2016 Cadillac ATS
22
5912
Almost 20 years after the commercial left the airwaves, the car finally does zig.'16 ATS lead pic
It just took a while for them to catch up to the catchphrase.
Maybe you recall.
It was the late ’90s and Cadillac was trying to shed the AARP Aura that had enveloped the brand like a sickly fog since at least the late 1970s.
GM’s luxury line had been slick and cool and most of all, young … back in its Mad Men-era heyday in the late 1960s. But atherosclerosis set in as the years rolled by. By the Disco era, only old men and young pimps were interested in Cadillacs. BMWs and Benzes became the in cars for those not close to being on their way out.
GM’s first attempt at code blue defibrillation was the Catera, a quickie rebadge of the European GM (Opel) Omega. It was pitched as “the Caddy that zigs.”'16 ATS interior 1
A white-walled (and vinyl roofed) Sedan deVille it wasn’t.
But it also wasn’t a BMW 3, either.
Still, a step in the right direction.
The next step was even better – the CTS sedan. Cue Led Zeppelin soundtrack.
Those with a pulse (and without a pacemaker) began to notice. Some began to buy.
Today – 18 years after the first tentative steps at changing course, Cadillac has come full circle and is once again a happening brand rather than a past-it brand.
Check this new ATS sport sedan, for instance.
You will love it … but your grampa will not grok it.
Which is as it ought to be.
WHAT IT IS2016 Cadillac ATS
The ATS is Cadillac’s entry-level model, in the same class as compact-sized, luxury-sport sedans like the Mercedes C-Class, BMW 3 and Lexus IS.
Like them, it is based on a rear-wheel-drive layout (with AWD available optionally) and offers several engine choices, including a non-turbocharged four-cylinder in the base trims, a turbocharged four in mid-trim models and a powerful six in top-of-the-line trims.
You can also get a manual transmission in the thing – an example of “zig.”
Base price is $33,215 for the sedan with the standard-issue 2.5 liter (non-turbo) four cylinder engine, eight-speed automatic and rear-wheel drive.
A 2.0 (turbo) equipped base trim with the eight-speed manual and RWD lists for $35,245 ($37,245 with the optionally available AWD system).'16 ATS detail 2
From there, you can upgrade to Performance, Luxury and Premium trims, with either the 2.0 turbo engine or a 3.6 liter V6 and in either RWD or AWD form.
A top of the line Premium with the V6 and AWD lists for $48,715.
There is also a coupe version of the ATS as well as a high-performance “V” version – but these are effectively separate models and will be reviewed separately.
The ATS’ top-of-the-line 3.6 liter V6 is heavily revised; new block and heads, revised fuel injection system and a number of other internal changes. Output is upped to 335 hp (up from 321 last year) while fuel economy increases by about 9 percent vs. last year’s V6.'16 ATS CUE
There’s also a new eight-speed automatic, replacing the six-speed automatic used last year. It’s standard with the V6 and the base 2.5 liter four (which are both automatic-only) and available with the mid-trim 2.0 liter turbo four (which can also be ordered with a six-speed manual transmission).
The CUE touchscreen interface has been updated as well and 4G Wi-Fi capability is standard equipment in all trims.
335 hp V6 engine is a gnarly and snarly beast when called on; it’s the strongest engine in this class. And you can get it with burnout-friendly RWD (Benz C-class with top-dog V6 comes only with AWD).
Eight-speed automatic shifts like a well-oiled switchblade.
Manual transmission in a Cadillac.
Finely crafted interior.
Focused handling.
WHAT’S NOT SO GOOD'16 ATS six speed
Manual is only available with base 2.5 liter engine.
AWD is only available with the mid-trim 2.0 turbo engine or the top-of-the-line V6.
Back seat is tight; less leg and headroom than several rivals.
CUE will drive grampa into the ICU.
You’ve got three options – each of them very different in focus and demeanor.
The base engine is a 202 hp 2.5 liter four, which is paired only with the new eight-speed automatic transmission and rear-wheel-drive.
