2016 BMW 340i
10
5440
I like a plain brown wrapper.'16 340i lead
Why advertise what you’re up to? I mean, if you plan to actually do it as opposed to just thinking about doing it…?
Well, maybe a white wrapper… like this one. This innocent-looking all-white BMW 340i they sent me.
Or silver. Blue’s ok, too.
Who’d suspect?
It’s an upmarket sedan, obviously. But that is nothing uncommon nowadays. What’s not obvious – what’s not made a huge issue of – is what this particular BMW can do.
Zero to 60 in in the mid-fours, for instance.
That is hot enough to singe a Hellcat.Hellcat burnout
Well, ok… almost.
Only about half a second’s difference between the two at the end of the run.
And the Hellcat’s got 707 hp.
This BMW only has half that.
Less, actually.
Well, so they say.
Allegedly, 320 hp from the updated 3 liter (and twin-scroll turbo’d) straight six.
I wonder…'16 340i gauge cluster
It is said BMW under-rates the power output of its engines.
This seems probable here.
I’ll tell you what’s certain: Nothing in its class – the Mercedes C450 AMG, the Lexus IS350 – runs with it.
In a straight line or otherwise.
The 3 is BMW’s mid-sized luxury-sport sedan/wagon; the subject of this review will be the 340i sedan – which is the new name for what used to be the 335i sedan. The raise-you-five actually raises you 20 (horsepower) … at least … vs. last year.'16 BMW 340i retro
And much ups the car’s performance.
Cue Suspicious Minds.
The 340i stickers for $45,800 if you like to smoke the rear tires; $47,800 for the same ride with xDrive AWD.
This is less than immediate-obvious cross shops like the Benz C450 AMG (which starts at $50,800).
And the Three gives you also more performance.'16 340i manual
You also get a choice the Benz does not offer. To go automatic… or go manual.
The Benz (and another possible cross-shop, the much-less-speedy but slightly less expensive Lexus IS350) are automatic-only.
And so, incidentally, is the Hellcat.
While the turbo four-powered 320i and mid-range 328i remain functionally the same as last  year – and keep their designations – the six cylinder-powered 335i becomes the 340i. Engine output is increased by a supposed 20 hp – from an advertised 300 to 320.'16 340i LED
The new 340i also comes standard with additional amenities, including a 16 speaker ultra-premium Harman-Kardon audio system and LED headlights (these are available optionally with the 320i and 328i).
All 2016 Threes get minor exterior and interior styling tweaks and an updated suite of apps, including BMW’s Online with MyInfo system – which pipes real-time news and info directly into the car.
There’s also a new Track Handling package – which is basically the same as last year’s Dynamic Handling package. It bundles lightweight 18-inch wheels and summer tires, upgraded M Sport high-performance brakes, an adaptive suspension and faster-ratio steering.
WHAT’S GOOD'16 BMW burnout
It’s a ripper.
Not an obvious ripper.
Shift for yourself, if you like.
You don’t have to buy the automatic – or AWD – to get the ripper engine.
Gives up nothing on luxury – or tech – to less-quick (and more expensive) rivals like the Benz C450 AMG.
WHAT’S NOT SO GOODstorage cybby
Easy to spend Hellcat money on one (my test car’s sticker was about $50 short of $60k).
Easy to get yourself into real trouble with one.
Ridiculous center console storage cubby.
12V power point (for the radar detector) is located in a not-great place and isn’t deep enough; intermittent radar detector power plug connection issues.
BMW was one of the first car companies to buy whole hog into small engines made big when needed via turbocharging. Most Threes (the 320i and the 328i) are powered by a 2.0 liter four that makes – respectively – 180 and 240 hp.'16 BMW 3401 engine 1
And then there is the 340i.
It’s also turbocharged (twice) but you get six rather than four cylinders  – and 320 hp. That’s an 80 hp bump up from the 328i and 20 (on paper) up from last year’s 335i.
Now, that’s not a huge bump – from last year to this year. But here’s where things get interesting.
