Delta Gamma Epsilon Semi Moron . . .
140
5652
Doctors check the patient’s pulse for any signs of abnormality – as an indication of what might happen to the patient going forward. The pulse of another kind of patient – the weaponized hypochondriac – can be checked by scanning the headlines of the organized news.
This latter being a better – more descriptive – term for it than “mainstream” (which it isn’t; podcasters like Joe Rogan are more “mainstream” in terms of how many viewers he has than CNN) or “corporate” – which it is.
But that latter doesn’t convey the point quite as well as organized  – which is how it works.
At every stage of this mass hysteria, there has been an organized push – as for example, in the initial stages, the organized hyperventilating about “cases.” Without any attempt made to convey context. The impression was deliberately fostered that a dread disease was spreading – by the organized relating of “cases,” practically on the half-hour.
Each “case” was treated as if the person had died – or soon would.
It was rarely – if ever – explained that most – almost all, as it turned out – of these “cases” were simply positives on a test of dubious accuracy and that most of those who tested positive did not die.
Or even become a case – medically speaking.
A majority only experienced mild to moderate symptoms and recovered, on their own, without ever being under a doctor’s care.
There was no organized effort to explain to people that in medical terms – the way doctors previously discussed and gauged such things – a case had always meant someone sick enough to require medical care. One did not have a “case” of the sniffles. One did have a case of Ebola.
This crucially important distinction – if the goal is to spread truth and thereby prevent unfounded mass hysteria – was suppressed in a very . . . organized manner.
Instead, there was an organized effort to spread hysteria – by endless, breathless “case” counts and the unspoken but clearly intended suggestion that every “case” was doomed to die.
Then came the organized – the lockstep – pushing of “masks,” to augment the incipient hysteria ginned up by the endless screeching about “the cases! the cases!” People were made to see sickness – or rather, hypochondriacal dread of it – via the “masking” of everyone they saw. Including themselves, in the mirror.
Every TeeVee, every radio station – and every online venue controlled by the same organization – spread the same “message.”
And then, having created a crisis – a solution was offered. Get the “vaccine” and you will be free again! And if you don’t get it, expect to never be free again.
Extremely organized.
And it almost worked.
Were it not for the disorganized media – which managed to spread just enough truth to cause what the organized media styled “hesitancy” about the “vaccines.” A term of soft derision meant to imply cowardice, as well as stupidity and thereby apply shame to the “hesitant.” Who, in fact, were (and remain) determined to not be injected with a substance developed – supposedly – at “warp speed,” in less than two years’ time and which for that reason cannot possibly have been sufficiently long-term/placebo/double-blind tested to assure both its safety and its efficacy.
Determined – not to become the next “adverse event” among the thousands accumulated so far by VAERS, the Vaccine Adverse Events Reporting System – which is said to be grossly under-representative of the actual number of “adverse events” due to the hassle of reporting to VAERS and the reluctance of many doctors to report to VAERS.
Determined – to not be forced to “just trust us” the pharmaceutical cartels that have an established track record of untrustworthiness; that have no incentive to make their drugs either safe or effective – having been legally immunized from all liability of they aren’t – and having every financial incentive to rush unsafe and ineffective drugs to market and to use the power of the government to force people to take them.
Determined – to not allow the precedent to be set that whenever a medical bureaucrat cries Wolf! everyone must not only do as they are told, they must submit their bodies to these medical bureaucrats, as if they were rats in a skinner box.
The organized media did its best to make light of such adult concerns. Did its best to pathologize dissent, no matter how well-reasoned and reasonable. Has served as the vicious unchained cur of our era’s equivalent of another sick little docktor from the pages of history. He also deployed an organized media to supplement his speechifying.
Wollt irh den totalen krieg?  ‘
Yes, indeed.
But not everyone is sieg heiling, in spite of the best efforts of the organized media. Which has therefore organized a new hysteria, or rather another means of fomenting a resurgence of it.
Reports are percolating in the organized press about an all-new “super variant”  that is much worse than the “Delta” and previous “variants.” One that is not amenable to the “vaccines” – which have proved to be extremely ineffective, as well as dangerous to a degree unprecedented in the history of “vaccines” to date. Perhaps because this “vaccine” doesn’t immunize, the thing which formerly defined a vaccine . . . until the organized effort to change that definition.
Two things are possible and maybe more.
One if that the “super variant” is meant to re-scare the populace, which has grown greatly jaded about a sickness that they’re becoming more and more aware hasn’t killed most of the people who’ve had it. To get them back in line to be Jabbed.
Or – two – it could be the means by which the adverse events being caused by the Jab are covered up. And then blamed upon those not yet Jabbed. To set the predicate for a pogrom – directed against those not Jabbed. Who – per the other little Docktor – are “to blame for everything.”
Whatever the case may prove to be, one thing is certain.  The organized press isn’t going to tell you the truth about it.
140 COMMENTS
  1. No vaccines have undergone double-blind, placebo-based testing. And you can’t sue vaccine manufacturers for injuries or deaths from any of them–except adult-only vaccines, like the shingles vaccine, because of the NCVIA of 1986. Why are babies being injected with hepatitis B vaccines? Because the target market, drug addicts and sex workers, didn’t want them. To save the market, they approved them for BABIES.
    • Hi Alison,
      Yup. So many facets of this to look – and marvel – at. One of my favorites being that we’re told we must just trust these pharmaceutical cartels – with our lives. These cartels, who have legal immunity for any harms they cause us; who have a massive financial incentive to push their drugs – harmful or not – on us. Who have an established track record of being untrustworthy.
      It’s incredible. Obscene. Enraging.
  2. Got this from Phil over at Busted Knuckles…
    Things that make you go Hmmmmmm.
    PEDOGATE LIVES and The Powers That Be don’t want The Normies to be paying
    the slightest bit of attention to what is most certainly promising to be the
    exposure of very many, very rich and powerful people, allegedly being tied
    into a world wide pedophilia network with Ms. Ghislaine and her now dead
    cohort ( who didn’t kill himself) one Jeffry Epstein, being the guy all
    these alleged kiddie diddlers went to and flew off with to various places
    far from prying eyes and news crews to do these alleged dirty deeds.
    Remember PizzaGate?
    Oh yeah, all of this shit is connected.
    Have any of you put two and two together in regards to the timing of this
    Corona Virus bullshit and when Epstein got snagged and thrown in jail?
    HMMM?If you start digging on her and Epstein, you will very quickly see that
    they were so well connected that there are literally pictures of her with
    everyone .
    I’m not even kidding. Hollywood stars, Politicians and Royalty.
    She was at all the parties and all of the functions.
    Pick the name of someone famous and eventually you will be able to connect
    her and them together at some point even if it’s by attending the same party
    twenty years ago.
    She was EVERYWHERE.
    Now that Ms. Maxwell’s trial and guaranteed public naming of big names is
    scheduled to start, miraculously this heretofore unheard of SOOPER DOOPER
    DEADLY VIRUS VARIANT MAKES AN APPEARANCE.
    And according to the article I linked to above, these absolutely brilliant
    pharmaceutical companies have miraculously defied the laws of physics and
    set an absolutely impossible medical precedent by coming up with a vaccine
    for a strain of corona virus that supposedly has THIRTY TWO different
    modifications coming along with it inside of TWO WEEKS?!