Cadillac won’t sell you AWD with this engine – or a manual transmission.
Dammit.'16 ATS 2.5 engine
You’d think the manual would be the go-to box with this engine, which is the ATS’ economy engine. But it’s not offered because the new eight-speed automatic returns better MPGs than the manual six-speed. This (mileage) is also probably why the 2.5 engine is only sold in the RWD configuration.
With AWD – and the less-economical six-speed manual – the ATS’ advertised EPA numbers would likely be unacceptably low. Not necessarily for buyers, but for the government. The Fed’s CAFE fuel economy fatwas are really putting the squeeze on car companies. The rear-drive/autoamtic ATS’ mileage (21 city, 33 highway) just barely cuts the mustard. With AWD and the less efficient (by about 5 percent, according to Cadillac) manual, the highway number might slip into the high 20s – and that’s doubleplusungood these days.
So, to get AWD – and a manual, if you want that – you will have to move up to the optional 2.0 liter turbo four. It makes 272 hp under 18 psi of boost and also 295 ft.-lbs of torque (upped last year from 260 ft.-lbs.).'16 ATS autoamtic
With the manual and AWD, this engine dips into the high teens (19 MPG) in the city and just barely gets out of the 20s on the highway (30 MPG). The same engine with the eight-speed and RWD manages 21 city, 30 highway. Almost politically correct.
Performance is snappy, too: Zero to 60 in just over six seconds.
The big Kahuna in the ATS is the 3.6 liter V6, pumped up to 335 hp for 2016. You can go RWD or AWD – but this engine comes only with the eight-speed automatic. Which is a damned shame (blame Uncle) because it is a killer. Mid-fives to 60 and the capability to almost bury the 160 MPH speedo on top.
Don’t ask how I know.
It’s not even all that thirsty, either: 18 city/28 highway with RWD and 18/26 with the optional AWD. This is actually slightly better than last year, when the V6 was less strong (and came paired with a six-speed automatic). Credit for the mileage uptick goes to the new eight-speed box and cylinder deactivation technology, which is seamless. Under light load conditions, such as steady state cruising on the highway, the engine’s computer tells two of the V6’s cylinders to go to sleep, reactivating them as necessary when more scoot is wanted. The only way you’ll know this is happening is by taking note of the small LCD display in the main gauge cluster. “V6” – or “V4” – will illuminate.  2016 Cadillac ATS Coupe
Less seamless is the stop-start system that’s now included (want it or not) with both the V6 and the 2.0 turbo four. Unless you manually disable the system by pushing a button near the gear shifter, the engine will cut off when the car is stationary, as when you roll up to a red light. It will automatically re-start when you take your foot off the brake.
It’s not obnoxious, but you do notice the on-off transitions and one wonders whether there will be any long-haul repercussions (post warranty) that crop up from this constant cycling on and off of the engine, such as earlier-than-usual problems with the starter motor.
This is not just a Cadillac Thing. Every major car company has added a similar system to their vehicles for the sake of 1/2 a MPG here, perhaps 1/4 of a MPG there.
Once again, send fan mail to Uncle.
The V6, by the way, is designed to burn regular unleaded – not premium. The top-dog engines in rivals like the BMW 3 and Benz C demand premium.
Send fan mail to Cadillac.
ON THE ROAD'16 ATS road 1
If anything, the ATS may be a touch too youthful.
It’s a car that makes 14-year-olds  grin when the automatic seatbelts cinch tight as you drift them through a corner posted 35 at 60, the Caddy’s rear tires smearing the asphalt with molten rubber. In Sport mode, the eight-speed automatic behaves as belligerently as Donald Trump on a Red Bull bender, keeping the engine’s revs up in the curves and waiting until it bounces off the limiter (7,000 RPM for the V6) before conceding a begrudged upshift to the next gear.
God bless Cadillac for letting you buy the 335 hp V6 without AWD. And for programming the traction control system so that it goes off when you push the button on the center console.
