Reader Question: Automatic Swap
2197
Mike asks: I enjoyed your rant about automatic transmissions. Ditto. My question is this: When the automatic transmission on my 2005 Toyota Camry dies, can I replace it with an OEM 5 speed?
My reply: It is mechanically very feasible; the parts bolt right up. However, you will also have to make everything electronically compatible. You’ll need to swap the factory ECU, for openers, for one from a manual car. There may be other parts necessary to make this swap, too.
Another big issue – depending on where you live – is emissions legality. Even if the swap is done right – and the car’s actual’s emissions are within spec – this may constitute illegal “tampering.” Before you venture down this road, check with your local Uncle (government authorities) and find out whether, in the event you did such a swap, there would be an emissions-related legalities.
