2017 Toyota Tundra
11
8195
It’s much simpler buying a Japanese 1500 series full-size truck like the Toyota Tundra – and its across-the-street rival, the Nissan Titan (reviewed here).
Both come in fewer configurations –  so there’s less confusion – and they only come with V8 engines (the Titan has just one V8 engine).
The Big Three trucks are available in a wider variety of configurations and they each offer multiple engine options – four of them, in the case of the Ford F-150 (reviewed here) three of them V6s and two of those with turbos.
On the other hand, it’s also more expensive to buy a Japanese 1500 pick-up.
Both the Tundra – focus of this review – and the Titan each cost several thousand dollars more to start than the base trim versions of the Big Three 1500s.
But, it has other charms – and those charms may make it less expensive to keep as the years and miles roll by . . . .
The Tundra is Toyota’s full-size pick-up. Like other 1500s, it’s available in regular cab, extended cab and four full-size door crew cab configurations – with three different bed lengths available, depending on the cab style you pick.
Unlike the Big Three 1500s, the Tundra comes standard with a V8.
Unlike the Nissan Titan, you have your choice of a smaller or larger V8.
But there is no diesel option, V8 or otherwise. The Dodge Ram 1500 is available with a diesel V6 and the Titan XD, which is more than a 1500 but not quite a 2500, is available with a Cummins turbo-diesel V8.
Prices start at $30,500 for the base SR trim regular cab with an eight-foot bed, 2WD and 4.6 liter V8.
Double cab Tundras – two standard-sized doors and two smaller rear doors – start at $30,120 with 2WD, a six-foot bed and the 4.6 V8. The scale got up from there to $43,495 for a double cab with 4WD, the eight-foot bed and the upgrade 5.7 liter V8.
A top-of-the-line Platinum crew cab – four full-size doors – with 4WD and the 5.7 V8 lists for $50,130. There are also Limited, off-road-intended TRD Pro and 1794 editions of the Tundra.
Be advised that Crew cab Tundras are only available with a shorter-than-usual (5.6 foot) bed.
For cross-shop reference, a Chevy Silverado 1500 stickers for $27,0975 to start for a 2WD regular cab with an eight-foot bed; this trim comes with a 4.3 liter V6 – which can be replaced with either of two optional V8s.
The Ford F150’s prices start at  $27,030 for a similarly laid-out 2WD/regular cab, also powered by a V6 (with two turbocharged V6s or a 5.0 V8 available optionally).
A Dodge Ram 1500 regular cab in the same configuration – with a 3.6 liter V6 – lists for $26,495. The V6 can be upgraded to a V8 or – unique in this class – a turbodiesel V6.
The Nissan Titan is more Tundra-esque, both in terms of its base price ($29,580 to start) and because it is the only other 1500 series truck that comes standard with a V8 engine.
Limited trims get standard power seats; otherwise, the Tundra carries over from 2016 largely unchanged.
Regardless of trim, a V8 is standard.
Higher standard tow rating (10,500 lbs.) than V8 Titan (9,740 lbs.) and Big Three – and small standard V6 – rivals.
Simpler technology should prove more long-term durable.
Not as Cod Piece-y as the Big Three trucks; it’s possible to  touch the bed floor without standing on a milk crate.
No step ladder or Metamucil pole necessary to get into bed.
Big Three trucks are the better deal on the lower end and offer more drivetrain options.
Crew Cab versions come only with stubby 5.6 foot bed.
Just one USB hook-up.
In a way that really matters – if you’re shopping for a truck – the Tundra is closer to the way American trucks used to be made.
Because it comes standard with big – and simple – V8s.
No turbochargers. No V6s.
Ironic, isn’t it?
And the Tundra is the foreign-brand truck.
The base engine is a 4.6 liter V8 that makes 310 hp and 327 ft.-lbs. of torque; optional (and standard in Platinum, Limited, TRD PRO and 1794 (named after the huge ranch in Texas) is a 5.7 liter V8 that makes 381 hp and 401 ft.-lbs. of torque.
Neither of these engines is saddled with direct injection, either.