Did I mention burnouts?
And yes, we are talking about a Cadillac.
Re-read that part about changing demographics.2016 Cadillac ATS (L) and ATS Coupe
This Cadillac will make grampa fill his Depends. He’ll want out. But you’ll want in. There’s no AARP sticker on the back bumper of this one; no pop-on wire wheel covers that fly off in the curves, either.
The tested Performance trim (available with the V6 or the 2.0 turbo engine) comes with staggered-size Bridgestone Potenza eighteen-inch low-profile sport tires (225/40s on 18×8 rims up front,  255/35s on 18×9 rims out back) that have no sidewalls to speak of and absolutely will not lean.
The downside is a ride that’s pretty stiff; you’ll want to be sure you can live with it before you commit.
You can raise the stakes even higher by stepping up a notch to the deceptively innocuous-sounding Premium trim, which adds a heavy duty 8.6 inch rear axle (standard issue is 7.67) with mechanical (not electric) limited slip.
As Iron Sheik would say, it’s the real deal.
The LSD really ought to be standard in a car this powerful that’s got all that power going to just two wheels… the rear wheels.
Watch out on the wet.2016 Cadillac ATS
The Premium also gets you auto-adjustable shock damping and run-flat Potenzas on those eighteen-inch rims. In addition, there’s a heads-up display (HUD) that projects your speed (and the speed limit on the road you’re on) in your line of sight, holographically – so it’s not necessary to glance down at the gauges to scan that info.
Cadillac will even sell you a Track package (RWD versions only) on top of all that. It includes a high-performance Brembo brake package and heavy-duty cooling. Nineteen-inch wheels can be dealer-installed, if you really want a Caddy that zigs.
Put that in your Sedan DeVille and smoke it.
Or, go with the Luxury trim, which rides on more forgiving 17-inch wheels and all-season tires. You can still get the V6 and all 335 hp, though – so acceleration is the same. The handling’s a bit less Grand Theft Auto, but the car is much more everyday agreeable.
Regardless, the car’s a runner – and a cornerer. Near-perfect 50-50 weight split. Compact dimensions; fairly light (3,319 lbs. vs. 3,340 for the BMW 3 and 3,417 for the Benz C) a shorter wheelbase than others in this class, quick (but not too light) steering) and the availability of a six that outguns pretty much anything in its class make this car a comer.
And, a goer.
AT THE CURB2016 Cadillac CTS-V
One of the lesser miracles of our age is that car designers have figured out how to give small – and entry level – luxury cars the presence they used to invariably lack. Examples of the former include the Catera of the late ’90s and, of course, the infamous early-edition Benz 190s …which still get laughs today.
The ATS has the upper-class ambiance essential to success in this class today. The slit-eyed/swept-back (fully horizontal as they bleed back onto the fenders) headlight assemblies, a very distinctive lattice grille treatment and body panels that suggest billet rather than plastic – formed into jaunty angles (a theme cribbed from the mid-sized CTS) – give the ATS a modern Mad Men vodka martini and unfiltered Marlboros mien.
It’s a car Don Draper would buy.'16 ATS interior 3
Cadillac did a fine job inside, too. “Cut and sewn” panel pieces, crushed suede and wood trim inlays, real metal (not plastic made to look like metal) for the paddle shifters, a “configurable three window” LCD main gauge cluster and a tablet/smartphone-style secondary LCD CUE (Cadillac User Experience) touchscreen (and pinch-screen) display in the center stack do not disappoint. The look/feel and function are very similar to what you’d find in a higher-end model like the CTS or the XTS.
Premium-tech, too.
For instance, the available collision mitigation system, (automatic braking) works in reverse, as well as when you’re moving forward. If you don’t happen to see a car behind you while you’re backing up, the ATS will automatically apply the brakes in time to avoid a collision. Other cars in this class are forward-crash avoidance-only.
The chief difference between an ATS and a CTS or an XTS is size.
