2013 Infiniti JX35
3
5356
No car salesman ever wants to find himself admitting to a customer that he just hasn’t got what they’re looking for . . . but the guy down the street does.JX lead
Before the introduction of the JX35, that was exactly the situation Infiniti salesmen – and dealers – were in. There was the Q56 – for people who wanted a full-size SUV with three rows of seats. But what if you wanted the three rows – but not the full-size SUV?
No dice.
The next-down model in the Infiniti lineup was the much smaller (and five passenger-only) FX.
Nothing in-between
Well, not anymore.
The JX gives Infiniti a vehicle that can go heads-up against the very successful Acura MDX and also newcomers like the Buick Enclave – and which straddles the gap between the too-big-for-some Q56 – and the too-small-for-others FX.
WHAT IT ISJX rear
The JX35 is a full-size/three row luxury crossover, available in both FWD and AWD verisons. It’s based on the Nissan Murano – but much larger and fitted out with every tech-lux gadget Infiniti’s got in the bin.
Prices start at $41,250 – about $2k more than an Acura MDX and about $3k less than a Buick Enclave.
Other possible cross-shops include the new Lincoln MKT wagon ($45,285) and the Audi Q7 ($46,800).
The JX is a new model, just added to Infiniti’s lineup.
WHAT’S GOODJX room
More room inside for people than the QX – but not as large on the outside as the QX.
Plush ride.
A pretty decent deal – relative to most of the others in this segment.
Some controls are poorly located/hard to operate.
Complex – and expensive – “bundling” of options. Out-the-door price can rise real quick.
Lower tow rating (3,500 lbs.) than rivals like Q7 (8,500 lbs.), MDX (5,000 lbs.) and Enclave (4,500 lbs.)
UNDER THE HOODJX engine
For now, the JX comes only with a 3.5 liter, 265 hp V-6 paired up with a continuously variable (CVT) automatic and either FWD or a full-time AWD system.
Some have criticized both the power and the performance of the JX’s drivetrain, but both are par for the segment.
Better than par, actually.
The JX takes about 8.2 seconds to reach 60 with FWD; AWD models are slightly behind that at 8.3-8.4 seconds. That’s quicker than the stronger-on-paper Buick Enclave (3.6 liters, 288 hp and 0-60 in about 8.6 seconds) and Lincoln MKT with its standard 3.7 liter, 300 hp engine (0-60 in about 8.6 seconds).JX shift
The Acura MDX (3.7 liters, 300 hp and 7.2 seconds to 60) and Lincoln MKT with its optional twin-turbo EcoBoost 3.5 V-6 (zero to 60 in 6.3 seconds) are both quicker – but both cost more. In the case of the EcoBoosted MKT, a lot more. The base price for this model is $48,175 – seven thousand dollars more than the JX’s base price.
Mileage-wise, the JX comes in at 18 city/24 highway for the FWD version and 18/23 for the AWD-equipped version. I averaged 20.5 during my week long test-drive.
This, too, is par for the segment. The FWD Enclave rates 17 city, 24 highway and 16 city, 22 highway with AWD. The MKT: 17 city, 24 highway with the 3.7 liter V-6 and FWD. The MDX rates 16 city, 21 highway. The hungry hippo Q7 comes in at a V-8 SUV-esque 14 city, 20 highway.
One area the JX comes up noticeably short is towing capacity. This full-size crossover only pulls as much as a typical mid-sized car: 3,500 lbs. That’s adequate for small single axle trailers. But if you need more capability, the others offer more. In the case of the Q7, a lot more – 8,500 lbs., which is in the same ballpark as V-8 pick-ups and SUVs. The Acura MDX and Lincoln MKT can pull a decent load, too: 5,000 lbs. for the both of them. Ditto the Enclave, which has a max rating of 4,500 lbs.
ON THE ROADJX road 2
Some reviewers have criticized the J for not-so-hot acceleration. I’ve already pointed out that, in fact, it’s at least as quick as most of its price-equivalent competition – and quicker than some of them.
