2016 Buick Enclave
13
6872
GM still has two “near luxury” brands – Buick and GMC – which is double what other car companies have. They have the mass-market line (Toyota, for example) and then the luxury line (Lexus).'16 Enclave lead
Theres nothing in the middle.
With GM, you can go incrementally up two steps from the mass-market brand (Chevy) before getting to the top-of-the-line brand (Cadillac).
Or down a step.
Or, sideways.
As a case in point, consider GM’s full-size/three-row crossover SUV. It is sold three ways, with prices that are less … or more … and sometimes, overlap.
There is the Chevy-branded Traverse – which starts at $31,205 and tops out at $44,145. Next up is the GMC Acadia, which actually starts lower than the Chevy at $30,975 but tops out much higher, at $49,890. From there, you can go down – or up – to a Buickized version of the same basic vehicle, the Enclave, subject of this write-up.'16 enclave cut away
It starts higher than either the Chevy or the GMC at $39,065 but tops out a few hundred bucks down from the GMC, at $49,515.
Mechanically, these are all basically the same rig.
They differ – slightly – in terms of styling and (nominally) the Buick and the GMC are positioned as the “nicer” versions but as the pricing structure reveals, this can get confusing. A loaded Traverse is arguably “nicer” – and pricier – than a base Enclave. And is a loaded Enclave any less (or more?) “nice” than a loaded Acadia Denali?
GM retorts that the Buick version is the softer/quieter version, a kind of seven-passenger ermine slipper – while the GMC is more “rugged” (though also “nicer” than the Chevy, which is also “rugged.”)
Yeah.
My teeth hurt, too.
WHAT IT IS'16 Enclave Tuscan
The Enclave is the Buick-badged version of GM’s full-size crossover SUV. Its big sell is that it has more interior space (especially cargo room) than an Acura MDX, a Lincoln MKT, an Infiniti QX60 or an Audi Q7 – but isn’t as huge on the outside as something like a Chevy Suburban (or Infiniti QX80).
It shares mechanicals with its Chevy and GMC-badged siblings but – being a Buick – it comes with luxury features such as three-zone climate control, leather trim and 19 inch wheels standard whereas these are available optionally in the Chevy and GMC.
The Buick also has exterior styling that’s more “Buicky.” It’s rounder and softer-looking than its more “trucky” and squared-off looking siblings.
Base price (as mentioned up above) is $39,065 for the Convenience trim, which is only offered in FWD form. Next up is the Leather trim, which is available in both FWD and AWD forms ($43,660 and $45,660 respectively). The top-of-the-line Premium trim is likewise offered with either FWD ($47,515) or AWD ($49,515).
All Enclaves come standard with the same 3.6 liter V6, six-speed automatic and three rows of seats.
WHAT’S NEW'16 Enclave LCD
Like its Chevy/GMC siblings, the Enclave (all trims) gets 4GB in-car Wi-Fi and the latest version of GM’s On Star concierge system.
Premium trims can be ordered with a Tuscan package that adds 20-inch chrome wheels with bronze trim accents.
This will be the final year of the current-generation Enclave; an all-new model (three all-new models, actually) is on deck for the 2017 model year.
Third row is more than just a jumpseat for kids, as in smaller rivals like the MDX and QX60.
Super smooth, super quiet.
Class-best cargo capacity behind third row and with first and second rows folded down.
Get one for a couple thousand less than Acura asks for an MDX or Lincoln wants for an MKT.
Final year of this generation Enclave probably means you’ll be able to negotiate a sweet deal on one as dealers try to clear inventory to make room for the new/2017 Enclave.
WHAT’S NOT SO GOOD'16 Enclave dash 2
If you want AWD, the price jumps by $4,595 (the difference between the base FWD-only Convenience and the base AWD Leather trim).
It’s kinda slow for the money, very thirsty – and doesn’t pull as much as most of the others in its class.
Wide-load turning circle (about two feet more than MDX).
Getting long in the tooth.
Current model is about eight years old (first year, 2008) and the ’16 will look really old when the-all new 2017 Enclave comes out.
All trims come standard with GM’s 3.6 liter V6, an engine that is used in everything from Camaros to Cadillacs (as well as Traverses and Acadias).'16 Enclave engine
It is direct injected, has variable valve timing and – in the Buick – makes 288 hp. A six-speed automatic is standard and you have the option of FWD or (in all but the base Convenience trim) AWD.