They are fed via port fuel injection – a simpler system that doesn’t need multiple fuel pumps or operate at 3,000 PSI and which will never cause you problems with carbon-fouled intake valves, as is becoming a problem with engines fitted with direct injection systems. In fact, Ford is going to add a separate PFI circuit to its direct-injected engines next year (2018) to deal with the carbon fouling. So, two fuel delivery systems – one to feed the engine, the other to keep the engine from being carbon fouled by the first system.
Chevy’s engines are direct-injected, too. As is the Nissan Titan’s.
As to the Why – it’s because they are newer trucks and were designed with the latest – and pending – federal fuel efficiency fatwas in mind. These fatwas – CAFE, or Corporate Average Fuel Economy requirements   are becoming more onerous and to cope with them, the other manufacturers have resorted to extremes such as twin-turbo V6 engines in trucks (and eight and ten speed transmissions) as well as affronts to common sense such as aluminum bodies . . .  more on this follows below.
The crazy thing is that tall this effort – and expense – hasn’t had much effect, as far as the individual trucks are concerned.
The Toyota’s V8s may suck more gas – but not all that much more gas – than the V6/turbocharged and direct-injected V8 competition. 15 city/19 highway for the 4.6/2WD combo (best case) and 13 city, 17 highway for the 5.7 liter/4WD combo – vs. 17 city, 23 highway for the Ford F-150 with its top-of-the-line twin-turbo 3.5 liter V6 and 4WD.
The Titan, with its direct-injected 5.6 V8, rates 15 city, 21 highway.
It’s not that big a difference.
And how will those turbo’d V6s and direct-injected V8s hold up after 150,000 miles of back-and-forth on dust roads out in the middle of Nowhere, TX?
Big, simple (and PFI-fed) V8s like the Tundra’s are not the Latest Thing, but they are known things – durable and rugged. Ditto the simpler six-speed automatic transmission that comes standard with both the Tundra’s V8s – vs. the seven, eight and ten-speed automatics in the Nissan, GM and Ford trucks.
Plus, you get more standard towing capacity – 10,500 lbs. – with either of the Tundra’s V8s than the rival 1500s can manage with their smaller/lighter-duty standard equipment sixes.
Or the the Titan – with its standard V8.
Another virtue of the Toyota’s V8s is that they are both regular fuel engines, designed to run best – and give their best mileage – on 87 octane, the cheap stuff.
Though it’s about the same size as other 1500s, the Tundra somehow feels – and drives – less Huge.
Here’s how it does that.
First, there’s less of it projecting forward. It is stubbier – from the A pillars at the base of the windshield to the front bumper. The front clip/hood is about Camry-sized, as far as how long it is. You don’t feel as though you are on the bridge of a supertanker, the prow miles ahead in the mist.
And it’s more than feel.
Because there’s less schnoz, the Tundra has more effective clearance. Tight turns – where there are things you might hit on either side of the thing – are less hairy and can generally be done without having to stop, back up, then inch forward – repeat.
The tested crew cab/short bed Toyota’s turning circle is three feet tighter than the same configuration F-150’s: 44 feet vs. 47.1 for the Ford. And four feet tighter than the Titan’s (48 feet).
That is a big difference.
The extra cylinders, too.
It’s true the V6s in rivals like the F-150, Silverado 1500 and Ram are nearly as powerful as the Tundra’s standard V8, but they don’t make as much torque – and what they do make, is made higher up in the rev range. The Tundra’s standard 4.6 V8 produces 327 ft.-lbs. at 3,800 RPM. The standard 3.5 liter V6 in the F-150, as a counter-example, only makes 253 ft.-lbs. and not until 4,250 RPM.
And of course, there’s sound.
That V8 lope. Nothing else quite like it.
Or that tows like it.
The standard-issue Tundra pulls 10,500 lbs. – and you don’t have to buy the optional V8 to get that capability, either.
A 26.4 gallon fuel tank is standard – but you can upgrade to 38 gallons (the larger tank is standard in Limited, Platinum, 1794 and TRD Pro trims) which gives the truck long highway legs – almost 500 miles – even with the 5.7 V8 and 13 MPG.
It’s quick, too. With the 5.7 V8, a Tundra gets to 60 in about 6.4 seconds. It’s not as quick as the class-quickest Silverado armed with its top gun 6.2 V8 (which is basically the Corvette’s V8 snugged into a truck) but you will never be afflicted with The Slows.
