2016 Nissan Titan XD
19
6827
Straddling the middle is no easy thing – but that’s what Nissan hopes to do with its new Titan XD.'16 Titan lead
It is tougher – in terms of the beefiness of its frame, the grunt of its engines (including a standard gas V8, with a turbodiesel V8 available optionally) and its ability to pull and push more than a light-duty 1500 series pick-up (like the previous Titan) but not quite as much of a handful to deal with as a heavy-duty 2500 or 3500 series pick-up.
Not everyone needs a dually – or the ability to pull 18,000 pounds (which is about what the Ram 2500 turbodiesel can pull).
The bad news – arguably, the stupid news – is that Nissan is only selling this thing in Crew Cab configuration. And only with a 6.5 foot bed.
Which is an obvious deficit, no matter how much it can tow.'16 Titan 5.0 Cummins
Also, its max tow rating – 12,300 lbs. with the optional diesel V8 – isn’t that much higher than the max tow ratings of either the Ford F150 (12,200 lbs. when equipped with the optional twin-turbo 3.5 liter gas V6) or the ChevySilverado 1500 (12,000 lbs. when equipped with the optional 6.2 liter gas V8).
However, the Titan does out-tow them all with its standard gas V8.
All the 1500s – except the Toyota Tundra – come standard with V6s and much lower standard tow ratings. And even the V8 Tundra (with its top-of-the-line optional V8) can’t match the pulling power of the gas V8-powered Titan XD (11,270 lbs. vs. 10,500 lbs. for the Toyota).
So while the diesel is getting most of the press, it’s the gas-engined Tundra XD that may make the most sense.
WHAT IT IS'16 Titan XD composite
The Titan XD is a new take on Nissan big trucks. It’s bigger and beefier than the previous Titan (no XD) and offers as an option a turbo-diesel V8 engine that can pull up to 12,300 lbs. – outclassing the max tow rating of currently available 1500 series trucks (though its maximum capacity is well below what 2500 and 3500 series trucks can handle).
It comes only in crew cab (four door) configuration and only with a 6.5 foot bed, though Nissan may – and hopefully, will – expand the cab/bed configurations later in the model year.
Base price is $35,290 for a 2WD 4×2 S trim with a 390 hp 5.6 liter gas V8; adding 4WD puts the MSRP at $38,290.
With the optional 310 hp (and 555 ft.-lbs. of torque) Cummins diesel V8, the MSRP is $40,290 with 2WD and $43,290 with part-time 4WD.'16 Titan tow
The most expensive version is the Platinum Reserve with the Cummins diesel and 4WD. It lists for $60,520.
This pricing structure puts the Titan XD to the right of the Toyota Tundra CrewMax – which starts at $33,270 ($34,970 with the step-up 5.6 liter V8 in place of the standard 4.6 V8) and the Ford F150 Supercrew with 6.6 bed, which stickers for $34,165 to start. You can add the twin-turbo 3.5 liter Ecoboost V6 (and 12,200 pound max tow rating) to this truck for an additional $1,515 – bringing the sticker price to $35,680 or just a couple hundred bucks more than the MSRP of the base trim Titan with the gas V8 and an 11,270 lb. max tow rating.'16 Titan step ladder
But the Nissan costs thousands less – and tows more – when equipped with the hunky diesel V8 than a Chevy Silverado 1500 crew cab equipped with the optional 6.2 liter V8 and 6.6 foot bed, which stickers for $46,705 to start in LTZ trim.
A Dodge Ram 2500 Mega Cab with the optional 6.7 liter Cummins turbodiesel six tows more – but costs a lot more: $50,420 to start in SLT trim.
The Titan XD is all-new.
The regular Titan (no XD) is on vacation for the 2016 model year. It will reappear in fall as a 2017 model.
WHAT’S GOOD'16 Titan gooseneck detail
Burly towing capability with the standard gas V8 engine; competitive price vs. lighter-duty 1500s.
Available heavy-duty diesel pulling power – without the clunky ride and handling that’s typical of 2500 and 3500 series pick-ups.
Factory-installed integrated gooseneck trailer hitch.
Sensible column shifter for the transmission (maybe not as “sporty” as a console-mounted shifter but it de-clutters the center console).
Rear seat bottoms can be folded out of the way to make more room for cargo inside the cabin.