    The absolutely hilarious part is that these dumbasses have been naming these
    variants using the Greek Alphabet except they skipped over one to name this
    new variant.
    They named it Nu.
    It was supposed to be Xi.
    Except Xi is the name of the guy in charge of China where all this crap
    supposedly came from in the first place.
    Can’t be having that kind of irony get out and played with by us
    Deplorables, right?
    We would have a fucking HEYDAY with that shit and they know it.
    But this supposed miraculous break through new vaccine for a brand new
    strain of this crap that half the planet probably doesn’t even know exists
    yet stinks so bad that I could smell it on the Dark Side of the Moon.
    This is how desperate they are people.
    Scared shitless that this world wide pedophilia network is going to be
    spread out for the world to see.
    It’s too late.
    It’s already out there if you want to look.
    Making it a hot topic of daily discussion will end them and they know it.
    That is why they are so desperate to pull the most obvious diversion .
    I saw this coming months ago. That’s how predictable they are.
    I also believe that they aren’t going to be able to sweep this one under the
    rig as much as they would like to.
    Although they didn’t seem to have a problem murdering a Supreme Court
    justice and getting away with it a few years ago.
    Ya never know, as desperate as they are, I might as well say it now.
    Ghislaine Maxwell did not kill herself.
  3. Why not? We can expect another Greek-lettered “Variant” to be “found”, thus far, 15 of 24 characters used. Handy to sell what HL Mencken termed “The Boobsie” that this is the “bad one” that’ll kill everyone. Of course it’ll be used to justify more outrageous Federal deficit spending, more fatwas, and if it appears that the PTB could actually be voted out of office in less than a year’s time, to alter the elections to make them “fraudable”, as was done the last round, or to suspend them altogether. And, of course, it’ll justify more “Jabs”, with Big Pharma reaping the enormous profits, thanks to the politicians they’ve bought.
  4. A large crack has opened up in FJB’s wall of tyranny:
    ‘A big win for medical privacy and the principles of freedom. Ford, General Motors and Stellantis have agreed the United Auto Workers union members will not be forced to take the mandatory vaccine as a condition of employment. Additionally, the vaccine status of the workers will remain private with a policy of private and voluntary disclosure.’
    https://tinyurl.com/
    OF COURSE, unions should oppose unilateral changes to working conditions.
    What’s so disgraceful is that Labor Secretary Martin Walsh is a former Laborers Union president. But now that he’s Jackass Joe’s valet, water boy and flunky, he had no qualms about selling out his union brothers by issuing OSHA’s large employer mandate.
    Already I wrote to Walsh, urging him to resign in disgrace. But I’ll punch him again soon, preferably after the Sixth Circuit shoots down his stinking vax mandate for good.
    FJB and all his servants.
  5. In the first place, no virus has EVER been contained once it reaches the general population. I don’t see any intellectual power in play that indicates it now could be. In the second place, central Europe is now experiencing higher case counts than they did this time a year ago when there WAS NO VACCINE. So obviously they don’t work. Never mind, we’ve got this new and improved super duper variant, that could just as likely as not be another common cold in effect, to panic about. Fear is useful, in critical situations. To live in fear? Well, you might as well go on and take your dose of Hemlock. A life lived in fear is no life at all, unless you are a prey species.
    • Damned if I can remember where, but not long ago read a treatise on how even Small Pox was defeated by its own mutation, not a vaccine.
  6. All the experts have a cartoon drawing of the killer “virus”, but they can’t get one single picture of it under a microscope, apparently because it’s too small for microscopes to see, which makes sense. So how do they know what it even looks like, or if it even exists? But egads — beware of the cartoon “virus” that’s going to kill us all!
    I listened to some real doctors on a talk show, describing in fairly good detail about how the experts determine if a virus exists. And it’s such a crock of absolute nonsensical rubbish — ZERO science involved in all of the pathology research. All of the “virologists” are complete total liars & quacks. If the sheep knew how they go about finding “viruses”, they would pass out — their entire world would be shaken.
    Does anyone know of a good space taxi, so I can move to another planet? Maybe some other planet ruled by logic will let me move there. This Earth has gone completely mad — it’s a huge insane asylum, with mass stupidity and mass terrorism and mass murder going on everyday en masse. Ugh. I just try to ignore it all as much as I can, and I try to focus on doing something positive to help the remaining sane people.
    There’s big underground bases with naughty space alien species working with naughty humans doing crazy genetic/etc experiments, … been going on for many decades at least. Yet the sheep have no clue and are afraid of a fake “virus”. OMG. This planet is a complete total DISASTER.
    • One more thing I forgot to mention… the “killer virus” is a ball with sticks/legs coming out of it, with little blobs on the end of each stick. Wow, apparently that’s so intelligent that no other microbe lifeform ever thought of that before. And no other thing in the world is shaped like that. Since it’s such a complicated shape. And it just somehow formed out of the blue after millions of years of humans living on Earth. Yeah, that all makes perfect sense. I believe! I believe! This “virus” is so smart, it has outsmarted all life on planet Earth, including all plants & animals (because they test positive to the “virus”) and all humans. Gosh, it’s tiny little brain has outsmarted our huge human brains! Wow, I’m truly impressed with this “virus” because “viruses” aren’t even alive or even have brains… yet it outsmarted us all, and is taking over the entire world. It must be planning to kill us off so that it can take our houses & cars & money and then all the “viruses” will have lots of fun parties on the yachts they stole from us humans. Gosh, I wonder what all the other “viruses” & bacteria & worms are going to do — will they be mad and want some of the money or do they get along with the killer “viruses”? Such a soap opera. Only time will tell. But we humans won’t be here to see it.
      • Agree with all of the above – for me, the whole lie hinges on the fact that “viruses” aren’t even living things…so how/why would they “seek a host”?
        Virus = poison
        • Yeah exactly. This is all literally things no-one can see, and so tiny even a microscope can’t see it. Yet, people are afraid of this imaginary fairy tale? I think I know why — because they’re retarded from being injected with brain-damage poisons. The injections cause people to believe in lies, which makes them want more injections. The worlds’ population just gets stupider and stupider.
          • Actually, that’s what various types of electron microscope are for. There are also more advanced imaging systems these days. I’d hardly call that a “fairy tale”. The existence of fine scale viral structures isn’t in doubt. What is still under investigation is how such structures interact with other biological systems.
            • I listened to a doctor on an internet talk show, explained how scanning electron microscopes work. They have to do alot of hinky things just to prepare the sample for viewing — so in reality, they don’t know what they’re even looking at anymore. It’s all BS, and the con-job-ers hide their fake science behind complicated stuff like this, so we suckers believe in their BS. If they say they see a “virus”, how do you know it’s really not just something else? They’re just making up BS all the time, they’re all liars and told what to say & see.
              • Well. You do know that many people have actually used these devices? Spec Prep is entirely routine for most systems. The more advanced systems require more prep. Keep in mind that the target area for an electron microscope has to be in high vacuum. Its like any other piece of technology, it has its uses and limitations. If you look at a bouncing ball, how do you know its not something else? Try to keep in mind that there are still some real scientists out and about. I know it can be difficult to believe, given the antics of the political class, and the fools chasing grants and willing to say and do anything to keep and/or receive them.