The six isn’t weak but the Buick is heavy: 4,724 lbs. for the FWD version and 4,992 lbs. for the AWD-equipped version.
Which explains why it’s kinda slow – and very thirsty.
Zero to  60 takes about 8.5 seconds, about two seconds slower than the slightly more powerful (290 hp) but much lighter (3,960 lbs. ) Acura MDX.
This would probably be okay if the Buick were easier on gas, but it’s not. The FWD version only manages 17 city, 24 highway while the heavier AWD model’s mileage is just 16 city, 22 highway.'16 enclave shifter
During a weeklong test drive of mixed city/highway driving, I averaged 16.7 MPG.
A V8 powered Chevy Suburban actually gets better gas mileage (16 city/23 highway) than the V6 Enclave.
So does a Lincoln MKT equipped with its optional – and 365 hp – twin turbo V6.
This highlights the Enclave’s power-to-weight problem. A stronger engine would not have to work so hard to haul the thing around and so would probably use less gas than the hard-sweating 3.6 V6 does.
A weaker-than-others maximum to rating – 4,500 pounds – is another indicator of the Enclave’s under-engined issue.
The MDX can pull 5,000 pounds.
Probably, GM will address this problem with the new (2017) Enclave that’ll be out in a few months. Maybe there will be a hybrid version (like the Infiniti QX60 hybrid, which tickles 30 MPG instead of flirting with teens) or a diesel engine option, as in the Audi Q7 TDI (which can pull up to 6,600 lbs. and also manages close to 30 on the highway).
Or, perhaps they’ll just up the output of the 3.6 liter V6, which in the 2016 Camaro makes 335 hp and gets 17 city/28 highway while also getting the much-less-heavy Chevy (3,339 lbs.) to 60 in just 5.1 seconds.
ON THE ROAD'16 Enclave road 1
It has no ass.
That’s what one of my country friends  said after I floored it for her, to demonstrate the Buick’s passing prowess.
Or lack thereof.
This $53,000 ride (as tested) accelerated about as quickly as the Toyota Corolla I was also test-driving (reviewed here) the week I had the Enclave. But the Corolla’s an economy car, with a base price just over $17k. People don’t expect much to happen when they firewall the gas pedal of a car like that … but at least you get good gas mileage out of the thing (32.3 MPG, about twice what the Buick averaged).
It’s kind of deflating, on the other hand, to be driving a $53k vehicle that cannot out-accelerate a just-over-$17k vehicle. And which drinks about twice the gas, too.
The V6 tries; it’s just not strong enough.
The beefy Buick weighs (wait for it) a pavement crushing 764 pounds more than an MDX (and 22 pounds more than  Lincoln MKT – which has 77 more hp).'16 Enclave road 2
More ass is badly needed.
Or less weight.
Once you get up to speed, though, the Enclave recovers its poise – which is as good or better than that of its rivals, almost all of which are tuned for “sporty” handling. Which inevitably means firmer riding.
The Enclave’s ride is super smooth – and super quiet – even though the Buick rides on 19 (or 20) inch wheels, with the short/stiff sidewall tires that go with them.  It’s obvious much thought went into suspension tuning – and sound deadening.
The latter probably accounts for a good portion of the Enclave’s bulk.'16 Enclave interior 3
It corners with less body lean than you’d expect from a Buick. It’s not an MDX – but that’s not what Buick’s about. From an everyday driving standpoint, the Enclave’s chief weaknesses are probably its length (201.9 inches; which almost a foot longer overall than the MDX) and its 40.4 foot turning circle. These conspire to make it more challenging to deal with u-turns, curbside parallel parking and busy city traffic scenes.
In the Enclave’s defense, the Lincoln MKT is even more of a bus (207.9 inches) and has an even wider turning circle (42.4 feet). And something like the Chevy Suburban – which seats about the same number of people and only has about 5 cubic feet more total cargo capacity (I’ll get into this in greater detail shortly) is about two feet longer overall and has a three foot wider turning circle.
The Suburban is a nice rig, but it’s not easy to deal with if you actually live in Suburbia … much less urbia.
AT THE CURB2016 Buick Enclave Tuscan Edition highlighted by a bronze-tone g
Let’s start with the Enclave’s objective charms. The thing is immensely roomy inside. Even with all three rows in place, there’s 23.3 cubic feet of cargo capacity behind the third row. Lower the second and third rows and the Enclave can house a mariachi band plus a few trays of margaritas: 115.2 cubic feet of open space.