Removable “Titan box” bed storage system for hauling ice (and beverages) or tools or whatever… and you can take it out of the bed when you’re not in order to haul more things in the bed.
WHAT’S NOT SO GOOD'16 Titan bed detail
Heavier – and slower – than 1500 series trucks.
Not as burly as 2500 series trucks.
Diesel-powered Titan’s tow rating isn’t that tremendous vs. what’s available in several 1500s.
Fuel tank is just 26 gallons (Ram 2500 carries 31).
Uncle’s emissions rigmarole requires regular DEF top-offs.
Crew cab (and 6.5 foot bed) configuration only.
UNDER THE HOOD'16 Titan 5.6
The Titan XD comes with your pick of gas or diesel V8 power – unlike the Ford F-150, Chevy Silverado and Dodge Ram, which start out with V6s. The Toyota Tundra comes standard with a V8 – but doesn’t offer a diesel option. The Ram 1500 is available with a diesel – but it’s not a V8.
Score one, Nissan.
The Nissan’s gas V8 – standard equipment – is an uprated version of the 5.6 liter V8 used in the previous Titan 1500 but making 390 hp now vs. 317 hp before. It is paired with an also-new seven-speed automatic (two more gears than the previous Titan’s five-speed automatic) and your choice of 2WD or part-time 4WD with two-speed transfer case and Low range gearing.'16 Titan 4x4 detail
The Titan thus starts out with more engine –  and not surprisingly – boasts more standard pulling power: 11,270 pounds.
To beat that in a Ford F-150, you will have to move up three engines – from the base 3.5 V6, past the next-up 2.7 liter V6, passing over the available 5.0 V8, to the top-of-the-line 3.5 liter twin-turbo “EcoBoost” V6, which can pull 12,200 lbs.
It’s a similar story over at the Chevy store.
The Silverado’s base V6 doesn’t cut the mustard; neither does the next-up 5.3 liter V8. To match – to slightly beat – the Titan, you have to buy the top-of-the-line 6.2 V8, which can pull 12,000 lbs. But unlike Ford – which offers the 3.5 Ecoboost V6 and 12,200 lb. tow rating in less expensive trims – Chevy only sells the 6.2 V8 in the higher-cost trims.'16 Titan 5.0 detail
Dodge and Toyota can’t hang, regardless of what’s under the hood. The best the Tundra can do – with its top-of-the-line 5.7 V8 (a 4.6 V8 is standard) is 10,500 lbs.
The V8 (gas) Ram 1500 is the same (lesser) league: 10,620. Its available diesel V6 pulls 9,210 lbs.
Optional in the Titan XD is a DOHC 5.0 liter Cummins turbo-diesel V8 that ups the towing ante to 12,300 pounds. This engine – which makes 310 hp and 555 ft.-lbs. of torque at 1,600 RPM – is paired with a heavy-duty Aisin six-speed automatic with tow/haul mode and a standard 3.92 rear axle ratio.
The Cummins block looks like aluminum, but it’s actually a special type of lightweight cast iron called compacted graphite iron. The heads are conventional cast aluminum.'16 Titan DEF
Unfortunately, even though the Titan is in a weight class of truck that used to be exempt from (or at least, subject to less strict) emissions requirements, it’s not anymore. Uncle is going after the bigger rigs, too. Which is why the diesel Titan has both a particulate filter and the dreaded DEF tank, which must be topped off periodically. A dashboard light comes on to nag you about this – and if you ignore it long enough, the engine will go into a “limp home” mode until you do as Uncle demands and top off the DEF tank (filler right next to the fuel filler).
Regardless, the Titan can pull.
It’s just not very quick.
Even the gas version – notwithstanding its solid hp numbers. Because of its weight numbers.
Being a heavy-duty truck, the Titan XD is also a heavyweight: 6,005 lbs. for the 2WD version (6,276 for the 4WD). For a sense of this, the previous Titan 1500 weighed just 4,847 lbs. for the 2WD version and a comparatively svelte 5,549 lbs. for the 4WD version.'16 Titan XD 5.0 badge
Not surprisingly, it takes longer to accelerate to 60.
A lot longer.
About 9.3 seconds – vs. as quick as 6.4 seconds for the F-150 (with the mid-range 2.7 twin turbo V8 and a stunning 5.9 seconds for the 6.2 liter-equipped Silverado.