This truck still has a leaf spring suspension (some of the others -the Nissan Titan is one – have coil spring rear suspensions) so the ride is a little stiffer and on washed-out/rutted gravel roads, there’s more axle hop than in the newer-design trucks. But the Tundra’s one-finger steering – and tighter turning circle – makes up for a lot of that.
Besides which, leaf springs are simple and tough and durable – you know, the design attributes that used to be desirable in a truck.
The Tundra’s being an older design is a good thing in other ways, too.
The steel body, for one. If you dent the bedwall, it’s a straightforward fix to pull the dent or weld in a new panel. With aluminum panels – like the new Ford F-150 – it’s not as straightforward. But it is more expensive. Aluminum is harder to work, requires dedicated work space at the body shop due to cross-contamination issues while welding and takes more skill to weld than steel.
Ford went to aluminum to cut weight in order to increase fuel economy, to placate federal bureaucrats. It is understandable. But it may not be advisable – from the perspective of the people who actually own the trucks.
Another thing about the Tundra that’s good – and a function of it being an older design than the others: It has not-too-tall bedwalls. They are still tall – about 55 inches, or about a foot taller than the bedwalls of my compact-sized ’02 Nissan Frontier pick-up – but not so tall that a tall guy like me (6 ft. 3) has to stand on tip-toes to just barely be able to touch the bed floor. I can almost lay my palm flat on the bed, without both feet flat on the ground.
CodPiece Fever hasn’t yet caught up to the Tundra.
It is big, certainly. But it’s not as overwhelmingly outsized in proportions as some of the current 1500s. The shorter front clip, the not-quite-as-high roofline, the not-too-tall bedwalls.
It’s more manageable.
But, there’s a downside.
The crew cab (four full-size doors) Tundra is only available with a 5.6 foot bed, which means dropping the tailgate – and tying stuff down – if you need to carry longer items. On the other hand, you do get 42.3 inches of backseat legroom with this combo.
Some of the others – like the Chevy Silverado – offer the crew cab configuration with a 6.6 foot bed. It makes them more unwieldy to maneuver, of course –  the crew cab/6.6 foot bed Chevy is 239.5 inches long overall vs. 228.9 inches for the crew cab Tundra with the 5.6 foot bed.
But they’re more useful for hauling stuff.
Horses for courses.
All Tundras have more-than-usual ground clearance – 10.4 inches, minimum, including the base 2WD version.
The 1794 edition – named after the ranch in Texas – comes with handsome cowboy suede seat inserts and even better – because extremely politically incorrect – floormats decorated with what looks like spent .45 Colt brass.  If they see this in New York City, they’re going to have a stroke.
There are three power points on/in the center console, but only one USB hook-up, a small tell-tale about the Tundra’s age. The newest trucks have several USB hook-ups, given how hooked-up to gadgets everyone is now vs. back in 2007.
But, the Tundra is less bedazzled by gadgets – there are fewer displays and buttons and menus to scroll through – which makes it both simpler and less trouble-prone (probably) and also easier to just drive.
Some things do get better with age.
11 COMMENTS
  1. Bought a new Tundra Limited TRD in 2014. At that time, I regularly needed to carry a lot of cargo (high volume/low weight,) from the Valley to our place WAY offload in the mountains. It was “perfect,” both on road and off.
    Once we sold our ranch, the Tundra sat in our garage, almost un-used. It was just too massive for general suburban driving….and “especially” parking. So we traded it for a Hemi Grand Cherokee. Still has off road chops, and adequate cargo capacity for current needs.
    Final observations about the Tundra. You’re right, that engine ran great and sounded better than anything else, including the Hemi. Second, it ran flawlessly, and was assembled the same way. Third, the steering was not confidence inspiring, except in a straight line.
    Bottom line….it was the greatest car/truck I ever sold.
  2. I have a 2006 double cab Tundra that I bought off lease with 17k miles to replace a suburban for work and towing. There must be about 140k on it now. It is a great pickup and has served me well. It seats four really comfortably, or five family members if no one’s blood sugar drops. It pulls better than the suburban ever did, and it is understated in its styling…not a codpiece. I thought about trading it in on a ca. 2013 at one point, but upon reflection, I addressed a few things that bothered me about it; I had leather installed with heaters on the front seats and put in better stereo components (new head unit with backup camera, new speakers, amp, and subwoofer). That was probably the best $3,000 I could have spent. As I look at the new trucks, I will remember your codpiece comments; I wasn’t able to articulate just what I disliked about those before, but I think you are spot on!