The Lincoln MKT – which is about half a foot longer overall (207.6 inches vs. 201.9 for the Buick) has only 75.9 total cubes of space. The MDX, 68.4 cubes. Even the Audi Q7 comes up way short – just 72.5 cubes of total space and a puny 10.9 cubes with its third row up. (That’s smaller than a Corolla’s trunk, incidentally.)
You pretty much have to move up to a full-sized SUV (not a crossover SUV) to find more interior real estate – and then you’ll really be driving a bus.
Something like a Suburban. '16 enclave cargo
And the Buick’s third row is usable – and accessible.
Many of the others’ third rows are “seats” in the same way that you are a “customer” of the DMV’s. It’s an abuse of language – and in the case of the others’ third rows, your body. The seats are often small and flimsy, with not much cushion – and you typically have to tuck your legs up, with your knees against your chest, because of the absence of a footwell.
Getting to the seats requires manhandling the second row forward, then clawing and crawling your way back there. Many of these “three row” crossovers would do better chucking the useless third row and opening up the space for more cargo room (see, for instance, the Ford Flex and the Lexus RX350).
The Buick is among the few that has third row seats adults can get to without pulling something – and sit on without sterilizing themselves. There is 33.2 inches of legroom – comparable to the second-row legroom in several mid-sized cars and enough to make them comfortable for even a six-footer like me.'16 Enclave second row
Access is simple and not only is there a footwell, there are also foot vents – so you get heat and AC directly instead of having to wait for it to make its way back there, eventually. That you get this useful third row with more useful cargo room, too, is a Buick standout that can’t be argued with.
Some things that can be argued with:
Even my $53,600 Enclave (Premium, with AWD and “the works”) came with an old-timey mechanical ignition key. Old-timey being circa 2008 – when the current Enclave came out. Yes, this review is about the 2016 – but it’s not much different than the ’08. Which had a turn-it-in-the-cylinder key, too.'16 Enclave LCD 2
You do get an electric transmitter fob, but it does not unlock the doors automatically as you approach; you have to manually push the button. The newer stuff just opens sesame, magically.
Another item that shows the Enclave’s age is its still-attractive but entirely analog instrument cluster and its smallish-for-the-class (and price) 6.5 inch LCD touchscreen. It has the latest apps (and built-in WiFi Internet access) but it’s nothing special to look at – which it ought to be, given the price tag. To bring up the Corolla comparison again: The little Toyota has a nicer looking (and larger) LCD touchscreen. So do many other cars in the sub-$20k bracket. That is a problem – for Buick.
They ought to have brought out the 2017 this year, if you ask me.
THE REST'16 Enclave in snow
If it had been my call to make, I’d have made it possible to order the Convenience trim with AWD for another $2,000 or so (what it costs to go from a FWD Leather trim to an AWD leather trim) instead of the $4,595 kick in the soft parts it takes to move from the FWD-only Convenience to the AWD Leather. The Enclave’s primary appeals are its space – and its value. As the price goes up, its deficits – relative to newer rivals – become more apparent.
The Enclave’s biggest problem, though, is that it has to compete with the Traverse and the Acadia before it competes with models like the Acura MDX, the Lincoln MKT and so on. Can anyone explain why an Acadia Denali is justified given an Enclave Premium with the Tuscan Edition package?
Or, the reverse?2016 Buick Enclave Tuscan Edition, a distinctive expression of t
For that matter, why buy either the Buick or the GMC when you can buy the Chevy – which is almost exactly the same thing – for less?
Buick – and GMC – are anomalies. Anachronisms. They are remnants of the Alfred P. Sloan business model, which made sense when GM owned 50 percent of the U.S. car market (yes, it did). Today, that share is around 22 percent – and having three divisions selling the same vehicle rebadged and with overlapping prices is hard to grok.
On the other hand, this Buick is “nicer” than a Honda Pilot or a Mazda CX-9 … and the Convenience and Leather trims (available with AWD) are relative steals compared with the MDX (which can tickle $60k, loaded) while being at least competitively “nice.”
The old gal still has some life left in her.
But you might want to wait and see what 2017 brings.
Will you help us?
