2020 Hyundai Sonata
11
6260
When you can’t sell practical anymore, it’s time to start selling something else.
Mid-size sedans like the Toyota Camry, Honda Accord and Hyundai Sonata used to be top sellers – largely on the strength of their family car credentials. But crossovers – with their two or three-times-as-much cargo room and (usually) available all-wheel-drive – have made huge inroads into the family car market.
This probably explains why mid-size sedans like the Camry, Accord – and now the new Sonata –  have become so sexy.
But will it be enough to prevent their going extinct?
Like its primary rivals – the Camry and Accord – the “mid-size” Sonata is almost a full-sized sedan in terms of its overall length.
And its interior spaciousness.
This “mid-sized” sedan has more front seat legroom than six-figure luxury cars.
Which brings up something else. The Sonata has also become a de facto luxury sedan in almost every way – except price.
And the lack of a heated steering wheel. For now.
Most of all, the Sonata has also been restyled to summon interest.
It doesn’t look like everything else. Fundamentally, it’s more about the drive and how it makes you feel than how many bags of groceries/gym bags will fit behind the back seats.
The only thing missing – and just for now – is performance.
Prices start at $23,400 for the SE trim with a 2.5 liter engine and eight-speed automatic transmission.
A top-of-the-line Limited stickers for $33,300.
It comes standard with an updated version of the 1.6 liter turbocharged engine that’s the same size as the optional engine in last year’s Sonata – but bumped up to 180 hp from last year’s 178.
A hybrid version will appear later in 2020.
Everything. Pretty much the only thing that carries over the same is the name.
Turns heads.
Stretch legs ; the Sonata has more legroom for the driver and front seat passenger than a limo-sized (and six-figure) Mercedes S-Class.
Luxury car features – including an available 12.3 inch LCD instrument cluster and driver-less self-parking – at a family car price.
About an inch less backseat legroom than last year.
Much less space for cargo than a same-size crossover.
Not as powerful as Camry/Accord with their optional engines… for the moment.
The horsepower numbers of the Sonata’s new and slightly larger 2.5 liter engine (no turbo) and its optional 1.6 liter engine (with a turbo) are so close – 191 and 180 hp, respectively – you might wonder why not just offer one  . . . or the other?
Because of the torque.
The optional 1.6 liter engine makes more (195 ft.-lbs. vs. 181 ft.-lbs.) and sooner (1,500 RPM vs 4,000 for the 2.5 engine). This translates into more forceful acceleration – sooner.
Without burning more gas.
The turbo makes the smaller 1.6 liter engine bigger – more powerful – when more power is wanted. But when more power isn’t needed, it reverts to being a smaller, less thirsty engine.
Official figures for the 2020 Sonata weren’t available when this review was written in early December of 2019 – but should be in the ballpark of 28 city, 37 highway (the stats for the ’19 Sonata with the 1.6 engine).
Hyundai says the ’20 Sonata with the 2.5 liter engine should pull down 28 city, 38 highway. But it won’t get to 60 as quickly – and as easily – as the ’20 Sonata with the torquier 1.6 liter engine.
With either engine, the new Sonata gets to 60 in about 8 seconds but the 1.6-equipped Hyundai feels stronger because its torque swells sooner. The larger engine sounds like it’s working harder, too – because it has to rev higher to produce its maximum thrust potential.
But, which will last longer over the long haul? Not the next ten years (during which you’ll be covered by Hyundai’s class-best drivetrain warranty anyhow) but over the next 15 or 20? Modern cars last that long routinely.
How about modern – heavily turbocharged – engines?
We will have to wait and see.
One thing that’s for sure right now is that the ’20 Sonata needs more engine. Or at least, more power. Both of its currently available engines are outclassed by the engines available in the Camry and Accord. The Toyota offers a 3.5 liter V6 (last one n the class) with 301 horsepower; the Accord’s optional engine is a turbo 2.0 four with 252 hp.
The V6 Camry can get to 60 in about 5 seconds – which is three seconds sooner than the 1.6 Turbo Sonata.
Woof!
But there is good news . . . in the pipeline. By spring, you’ll be able to order the new Sonata with a third engine. A turbocharged version of the 2.5 liter engine that makes 290 horsepower and 310 ft.-lbs. of torque.
This one ought to close the gap.
The bad news is that Hyundai has gone all-in on direct injection, regardless of engine. This is a government-caused plague of mechanical Rube Goldbergism – gratuitous complexity – for the sake of slight gains in mileage and slight reductions in emissions.
