            • Hi Phillip,
              Yup.
              Same deal with the “twins.” There are different pricing structures, as well as different trim/options. It gives people more choice, which is good.
      • Dear Eric,
        “My guess/bet would be that the Miata costs less to insure – because it’s less powerful and not perceived as a “racy” car. ”
        That actually makes me glad the Miata is perceived by insecure macho types as a “chick’s car.”
        They’re unwittingly helping to drive down the ownership cost of what is in fact a dyed in the wool sports car akin to the Lotus Elan. They are unintentionally helping out other more level-headed car buffs who are not intimidated by insinuations that they “lost their man card.”
    • Dear Chip,
      “the real reason that back seat being there is to make the insurance somewhat affordable… ”
      If so, shrewd move. Personally I would simply reframe the car as a two seater in my mind and not worry about it.
      After all, the back seat apparently folds right down and creates a huge trunk, so what’s not to like?
      http://www.cars101.com/subaru/brz/brz13-trunk-tray1.jpg
      It’s a two seater with a huge trunk. How is that a problem?