Uncle doesn’t publish mileage stats for trucks in the Titan XD’s weight class, but I averaged mid-low teens driving a diesel-powered 4WD around for a week. The gas-engined version will probably give you about the same mileage – its lesser inherent efficiency (as a gas engine) crutched somewhat by its new and very efficient seven-speed transmission.'16 Titan seven speed Aisin
So why didn’t Nissan put the new seven-speed box behind the Cummins diesel? Two reasons: It probably could not handle the torque output of the diesel V8 – or the loads it would be expected to be bear.
Side note: As mentioned up above, Nissan gave the Titan XD a comparatively small fuel tank – just 26 gallons. This makes the thing deem thirstier than it really is. Other big trucks offer larger tanks – or even dual tanks – which greatly extends their range in between pit stops.
ON THE ROAD'16 Titan 4x4 detail
Well, it’s a behemoth. Twenty feet and change (242.7 inches) long, almost seven feet (77.9 inches) tall and riding on a wheelbase (151.6 inches) that’s almost long enough to swallow an entire Versa Note sedan (163.7 inches).
But – except in close quarters – it is a manageable behemoth.
The ride quality is as pleasant as the Urban Cowboy 1500s – and much better than the real cowboy 2500s, which almost have to be that way (harder-riding) in order to be capable of doing the things they can do (like pull almost 18,000 pounds). You can only do so much with so much unsprung mass.
The Titan’s body-on-frame (with rubber biscuits in between) construction  – typical of heavy-duty trucks – also helps dissipate the dissonance that would otherwise intrude.'16 Titan XD road 2
It’s only when maneuvering in close quarters that the scale of the aptly-named Titan becomes apparent.
Turning radius is almost 54 feet (53.8 to be exact) and to put that in perspective, a Versa’s turning circle is 34.8 feet. Granted, that’s an apples-orange comparison – but it gets the point across.
You almost need tugs to line this thing up for a parking spot and negotiating city streets with cars parked on either side (and other cars coming at you from the other direction) can be entertaining. At least you’re bigger – so the cars coming the other way usually defer and do the backing up.
At idle the diesel burbles just enough to let you (and others) know it is a diesel. It does not, however, feel particularly strong. Its numbers are good – 555 ft.-lbs. of torque at 1,600 RPM is very decent – but its also nowhere close to the axle-twisting rotational force of something truly hairy like the Ram 2500’s Cummins 6.7 turbo-diesel, which metes out a Kenworth-level 800 ft.-lbs. of torque.2016 Nissan TITAN XD
“Neck snapping” doesn’t quite capture it.
The Nissan/Cummins diesel’s chief virtue is its easygoing pulling power. It does’t feel like it could wrench a double-wide off its cement blocks like the Ram 2500 does (and could) but it also doesn’t feel at all winded pulling a 10,000 pound-plus load (which I did). Read Ford forums and you’ll find many complaints about the real-world performance of the Ecoboost 3.5 V6 when tasked with pulling serious weight – its advertised capacity notwithstanding.'16 Titan XD pulling
The Chevy Silverado with the 6.2 V8 is probably the Titan XD’s biggest worry as that hero of a V8 makes almost as much torque (460 ft.-lbs.) as the Nissan/Cummins diesel and much more hp (420).  However, as noted earlier, Chevy will only sell you the heroic 6.2 in expensive trims with result being you’ll spend thousands more than you would to get into a diesel-powered Titan XD.
The gas V8 offers a bit more pep at the expense of some pull. But you can still pull a lot, even so (see above) and the economics of this version of the Titan XD are pretty compelling unless you really do need to regularly pull a load that weighs over 11,000 pounds.
AT THE CURB'16 Titan Behemoth
The biggest shortcoming of full-size Japanese trucks has always been the limited choices they offer (vs. American-brand full-size trucks) when it comes to cab/bed configurations.
The Titan XD doubles down on this pattern by offering no choices at all.
It’s the crew cab (four full-size doors) and 6.5 foot bed, take it or leave it.
I suspect a lot of potential buyers will leave it.
It’s frustrating to see an otherwise appealing truck – a really solid effort – gimped by a corporate decision to ignore the needs of people who want less cab and more bed. Or the reverse.soup nazi image
Why?
The Ford F150, the Chevy Silverado 1500, the Ram 1500 – even the Toyota Tundra – can be had in regular cab, extended cab or crew cab form, with various bed lengths to suit.