EPautos stickers are free to those who sign up for a $5 or more monthly recurring donation to support EPautos, or for a one-time donation of $10 or more. (Please be sure to tell us you want a sticker – and also, provide an address, so we know where to mail the thing!)EPautoslogo
13 COMMENTS
  1. For that matter, why buy either the Buick or the GMC when you can buy the Chevy – which is almost exactly the same thing – for less?
    It’s called branding. Brands matter. They say perception is reality and the perception of a particular brand matters. For example, take a $75K Lexus LS460. Swap the Lexus badge with a Mercedes badge and it will still command a $75K price tag. Swap it with a BMW and it will command a $75K price tag. Swap it with a Chevy bow tie and it will not command a $75K price tag. Why? Because it’s a Chevy.
    One of the problems that Cadillac faces is the perception of their brand. Cadillac is making some great cars right now. They do have price parity with BMW and Mercedes Benz but their sales have been sagging because people don’t perceive their brand as on par with the European rivals. The challenge for Cadillac isn’t just keeping their cars competitive. It’s about changing their perception of what the Cadillac brand is.
    • There are certain options not available on Chevy’s that are on GMC. If you have to have them, you get GMC. And then there’s the whole upscale thing with GMC vs chevy. GMC has options the dealers don’t even understand since I asked a few and this is above a Chevy. Only the individual can decide which is a mandatory option and which is not.
      On pickups, GMC’s used to be different, even in the 90’s but now it’s all about options and not the suspension or drivetrains. It also depends on the look you want and the GMC pickup has always(or for decades has had)had the best looking grill and some front end parts. As far as performance and quality, it’s fairly much the same thing now. I like the looks of GMC’s vs Chevy’s and for years it wasn’t a big deal. Now, the price difference is substantial so a Chevy is for all practical purposes, a cheaper priced GMC with almost no options not available compared to the GMC. Money no object, I’d take the Jimmy. If somebody else paid for it, I’d order the Jimmy hands down. But then again, I don’t buy new, never have and don’t expect to. The thing that would warrant, for me, a GMC over a Chevy would be seats for the most part if that sill holds true which I doubt.
    • Hi Jeff,
      Yeah, brands matter. But having “middle” brands is – my opinion – muddled. It’s slicing the pie too thin. Can GM really afford to market the same vehicle three different ways? In 1970, sure. But it’s 2016. Having a “regular” and a “luxury” line makes good sense, branding-wise. But a brand that’s not quite luxury? That’s priced about the same?
      I dunno!
      • Take this as an example of the importance of brands. Back when they were downsizing GM, GMC was going to be on the chopping block. From what I read, the reason why GMC stayed is because had data that showed there were a significant number of GMC customers who would not cross shop with a a Chevy. As you and I know, a GMC and Chevy are the exact same truck except one has a GMC badge and the other has a bow tie. The idea that people would not purchase the exact same vehicle due to a badge difference seems ridiculous to me but it is reality.
        • Hi Jeff,
          I agree – but also think GM has the proverbial wolf by the ears. Meaning, it has to compete internally before it competes externally. It’s a waste of resources.
  2. One virtue not mentioned is that the Enclave is perhaps the best looking CUV ever (at least to me….and probably others too.) That’s not enough to turn the Enclave’s whole game around, but it helps a bit.
    The more their TV commercials say “this is not your grandfathers Buick,” the more they remind people that it really still is.
    Good thing the Chinese like Buicks, or this marque would be pushing up daisies already.
  3. Is GM using designing vehicles to ace government tests yet flunk in the hands of buyers? Unfulfilled promises tend to make for unhappy consumers, YMMV.
      • GM has a bad habit of manufacturing a chassis well beyond it’s shelf life. Must be trying to wring some profit after excessive cost over-runs.
        Once upon a time, the outgoing platforms were sent overseas to become the new and improved models elsewhere. That practice stopped as GM struggles to remain the biggest fish in the pond, even third world markets have better choices than US leftovers. Perhaps that is why Toyota and VW got slapped down hard just as they reached #1 world status, GM still has enough clout to suppress competition.
        • “the outgoing platforms were sent overseas”
          Yeah, I remember reading somewhere years ago that the sheet metal on Kias was stamped on 2nd hand dies purchased from Mazda, IIRC. Sure that is no longer the case.
          • My guess is Kia contracted with Mazda to stamp parts. It is common practice among manufacturers to provide parts for each other, idle machines produce no income.
            • Yep. There is a low volume product my employer makes. We make it for ourselves and all our competitors. Put their labels on it. Put it in their boxes.