Though it’s basically the same car – no lighter than last year – and (on paper, at least) only packing an additional 20 hp vs. last year – the ’16 340i practically explodes from rest to 60 in 4.6 seconds, which is almost one full second quicker than the 2015 335i (5.6 seconds to 60).
So, something’s fishy… in a very good way.'16 340i engine detail
Also, good – spectacular, really – is the 340i’s potentially near-economy car fuel economy: 22 city and 33 with the optional eight-speed automatic (RWD version). Those numbers would have looked good on a Civic not all that long ago – and even today, they’re not all that far from the numbers delivered by a new Civic.
Which will not explode to 60 in under 5 seconds, either.
You lose a few MPGs if you stick with the standard six-speed manual transmission: 20 city, 30 highway. But these are still impressive numbers given the other number.
Context: The Dodge Hellcat – which can explode even more explosively to 60 (in just 3.9 seconds) also has an appetite for gazzuline that would appall Mad Max: 13 city, 22 highway.
Remember: The Hellcat’s only about half a second quicker to 60.
It may be packing 707 hp… but it’s also carrying 4,575 lbs., about 1,200 pounds more than the BMW’s curb weight of 3,370 lbs.'16 340i auto shifter
But the Hellcat has the excuse of being a full-sized lunker. The BMW is mid-sized. It’s also a sport sedan whereas the Dodge is what Arnold in his Terminator prime would have been if he’d been a car.
How about the direct cross-shops?
The obvious counterpoint is the C450 AMG version of the Benz C-Class sedan. It’s also got a turbocharged six (though a V6 instead of an inline six) and its 362 hp sounds like a winner. But the Benz is hobbled by a much higher curb weight – 3,748 lbs. – and it comes only with an automatic transmission and only with all-wheel-drive.
Hence the excess poundage.'16 340i sport displays
And hence, a less quick (4.8 seconds) run to 60.
The AMG-amped Benz is also expensive – $50,800. That’s exactly $5k more on the sticker than the rear-drive/manual transmission 340i ($45,800).
The Lexus IS350 isn’t even in the running, really. Though it comes with a 306 hp 3.5 liter V6 (a big one, these days) and its 306 hp rating is respectable… it only manages a 5.9 second to 60 run.
Don’t mess with a Hellcat in that one.
ON THE ROAD'16 3401 blue
Ever drive an old muscle car with lots of engine – and a loose throttle return spring? The 340i’s accelerator pedal is …sensitive. It translates intention into action instantly.
And there’s a lot of it.
I am not buying BMW’s 320 hp claim. The math doesn’t add up. Another 20 hp vs. last year – in the same car – no way that translates into almost a full second off the 0-60 time.
Or even half a second.
Please.
The six has the double advantage of six cylinders and turbocharging – which is torque plus more torque. A bigger engine is already at an advantage, torque-wise. Adding a turbo not only boosts the total torque output, it makes the torque swell sooner. The six’s 330 ft.-lbs. (comparable to the torque output of a 4-5-ish liter V8) peaks at 1,380 RPM.'16 340 i road 2
What that means is sucker punch acceleration … the guy in the lane next to you being the sucker.
Even if he happens to have a Hellcat. How’s your reaction time? If it’s a little better than his, if you get The Drop on him – you’ve got him. Maybe you won’t walk away from him. But you’ll annoy him severely by preventing him from walking away from you.
And bye-bye C450 AMG.
Lexus IS350 even more so.
The hilarious thing is all of them look like they’d be quicker – the AMG Benz with its fierce squat and powder-coated brake calipers; the Lexus with its skin stretched tight over bulging flanks like an Amazon Anaconda squeezing the life out of a deer.'16 340i road 2
But they’re not.
And – numbers aside – the BMW  is more emotionally satisfying. The unique pitch of its straight six engine; the opportunity to shift for yourself. Hoon-Friendly electronics (the Lexus’ and the Benz’s aren’t; Big Momma steps in early and often).
Select Sport+ mode and throttle tip in becomes even more sensitive; if you have the automatic, shifts firm up, the adjustable dampers cinch down – and you are ready to do Very Illegal Things and – unlike the Hellcat pilot – probably get away with it.