But perhaps the most standout characteristic is not so much the engine – but the CVT automatic transmission it works through. It is turbine-smooth, yet also capable of mimicking a conventional “stepped” automatic – as when it seems to shift gears during full-throttle acceleration. Most CVTs will let the engine rush right up to redline – or very close to redline – and just hold the engine there, for as long as you hold your foot down. It’s not just that it’s noisy – it sounds like something’s broken – or may be about to break. The J’s CVT doesn’t sound like that – because it doesn’t operate like that. It lets the engine rev, then does a perfect imitation of a conventional automatic upshift to the next “gear” – which in fact is just a different CVT pulley ratio. But it could fool almost anyone insofar as how it feels – and sounds. The benefit? You get the superior efficiency of a CVT (relative to a conventional hydraulic-actuated automatic) without the thrashy sounds/sensations typical of CVTs. Nissan (Infiniti’s parent company) makes the best CVTs in the business. Drive the J (or any other Nissan/Infiniti vehicle with a CVT) and you’ll see what I mean.JX road
Ride: It’s medium-soft. The Enclave is softer – and the MDX is firmer. As such, the J is a good middle-ground choice. There’s a “sport” setting on the console – but it’s more for the drivetrain (throttle tip-in, transmission shift points, etc.). The other two modes – Eco and Snow – alter the calibrations for those conditions.
One interesting thing about the J that I have not encountered in any other vehicle – crossover, SUV, luxury car, sedan or any other kind of car – is its “in the background” traction/stability control. When it comes on, you may feel it – brakes being applied, throttle being dialed back – but you will not see it. The “trac” light does not flash furiously when engaged – as it does in every other traction/stability-controlled vehicle I have ever driven. This is calming. The car’s systems intervene when they need to – but don’t make a federal case out of it. This is of a piece with the J’s lack of a Belt Minder buzzer. The car will not do the electronic equivalent of beating you over the head with a ruler if you have elected not to “buckle up for safety.” As far as I have been able to determine, Nissan/Infiniti is the only major automaker that doesn’t foist a Belt Minder buzzer on you.
God bless them.
AT THE CURBJX dash
Though large, the J is not humungous – on the outside. In fact, it is almost a foot shorter, bumper to bumper, than the Q56 (196.4 inches vs. 208.3 for the Q). It’s also 8 inches less tall (67.8 inches vs. 75.8).
This makes it look – and feel – less imposing. Yet, it’s actually got more room inside for the driver and passengers than the Q: 42.3 inches of front seat legroom and 41.7 inches of second row legroom in the J – vs. 39.6 inches of front seat legroom and 41 inches in the Q.
But, how does the J compare with other large crossovers?J cargo
It beats the MDX, second row-wise (38.7 inches) by a significant margin and edges it out by about half an inch up front (41.2 inches). And it really beats the Enclave, which has just 36.8 inches of second row legroom (and 40.4 inches up front). The Audi Q comes in just under par, with 39.6 inches up front and 41 inches in the second row.
Only Lincoln’s MKT wagon edges out the J when it comes to second row spreadin’ out space – and only by a hair, literally: 41.8 inches. And the MKT’s down about half an inch up front, vs. the J.
But, no free lunches in crossover land. The J’s edge in passenger roominess comes at the price of reduced cargo capacity – 15.8 cubes behind the third row, which is considerably less than several of its rivals, most notably the Buick Enclave (23.3 cubes) and also the MKT (17.9 cubes).J quarter
However, the J still has a slightly bigger cargo area than the Acura MDX – which has 15 cubic feet of capacity available behind its third row.
Speaking of the third row. It’s got adequate legroom but – as is true of the third rows in all these crossovers – headroom is limited by the slant of the roof and by floor height. Adults consigned to the third row will sit in a half-fetal. Not totally tucked in, but halfway there. This is an area where a full-size SUV like the Q has an advantage – at least in terms of headroom. The usually boxier/taller profile allows for that.JX guppy
As far as aesthetics: That’s in the eye of the beholder, but to my eyes, the J’s nose is a bit ponderous and super-sized guppy-like. The side and back views are “cleaner” – and I applaud the for-once different (stylized “S”) rear side glass shape.