                Science is just an endless search for understanding the nature of the universe. It has its heroes, villains, and legions upon legions of fools. Given that it is a very human activity, how could it not?
                The best way forward is to think for yourself, do some personal study, and only believe what makes sense to you. As your experience and knowledge base grows, your insight and perspective will change. Its a life time activity. Good luck.
  7. Every time people start taking their masks off, the MSM starts in with another scary variant story with the message: “Put your masks back on!” The sad thing is, it works every time as the public has been trained like seals.
    Meanwhile, the retail chains’ mask enforcement of the past year is backfiring. There have been a rash of robberies in major stores across the country (most notably Best Buy). In almost every case the thieves are wearing (perfectly “legal”) masks when they enter the stores to steal in broad daylight:
    https://www.youtube.com/watch?v=fcqTBz5nkHE
    • I’ve been wondering when that was gonna start happening in force! Also wondering how long until straight-up armed robbery of cashiers with mask wearers starts to be a thing. The idiots that have insisted on this stupid shit are to blame IMO.
  8. Did everybody have a happy Thanksgiving?
    Our family get-together this year consisted of me, my wife, our daughter, and my younger sister and her husband. My wife’s brother, a rabid diaperer and clot-shot propagandist, has declared that their side of the family will never set foot in our home again – because I have refused to practice his stupid superstitions.
    We had a wonderful time. A 16-pound turkey, and four pies for five people. This is how the pilgrims meant it to be. Just so you know: Cool Whip is my favorite food group.
    The conversation eventually turned to all things vax (I did not bring it up). Not to my surprise, my sister and her conservative husband are not fans. The day her employer’s mandate went into effect, she arrived and immediately started cleaning out her desk. When her supervisor asked what was up, she said, “I’m not getting your damned shot, so I assume I’m fired.” They backed down.
    The bad news is that my older sister and her husband, who were “fully vaccinated,” couldn’t be with us because they came down with covid right after a trip to Branson, Missouri (where, with its older clientele, I’m sure the vaccination rate is near 100 percent). She is at home in decent condition, but he has been in the hospital for a week and a half. He is not in good health generally, and we are very worried about him. They keep saying he’s doing better and should be released any day, but nobody has been allowed in to see him.
    I blame the useful idiots like my other brother-in-law, who have been shaming people and spreading the lie that the frankenshot actually protects them. In doing so, they have introduced tremendous moral hazard. My loved ones never would have gone to Branson had they not felt “protected” by the useless Fauci/MAGA jab.
    • I un-invited myself, although it was made quite clear that this would be the correct course of action. Wouldn’t want to contaminate the gathering. Move over football, everyone has to play Sickness Kabuki, apparently, or else they are Bad People.
      Screw that noise, consider me one of the Bad People if you want, I’m out.
    • Hi Roland,
      I am glad to hear Thanksgiving with your family went well and wish your BIL a speedy recovery.
      I hold Thanksgiving each year for my family and we had a total of 13 unvaxxed people attend. Everyone hugged, hung around the buffet, and sat around the dining room and family room conversing like normal people. We did get on the vax discussion, but since we all agree that it is BS it didn’t last long. Everyone left full, happy, with a plate of leftovers.
      • Morning, RG!
        We amazingly continue to be not sick. It is astounding! No masks, plenty of contact. I even had the audacity to mention this to one of my now ex-friends, who joined the Cult of Sickness Perpetual, pointing out (I couldn’t help it) that he gets sick regularly (not yet the ‘Rona) and . . . hmmmm… might it have anything to do with his being 75-plus pounds overweight and smoking like a ’66 Newport with bad rings?
      • Even though I’m averse to crowds, even more so since my hearing has degraded, I determined I WOULD participate in one at my son’s house this Thanksgiving. While I do not hear well enough to participate in conversation in such crowds, 15 of us, unmasked, simply being there brought joy. I met a number of my son’s in-laws that I had never met before, including there children, which always brings joy to this old man’s heart. In short, there was no fear. Period.
        • Hi John,
          That sounds wonderful. I am happy to hear that everyone was unmasked and unafraid.
          I was asked by my daughter why her father and I continue to have Thanksgiving because she sees us so stressed the week of the event. My husband sarcastically responded “your mother believes in making memories.” But, that is the truth. I remember my mother putting together these all out bashes….house cleaned and decorated, food made from scratch, etc.
          When my husband and I purchased our home 20 years ago I started hosting the events to reduce the stress on my mom. She continues to hold Christmas and my youngest sister hosts Easter each year so each of us have the ability to enjoy a holiday or two without worrying about cooking and cleaning.
          I want my children and their cousins to look back at these events with fond memories and to continue these traditions. It also gives the elders a chance to reminisce and appreciate the day being celebrated. There will be a day that all of us will not be here and I want the others to be able to reflect back and cherish these experiences.
          In other words, I am a sap. 😁
          • This was a Great post, RG. Perhaps, in light of the times, heroic even.
            Our culture. The Remnant. Stuff like that. You’re, Da Bomb.
            • Thank you, helot. That is very kind of you. I am just doing what my great grandmother, my grandmother, and mother have done. Both of my grandfathers have passed and it is comforting to me that I am able to look back and remember all of the birthdays, holidays, and family events that we were together as a family and are able to cherish those memories after their passing.
  9. Interesting observations about the medi– er, I mean, “organs of propaganda.”
    I don’t get cable TV. I watch little to no TV, with the exception of the “news,” so I utterly refuse to pay a monthly bill to be able to watch that damned thing. Paying for television is about as seedy as paying for sex.
    So I get the three main networks — ABC, CBS, NBC — over the airwaves, instead of paying for the 100+ channels of pure nonsense.
    Anyway, I would use the remote to flip between the three networks while watching the nightly news, and many years ago I noticed something very odd about the three networks that were SUPPOSEDLY competing with each other in the “free market” of journalism.
    They would all lead off with the same stories.
    They would all read the story using almost identical language.
    They would all go to commerical break at the exact same time.
    As the broadcast went on from the lead, they would all cover the same subsequent stories — in almost the exact same order — going 5-6 deep into the newscast.
    Late in the broadcast, they would all shift from “hard news” and close out with some “human interest” story — about a crippled black child, or a single mom getting a GED or something like that. And they would almost always cover the same story there as well.
    Try this yourself. Flip through the three main networks every few seconds during the national news. You’ll see it. It’s positively creepy, and once you notice it, you can’t un-notice it.
    It’s ALL the Exact. Same. Thing.
    The notion that the “journalist” is a heroic, dogged, gumshoe investigator uncovering the raw truth in the seedy part of town is a lie. They’re all whores to the corporate bottom line and whores to the government.They’re all self-important and self-referential attention seekers and airheads parroting the exact same bullshit.
  10. The entire charade reminds me of elementary school, way back when dirt was invented, when one kid or a group of kids would decide that another kid or group of kids had “cooties”. So we’ve devolved even further than high school or junior high?
    • It’s always been elementary school John you know that, people need their daddy govt, without them who else would lead us right aboard those friendly looking trains to camp? You like camp don’t you
    • With regards to management, the political class and so on they are trying to run human society on the model of junior high school.
      It took so long before I heard another person come to that conclusion. Louis Rossmann on his youtube channel was relating the present conditions to his jr. high school experiences. Specifically where the administration would punish everyone because one kid talked durring the announcements and that kid would be blamed instead of the principal. Same thing is going on in society right now. People are being aimed at those who won’t take the jab instead of their actual oppressors.
