2017 Mitsubishi Mirage
19
5779
The 2017 Mitsubishi Mirage costs no more than the 2014 Mirage – despite a horsepower infusion (not that it’s a lot, but still) excellent fuel economy (preliminary estimates are 44 maybe even 45 MPG on the highway) and a major wheels-up re-bop of the body/cosmetics/features (the latter of which now includes an available 300 watt audio rig, heated seats, LCD touchscreen and LED/HID lights, even).'17 Mirage lead
For the money – and otherwise – it’s untouchable.
So … what’s the catch?
The Mirage hatchback sedan is Mitsubishi’s littlest/least-expensive car and  – other than the Nissan Versa sedan – it’s the least expensive new car on the market.
$12,995 for the ES trim (topping out at $16,495 for the sporty-ish GT version) and that’s with AC and a decent (140 watt) four-speaker stereo system, power windows and locks (the latter two features cost extra with the Nissan).
The $11,990 Versa sedan (more on that in a minute) is stronger – it has a 1.6 liter four cylinder engine vs. the Mitsu’s 1.2 liter three cylinder engine – but it’s less fuel-efficient.'17 Mirage composite
It’s also a sedan – and that means it has a trunk rather than a liftgate. It also means just 14.9 cubic feet of trunk space… vs. 47 cubic feet for the hatchback Mirage. You can buy a hatchback version of the Versa – which ups the Nissan’s cargo capacity to 38.3 cubic feet.
But the price goes up, too … to $14,230.
However, the biggest difference between the two is that Nissan’s not desperate while Mitsubishi is. Not because its cars are bad, but because Mitsu really screwed the poodle a few years back with a “Zero down, Zero interest and Zero payments for a year” program that was designed to move cars off the lot (it did) but also resulted in most of them coming back (repo’d) a year later, thrashed. This killed the resale value of Mitsubishi cars generally and that plus being a small company and generally Bad Times for the car industry have left Mitsu badly gimped and desperate for your dollars.'17 Mirage rear view
The current (2015) Mirage – which you can still find new at dealerships, even though we’re well into 2016 –  has been massively discounted ($3,500 off sticker, so $9,495 for a brand-new (if one year old) car.
Imagine the deal you could snag on a 2017.
The Mirage’s three cylinder engine has been tweaked to produce a bit more power while the car’s curb weight has been reduced to less than 2,000 pounds – vs. almost 2,400 pounds for the Versa sedan.
It’s still not exactly quick – but no longer unacceptably slow.    '17 Mirage GT
There’s also revised exterior styling and an updated interior as well as a slew of new, un-econocar options – such as the previously mentioned 300 watt premium stereo system, seat heaters and apps such as Android Auto and Apple Car Play. These are examples of “nice” items not available in the Motel 6-ish Versa.
Expect to pay significantly less than sticker.
No cost-adding turbo.
Exceptional fuel economy.
A nice new car for the price of a used car.
WHAT’S NOT SO GOOD'17 Mirage androd detail
Mitsubishi’s on life support.
Likely hideous depreciation (see point above) but, this is a non-issue if you plan to keep it until the floorpans rust through.
Which probably won’t happen for 20 years at least.
Like several other small cars (e.g., the current Ford Fiesta and Mini Cooper) the Mirage is powered by a three cylinder engine.
Unlike them, it isn’t turbocharged.
This has its upsides and its downsides.
On the upside: The 1.2 liter engine is by dint of not being turbocharged a simpler engine. Fewer parts, less to go wrong.
It’s also not under pressure – literally.
Turbochargers make an engine more powerful by force-feeding it air. Instead of the engine just sucking it in, it is compressed (positive air pressure) and the pressurized air is stuffed into the cylinders rather than being inhaled (negative air pressure) as it is in a “naturally aspirated” (non-turbo or supercharged) engine.
This is why turbocharging is measured in pounds of boost.
But the increased pressure increases internal stresses. An engine can be (and ought to be) built with special heavy duty parts to deal with it, but the fact remains: The engine is under pressure and that often leads to a shorter (and more expensive) life.
No such worries here.
Your worry is power/performance – which you don’t get much of.
The 1.2 liter engine makes just 78 hp and 74 ft.-lbs. of torque. Hello, Geo Metro!2017 Mirage GT
Meanwhile – as an example of what turbocharging can do – the smaller (1.0 liter) three cylinder “EcoBoost” engine in the Ford Fiesta conjures up 123 hp and 125 ft.-lbs. of torque.