Speaking of which:
The ATS is a somewhat more compact car than other compacts in this segment.
Not necessarily overall (the BMW 3 sedan, at 182.2 inches, casts virtually the same shadow as the 182.8 inch long ATS sedan) but inside.'16 ATS back seat
Here we come to the Caddy’s biggest deficit relative to rivals: its more confined cabin.
The back seat has 33.5 inches of legroom – and 36.8 inches of headroom. As compared with 35.2 inches of legroom (and 37.1 inches of legroom) in the Benz C sedan and 35.1 inches of legroom (and 37.7 inches of headroom) in the back seat area of the BMW 3.
The Caddy fires back with more front seat legroom (42.5 inches vs. 42 in the 3 and 41.7 in the C) but the ATS’ interior designers probably should have shaved off an inch up front for the sake of the backseaters. The front-rear real estate disparity in this car is similar to what you’d find in a Benz CLA “coupe” (it’s also a sedan) but that car sacrifices back seat viability for the sake of swoopy two-door-with four-doors styling.
It’s a liability in a straight-up sedan like the ATS.
The Caddy’s trunk is also very small – just 10.4 cubic feet (vs. 13 cubic feet for the BMW 3 and 12.6 for the Benz C).
Still, it’s a small gripe given the overall goodness of the thing.
THE REST'16 ATS CUE 2
Some reviewers have kvetched about Cadillac’s CUE interface, with its swipe/touch inputs and “haptic” feedback (you’ll feel a pulse emanating from the surfaces as you swipe/touch them). But the system – with its large icons for the main menu items – is (my opinion here) easier to use than some other systems, which have tiny icons and require multiple steps to get the thing to do what you want. The chief functional issue with the CUE flat-panel is that its sometimes hard to touch the exact spot on the thing while the car’s moving. If you miss, you might launch an app you didn’t want – or change from Sirius to FM when all you wanted to do was change the station. Stuff like that. There are secondary controls for some key functions (volume, for instance) but the inherent ergonomic flaw of a flat screen in a moving car remains.'16 ATS-V
Other than that, what’s not to like?
And if you need more power, there’s always the ATS-V.
Go out and hurt you a BMW M3. Old school. Put him in the camel clutch, make him humble.
The smell of Noxzema has been replaced by a much more appealing smell. The smell of burning rubber.
Will you help us?
EPautos stickers are free to those who sign up for a $5 or more monthly recurring donation to support EPautos, or for a one-time donation of $10 or more. (Please be sure to tell us you want a sticker – and also, provide an address, so we know where to mail the thing!)EPautoslogo
22 COMMENTS
  1. Fun Cadillac Fact: Antoine Laumet de La Mothe, sieur de Cadillac, founded Detroit in 1701, a settlement also known as the Paris of the Western World.
    Queen’s-Reich Ontarian-Canadian Jim Carrey eats the lunch and takes the piss of dead Okie-American Revivalist Tent Preacher Gone Hollywood Sam Kinison.
    https://www.youtube.com/watch?v=vpBDXZtv4Rg
    Always respect and understand your elders and betters. It’s our Big Brother UK Britannian frenemies who manipulate and destroy us, just as they’ve done to their lower classes since forever.
    Turn your back on the wrong geezer, and you’re dead, or far worse.
    “Used to” Rule the World – My Ass
    https://www.youtube.com/watch?v=d9d07IXVuIA
    Our cold war with Lenin Putin et. al. was a fleecing by proxy via Moscow, the former HQ of the first major Olde Englishe company town.
    http://www.telegraph.co.uk/sponsored/rbth/opinion/8804067/Russia-Britain-share-history.html
  2. Great review as always, rich, full, and usefully informative. However, I wonder if you have conflated “grandpa” with “clover”? Or did you actually have a (insert bad word here) for a grandfather? I think I counted about 10 more anti-elderly phrases in this review than I could stand. Frankly, my own grandfathers are not negative images to me (just the opposite), nor was my father when he got into his 90s–in fact, far few men could even be the slightest fraction of a man like him. Cadillac used to be Cadillac, for all that was worth and what it meant in America. Now we are in another era that I don’t think is as admirable, and Cadillac, what is that, now? The cars may be great, I don’t really don’t know, but I view them as a cross between “Obama Motors” and “Kiss China’s Ass”. Frankly, I think I’ll stick with grandpa and his values over the “youth” of today, who care more about computer gadgets than they do cars anyway and probably would vote to ban all the cars anyway because their “carbon footprint” is too large.