  3. This Toyota is very, very “long in the tooth” as they say. You pointed out many of the reasons this is a good thing, but it’s also a not so good thing in others. However, more interesting to me is how much the rest of the market has changed since the introduction of this second generation Tundra.
    Introduced in late 2006 as a 2007 model, it was considered quite advanced in terms of powertrain back then. With a dual overhead cam, variable valve timing for both intake and exhaust V8 engine putting out horsepower in the high 300s, nothing in the Big Three’s stable was capable of competing at the time. This also raised much concern over durability and longevity of this power plant, given how much more complicated it was than contemporary pushrod V8s of the day.
    It was also plagued by horrendous styling (which has been much improved over the years) and a humongous footprint compared to other full-size trucks. This was likely in response to the poor reception of the previous generation Tundra which was roughly 20% smaller than a full-sized American truck of the same era. Toyota decided they needed to go big, and they dwarfed the Big Three in terms of on-road size, which also earned them laughs. Yet it failed to compete by almost any other measure. Then they sat on their laurels, doing little to update the truck in the intervening 11+ years aside from minor body panel tweaks. In the meantime, the Big Three have released two more generations of updated trucks, further leaving Toyota in the dust in terms of capability.
    Now, the powerplant has been proven both rugged and reliable, even by Toyota standards. But the interior has continued to be cheap and plasticky, the frame has proven to be weak and highly flexible, and it continues to be far too pricey for what you get.
    On the other hand, as you mentioned, the American models have all switched to direct-injection engines to boost fuel economy numbers. I’d beg to differ that a 6mpg difference in highway mileage is not much. It’s actually huge. Basically a 35% improvement. Yet I’m not sure that whatever fuel savings you see on the front end will offset the cost of repairs on DI engines and turbos and such in 5 years. Thus if you plan to keep your truck for the long-haul, especially if you’re going to work it, the Tundra, which used to be the most advanced powerplant, is probably the simplest and most dependable one out there short of a diesel (and possibly better than some of them).
    I’m really curious to see what Toyota does with the updated Tundra. It’s been pushed back so many years now that it really needs to be something special. Nissan’s updates are underwhelming at best, so it falls to Toyota to pull something off. Unfortunately, I’m afraid they will fall into the mpg trap as well, but here’s to hoping. Rumor is that they may also get the 5.0L Cummins diesel that’s in the Titan. If they can produce a better truck to put it in, that could be a real winner. At least as long as Uncle Sam doesn’t find a way to ruin the party any further.
    • Hi SJ,
      On the fuel economy thing: Having driven all of the current 1500s, including the F-truck with the 2.7 and 3.5 Ecoboost V6s, I can state that the real-world mileage difference between them and the V8 Tundra is a wash. Yes, the 2.7 and 3.5 V6s are capable of noticeably better mileage . . . if driven Clover-style! But the rub is most truck people won;t drive that way; I certainly don’t – and then the mileage is not as high as touted and the difference between it and the Tundra is about 3 MPG overall.
      But – I agree with you – even if it is 6 (hell, make it 10!) I would rather pay more for fuel than much more later for the repairs to the engine/DI system in the others – which are also laded with gimmicky, likely-to-break technology.
      We have reached an Event Horizon.
      • I can’t tell you the number of people who tell me that’s why they bought a drama or power stroke. They just couldn’t take 13 or 14 mpg’s. These same people don’t pull often, sometimes never. They don’t think hard enough to realize how much extra they are spending to get 2 mpg’s. 10 grand for the diesel engine option. 30-50 cents per gallon more at the pump in my state. All so they can feel warm and fuzzy when they tell their friends they get 15 mpg’s.
        It’s utter stupidity. I work in a field where I use diesel power and have several diesels at my disposal, but 90% of the time my gas Tundra fits the bill just fine. As do the gas Chevy’s.