You will definitely have to stop for gas (if not cops) less often. I love the Hellcat but even the advertised 13 MPG (city) is as optimistic as hoping for snow in Phoenix. It’s possible, maybe. If you drive it like Al Gore hypermiling a Prius… but then, what’s the point?
The BMW, on the other hand, can be driven exactly as it ought to be – and you will still see mid-20s. Better than the Hellcat on the highway  driven like a hypermiling Prius – except you are not driving the BMW like a hypermiling Prius.
It helps, of course, that the 340i weighs some 1,200 pounds less than a Hellcat.
It also weighs less than either the C450 AMG  (a lot less than the C450 AMG) and also the Lexus IS350.
Which helps when the road bends.'16 340i road 4
Not that either the Benz or the IS (or the Hellcat) haven’t got lots of lateral grip.
They do.
The BMW just feels lighter on its feet – because it is.
You can one-finger (well, one hand) it around the apexes. It takes more effort to do the same in the others, especially the Mercedes. The Lexus IS is better in this respect (maybe in part because it is only slightly heavier than the BMW) but it doesn’t pull as hard coming out of the apexes as the BMW does.
Note also that Lexus downgrades you to a six-speed automatic if you want the AWD.
And the RWD version comes only with the eight-speed automatic.
AT THE CURB'16 340i curb 1
It’s said that imitation is the most sincere form of flattery. If so, BMW should be very flattered.
Take a look at almost any current (or recent) mid-sized sedan… luxury-branded or not. The overall shape is… familiar. In some details (the shape of the rear quarter glass, for instance) the flattery is so enthusiastic it’s like the difference between McDonald’s and McDowell’s (for those who remember this Coming to America reference).
The upside is the 340i blends in better today than a 635 CSi did back in the ‘80s.
If you’re running from Roscoe, all you really need to do is find a large parking lot – any shopping mall will do – and just… park it. You are one of many. No, officer, it wasn’t me back there… I’ve just been doing some shopping… you have me confused with someone else.'16 340i back seats
Meanwhile, the Benz C450 and even the Lexus IS350 stand out a little more – and that makes them a riskier proposition for risky business.
But illegalities aside, let’s consider practicalities – a criteria not usually associated with BMW sport sedans.
And yet, it is the more practical car of this trifecta.'16 340i main cluster
Three inches more backseat legroom (35.1 inches) vs. the Lexus IS350 (32.2 inches) and nearly an inch more headroom back there, too (37.7 inches vs. 36.9 inches for the Lexus). And the Lexus is the slightly bigger car overall (183.7 inches long vs. 182.4 inches).
The Benz C has about the same room in the backseat (slightly more legroom, 35.2 inches; slightly less headroom 37.1 inches) but – in power/performance-comparable trim (C450 AMG) it is priced $5k higher to start – no small change even at this price point. You could buy the six-speeded 340i and the Track Handling package and still be out the door with a decent bit of money left over for track day fees and tires.'16 340i door detail
Though it is a new and fully modern car in terms of the technology and features it has – including an LCD dynamometer showing you horsepower and torque output as well as peak hp/torque achieved, the ability to use your phone to lock the car remotely or turn on the climate control – it is also happily retro in some other areas. The door tops, for instance, are low enough that you can almost rest your elbow on them with the window glass rolled down. Most modern cars have doors so high you feel as though you’re sitting way down low, bathtub-style.
In addition tot he claustrophobia factor, this also makes it harder to see to your left and right… in those other cars.
Not in the Three.heated wheel
Also “period” (in a good way) is the main gauge cluster, which consists of large circular/analog speedometer and tach, with traditional BMW fonts. To the right of this is a nearly 9 inch LCD display (the base 320i and 328i come with a smaller 6.5 inch screen) which is controlled via a rotary/push knob and secondary buttons mounted just behind the gear shifter. Which – if you opt for the automatic – is a fully drive-by-wire toggle-style shifter that you tap forward and back to engage the ranges.