  3. Eric – if you still have the car, take a look at something for me on it.
    A few years ago I was at the local autoshow, and Caddy & Lexus were across the aisle from each other. When I sat in an ES350, all I saw was trim. Either Alcantera leather, or cloth, or soft-touch plastic. When I sat in the CTS, what I saw was metal around the window frame and hard plastic.
    Does the new ATS still have bare metal visible to the passengers?
    • Clicked send too soon —
      These days, the difference between a “nice” car and a luxury car is the 1% that is attention to detail. You can buy a Camry with auto-up driver’s window, but a luxury car will have all four windows be auto-up, and they’ll slow down when they get close to closing so they don’t make slapping sounds when they hit their limits. A “nice” car will have leather seating surfaces, but a luxury car will have the entire seat covered with cowhide, not a mix of leather and vinyl.
      Cadillac for the past couple of decades has been *almost* in the luxury category, but they have missed that last 1% that is the crucial difference. They have been priced like a luxury car (the ES and CTS I compared were within a few thousand dollars of each other) but looking at the details it was obvious that GM had cut corners. Knowledgeable buyers can see this.
  4. Flash and opulence stopped being exclusive to luxury brands. Everything glitters like gold in today’s world. Even basic entry level automobiles are loaded with high end power anything, automatic everything, electronics galore, comfortable, road worthy and powerful enough to keep up with or surpass the daily grind. Today’s Cadillac offers slightly more posh for a whole lot more money, yawn, big deal.
  5. re this: “The Caddy fires back with more front seat legroom (42.5 inches vs. 42 in the 3 and 41.7 in the C) but the ATS’ interior designers probably should have shaved off an inch up front for the sake of the backseaters.”
    Actually, this is a good thing. If you’re tall and really need the extra legroom, you have it. If you’re shorter, or the people in the back seat need more legroom, move the front seat forward an inch or three.
    In my Avalon, I could use another couple inches of legroom, but the seat won’t go further back despite ample legroom in the back and usually no one sitting there. Having that option would be handy for people over 6 feet tall.
  6. Back in the 60’s when pick-ups were just a shade of what they’ve become, a Sedan de Ville would pull 2 cotton trailers vs. the one a pick-up could pull. I knew one farmer who had Caddies like others had pick-ups and literally never owned a pick-up. Not long before he died he bought a 6 cylinder El Camino, as close to a pick-up as he’d ever been I suppose and don’t know he ever rode in it.
    I never knew him to buy a new Caddy either. But on the off chance you saw him, you knew who it was by the car. He didn’t chew and spit out the window either.
    • Yup.
      Caddy offered the biggest V8 GM ever sold to the public. 500 cubic inches. About the same size as a Viper’s V10. Those eight liter Caddy V8s were not high horse, but they made tire-torturing torque. A FWD ’70 Eldorado was all kinds of fun!
      • This same guy got stopped in a newly acquired Caddy, about a year old, still a fair price even used. The DPS was telling him what he clocked him at(in a notorious county for lying). He said ‘Do you know what this unit costs?”, referring to his radar. The guy replied “Do you know what this car costs?” and put him in his place not getting paying paper.
        It was a fool’s errand anyway since this guy never drove as fast as the speed limit. Don’t get behind him on a windy 2 lane road.