      There’s more to the jr high analogy that I have, like how self defense is to be punished and so on, but it’s all jr. high stuff.
      As to the behavior of people, yeah that’s probably sinking below jr. high.
    • Hi Anon,
      This woman is typical of the clergy of the Sickness Cult. She’s a mannish, menopausal old bag. Whitmer is another. And of course, the Coonman. I’ve yet to find a cultist who is fit and healthy. It’s always these people who care so very much about their “health” that they insist it’s the obligation of others to care for it.
      • Perhaps it’s my own prejudice, a thing one cannot survive without, but it is remarkable to me that a great many of the pontificators of this or that leftist delusion trend to be very unattractive, and/or genetic deviations. As in Greta, and David Hogg. AOC being an exception.
    • Another “fellow white” lady talking about getting rid of the whites. These anti-white “whites” sure are excited about getting rid of the European-descended Americans and are disproportionately represented in the Covid19 “task force.”
      Hint, hint. In their sacred texts, the sons of Shem are NOT the sons of Japheth.
      This powerful group of people will ruin your life for saying they are a powerful group of people…
  11. The thing is the virus will mutate to less dangerous “variants” over time, just because the strains that kill won’t have as much opportunity to spread. So of course the darn thing mutates, that’s life. And eventually, it will be as much of a problem as any other cold virus, that is to say not at all, just because that’s how they work.
    • Exactly, but most of the lemmings don’t realize that, and now the fear merchants are pushing the “Omnicron variant”. Sounds like something out of Star Trek, what freaky geek picks these names? Anyhow we’re supposed to believe it spreads at the speed of light and is deadlier than Ebola.
      Wolf!!
      • The “killer germ” is a Sci-Fi staple, both in Star Trek, somewhat in Star Wars (relies on good-old fashioned ass-kicking and not QUITE as much “woke” moralizing), and other franchises.
        At some point, as there are but 24 letters in the Greek alphabet, they’ll run out of these much-feared “variants” and they’ll have to come up with a techy-sounding name that’ll make it scarier.
  12. variant “A” is gone now. emergency is over… so all the vac//cines are useless….what a cluster fu….c,,c…k
    mandates for a useless obsolete injection= insanity = stu//pid f….u,,,,kk kkks
    passport? no point the A variant is gone…. but they will still try to force inj//ect you with the lethal experimental genetic inje//ction…………..satanists (wef depo//pul..ation agenda)
    if you are injected you can transmit and get infected
    if you aren’t injected you can transmit and get infected
    no difference then
    if you are injected with the right injection, you might have milder symptoms that is the only difference, but who could care less other then you.
    if you are injected with a vac//cine for the wrong variant there is a huge problem, get get sicker and worst of all you turn into a variant factory, a super spreader, spreading everywhere.
    so you inject people with the wrong vacc//ine so they are super spreaders and then give them a passport to go everywhere at the same time as banning the un-injected clean people from going anywhere, makes sense…..
    government could screw up anything…….did they buy 100 million doses of an obsolete vac//cine? going to force it into you anyways, to hide their screwup, that is evil….. how many billions of dollars will they waste now?
    The science is conclusive and widely accepted within the medical community of virologists on what this vac//cine does and doesn’t do. in the video:
    None of the vac//cines stop infection
    None of the vac//cines stop transmission
    the 95% number they claim is just refering to symptoms reduction…..only effective at reducing the symptoms (they say 95% effective but in practice even this is proving false),
    The vac//cines were only effective at reducing the symptoms (they say 95% effective but in practice even this is proving false), of the “A” variant for which they were designed.
    ATTENTION: very important: this A variant is gone now so all these injections are useless now, they do nothing at all zilch……..there is no point in getting them, refuse them they are useless, worse then useless they will make you sicker.
    the predominant variant now is the delta variant, now they say NU variant, all these vacc//ines are useless now, no help at all with that new dominant delta or NU variant, they weren’t designed for the delta or NU variant,
    Dr. Paul Alexander
    ATTENTION: it is over, the virus has mutated down to it’s mildest, weakest, harmless form the delta variant and now NU variant, it is not a problem or threat at all, non fatal, very weak, benign…… data from isreal shows. so no need for the vaccine now…..
    NOTE: but the people that were injected destroyed their immune system so delta and NU and all the other new variants will get them…bringacoffin
    The winners: so the uninjected are the winners…they didn’t get the lethal experimental injection and there is no need now because the virus has mutated down to it’s mildest form the delta variant, it is not a problem or threat at all, non fatal, data from isreal shows.
    The losers: If you took the experimental gene modification injections here is what you have to look forward to over the next 2-3 years:
    1) Sometime between October 2021 and April 2022 we will see if ADE (Antibody Dependent Enhancement) strikes you like it did the animals in 2012.
    2) Around 18 months we will see if “mad cow” strikes you like it did to the humanised mice that were injected with the spike proteins.
    3) Around 24 months we will see if Alzheimer’s strikes you like it did the Macaque monkeys that were injected with the spike proteins.
    4) 60% of the injected have detected ‘microclots’ with the d-dimer test in the first week after injection. Right side heart failure within 3 years is common.
    5) The spike proteins impair your telemerase synthesis which is known to lead to cancer, CVD, diabetes, vascular dementia.
    in one outbreak of 469 cases 74% were in fully vacc//inted and 4 out of 5 of those were hospitalized.
    The old useless vac//cines are now assisting those who were vacc//inated at developing more severe symptoms and developing higher viral loads for the variants, because of this useless vac//cine they become variant factories, super spreaders, the new zombies……
    NOTE: be careful these inj//ec..ted people are now biosecurity ter//ro…rists, super spreaders, spreading to the un inj//ec…ted people.
    these vac//cines were NOT designed for the Delta variant, so they become a virus helper. you are worse off getting more sick, and spreading to the un injected.
    she says the most vac//cine hesitant are Phd’s because they understand science, followed by people with less then high school because they know they don’t know and don’t trust the government, the most hesitant are african americans, 70% have not been injected, because they don’t trust the government because in the past the government has done medical experiments on them. that means with mandates 70% of african americans won’t be able to work or be part of society. that is discrimination and segregation.
    (other vac//cine hesitant groups in the U.S. are hispanic and indigenous people, they don’t trust the government either). in canada the most vaccine hesitant are the indigenous people. in australia the injected rate is a low 27% the most vaccine hesitant are the indigenous people, there is a huge push on there to inject, it is locked down now worse then anywhere, chasing the indigenous with the na.. zi nee..dle.
    https://odysee.com/@Infoweapons:1/Dr-Christina-Parks-Testimony-for-Michigan:6?&sunset=lbrytv
    Harvard Medical School professor Martin Kulldorff said research showing that natural immunity offers exponentially more protection than vac//ci…nes means vac//ci…ne passports are both unscientific and discriminatory
    ,………vac//cin…..ated individuals were 27 times more likely to get a symptomatic COVID infection than those with natural immunity
    after the injections started in isreal the death rate jumped higher, this is happening everywhere but is being covered up.
    in england a tender for a large supply of body bags and crematory services was advertised, a great business now.
