Stacie asks: My Saturn Aura has a leaking power steering pump. The reason I know is it squeals – and stops after I add fluid. What do you think I should do?
My reply: If the power steering is leaking it is either a hose – there are two – or the pump itself. If the leak is minor – just a few drops per day – you can check/add/top off the reservoir until it gets worse or the hose bursts or the pump fails, which may take a long time and will be much cheaper than getting a new power steering pump, which may cost a couple hundred bucks in parts and labor if you’re not able to do the job yourself.
If the power steering does fail while you are driving you will still be able to steer the car but it will take much more physical effort. If you are pretty strong this won’t be an issue but if you aren’t, it could be dangerous. In the latter case, it might be smart to just get the thing fixed since a couple hundred bucks in repair costs beats a few thousand bucks in damaged car costs.
My latest eBook is also available for your favorite price – free! Click here. If that fails, email me at [email protected] and I will send you a copy directly!
Spanish compny with data server in Germany raided by the US military dictatorship
https://mobile.twitter.com/orijonal/status/1327277595583414274
Vote recounters in Georgia not even trying to hide the steal
https://townhall.com/tipsheet/bethbaumann/2020/11/16/georgia-recount-auditor-first-checker-was-incorrectly-calling-votes-for-biden-n2580198
Ukraine has Biden under criminal investigation. America is pathetic, this confirms it.
https://twitter.com/i/status/1328537623967772672
All the electronic votes are housed in two private databases, the states have no control of anything.
The left hates questions from citizens – Dan Bongino
https://rumble.com/vb5u6d-ep.-1394-the-left-is-terrified-of-this-question-about-the-2020-election-the.html
With Dominion, there is a drag and drop feature. The tallied totals can be changed.
The states that are controlled by Republicans should all refuse to send delegates to the electoral college in December. This means the House of Representatives will vote for president and each state gets one vote. If voting along party lines, Trump wins.
This process was used to elect Thomas Jefferson.
They have blatantly tried to selwect a leader and not allow a popular election. Why would you continue giving them another chance to permanently lockdown the world and put free exchange of goods and services under permanent blockcade with no input from any individuals whatsoever?
