Results 1 to 8 of 8
Thread: Temperature gauge not working.
    2,028
    I'm trying to figure out why my temperature gauge isn't working very often. It sometimes works, when it feels like it, but not all the time. The cooling system is clean and full, I've replaced both sending units for the computer and gauge. It quit working once when I went to the store. I've been driving down the road and it would start to work. Later, when I start the car, it doesn't do anything.
    When the gauge is not working, and vehicle has had enough time to warm up, do you ever turn on the heater and feel if it's blowing normal hot?
    Just to confirm it is in fact the gauge/sensor/wiring problem and not the thermostat wide open.
    2,028
    It's a fairly new thermostat. I use FailSafe units and they will stay open when they fail. I'm getting heat, it makes no difference if the gauge is working or not. I'm sure the problem is electrical, I just am trying to track down where to look.
    What is the year, make, and model of the unit?
    642
    Is there one of those film type circuits behind the gauges? I have seen those go intermittent.
    2,028
    It's a 1998 Ford Taurus SE. I suspect a loose wire somewhere but neck injury keeps me from getting down in there to trace it easily.
    3,339
    The symptoms you describe are typical of a loose/corroded connection, Grouch. On a 98 Ford, I would tend towards the possibility of a corroded connector somewhere in the circuit. If so, as you obviously know, it is a track and clean task that can take a few minutes or several hours. I have, unfortunately, no idea how many connectors there are between the sender and the dash circuit panel.
    642
    I used a Failsafe ONCE. In failed in 50 miles and stayed stuck OPEN. Replace it with a NORMAL thermostat!
    Don't be so sure it's an electrical problem! At least not yet!
  1. Temperature gauge problem found, maybe.
    By grouch in forum Car Care & Repair
    Last Post: 02-21-2011, 10:31 PM
  2. Temperature gauge
    Last Post: 02-19-2011, 09:56 PM
  3. oil pressure guage not working
    Last Post: 07-15-2010, 07:01 AM
  4. Oil gauge installed on old Kaw
    Last Post: 01-13-2008, 05:41 PM
  5. Oil gauge for old Kaw
    Last Post: 01-09-2007, 02:56 PM