        For anyone who plans or doesn’t plan on being in Texas, stay away from Jones county. Anson(the man, not the town)would be appalled at what it’s become. To this very day, there’s still no dancin in Anson, it’s illegal. The county is wet but you can’t get a cold one in Anson.
        • Hi Eight,
          I used to think Texas might be an ok place to live; more free than Yankee-infested turf further North.
          Apparently, not.
          • eric, Jones county is an aberration for a rural county. I wouldn’t go near one of the big cities since big cities tend to be replete with their own laws no matter where you go. But rural Texas is a breath of fresh air still, compared to other places I’ve been.
            Jones county is this hive of Bible-thumping hypocrites. So much so that when Monsanto sued farmers for illegally selling seed, they had 31 of them on the docket. And they all paid through the nose. But hey, you can’t beat a racket like cotton farming even if it is killing everything including people.
          • Texas has a lot of different options depending on how and where you want to live. Austin has a lot of liberals (including my bleeding heart liberal GF), which can be a good thing if you like entertainment and interesting people. The surrounding conservative countryside keeps them from passing the more asinine policies they’d like.
            I’m surprised that an anarchist like you would put up with Virginia’s statism instead of moving a bit further south on the Blue Ridge mountains into Tennessee.
    • One of my grandfather’s friends always drove a Caddy because it was the only car with a trunk big enough to carry 4 bull calves to the auction.
      • I don’t even want to think about the condition of the trunk. Say, what’ll you charge me to clean the trunk. Guy looks it over and says “Nothing”. Gee that’s awful nice of you. Nope, I won’t touch it for any price. Grandpa. Ah well, it’ll all be dry in a few days.
  7. In today’s market, very few people buy new luxury cars. They’ll rent them like tuxedos for the senior prom but for some course of months instead of the day. Unless you’re hip to automotive fashion nuance, no one really knows what brand any particular car happens to be. Cadillac versus Kia, they could be twins when viewed from a distance.
    Grandpa always paid cash for his Cadillacs. No one ever mistook them for Ramblers or Plymouths or anything other than Cadillacs. Grandma drove the last one for another 25 years after he died. The Cadillac’s aura of luxury held up for three decades. Even the dullest sap easily recognized the automotive Standard of the World.
    No more, those days are gone forever.
    • Hi CC,
      True.
      Leasing makes it possible to be driving a new or at least newer car pretty much continuously and there are tax advantages for some people as well.
      But Caddy has managed to turn back time in the sense that its buyer demographic today is more like what it was back in the day (’60s) when brash young executives (e.g., the Don Draper type) bought them, not glaucomic geezers.
      I actually like the white-walled/vinyl-roofed Caddys of the mid-late ’70s. I’ve driven them and they are the antipodal opposite of any modern luxury car, because modern luxury cars are all luxury-sport cars. The Caddy floats down the road, gently undulating with the road. You sit on a sofa-like (and typically, three-across) chair rather than in a bucket. The engine is tuned for low-end torque; there is no tachometer (and forget paddle shifters). It is dead quiet, inside and outside.
      The experience is nothing like anything being made today.
      I recommend it, if you get the opportunity!
      • eric, so true. Even the air intake had a muffler. You could haul a load of cattle to the sale, drop the trailer, go shopping, take in a movie and never hear much of the world behind that thick glass and foot thick doors full of sound deadening.
      • eric, I cleaned out our account and bought one of these last week. I haven’t figured out what color I’m going to paint it. I was thinking about midnight blue with gold flake but Krylon doesn’t make that particular color. And then the second let down was when Barbie was too big to fit in it. But they do have nice selection of wheels.
      • I drove a 1958 Coupe de Ville for 10 years. Most cars back then were practical tools for basic transportation and designed for minimal expense with few creature comforts. A Cadillac was the polar opposite; opulent with plush carpet, soft padding, beautiful upholstery, effortless controls, smooth and quiet with power on demand. All that with fuel economy near that of a Chevy six and considerably better than a Buick. All age groups yearned for Cadillac ownership, not just 20 somethings or old geezers.