The inside is a winner. All the superlatives: luxurious, sporty, tasteful. Very “rich” looking – but not Donald Trump rich looking – if you know what I mean. The only thing I find fault with is the location of some of the secondary controls – such as the buttons that turn on (and off) the lane departure warning system, traction control and steering wheel heater. These are all located almost underneath the dash, to left of the steering wheel – and recessed such that you can’t easily see the individual buttons. After a week or so in the J, you know where the buttons are by feel – and memory. But it’s not ideal – and may be off-putting to people who haven’t yet spent a week in a J.buttons
Technological highlights include Nissan/Infiniti’s unique “around view” monitor – which gives you a panoramic, 360 degree view of the vehicle from the perspective of someone looking down from above. It is much more helpful than the limited view of your surroundings you get with the typical rearview-only back-up camera.  The twin LCD flatscreens built into the seatbacks – included with the Theater Package – can be tilted up or down to adjust for sun glare. There is an available semi-automatic blind spot braking feature, too. The system will apply the brakes if it senses you inadvertently turning into the path of another vehicle that’s in the J’s blind spot.JX around view
However, many of these options are bundled together in packages – some of which are very expensive, even for a luxury vehicle. The Premium Package – which includes hard drive-based GPS, a 13 speaker Bose stereo, the Around-View monitor, Blind Spot Warning and several other items – stickers for $4,950. The Deluxe Touring Package – which adds 20 inch wheels, an even higher-end Bose system, heated second row seats, rain-sensing wipers and maple wood interior accents – goes for $2,550. To get certain features, you not only have to buy the package, you sometimes have to buy several packages. For example, to get the Deluxe Touring Package, you have to also buy the Theater Package – and the Premium Package. But you can’t buy both the Deluxe Touring Package and the Driver Assistance Package.J rear console
There are two reasons for this confusing (and costly) mish-mash: One, it’s easier for Infiniti to produce cars this way, as opposed to allowing buyers to order options on a more a la carte basis. Two, there’s more potential profit per car. As an example, my J test car – which remember, has a starting MSRP just over $41k – stickered out over $55k, once the additional cost of all the options (Technology Package, Theater Package, Deluxe Touring and Premium Package) was folded in.
Infiniti-minded buyers interested in not-too-big – but not too small – will be pleased to discover there’s now a model at Infiniti stores that meets their needs.J last
3 COMMENTS
  1. Options packages are crap, in my opinion. You want projector headlights? Gotta also get the upgraded interior. What do they have in common? Well, because most of us buy off the lot instead of ordering, we rely on the “good sense” of the dealer to pick the options we want. Since they want to sell you a car based on what your credit score and monthly payment says you can afford, not what you want (or can pay for), you get cars with screwy options “packages” that are all-or-nothing piles of extras (along with crazy 6 year loans, but that’s another rant).
    I think in Europe most cars are ordered from the factory, not sitting on a lot waiting for a buyer, but I could be wrong. I could see an article on this, Eric. A short history of how options packages came about and how the dealers control them.
  2. I think the real competitor here is Nissan’s own new Pathfinder. From what I’ve seen, and what I’ve been reading, it offers most of the niceness of the Infiniti J but at a much lower cost. Same engine, suspension (mostly), and general layout. Plus it’s a lot better looking than the awkward J. And keep in mind, I’ve owned a few Infinitis.
    Really, the J is just a very tarted up Pathfinder, which is a common strategy used by most every major car maker that has a luxury division. I’m just not sure that the extra luxury you get with the J is worth the extra $12,000 or so over the Pathfinder’s base. Or, more realistically, that the top-of-the-line Pathfinder with full kit isn’t the better deal vs. a base-level J that costs the same. Plus it has a 5,000 lb tow rating.
    Aside from styling, the biggest problem I had with the J that I sat in and checked out was the visibility. You really DO need all those backup cameras, side view cameras, self-braking, lane change monitors, etc.
    I’ve been driving SUVs since I was 8 years old learning on an old ’72 Blazer. Back then visibility out of them was actually relatively good with large, upright windows, sharp drop-off corners, large side mirrors, etc. I’ve more than once navigated a Blazer through tight shops full of crap with about 2″ to spare on either side. . .in reverse and never thought twice about it. Today’s SUVs (and cars in general) now have what seems like HUGE A-, B-, C-, and D- pillars presumably to help with rollovers and to house airbags. The roof line is much lower and the rear glass much smaller relative to the size of the vehicle. And the greenhouse tends to noticeably slant inward with the windshield raked further back and the belt line much higher. This helps with styling and aerodynamics, but at the cost of visibility. It’s now much more difficult to know where the corners of the vehicle actually are.
    Unfortunately, the J exemplifies all of these trends. Given the apparent steady decline in driver skill, this is a recipe for disaster. Add all the driver-disengaging nanny minders and the future of driving seems grim. How long until all these new “safety” features are mandated?
  3. Yes, aesthetics are indeed “in the eye of the beholder.” Personally, I think the JX35 looks more “minivan” than most minivans do.
    I really want to like Japanese premium brands. But, as evidenced by that Acura, and now this JX35, too many of their products are not appealing to people who actually like cars. And the end result is….for the price…. pretty mediocre.
    The Q56 totally rocks! But that is excellence in a niche that most buyers can’t afford.