        • ancap, you are correct but my 93 Chevy one ton 4WD ext. cab long bed diesel got 4mpg better fuel economy than my 2000 Z 71. And no comparison on towing or stopping with a trailer and to be honest, the 93 handled much better, unloaded and loaded. At least you can reach into the bed of both and get something. I got out of a new Dodge extra cab half ton last year and looked in the bed for my crap I carry with me in a big rig. I could see the very top of my 5 gallon bucket and nothing of the soft tool bag. I finally felt the top of it, just about to pull my arm out of socket, barely got the top handle in my hand and lifted it out. I knew to drop it as close to the side as I could.
          I was surprised that eric saw the 3 leaf spring Ford as an improvement. Starting back in 71 GM began making the load compensating spring system that got stiffer was it was loaded. It allowed the pickup to be much closer to the ground, handle better with or without a load so it was easier on tires, brakes, shocks and your backside plus the superior handling could save your ass. If you needed to replace springs on any other pickup, you could go to a spring shop and have them bend any size spring you wanted to stick in there on a Dodge or Ford but they couldn’t make a GM spring, a good thing as far as I was concerned. I’ve had friends point out the difference in their Ford and my Chevy siting the unloaded height as proof it would haul more weight. And haul more weight is not what it was capable of nor holding up with big loads but I’ll agree the Chevy did cost a few more dollars when new. I’ve seen that difference be less than $20 but Ford always claimed the cheapest price. Man, if you are concerned about a $20 list price difference you need to just borrow grandpa’s pickup since you don’t really need a pickup.
          Some younger friends(10 years)sitting around and bs’ing one day about the ultimate pickup they’d buy giving no limit. I told them they could have every pickup out there and I’d be glad to do everything I needed to do in a luxury sedan. One of the guys who owned a Caddy laughed and said it sounded good to him. A friend’s dad farmed his whole life without a pickup. He had a fleet of Caddy’s and pulled two cotton trailers to everyone’s one their pickup would pull. If he needed a bed, he had a trailer. See him come into the house dirty from a hard day’s work……driving his Caddy. He was always the talk of the county. Why my Ford will outpull your Chevy all day long as he’d pass them both with 500 cubes…..pretty funny.
    • In 2006 there was something like 5 hp difference in the Toy and GM V 8’s but the GM got better mileage.
      I guess 1/2 T pickups aren’t, for the most part, concerned with gooseneck trailering but anything above that payload rating leaves only the Big 3 in the running. Some friends new SS Tundra is damned sure tall.
      I suppose it all depends on your needs but I work whee out of a pickup and bought my first 3/4T in ’82 in response of having my heavy half down on the ground and not being able to keep forward motion in deep sand with a heavy trailer. I’m biding my time with that Z 71 till I can find the old pickup I like, a 92 or 3 GM that are bulletproof and cheap to fix when something needs to be replaced. I barely had the the thing warmed up before I needed to haul plywood……damn those short beds.
      I didn’t realize the front of the hood was a plastic piece on the Tundra till yesterday when I saw one that had hit a small limb and knocked it off. Aluminum cabs are fine, same as big rigs but beds? I don’t think so. Plastic is fine for some things and my neighbors new GM crewcab has plastic skin on the doors which are actually less flexible than steel but I’d hate to see the shop bill for fixing one.
      I like the idea of PFI but would like to see the torque specs on that engine.
      And ancap is certainly right about the pre 98 Cummins.
    • I have no inside knowledge, but I expect the Americans working for Toyota here in the US had a tough job convincing the Japanese management that yes, the US buyer wanted a truck that large. The first one (T100) being all they could get away with, and when it proved to be a non-starter in the market, they were allowed to “go big”.
  4. Eric,
    Enjoy it now. For 2018 rumor is these pickups are going to be addled with all the stuff that the majority of people–so it seems–demand, like lane maintenance assist, adaptive cruise and all the other bullshit. Standard. I’m glad I got my 16 Tundra last year. May have to keep it forever.
    That 5.6 foot bed is annoying. The cab is the greatest thing ever on those crew max’s but the bed is a joke. Even a 6.5 bed is a joke imo. Mine is the Doublecab w/8ft bed. I waited 30 days for them to build it for me because they are rare. I’d love to have one of these with a pre 1998 5.9 ltr 12 valve Cummins diesel.
    • I know, Ancap… sigh.
      It’s such a shame.
      I plan to keep my ‘o2 Frontier as long as I possibly can – and when it sleeps with the fishes, I’m getting something from the ’70s, without a got-damned computer or air bags or any of the rest of it! 🙂