And it may not even really be about that.
There’s a persuasive argument to be made that Rube Goldbergism is the point – to complexify  (my neologism) the non-electric car out of existence – or at least, viability.
In order to nudge everyone into electric cars – or onto the bus.
On the Road
One of the draws of crossovers is that you sit higher up – which used to be a visibility advantage, until crossovers became as common as sedans used to be. It’s no longer much of an advantage – because you’re surrounded by other crossovers, also high-riding.
And you’ve lost the handling/stability advantage of being closer to the road.
The Sonata has the superior stability that comes with being several inches closer to the pavement as well as the superior visibility of its fastback rear glass and lower trunkline. It’s at least as nice to be able to see what’s behind you as well as what’s ahead of you.
It also makes parking easier, without depending as much on a back-up camera.
The electric-assisted power steering feels a bit disconnected but it’s accurate – and more important, the rest of the car isn’t electric. Which means it can travel 400-plus miles on a tank of gas and you can conveniently refill that tank to full in less than five minutes, without spending $1,000 to install a “fast” charger in your garage that instills an 80 percent charge in 45 minutes, enabling you to travel maybe 200 miles.
The Sonata, like most of the cars in its class, doesn’t offer all-wheel-drive. But it’s arguable that AWD has been oversold, by playing on people’s fear of snow-driving and by convincing them that it’s “unsafe” to drive in the snow without AWD.
In fact, it’s mostly a question of being able to drive that’s determinative.
A front-wheel-drive car is actually a great material for a snow-day drive, if you have the right tires for snow-day driving. A FWD car shoed with snow tires will do better in the snow than an AWD car riding on sport tires – which many of them do.
That’s the real key as far as not getting stuck – but a set of snow tires costs a lot less than AWD, so guess which gets hard-sold as the gotta-have-it?
At the Curb
The new Sonata is longer, wider – and much roomier.
And it’s a looker.
Or rather, it doesn’t look like everything else – high praise these days. The fastback punctuates in a beveled ducktail trunklid that interestingly integrates the lip spoiler with the tail/brake lights.
Viewed head-on, it has the mien of a puff-adder. One almost expects it to hiss.
It also has 46.1 inches of legroom up front – which is almost five inches more legroom than a Mercedes S-Class, which has 41.4 inches.
The Sonata also has some other things you wouldn’t have found in anything less than a six-figure Mercedes just a few years ago, including an available 12.3 inch flatscreen instrument cluster paired with a 10.3 inch touchscreen off to its right for the car’s secondary systems, a Heads-Up Display on top of that – and a key-fob remote-park feature that maneuvers the car into place without you behind the wheel.
This latter system is designed to let you make use of very tight parking spots you otherwise couldn’t get into – and be able to get out of the car. This level of tech was the stuff of science fiction as recently as 2010.
And now it’s available in a Hyundai.
One of the functionally useful aspects of the LCD main display is that multiple displays can be displayed in the same space. In this case, the digitized speed toggles to your rearward view, which is preferable because it’s in the driver’s line of sight rather than off to the right (in the center stack, where most cars display it).
One of the downsides is that everything is displayed – or not, if (when) the LCD display croaks. But just as air conditioning and heated seats went from being high-end luxury car features to givens in almost every car, so also flatscreen displays are replacing physical/individual needle-type gauges.
Within a few years, it’s probable finding a new car without a flatscreen cluster will be as hard as finding a new car with an ashtray and cigarette lighter is today.
Just a few negatives detract from this otherwise appealing package.
One is that there’s less backseat legroom than before (34.8 inches vs. 35.6 inches). Another is that Hyundai elected not to offer a heated steering wheel – even in the top of the line Limited trim. This is a glaring omission, because heated steering wheels are becoming what heated seats were, ten years ago.
Something expected – in run-of-the-mill cars.
The good news is that Hyundai ought to be able to add this feature without much trouble. Hyundai may be withholding this feature – the plan being to include it with the N-Line version of the Sonata that’ll be coming out in a few months with the 290 hp engine and other upgrades, including the possibility of an adjustable suspension.
On thing you get right now, regardless of trim, is a spare tire. Not a full-size spare. But a spare. As opposed to a inflator kit – which many new cars have to save space and weight but which are as useless as a canoe in the desert if you have to deal with a sidewall puncture.