    Dr. Bryan Ardis says it is gen//oc…..ide
    the bottom line: Dr Sean Brooks PhD Oxford has a message he says:
    Anybody who gets it will be dead in 6 months to 3 to 5 years. . It destroys your immune system and you die. Everybody gets blood clots and is sterilized, people are getting their children injected.
    get injected to get a passport so you can go inside a restaurant = dead in 3 years if you are tough, a high price to pay…..prepay your funeral.
    Dr. Zelenko makes it very clear that, in his opinion, the Cv//19 injections are neither safe nor effective nor necessary and that, in fact, forcing anyone to take the experimental injections equals genocide. zelenko said the injection is like the gas chamber and people are running into it.
    • Everywhere they started injecting the extermination injection the death rate went up (of course some injections are a placebo to collect data and to target certain groups to be exterminated first, as in conservatives, old people and red states, or whoever they hate the most).
      These leftist/satanists/globalists will blame the pureblood unvaxxed of course, they can lie and twist facts better then anyone in history, they will say the unvaxxed are dirty, infected and killing everyone and have to be exterminated now, this is very well planned out. Meanwhile it is the injected that are the superspreaders.
    • You don’t get bonus points for word count. The art of writing is communication of thoughts and ideas with as few words as are possible yet effectively communicate them.
      • No voice for conservatives not even on conservative sites, the internet is infested with communist/ccp trolls, any conservatives are attacked, de-platformed.
        trolls are paid by communist/ccp/soros trash, they usually live in their mother’s basement.
        Fabians furthering the communist agenda are in complete control everywhere, 99% of the time they are also clovers, more leftist trash…..
        While Facebook portrays its army of fact-checkers as independent, the money behind at least one carries a distinct taint. One fact-checker, Lead Stories, is partly paid through its partnership with TikTok, a social media platform run by a Chinese company that owes its allegiance to the Chinese Communist Party (CCP). troll = ccp. These trolls are very active around elections and pandemics.
        note: TikTok is currently being probed by American authorities as a national security threat.
        Anybody cooperating with the cult is a 4th Reich collaborator with an occult satanic religious death cult, hiding behind a government/fake science front.
  13. Nice job, mr Peters in transforming this to a GOP-lite website. Its your site and obviously you can do as you please. Me? I am no “D” guy, for sure!
      • Eric, you should be impressed. You’ve just been trolled by one of the Enemies countless minions. Look at the structure of the statement. Its so cookie cutter, that it might as well be a bot. Such NPC’s are quite common on larger alt sites. They are especially frequent on alt sites that are critical of the Usual Suspects.
    • The new communist/ccp/great reset/one world government is in charge almost worldwide now, (a combination of government and a cult religion, using medicine as a weapon to exterminate based on fake science), it looks like Eric is opposed to these globalists, if someone doesn’t like, that they are on the side of the globalist monster exterminators.
      • Hi Anon,
        It baffles me. Trollish posts such as the one by the other “anon” to the effect that I run a “Republican lite” web site. It’s like accusing Al Sharpton of being a libertarian.
        • It makes no sense, Eric. I can assure you that you’re “GOP-lite” like absinthe is Dr. Pepper.
          (No one asks why I drink anymore, haha.)
        • I now skip over any Anonymous post lately. They think we give a crap to give more than a couple mins to pay attention to them drivel on.
          If they want me to pay more attention, get a handle.
          • RE: “If they want me to pay more attention, get a handle”
            I second that notion! …Two frickin’ seconds, & rubbing together two thoughts in their noggin. Seems like it takes more time to type out the word, Anonymous.
            • Anonymous autofills if you don’t select a name, But I agree, It ain’t that hard, unless you are a robot that doesn’t recognize the field.
          • Ditto. It is hard to follow which Anon is talking/typing. Sometimes, we have a discussion of Anons conversing with each other and I can’t follow who is saying what. Hell, I am all for Anon 1, Anon 2, Anon 3, etc. Anything to identify who is speaking.
            • If you are incapable of coming up with some kind of name, simple as your cat’s name. how likely is your conversation to be honest and thoughtful? How can you be related to in future conversation? As you see below, I use my real name, thought police be damned.
              • To all of you who resent “Anonymous” posts, maybe it has nothing to do with “coming up with a name,” all of us are “anonymous.” But this point has been made numerous times. And what does your handle have to do with your capacity for thoughtful dialogue? Feel free to carry on, skipping those posts you deem unworthy because you can’t tolerate someone’s personal choice to NOT identify.
                I am glad that Eric hasn’t adopted the fascistic practice of forcing everyone to self-identify.
                Can I check your ID to make sure it’s really you?
                • Seconded. This “identify yourself” stuff has destroyed every comment section ever. Years ago almost any website with comments, even MSM sites, could be an interesting source of info and debate. When the controllers realized this, they shut off comments or, worse, required some faceberg log in. Now it’s almost all (present site excluded for now, of course) Pravda to promote the illusion of serene agreement and not have any feathers ruffled.
                  This kind of thing illustrates how business owners and their property come under pressure not just from gov’t but from customers and people generally. Unfortunately, the squeaky wheel typically gets the greasing. Principles, if any, succumb to profits.
                  • To continue the point, (but since Anon is responding to Anon, I must apologize to all who may be triggered…)
                    I could use a different handle each time I post, or I could adopt someone else’s handle and post as if I was them. Would that make these huffy posters feel more satisfied? Maybe, but what purpose would be served, other than to satisfy their unconscious desire to control others…wait, they are libertarians or something…
                    • Hi Anon,
                      No one here is trying to control anything. Not I, at any rate. We’re just suggesting it makes it easier to communicate when you can readily differentiate one commenter from another. When there are six or a dozen “Anonymouses.” it is hard to keep track of who wrote what and who replied to what.
                      That’s all.
                      You’re welcome to remain “Anonymous,” if you like.
                  • Other sites may disable comments, but they tend to concede to reenabling them in order to stay afloat. As one Philly goon told the cucks over at CrossingBroad sports blog, “No comments, no site!”
                    I understand club Anons gripes, though I don’t think there’s any being truly anonymous on here or anywhere since VPNs can’t really be trusted, and I’m pretty sure IP address logging is pretty standard in web platforms. So at a minimum from one session to the next it gets tied back to some individual internet session and device, and Eric could probably discern between anons if he really wanted to waste energy on it. Most of us are too lazy to track people down on the internet and also we’re not fuckin losers like alphabet agency employees are with all their serf stalking, but whether someone uses it or not, technology-wise it’s really more of an illusion of anonymous.. Kind of like the illusion of freedom in America or from the Constitution, or the illusion of choice in being free to leave the country just to go be ruled by over by some other dickheads in a smellier country elsewhere. What’s the point really.
                    But it is shitty to skip over entire anon posts just because of the actions of whichever anon was spamming TLDR stuff, I’m actively trying not to do that, I guess sometimes in a social environment it’s better to share ideas under a brand, people are naturally gonna judge the comment based off of who’s saying it so they can determine whether to expect quality or not the next time they see a post by that name. I post under certain screennames from site to site and most people fuckin hate what I have to say about virtually anything at all, they’re not shy about ganging up to say so either. But that’s commonly how people decide if they’re gonna listen to the idea. It’s admittedly not the best method because almost all the figures I’ve admired have let me down horribly over this past 3 month stretch or so of hell.