Ditto all the 2500 series trucks currently on the market.
The Titan XD stands alone, insolently – a kind of 4×4 soup Nazi.'16 Titan back seat
Right off the bat, Nissan has put this truck at a competitive disadvantage. I, for example, would be interested in a regular or extended cab Titan XD. But I am not interested in the crew cab because I don’t have a crew. And I’d rather have an eight-foot bed instead.
Or even just less length.
When I characterized the Titan XD as a behemoth, I was using that word with deliberate precision. It is longer overall (and not by a little) than all the other major players: 242.7 inches vs. 228.9 for the Toyota Tundra crew cab (which to be fair has a shorter 5.6 foot bed, but still) 231.9 inches for the Ford F-150 Super Crew, 237.9 inches for the Ram 1500 crew cab and 239.6 inches for the Silverado crew cab.
The Nissan is also longer than the 2500 series crew cab versions of the F-truck (232.4 inches) and Silverado (239.5 inches) and nearly as long as the Greatest Kahuna of them all, the Ram 2500 MegaCab (248.4 inches).
Suffice to say, it’s a whole lotta truck.'16 Titan XD curb 4
Maybe too much truck for some.
And for others, perhaps not enough.
The shorty bed, for instance – although this can be crutched somewhat by dropping the tailgate and using (after buying) the available tubular extender cage to keep stuff from leaving the bed. But it’s not the same as having an eight-foot bed.
You also have to pay extra for a factory-applied, sprayed-on bed liner. Ditto a receiver hitch and wiring harness for your trailer.'16 Titan XD tent
You can, however, get things – like an integrated gooseneck trailering system – not available (or advisable) in lighter-duty 1500 series trucks.
An integrated trailer brake system is also available and the bed can be ordered with neat-o features such as Nissan’s “Titan box” storage system (these can be removed or left in place as your needs of the moment dictate) and a folding step ladder to get in the bed (tall walls).
An available Advanced Drive Assist off-road display shows the truck’s (and terrain’s) forward, rearward and lateral tilt. You can get an electric-locking tailgate – and a factory bed tent, too.
THE REST'16 Titan trailer brake
It’s about a $5k jump to go from the gas V8 Titan XD ($35,290 for the 2WD version) to the same truck with the diesel V8 ($40,290).
Is it worth it?
It depends.
On the one hand, the gas-engined Titan makes a persuasive case for itself (excepting the limited cab/bed configurations). As it sits, it’s much stouter than any 1500 unless you ante up those trucks with their optional (and higher-cost) engines and even then, they’re inherently lighter duty in terms of their construction.Titan last
On the other hand, the diesel pulls even more – and while it doesn’t pull all that much (on paper) than the max-effort versions of the F-150 and Silverado 1500, those are when all is said and done gassers – and gassers will never have the grunt (and probably not the long-haul durability) you’ll get with a diesel.
Still, if I’d been The Decider over at Nissan, I’d have made the diesel V8 gruntier. Maybe 650 ft.-lbs. of torque. To put some more distance between it and gas V8s like the Silverado’s 6.2 – and to get a little closer to diesel sixes like the Ram 2500’s 6.7 liter Cummins.
It’s by far the toughest Japanese-made (though made in the USA) truck yet.
But it’d be nice if they made it in more than just the one configuration.
Will you help us?
PS: EPautos stickers – new design, larger and magnetic! – are free to those who send in $10 or more to support the site. Please be sure to tell us you want one – and also, provide a mailing address, so we can get the thing to you!EP magnet
19 COMMENTS
  1. “… people who want less cab and more bed.”
    I’m one of them.
    The bed is the real reason for having a pickup truck. Trucks are for hauling things, not passengers.
    A pickup truck is not supposed to be a four door sedan with a too small bed attached just in case someone might want to haul something.
  2. I’m going to throw Nissan in the woods for using “XD” after “Titan”. Seriously, what retards work at Nissan. “XD” is an emoticon text to indicate a “big grin”. It is like idiot CBS naming their new abomination Star Trek show coming out next year “Star Trek Discovery.” Like nobody will notice that means “STD”…..
    • One reason I’ve never looked at KIA is that I can’t imagine driving a car while “killed in action” keeps popping into my head.
      • Dear Mike,
        Good to know that Chinese are not the only people with such concerns.