Sedans are in trouble. But this may be the way to get out of it.
11 COMMENTS
  1. Here are the specs from a 2011 model
    Engine & PerformanceFront Wheel Drive4 Cylinder EngineEngine Type: Gas I4Displacement: 2.4L/144Horsepower (Net @ RPM): 198 @ 6300Torque (Net @ RPM): 184 @ 4250Transmission: Automatic w/ODTurning diameter: 35.8
  2. That interior looks like crap. Hate the nasty touch screen in the middle. I would never buy one of those. Never. I think that the old 4 cylinder Hyundai had 200 hp. Now only 174 or so? Sounds like they are running backwards. I’ll pass.
  3. And so it goes. I’d like to have a 2004 or so Avalon. Everyone I knew that had one loved it. They ran them into the ground and mostly bought a Lexus after that. I’d speak with strangers that had one and to the last person, said they loved them. They were the Japanese equivalent of the Ford Crown Vic but better.
    It hurts my feelings as much as the next guy’s that cars are too expensive and not what you’d want these days. I’d take a anniversary model Buick Roadmaster stationwagon from 1996……I can wrench…..
  4. When I first saw the pic in a passing glance, I thought it was a new Mazda 6. The new Sonata looks like a “relative” of the Mazda 6…
  5. Eric,
    I must point out something about home EV chargers. There are no FAST, home EV chargers, per se; they charge faster than 120V are, but they’re not fast chargers. If you use 120 VAC to recharge an EV, you’re looking at 10-12 hours recharge time; even if you get home early, that may not be enough time to ‘fill up’ the EV’s battery by morning. So, to be sure that their EV WILL be ready in the morning, most EV owners put a 240 VAC charger in the garage, which cuts recharge time to about half; now, instead of looking at 10-12 hours to recharge, they’re looking at 5-6 hours at the most. With a 240 VAC charger, their EV WILL be ready to go in the morning, even if they get home late.
    Now, EV owners will often carry a 120 VAC adapter/recharge cable with them, so they can recharge somewhere where no charger is available. Though they’ll be looking at a long recharge time, at least they can recharge; it’s for emergency use though.
    The fast chargers, such as Tesla’s Superchargers, are the ones that can recharge an EV in 30-40 minutes. They found out in public places along popular routes of travel. These chargers run on 480 V or higher; they’re also a lot more powerful than what would be safe or practicable to install at home. These are the fast chargers that’ll have an EV ready to go in 30-40 minutes.
  6. “Turns heads.”
    OMG, that’s the last reason to purchase any car.
    What my neighbors, friends, fellow drivers think makes no difference to me.
  7. I’ve had a 2009 and currently a 2011 Sonata. I’ve liked them both. I certainly got way more for my money than the Toyota or Honda.
    But in both cars the engine died with little warning. Sudden low oil level, but no warning leading to knocking and (in the ’09) a seized engine.
    Luckily the ’11 was covered under a recall, where metal shavings from machining of the crankshaft weren’t cleaned, leading to oil starvation. That engine was replaced under the recall.
    I suspect something similar, but never recalled, for the ’09.
    I’m keeping the ’11 for my commuter (I can get 30mpg even with a very heavy foot), and with the new engine (replaced at 97k), it should hopefully last a good long time.
    • Hey freakNH,
      We had a ’14 Sonata Sport, which was a very good car. Direct injection was a bit tac tac tac. Traded it for a ’17 Elantra GT before a problem because of the engine recall. The Elantra was a piece of junk, toy car. Big mistake. Got rid of that for an ’18 Mazda 3 GT, awesome car, the real deal. On par with compact BMWs, Audi’s and Mercedes. Problem is, if you get a lemon or car you don’t like and can’t afford to get rid of it, that’s a big problem. Glad you got the new motor on the recall for the ’11.
      Happy Holidays, Vic
  8. Hyundai’s tend to be under powered now. I dumped an ’17 Elantra for an ’18 Mazda 3 for my wife for that reason. And too much interior plastic and marginal material and build quality.
    The Mazda 3 GT is a great car, no comparison. Good power to weight ration (2.5L), excellent interior quality with a lot of soft touch materials, very sporty, great build quality, excellent driveability and very comfortable.
    The ’20 Sonata look cool, it’s a possibility with the coming 2.5T. The build quality on the Sonatas tends to be better. If they use some better quality interior materials instead of all the hard plastic, it might be something to look at.