                    So I dunno. Posts can get ignored whether there’s a name or not. Posts can get tracked and traced and ultimately used in court whether there’s a name or not. It just makes it easier for individuals to interact with one another and converse. I regularly decline to participate in certain social customs but in this case it’s easy enough not to confuse the shit outta other folks when we’re looking to have a back and forth. If someone really wanted to troll they could sign in and select the same avatar as someone else.. but EP could just block their IP too..but we don’t see much of that behavior around here.
                • Hi Anon,
                  I don’t see this as a “papers, please” type of thing but rather one of being able to keep track of whom you’re attempting to communicate with. Many of us here have come to know one another and respond to each other by name. It doesn’t need to be an actual name. But it is helpful to know I’m responding to “joe55” rather than “anonymous” – when there are multiples of the latter. To be clear, I’m not imposing any requirement that people use a specific name; only suggesting that it would be nice if regular people here did.
                  • See rest of conversation between Anons above.
                    Any of us could use a different handle each time we post, or could use someone else’s handle. How would you know?
                    • Christ, Anonymous…
                      Of course I wouldn’t know – if the “Anonymous” did as you say.
                      This site doesn’t demand you produce ID or “papers,” nor will it ever. But it is helpful to be able to readily be able to direct a response to a specific poster; to be able to follow the conversation. When RG or Brent or BaDnOn posts a reply to me, I know to whom I ought to reply.
                      That’s all.
                      Using a name or making up one serves that purpose. You can be Napoleon Dynamite – or “Anonymous66.” Whatever you like – including (if you like) just “Anonymous.” But the latter does make it harder to reply specifically to a specific poster, which detracts from the communication this site tries to further.
                    • You could use a different handle each time you post. Personally, I don’t care. Call yourself Bugs Bunny, then Tom, then Jerry, maybe Elmer Fudd.
                      We are not asking for anyone to login just give us a handle so we can identify whom we are addressing. Anon001 works.
                      Has for trying to use someone else’s handle if they are logged in they have a unique face which you cannot duplicate.
                      You could be Raider Girl, but the standard pink Anon face would show next to the name and not icon that is mine when I login.
                    • “… or could use someone else’s handle. How would you know?”
                      If you used my handle you would have a different avatar. No matter what name I have used, I get the same avatar.
                  • Eric, I understand your point. My responses were in re those who are triggered, based on their own remarks, by those of use who choose not to create a handle.
                    Again, any of us could adopt someone else’s handle and no one would be the wiser.
                    The benefits of open debate and conversation, which you seek to nurture, far outweigh the risk of someone worrying about which Anon they are responding to.
                    • No one is triggered. It was merely a suggestion.
                      Those of us with handles have a certain camaraderie with others that post because we can identify each other. If I see the name BAC, or Jim H, Roland, or Nasir I can identity that person and follow their posts. We just feel a bit more engaged with that individual on the other side of the computer screen.
                      No one here is asking Eric to get rid of the Anon handle or force a login. It was a suggestion to those post, nothing more.
                    • I enjoy your use of the word “triggered”. It makes me yawn.
                      The only reason I am replying right now is because you were triggered by something I said. I am merely giving you my honest opinion. If you want to self-identify as anonymous, go ahead, I don’t care. I’m just saying how I feel, I’m skipping on anon people because I cannot differentiate between multiple personalities. You are handle-fluid, I get it.
                    • I’m more concerned I will skip over worthwhile comment because its just another over voluminous Anonymous posting it.
                • Your handle gives fellow commentators an idea of your position, the nature of your thinking, etc, which may actually encourage them to read and think about what you have to say. If you are an obnoxious Anonymous or a stupid one or an evil one, we have to read what you say to discover that, while I would prefer to simply ignore the stupid, obnoxious, or evil.
                  • “handle-fluid” Ha! Yup.
                    This, too:
                    “I’m more concerned I will skip over worthwhile comment”
                    Which means: it’s in the intrest of the Anonymous to pick a nic in order to drive a point home.
                    I guess that’s a difficult concept to grasp?
                • You don’t have to keep the same handle for every conversation on this site if you do not wish to. There’s an unlimited names one can give oneself on a per topic basis.
                  It just helps to personify each person as a reader. I don’t care who you are. I’ve used different names here myself. No one cares who I am either.
                  • No doubt!
                    Also, I dunno about you guys, but I ain’t “triggered” by any of this.
                    IMHO, “triggered” is like Trix, it’s for kids, and the weak, etc…
  14. You know for what else this latest fake is perfectly timed? The hugely critical lawsuits that are all about to come to a head!
    “Yes your honor, we know we don’t have the authority to force this on people in this fashion, but the variants!!! So we need you to yet again look the other way as we continue to violate the constitution.”
    “Seems reasonable to me!” (-every activist judge)
  15. Let’s not forget that they had to also change the commonly understood definition of “case” as well. Formerly that meant that took some ostensible form of disease to a doctor, received a diagnosis, perhaps one or more prescriptions, had some form of defined prognosis, and often one or more follow up visits to check on that prognosis.
    All of which were documented in your “chart” or “patient record”, etc.
    It never previously meant anything like a “drive by” diagnosis using a dubious test and “have a nice day, let us know if you get worse”. Never before.
    It’s all a lie. And, more importantly, it’s all a lie by the same political interests that truly believe they need and must have dramatically fewer people on the planet.
    And those coincidentally are the same people that are famous for “any means to an end”.
    • Definitions changed to promote the illusion of plague:
      Case
      Pandemic
      Vaccine
      Approval, by replacing with EUA
      Cause of death
      Others I’m forgetting.
  16. Another day of Covid madness. It is a plague of madness. Too late to panic, just go mad.
    Seems like that is happening here and there out there.
    You’d think that Uncle Joe would come to his senses and ask himself why in the hell he is doing and saying the things he does and says. Somebody is leading the entire planet to slaughter.
    Joedas Goat is doing a heckuva job.
    He ain’t got a brain in his head, the dumbass.
    And another thing, pigs get swine flu. Whoddathunkit?
    https://www.thepigsite.com/disease-guide/swine-influenza-virus-h1n1
    Those pigs get sicker than dogs.
    Oil is lower by five dollars per barrel today.
    The Dow is currently off by 727, so all markets are in a nosedive mode today.
    During the Bubonic Plague northern Europeans developed immunity to the plague. An allele formed in the genome that provided natural immunity.
    The History of Plague – Part 1. The Three Great Pandemics
    The overall mortality rate varied from city to city, but in places such as Florence as observed by Boccaccio up to half the population died, the Italians calling the epidemic the mortalega grande, ‘the great mortality’. People died with such rapidity that proper burial or cremation could not occur, corpses were thrown into large pits and putrefying bodies lay in their homes and in the streets. People were as much afraid they would suffer a spiritual death as they were a physical death since there were no clergy to perform burial rites:
    “Shrift there was none; churches and chapels were open, but neither priest nor penitents entered – all went to the charnelhouse. The sexton and the physician were cast into the same deep and wide grave; the testator and his heirs and executors were hurled from the same cart into the same hole together.”
    Bring out your dead
    It was madness, Bedlam, during the plagues, all caused by some flea-bitten varmit harboring a deadly bacterium.
  17. One thing is certain, and its probably more like two things. First the Lugenpress is not going to tell us the truth, about anything. Second, they won’t stop until they are made to stop. Either prison or an untimely demise would do the trick. We know prison is out of the question.