But then, nothing’s free in life.
The turbo-boosted Fiesta’s base price is $14,580 – but to get the 1.0 engine, you have to step up to the more expensive SE trim ($15,810) and then pay another $995 on top of that for the “economical” turbo-boosted engine. That’s a difference of  $3,810 vs. the Mirage ES.
A big difference.
The Ford is quicker (zero to 60 in about 9 seconds vs. about 11 for the Mitsu).
But it’s not more economical: 31 city, 43 highway – which is good – but not quite as good as the previous (2015) Mirage’s 37 city, 44 highway. And the new Mirage has been lightened up and the engine tweaked, so the ’17’s numbers ought to be better. Especially because it’s lighter. The Mirage is one of the few cars – new cars – that comes in under 2,000 pounds.
A five-speed manual transmission is standard – with the option of going with a continuously variable (CVT) automatic.
All versions are front-wheel-drive.
ON THE ROAD'17 Mirage road 1
When I last wrote about the Mirage back in 2014 (see here) I compared it with the Geo Metro of the ’90s – which also had a three cylinder engine (no turbo) and delivered about the same gas mileage in a similarly low-bucks (and small-sized) package.
Looking back, this was unfair … to the Mirage.
Its acceleration – compared with that of the Metro – is… well, maybe speedy isn’t the right word.
But it’s a lot quicker. Especially now.
The Metro (which had 55 hp to work with) needed almost 15 seconds to get to 60.
The updated ’17 Mirage is at least three seconds quicker.   2017 Mirage GT
That’s about as quick as a new Prius C hybrid – which isn’t exactly speedy, either. But it’s speed enough to keep up with traffic – especially in view of the depressing fact that all those potentially actually speedy cars out there tend to accelerate glacially – not because they haven’t got the power, but because the people driving them are addled by gadgets or cowed by fear of The Man. Almost no one actually drives fast anymore – no matter what they’re driving.
If you’re like me and actually notice that the light’s gone green – you’ll be fine because you’ll get The Drop on these half-asleep/gadget-addled drones every time.
Stick with the stick, though.
The little three does not do well when paired with the CVT automatic. It’s noticeably slower (even though slightly more fuel efficient) and not nearly as much fun. But, if most of your driving will be in-city (stop and go, mostly low-speed) the CVT may be the better choice.
Mitsu has increased the diameter of the Mirage’s brakes – discs up front and drums in back – which is actually good if the object is durability and low-cost. Drum brakes are hard to hurt, unlike disc brake rotors and calipers. And cheap to replace, if that ever becomes necessary.'17 Mirage road 3
The suspension system is also simple (strut-type up front, torsion beam in the rear). It’s  just the ticket for an inexpensive to buy – and inexpensive to maintain – car. In keeping with that ideal, the Mirage also comes with sensible shoe 14 or 15 inch wheels (both aluminum, which keeps the weight down) rather than the stupid (because heavy/expensive/increase rolling resistance and so kill fuel economy) gnomesayin’ 16 and 17 and even 18 inch ree-uhms that have become typical fare even on economy cars.
The Mitsu’s wheels are sensible because they do not impart excess rolling resistance and tires for such wheels are cheap.
And they last.
Which  is what you want … right?
You may have read reviews of the previous Mirage insulting it for its less-than-Porsche 911 handling. This is like slamming a 911 for not giving you 44 MPG. I will repeat what I have been trying to get across the transom for years now: Any new car (including the Mirage) handles better than most people are capable of driving. Or willing to drive. This doesn’t mean most people are poor drivers. It means most people do not drive at speeds sufficiently high such that they approach the limits of the car’s capabilities – or their own – particularly in the curves.'17 Mirage wheel detail
If you, like most people, do not operate at speeds at least 20 MPH above the posted limit in the curves – your foot on the gas rather than the brakes – you will have no complaints to register about such things as body roll or tires beginning to lose their grip, much less understeer slide or oversteer drift. It’s 2016 (and this is a 2017) not 1969, when most cars had truck-type suspensions and shitty tires that would squeal (and send hubcaps flying) if the car was driven 5 MPH above the posted limit in a curve.
The Mirage is a little winded on the highway – but so is the not-so-Smart car (which costs thousands more) and so are many other little cars (Prius C).