        Buildings in all regions of China, including the mainland, Taiwan, Hong Kong, and Macau, often lack a 4th floor. The floor numbering system goes 1, 2, 3, 5…
        Why?
        Because “4th” is a near homonym for “death”. Many people are averse to living on a “death floor”.
        The 13th floor has the same connotations for many westerners.
      • Cadillac actually put the initials ETC on the flanks of their final generation of the Eldorado. A luxury car formally branded as et cetera. And so on and so forth; yadda, yadda, yadda. Being an acronym for European Touring Coupe never came to anyone’s mind.
        Perception is reality.
    • You knew The Final Frontier was going to be the end. If it had been the “next” frontier then you’d have looked forward to a new show at the end of the run of that series. Oh wait, Nissan makes a “Frontier” don’t they? or was the Frontier final?
  3. It always amazed me in real world situations ..I could generally get the EPA rating (i do know how to check mileage ) but alas everyone else with bigger vehicles and more powerful engines always seem to get at least 20 mpg are those MPG numbers on the readouts correct? It usually takes me awhile to budge them up.On the MPG claims it seems that I dont have to fill up more frequently then other people.Steady driving at your vehicles sweet spot will net the best mileage.
    I can attest to the Tundras durability ,but the mileage seems a bit less then other makes,my Neighbor has a Titan that has been through the wringer and still runs good ,if nothing else I could recommend a Titan on the Durability alone . some of these urban truckers have to realize when you are pulling 10 tons you need something in front of the load to stop it as well,the Mega Pickups may be fine for some people ,but as for Me ,when I have to haul the heavy stuff ,I get a real truck(you can haul 30,000 # all day .all week no problem,a lot of the jacked up mega trucks around here haul nothing but a shiny 2 5/16 th hitch ball(you are starting to see a good many of the 60K trucks sitting around more and more)
    The public has been duped into believing they can afford those 84 months of mortgage plus size payments.
    • Kevin McCune,
      It depends on why a person is purchasing a vehicle.
      Some people buy with a specific reason.
      I need it for work use.
      I want to impress the neighbors.
      I like how it drives / looks / makes me feel — (Perhaps more than one)
      I want it for commuting to/from work.
      I want it for traveling.
      I want to be able to move X number of people with a trunk to match.
      I have money to burn.
      It is comfortable to drive.
      I want to travel off-road.
      I want to travel quickly.
      etc.
      Some people do not care how much something costs.
      Some people are frugal with their money.
      Some people have a limited budget to spend on a vehicle.
      I find small pick-up trucks (hopefully they can still be found for under $20000) to be useful for hauling small relatively light (under 1,000#s) items around and they have reasonable mpg (20-27). The mpg is lower than I would prefer, but is worth it if I often found myself using the truck for moving things around.
      $60000 for a work truck seems expensive to me, but I do not know what they should cost.
      • Well Mithrandir,the truth is these vehicles in this segment are the cash cows of the big auto makers,despite their shortcomings one particulat co has everyone pretty well hoodwinked,I asked the proud owner( a smallish lady ) what Her new Ecoboost got around in the sticks (pat answer 20 mpg ) makes you wonder what she needed a full size 4 dr pickup for,oh well ,each to their own, her significant other drives a 4 dr Duramax.I cant really figure out the infatuation with gargantuan vehicles.
        Decent small trucks could be produced ,but it seems the market isnt there .
  4. The tow ratings don’t mean anything. Ford just raises their tow ratings if someone beats them. Chevy/GMC used to use a standard for tow ratings along with Toyota. They quit so they could one up the competition if needed; leaving Toyota the lone company following any standards on tow ratings.
    I’m on my 3rd Tundra since 2007. I haul 3/4 ton loads on a weekly basis. It does fine. Not as good as a diesel, but sufficient. The resale value of Tundras is unbeatable.
    Fyi, Eric. The Tundras optional big engine is 5.7, not 5.6 litre.
    • Hi Ancap,
      I’ve received muey letters from F-150 owners not happy with the performance of the EcoBoost 3.5 V6…
      PS: Thx. for the catch – fixed!
      • It’s funny you mention that. I have noticed that people are either honest and say that they never get better than 18 mpg with their eco boost–thats if they baby it–or they are completely full of shit and tell you they get 23 or so.