    The picture in the article is worth a thousand words. Nothing says accountability like heads on a pike. Of Course we would never advocate violence against our kind and caring overlords.
    A few angry men in NYC and Atlanta could make a world of difference, just saying.
    • Yeh they keep talking about this Nuremberg 2.0…. i dont think thats how its going to go down…. because in theory the people who can arrange Nuremburg 2.0 will be the ones who should be tried there.
      I think the only thing that will change our trajectory is heads on pikes – the good old fashioned way….. till that happens things will just continue the same route as always..
      • It’s becoming evident that Nuremberg 1.0 was farcical and only designed for the moment. The crimes were certainly real but somehow those universal standards for the obviously good of humanity didn’t apply to the allies at that time.
        And, sounds crazy I know, still do not apply. Heck, apparently don’t apply to anyone. Never were intended for anything beyond the goal at hand in 1945 Europe.
        You see, the mere fact that the entire world in lockstep fascism is experimenting on its populations outside of informed consent, is no reason to measure the “benevolent intentions “ of these principled people even if they look, sound, act and smell just like 1945 Nazis.
        Because they say so.
      • Right-o Nasir,
        No justice, no peace. (for the wicked)
        I wish someone on our side with a great big brain would start a viral campaign to eradicate the coof in Africa.
        We could all sign a pledge to big Pharma. ‘We the people, of these former United States will forgo any and all jabs, until every man, woman, and child in Africa has been given the 1st, 2nd, and 3rd dose of Pharmas magic elixir.’
        In all seriousness, its what we should do. Helping those who don’t have access to this life saving vaccine is the kind, compassionate, liberal thing to do. We in the US should stop being so damn selfish and start caring moar about others than ourselves. I will be the first one to volunteer to give my dose away. Because I care, a lot.
        I’m sure the overlords will approve.
    • Wait, would these hypothetical angry men be burning down the news media, the UN, the CDC, or all of the above?
      I suspect that, just because it is apparently legal to burn down car dealerships in downtown Kenosha, does not make it legal to do the same thing to certain other entities.
      I may not be able to stop anything from happening, but I can certainly point out that it’s a bad idea.
    • Charlatans are already pitching the Nu, improved snake oil:
      ‘Pfizer’s CEO, Albert Bourla, said it could take scientists 100 days to develop a novel variant vaccine to combat Nu.’ — Citibank
      Step right up, folks.
      This way to the egress (from life).
      • A pot of homemade chicken soup, maybe some OTC supplements, and a couple days rest are just as effective as any of their poison and has little to no side effects!
        So now I’m getting that “operation warp speed” has essentially eliminated the entire process of “the gold standard” of double blind, placebo controlled, three phase clinical studies.
        Thank you Trump, that’s EXACTLY what we needed to MAGA, isn’t it?
      • A new “vaccine” in 100 days? Why not? After all, the previous round worked so well that central Europe now has more cases than the same time last year when there WAS NO VACCINE.
    • Did you see that they briefly toyed with a “symptomless variant “?
      That came and went quickly. I suppose few people are able to get scared over that, certainly can’t explain away vax failures with it, seeing as there’s dead bodies as a result.
      So now the failures of the vax will be explained away with yet another fictitious microbe 🦠 that cannot be disputed. Likewise, despite the abject failure of the vax the (perhaps “final”) solution will clearly be more of the same!
      Maybe those poison shots are actually achieving the intended purpose? The “benefit” of dramatically fewer people on the planet. I’m certain that outweighs the “risk” of these murderous tyrants ever being brought to justice. (In their minds)
  18. Another interesting thing why they found this new variant it seems is over the past few days, quite a few articles seem to have snuck past the censors in the organised (or propaganda) media talking about how theres like zero covid in Africa despite few there being being jibby jabbed….. now it turns out there is a scary new variant in some African country where most people in the west wouldn’t even be able to find on a map…. and ofcourse it means more restrictions and nonsense – already new and improved travel red lists…. im sure much more of the Kabuki to come….
    • And I’m certain that the degree of sanitation, healthy food and living conditions (or maybe the lack thereof) has absolutely nothing to do with it!
    • In sub Saharan Africa, very few are fat, the second most common comorbidity for COVID death after old age, and many regularly take Ivermectin for other reasons.
  19. “OMG! there’s a new strain!, put the masks on and line up for booster #12.”
    So very tired of it all, especially traditional media being lying parrots. Christmas parade massacre was a SUV accident according to the Washington Post, of course headline now deleted.
  20. ‘According to Wikipedia, under “List of association footballers who died while playing”, in 2001-2020 there was an average of 4.2 deaths per year attributed to Sudden Cardiac Death or Sudden Unexplained Death, the vast majority being SCD.
    ‘In contrast, in 2021, according to our list, there were 21cases of SCD/SUD among FIFA players.’
    https://stephenc.substack.com/p/5-fold-increase-in-sudden-cardiac
    With 18,853 deaths and 30,010 permanent disabilities reported to VAERS (source: third-party site vaersanalysis.info) — and likely undereported by a factor of ten times — more than enough evidence exists to take lethal covid ‘vaccines’ off the market.
    And to criminally charge those who perpetrated the biggest, deadliest medical fraud in history on human guinea pigs.
  21. Gee, who would think that the organized corporate news, that gets most of its ad revenue from Pharma, would be promoting Pharma’s products? Akin to insider trading, without the oversight. I suspect the reason for the “new and improved” variant is the widespread protest last weekend against being forced to take a “vaccine” that isn’t one, has had zero long term testing, the worst adverse event record ever, proven ineffective in places like Gibraltar, and the makers suffer no liability for damage they cause. Only the willfully ignorant, illiterate, stupid, or true “believers” would submit to this monumental pile of equine fecal matter.
  22. How to continue the propaganda fear campaign:
    1. Start rumors of a new “very contagious” variant circulating in one of the least vaccinated places on Earth. Check.
    2. Tell the public that it effects the young whose jabs just recently became approved. Check.
    3. Remark that the vaccines are not as efficient as originally promoted and everyone needs to get the new improved booster that was recently recommended to the public. Check.
    4. Have the medical community cry that enough vaccines are not getting to poorer countries and how everyone in the world should have one. Check.
    5. Don’t bother to explain how a shot made months ago is going to stop a new variant that has only recently been discovered. Check.
    6. Create intended panic and fear porn so Americans and Europeans will enforce new lockdowns during the holidays. God forbid we wouldn’t want them to get researched information from an intelligent family member while passing the mashed potatoes during Thanksgiving or Christmas. This may destroy the narrative. Check.
    • Local Faux News (Austin) tried its best to create a turkey shortage but that fell flat so on to trying to ruin the next holiday.
      Wednesday night’s trial balloon was a liquor shortage.
      • Hi Roscoe,
        I am starting to question if the shortage is really that or just a way to push higher prices onto the public and continue the scare narrative. I see the bare shelves in stores. I have had suppliers tell me they can’t get something. I have gone around them. Even calling the actual manufacturers (who are not located in this country). I have been able to get what I wanted each time. It hasn’t been cheap, but nothing has been impossible.
        Maybe I have just been lucky, but I am starting to believe that the manufacturers are withholding products whether it is a price control mechanism, government interference, etc.