It gets the job done. What else is there?
AT THE CURB'17 Mirage curb 1
There’s nothing hateful or embarrassing about the Mirage’s looks.
Arguably, it looks pretty upscale compared with some other cars you might shop in this general class, such as the no-frills Versa or the Scion (RIP) iA (soon to be resold under the Toyota label as the iM) or the Chevy Sonic and Hyundai Accent… all of which cost thousands more, don’t forget.
The Mirage has upscale touches such as LED/HID lights, “beveled” fog lights (SE and GT trims), piano black trim plates and a leather-wrapped steering wheel. It can be outfitted with a 300 watt Rockford Fosgate audio rig, heated seats and climate control AC, too. See what it costs you to get stuff like that in a Honda or a Toyota or even a Hyundai.
It is a small car, though – even relative to other small cars.2017 Mirage GT
Just 149.4 inches from bumper to bumper (the Versa sedan is 175.4 inches).
But room inside is actually better-than-you’d expect. There’s 41.7 inches of legroom up front (almost exactly the same as the much larger-on-the-outside Versa sedan, which has 41.8 inches up front) and while the Mirage’s 34 inches of backseat legroom is less than the Versa’s (37 inches) it’s significantly more than the Ford Fiesta’s 31.2 inches of legroom in its second row.
Rear headroom is also better-than-most: 37.3 inches; the Versa sedan has 36.6 inches.
The Ford Fiesta sedan has 31.7 inches; the Fiesta hatchback a bit more (37.2). Worth a mention here is that the arguably more desirable hatchback body costs extra at the Ford store ($14,880 vs. $14,580) while the Mitsubishi doesn’t charge extra for the hatchback bodystyle (the only Mirage bodystyle).
So why is the hatchback more desirable? You get more headroom in the second row because of the taller roofline and much more usable/versatile cargo space with a rear liftgate vs. a trunk.'17 Mirage cargo
For example, the Mirage has 17.2 cubic feet of cargo capacity behind its second row – vs. 12.8 for the Fiesta sedan (14.9 for the larger-on-the-outside Versa sedan) and 47 cubic feet if you fold the second row flat. That latter figure, by the way, is very close to the room inside the Honda Fit (52.7 cubic feet; best in class) but – again – the Fit’s higher MSRP ($15,890 to start, with much less likelihood of haggling that down appreciably) must be taken into account
I bitch constantly about new cars costing too much (they do) and being larded up (literally, they’re almost all grossly overweight) with Too Much Stuff.
Well, here’s one that’s not like that. It hasn’t got a turbo or a dual-clutch/automated manual transmission. By modern car standards, it is refreshingly simple, light and (by dint of not having a turbo or  a dual-clutch automated manual transmission) very inexpensive.'17 irage last
When you take into account the eagerness with which you (and your checkbook) are likely to be greeted at the Mitsubishi store, to say this car is worth a look at least is probably the understatement of the year.
My bet is you could walk out with the keys for about $11,000 – and that, folks, is about as good as it’s gonna get.
Seize the day – because cars like this are going away faster than the presidential prospects of Jeb!
Will you help us?
19 COMMENTS
  1. This is good to see, inasmuch as there will always be a market for gee-gaw free INEXPESNSIVE economy cars — albeit much nicer that the econoboxes of yesteryear.
    They say that Mitsubishi is seriously on the bubble in the American market. This should help.
    “If you’re like me and actually notice that the light’s gone green…” He hee
    • Fact is the FedGov wants to eliminate affordable. End of story. The Elio will never see the light of day. It will suffer the same fate as the Tucker. Mit in the uS market is like the Veebub dead and gone. Sorry to be such a realist but hell that is life in the united Soviet Socialist Republic of America.
      • Do you really think a crony capitalist like Elon Musk would allow a competitor like Elio come to market? If he did he’d be crushed. If you think Elon would do so then you are beyond naive. All one has to do is to look back at Tucker motors. Money buys power. Power stopped Tucker Motors. Nothing that is less expensive, innovative and better than what is currently available will be allowed. As I stated in one of my earlier post, any individual that exhibited the genius of Tesla would, today be considered an economic terrorist. This is not about anything other than power. No more no less.
      • Hi David,
        This is an interesting (and depressing) theory; that the object is to make cars ever-more-expensive such that most can’t afford them any longer. At least, not without assuming a heavy (and perpetual) debt load.