        I love my Tundra, but a fuel miser it ain’t. I’ve never seen the 17 mpg the epa got. Although I have noticed that my new one will get 14-15 in every day driving vs. my first two getting 13-14.
        Do you know if the fuel estimates at hwy speed are a cloverly 65-70 mph? I’m one of those people who counts on 2 mpg less than any sticker claims. That always seems to be my range.
        RE diesels, the old ones before def and particulate filters would deliver 18 mpg commonly. Not so with the new ones. Very disappointing to fork out up to 10 grand for diesels and have virtually no efficiency improvements, not to mention the extra maintenance. I remember the old 6.2 GM diesels, while not power house’s, they would deliver 20+ mpg in the old behemoth suburbans.
        • ancap, it’s the point of diminishing returns as to fuel mileage and power although I’m sure you’re aware of that. The old 350’s in the early 90’s model GM’s got over 20 mpg even with ext. cab and I personally know of 2 that went well over half a million miles with nothing more than a water pump and alternator change. Once they bumped them up with the roller cams the longevity the older ones had was diminished.
          My old 6.5 Turbo diesel would get 18 and it was a one ton ext. cab 4WD with 4.10 gears. I’m sure it would have done better with the 3.73 gears.
          Some friends bought a new Tundra SS, crew with 4WD(that may be part of the SS package, don’t know). They had to buy their hand another pickup and found an ext. cab Ford gas engine, 4WD, not known for good fuel mileage. Still, the wife(her Tundra) was sorta miffed the old Ford did 2 mpg better than her Tundra. Her husband has a dually GMC with a Duramax. It has a big ranch bed on it plus compressor, toolbox and nurse tank. He doesn’t check the mileage, only wants it to be reliable since churning around in 4WD pulling a fuel trailer and driving through plowed fields is probably not the way to get the best mileage. He laughed about the Tundra/Ford debacle, she didn’t.
          I have notice nobody ever really checks fuel mileage either. They say “Hey, I drove it all week without filling up”. That’s some scientific stuff there. I’ll fuel one to the top every time and divide that mileage by the gallons used, a thing I guess other people can’t seem to do.
          What sort of mileage do you get? Oh, it’s good, better than my old(fill in the blank). Oh yeah, I hear you, 60 grand in debt so it better be better than the old whatever.
          • I never trust myself (or the pump) to get a consistent fill. I use the trip OD and save the receipts for 5-6 tanks.
  5. They might sell some to ranchers that don’t have a lot of cattle, as the tow rating means that only smaller goose-neck trailers can be used.
    So far as fifth-wheel RV owners, it’s right on the border of being unusable by them.
  6. The Titan XD is basically a truck for Nissan loyalists. It’s specs and configurations make it completely adequate for at least 80% of the functions a full sized (but not seriously “heavy duty”) truck is used for. And that will satisfy most of those loyalists.
    Japanese trucks just can’t offer all the configurations that US Trucks do, because they don’t sell nearly as many. That said, I agree that a 6.5′ bed Crew Cab leaves a lot of potential buyers out of the picture. 8′ is more bed than most folks need. How about an Extended Cab with 7′ bed? That might hit the sweet spot. Bring a lot more buyers into the fold.
    Beauty is in the eye of the beholder. To me, the XD design is a loser. Exaggerated curves above the front wheels create an unappealing “bubble look.” Even in the truck market, extravagant designs can work well, if done with inspiration, or at least good taste. That’s not the case here. Won’t bother the Nissan loyalists much.
    The XD won’t make any market conquests….may not even do as well as the original. But Nissan HAS TO offer a full sized truck, to keep those loyalists loyal. The XD should satisfy that minimum requirement.
  7. I find that Pilot has DEF for around $3/gallon. Also, it’s interesting that the pumps are covered in shrouds, presumably to prevent them from blowing up in near-freezing temperatures.
  8. Eric – might want to double check your number on the most expensive version. I looked at a loaded Pro 4 X at my local Nissan dealer. Sticker was $72k!! I currently have an older Titan, which I like a lot, but there’s no way I’d pay anywhere near that kind of dough for a Nissan truck. The resale on my Titan is a lot less than if it were a comparable Ford or Chevy. A friend just paid 22k for a 2001 diesel F150. Bet that Pro 4 X won’t be worth anything close to that 6 or 8 years from now, let alone 15! Course, the way the Fed is screwing us with inflation, maybe it’ll be worth 220k.