        • RG, things are all sorts of f’d up right now. I’ve been dealing with it at my job in several ways. We fight inflation, we go around problems, but all this logistics nonsense, suppliers unable to supply, and record demand has made work very tiring this past almost two years now. I’ve worked on projects to change the manufacturing process of parts, resource parts in the USA, general cost reductions, etc and so all while developing new products. The problems out there are very real and not some manufactured fiction.
          Some of these problems have been around for years. Like the just in time nonsense for store stocking. Or as I call it just too late. It’s worse than ever when I go to a store but it is just an extension of what I’ve been experiencing for many years. People think the internet is killing brick and mortar stores, no their crappy stocking and other practices are. It’s like an autoparts store, thin stock, most everything special order. If I wanted to wait I would have saved money and bought it online. Also usually get something of higher quality if I wanted. The recent problems only made their continual problems worse. Trip to walmart for four things. They had two. Which was typical even three years ago.
          • Just in time became a thing way back in the late 70s, when we were likewise looking at extreme inflation, plus high interest rates. At one point the prime rate was 25%, and we may soon see similar to combat the inflation they’ve created. With credit that high, businesses simply could not afford to carry heavy inventory. After the dust settled, it didn’t go away.
        • I’m not sure about nationally, but the local media successfully created a “gas shortage” in Central Texas in September 2017. They would love a repeat, even if it isn’t in gasoline, especially now that the UT football season has tanked and Covid cases are on the decline state-wide.
          The worst culprit is the Faux News station in Austin which used to be owned by LBJ. According to legend, his penthouse apartment is intact on top of the studio building downtown.
    • Boy did you hit the nail on the head! Literally the day after this scarient hit the news there was a mask explosion at Whole Foods. The day before hardly anyone was wearing masks, the next day almost everyone. Proof in action that the public still reacts as intended to the organized news, even after two years of being lied to nonstop. Oh Lordy…
      • Hi RS,
        The interesting bit to watch is if the new variant will be a vaccine push for the scared masses or if it will be the variant used to “explain” the deaths of thousands to come. We should know shortly.
        • Indeed the latest and greatest variant has a high variation in its spike protein. Guess what the primary function of the current “vaccine” is. Why to talk your body into creating SPIKE PROTEINS.
          Could it be that this new and improved variant is in total the result of vaccination?
      • Well you see, the grocery store masks are, in fact magic, and among their powers is the ability to stop the transmission from Africa to the US overnight!
    • We’ll see if it works. I think the powers that be have shot their wad, and the only people who care about this new version of the same old, same old are going to be the ones who are still being neurotic about the first go-round.
      If the smallpox rumors are true, then they might generate a bit more of a response. But since TPTB are the only ones who actually have samples of that stuff, and everybody knows it…well, I suspect that they might not get quite exactly the response that they bargained for.
  23. Over at the CDC covid tracker, I see they list only 70.9% of Americans 18+ are fully shot up.
    Of the adult population, there are 29% who are not going along with the program.
    I’m sure some of these have medical reasons they can’t get shot, but the rest see the lies.
    Awful hard to keep the lies going & truth hidden when more than 25% of the people aren’t buying their propaganda.
    And even this number is subject to doubt. PA just announced they “overcounted” the jabbed by a bit over 1 million. How can that be a mistake?
    82% have gotten 1 dose. How many of them did so resentfully, so they can pay their bills? They are not supporters of the program either.
    Technology has enabled the dissemination of mass govt disinformation & censorship, but also allowed the rest of the story to be told. Something for which to be thankful.
    • I agree that there has probably been some “overcounting”, i.e., cooking the books. But even if these numbers could be trusted (from a source that has shown us over and again that it can’t be trusted), there is clearly a healthy (pun intended) resistance to the jab and its likely infinite iterations.
      I’m not hesitant, I’m adamant.
  24. The, ‘organized’ part. That, they are. I’ll never forget that montage online of local newscasters all saying the same line about, “a threat to our democracy”. For decades before that I often wondered why the big three news broadcasts, both local & national, NBC, CBS, & ABC all had just about the exact same news stories in the exact same order every single day & night. …Now, I know.
    After reading this bit this morning:
    https://www.lewrockwell.com/2021/11/no_author/pox-on-you-for-christmas/
    I wonder if the, all-new “super variant” meme is also a primer/pre-conditioning set-up for a plandemic pox release? If so, the word diabolical may only even begin to describe our overlords & their filthy minions.
    • That’s a POWERFUL piece! I have the video bookmarked. The various news outlets say the same thing, and they say it in the same way. The words used are the same; the emphasis on those words is the same; it IS the same! In fact, towards the end, when they put up the montage of all these different media people discussing the story, it’s plain to see that, other than voice and appearance, there’s no difference whatsoever.
      • It really was, as you wrote, a POWERFUL piece! Whomever created it, hats off to them. It seemed clear there’s no such thing as independent media.
        It’s the same with the order of news stories on the TeeVee, how did ABC know to put the same “top story” first as NBC & CBS did, night after night?
        How did each network know the second, third & fourth news segments were placed in the exact same order on all three networks? The only difference being the final feel good special intrest bit at the end. I seem to recall even the final segment on the local stations was sometimes the same, too.
        Sharing film footage only explains so much. As in, not hardly at all.
      • Bill Sardi, like Eric and so many other ‘riders’ do us the service of carrying the torch of truth, through the treacherous terrain of tumult and terror. We should be so thankful.
        This thing with the media being like one while pretending to present a choice. CNN, MSNBC, FAUX news is not new. I remember in the 90s, if memory serves, during wee Willies impeachment. “GRAVITAS, gravitas, gravitas.” They all of the sudden with much sound and fury began saying the same exact thing. It was really bizarre and eye opening to me.
        • Indeed, Eric, and most of those posting comments, remind me I’m not the only one still using my brain for something besides an ear spacer.
  25. ‘Reports are percolating in the organized press about an all-new “super variant” that is much worse than the “Delta” and previous “variants.” — eric
    It will get a Greek letter today from WHO. My money is on ‘epsilon,’ but we’ll see.
    Exquisite timing, no? To scare the living shit out of Americans (and Wall Street — Dow futures down -800) on a major holiday. Well played, sirs!
    Almost like a psy-op or something. Not that I’m a conspiracy theorist or anything. 🙂
    Before ‘they’ get control of this new narrative, it’s time for us to point out that this is yet another faceplant by the vaccinazis.
    Likely the phony ‘vaccines’ will be even more useless against this variant than the delta variant — which has killed more Americans in 2021 than in 2020, when no one was fully vaccinated.
    How do you spell A-B-J-E-C-T F-A-I-L-U-R-E?
    If they had been working on broad-spectrum anti-viral TREATMENTS (ivermectin being one example among many) instead of the useless vaccines pushed by Fauci, this latest scariant would not be a big deal.
    Call this what it is: a panic of the vaccinazis, as they once again are exposed as incompetent, useless, and criminal.
    Back to your basement, FJB.
    • The entirety of the “official” narrative, and the actions of “officials”, can only be described as ABJECT FAILURE. If it were not, we would be done with this already. If their “solutions” had any effect, why would we still need to use them? Continue to do the same thing and expect different results? If one jab doesn’t work the solution is two jabs that don’t work, then three, four, ten?
