The Hardley Mystery… Solved?
2107
Ace mechanic friend Tim came over and, together, we puzzled over the Hardley Ableson.
Why is the Bendix gear not spinning the big gear on the clutch basket – and thereby, spinning (and hopefully, starting) the engine?
The Bendix is new. It is the second new one. Everything lines up; everything looks like it ought to work. But when you push the starter button, the Bendix pushes out (as it should) and the gear engages with the big gear on the clutch basket… but all you hear is the starter spinning.
I had an epiphany.
Maybe.
What if – somehow – the starter is turning the wrong way?
The Bendix clutch is a one-way clutch. It is designed to allow the gear to freewheel in one direction (so as not to be damaged – or cause damage – when the engine fires and the gear on the clutch basket spins in that same direction).
It spins in the other direction to turn the engine – and (hopefully) fire the engine.
So my thought is that – somehow – the polarity of the starter is all FUBAR and the thing is spinning the wrong way. This would account for the symptoms. The fact that the starter does turn when the ignition button is pushed and the solenoid engages and the circuit is completed… but if it’s turning the wrong way…. then it would not turn the engine. All it would do is spin.
Which is just exactly what it is doing.
This could be it.
The question now, is: How the F did the starter become a “wrong way” starter? Is such a thing mechanically possible? I am trying to find a known good starter to test the theory. Then, there is also the possibility that the bike’s wiring itself is reversed. This could have happened. The wiring is as tangled as the hair of a guy who has been homeless for the past 30 years.
But, we may have identified the problem.
Stay tuned.
Meanwhile, site stuff:
Last month (September) was the first month in six months that EPautos ended in the red. Not hugely, but in the red. So far, October is not off to a good start.
The fact is I can’t do this without your help. If you enjoy EPautos – think it’s worthwhile – and want to see me continue to put Clover in the Libertarian Camel Clutch and make him hombel – then please, help us keep the wheels turning.
You can also help by supporting our advertisers, including Amsoil (see here) and Valentine1 radar detectors (see here) and Austin coins (see here).  The more you support these advertisers, the less we have to rely on individual reader support.
Thanks in advance to all of you. I’m confident that – with your help – October will be better than September!
And maybe, the Hardley will run again soon, too!
PS: I will be on Bill Meyer’s radio program today at 10:10 east coast time. The audio clip should be up on the main page (lower left column) in a day or so.
  1. (a simple conventional) DC motor’s direction is decided by which way the wires are connected. If + and – are flipped the direction it turns is flipped. That’s all it takes to make one run backwards. AC gets more interesting.
    Since you have to turn the engine with the wheel anyway, turn the wheel as if the bike is moving forward (in forward gear of course). see which direction the engine turns. the starter gear should rotate the opposite of that.