Everyone has heated seats now. But a heated steering wheel – that’s money. Order the Cold Weather package and you’ll never regret it.
Gripes:power point
In a car like this, a radar detector is don’t-leave-home-without-it. The problem is the 12V power point is both awkwardly located in between the two round holes for drink cups located toward the front of the center console – and it’s too shallow to provide a positive connection.
My V1 would go dark without my noticing it – or because a coffee cup jostled the pigtail connector.
It didn’t happen to me during my test drive, but it’s inevitable that – due to the location of the power point in between the places where you put drink cups – there will also be spillage.
Which will further erode the connection.'16 3401 last
The center console armrest is fine, but there’s next to no storage underneath it.
While the Three has plenty of room for legs and shoulders and heads, covered cubbies are insufficient.
These are minor irritants, though, when the package itself is considered.
I love this car. It’s just the ticket for doing the things you’d be inclined to do with a Hellcat, but with more discretion  – and for about $20k less, too.
Just don’t buy a red one…
Will you help us?
10 COMMENTS
  1. No offense, the c450 AMG is quicker in the corner and straights than a 340. Look at all the actual tests (car and driver and motortrend) instead of the manufacturer specs. The AMG lite trounces the BMW in all performance aspects.
    • Hi Frank,
      None taken!
      Of course, test results done by magazines are not authoritative. Different conditions/drivers, etc. Your mileage may (and probably will) vary. Also, the Benz is considerably more expensive – so if it does trounce the BMW… well, it ought to!
      And – intangibles…. the Benz is automatic-only. Yes, yes. I know. It’s a brilliant automatic; it shifts perfectly, every time.
      I still prefer shifting myself.
      We’re not racing for money, after all.
  2. How distracting is all the electronics & driver-programmable options on this car?
    I’d like BMW to produce a sports sedan without all that stuff, because it just gets in the way.
  3. Randy –
    I have often thought about purchasing a lightly owned BMW, however, the perceived poor reliability of these cars has kept me away. On the other hand, I drive a Subaru Legacy and have had a number of issues with it. These include suspension noise, airbag issue, and others.
    How is yours doing? How many miles do you have? What is your annual maintenance bill? How frequently do you have unexpected repairs to do on it?
    Do you drive mostly city or highway driving?
  4. All BMW drivers I see on the road drive them like there is a cop on their ass. Why buy the ultimate driving machine and drive like a clover?
    • C_lover:
      Not so around here. My commute is 1/3 curvy, hilly road and 2/3 expressway. (GA 400- also known as the Georgia Autobahn) These roads get burned up daily by myself and others.
      If you are ever around the northern Atlanta suburbs and see a light blue 335i sedan headed in your direction, please get out of my way!
  5. I almost bought a Bimmer once but we were car poor, a hot rod, a sedan, the Elco, one two wheel drive heavy half Silverado, a 3/4 T 4 WD Chevy Silverado loaded and a Nissan 4WD that would have been a tree climber if anyone, including Nissan, had ever made a locking diff for it. Nissan will sell you a pickup with lots of potential and never follow up on all the things you want to add…..so neither will the aftermarket. They can suck my balls as Cartman would say.
  6. This is THE car I’ve lusted after since it was announced. In today’s world of automobile appliances, a few stand out as true driving machines and I think this is one of them. The understated look only adds to the appeal, IMHO.
  7. I love it too- about as much as my (paid for) 2009 335i.
    The thing is amazing. With the JB4 tuner upping the boost to 17 PSI, I regularly pick on C5 Vettes, Mustangs, Hemi Challengers, 370Z’s and such, with success. No idea of the horsepower, but I’d wager it’s north of 400 at the flywheel.
    Driven carefully enough, it can hit 30 MPG on a long trip, too.
    Also, killer handling, decent quiet ride, and all the lux goodies I’d ever want.
    All in an innocent looking, quiet little sedan.
    Driven by a well dressed 57-year-old.
    No tickets in the 3 years I’ve owned the thing. Part luck- part image.
    Hee hee….