        • Dear Eric,
          Get the “mere mundanes” off the roads so the 1% can zip along in their chauffeured limousines to where they want to go without without delay.
          I can believe it.
          A relatively modest claim considering how the 1% openly admit to wanting population reduction.
          • “Get the ‘mere mundanes’ off the roads so the 1% can zip along in their chauffeured limousines”
            Where can I get a Zil?
  2. For basic transportation, I’d stick with an off lease Corolla. Bulletproof product, 40 years of success.
    Mitsubishi was THE manufacturer for bread and butter Mopars before Fiat moved in. That alone speaks volumes against the company. Cheap can be expensive as time goes by.
    • Hi Orville,
      I’ve yet to drive the Spark (but hope to this summer). The Sonic is an ok car, but it’s not as nice…. the question is – is it more durable? And which could you buy for less?
    • Thanks, Mith!
      It’s my kind of new car… I’ll spend money on my TA and bikes and so on for fun. But for an A to B appliance, something like this is just he ticket, in my book.
      • eric, one with 15″ wheels would be a good dirt roader I expect. That car would fill nearly all our driving needs with the rest being done by something with a bed. I see a great many cars now pulling small aluminum trailers made just for cars and for carrying things that need to be in a sealed environment.
        Do you have any idea of how much boost the typical turbo car has? I’m guessing they don’t come with boost gauges nor pyrometers.
        I recently drove a Chrysler 200. I came out of the last curve on the farm road at a little over 70 marked 35 and kept it nailed to just over 120 before I had to brake for an intersection. I was amazed and kept thinking some speed limiter would cut in. I almost took it down another road with a long straight to see just what it would do but business came before pleasure. I don’t know how the people drove it before me but going through the menu I saw that over a 1300 mile plus trip it had averaged just over 25mpg. That would be a lot of town driving.
        • Hi Eight,
          On boost – it varies a lot. I’ve had cars (Fiat 500 Abarth) that run 30 pounds; others no more than 10 or 11.
          • eric, thanks. I suspect they only run what they figure the stock rotating assembly will stand for most models. That’s gotta be some good stuff on the bottom end to stand 30 pounds. Even the really turned up diesels rarely get to 30…..close, but not quite.
            • …just got done checking/adjusting valve clearances on the ZRX1200… and damn, it was hard not to just pull out the stock cams and drop in a set of ZZR 1200 cams…. and at that point, hell, why not just pull the head and send it to Muzzy and have him bore the bitch and swap in some 11.5:1 slugs and then drop in the “hot” cams on top of that…. I think the combo’s good for 180 hp…
              • I think I’d have to get altered to open that much power. I’ve never been on anything with over 100 and that was scary fast. But it’s funny, as long as a bike is stable I’ll stay into it.
                I showed up at the doc’s one morning. I had just stepped out of a 550 hp rig (1800 lb.ft)after running 50 miles on squiggly little backroads with a 40 ton load. She asked if I’d had problems, what with my BP being so high. Only hustling that load through all those twisties and changing roads to get here on time. Big frown. I’ve seen the look before. You won’t die of natural causes you fool, driving like that. Nope, and I don’t want to. At least the wife understands my preference.
                • Morning, Eight!
                  It is all kinds of fun! My bike’s engine (it’s the same basic engine as the old ZX-10’s) has a few light mods and made 141 hp on the dyno with the stock cams. The ZZR 1200 – most powerful/fastest carbureted production bike – has basically the same engine and many parts (such as cams) interchange.
                  But the Muzzy top end kit is the serious business.
                  Better keep tucked in!
              • Even better, have your ZRX get the Dr. Suda treatment! Dr. Suda was a Japanese chap in the LA area who was ZRX guru; if you wanted serious work done on a ZRX, then Dr. Suda was the man you went to…
    • Eric,
      Basic transportation does not need to be expensive or complicated.
      One nice feature about this car compared to a two seat car is:
      • Can transport 4-5 people if needed
      • Can carry somewhat larger items within reason
      fuel economy is rated at least as good (if not better) than the (not so)smart car.
      Not as good as an Elio, but unlike the Elio, the Mirage is available now (or at least will be soon when the 2017 is released) Elio is still a dream until it makes it to market. (I hope it does become available soon.)
