2022 Lexus GX460
17
5163
Jurassic Park was all about resurrecting the dinosaurs – but wouldn’t it be better to just keep them from going extinct in the first place?
The Lexus GX460 is one such – and well worth preserving. It’s been around and largely unchanged since 2010 – an automotive Jurassic Era ago. Most cars – and trucks and the rest – get a major makeover after four years; it is almost unheard-of for a vehicle to go twelve years without one.
Unless, of course, they don’t need one.
The GX is a mid-sized, three-row luxury SUV that’s based on the Toyota 4Runner.
It is a real SUV, too – not a “crossover” SUV. Body on frame construction. Solid rear axle. V8 engine and four-wheel-drive, standard. There is no turbocharger. The transmission has only six speeds. There is no 48 volt starter/generator hybrid system to complicate things.
Which probably explains why so many people continue to buy these things.
The base trim stickers for $55,425. A top-of-the-line Luxury trim lists for $64,945.
You do not have to buy a higher trim to get the 4.6 liter V8 – or 4WD with Low range gearing and the heavy-duty off-road underthings.
All are standard in every GX.
The Lux adds a power-folding third row, leather and wood trim – and a self-leveling air suspension.
If it were still 2010, the GX would have several rivals. But in the intervening 12 years, almost all of them have disappeared. Or at least, their formerly standard V8s have disappeared. Most no longer even offer one as an option – including models like the Land Rover Discovery (which comes with fours and sixes, a “mild hybrid system and an eight speed automatic).
The Mercedes GLE is available with a V8 – and it’s a mighty one – but to get it, you’ve got to spend $20k more ($75,550 for the AMG GLE 53) than Lexus charges for the GX460 with a V8, standard.
And the Benz isn’t available with the V8 – and a third row.
The Lincoln Aviator has three rows, standard – but doesn’t offer a V8,  period. And while it’s rear-drive, it doesn’t offer 4WD, much less come standard with it. Ditto the otherwise-appealing Genesis GV80.
Those two offer – optionally – a lighter-duty AWD system without Low range gearing.
Which brings us back to the only mid-sized luxury SUV that still comes standard with 4WD, a V8, body-on-frame construction and a solid rear axle.
A Black Line Special Edition package has been added to the mix. It includes a set of black-anodized 18 inch wheels, “dark chrome” exterior accents, revised front and rear bumpers and a black ash steering wheel  inside.
Comes standard with things generally no longer available.
Twelve-year track record of reliability.
Mostly physical rather than digital controls are straightforward and easy to operate.
Steering is a little over-boosted and while one-finger easy, it’s not as precise as it could be.
Two-row version of the Benz GLE has more a much roomier second row.
Land Rover Disco’s available six is more powerful than the GX’s standard V8.
This Lexus still comes standard with a V8 engine, defying the trend toward replacing these engines with what are said to be “more efficient” turbocharged four and six cylinder engines, often paired up with some kind of “mild hybrid” system that shuts off the engine regularly – relying on inertia and battery power to keep the vehicle moving during these intervals – as a way to reduce fuel consumption.
But does it, really?
Or rather, how much does it reduce gas consumption to replace a V8 with a turbo-hybrid four?
As it turns out, the 4.6 liter, 301 horsepower V8 that every GX comes standard with is only slightly less “efficient” than the much smaller four and six cylinder turbo’d and often, hybridized, engines that are used in rivals such as the Land Rover Discovery and Mercedes-Benz GLE – both of which come standard with 2.0 liter four cylinder engines that make 296 and 255 horsepower, respectively.
EPA says the Lexo-saurus will travel 15 miles in city driving and 19 miles on the highway on a gallon of premium unleaded. Which sounds horrendous. But the four-cylinder Disco goes  . .  . wait for it . . . 19 in the city and 22 on the highway. The Benz GLE goes a bit farther  – on the highway – where EPA says it’s good for 27 miles. But in the city, it’s back down to 19 – so when you average it out, it’s about the same.
Or at least, not much of a difference for all that trouble. And parts, too.
The difference that really matters, arguably, is that the GX has a V8 rather than a turbo’d four – and not merely for reasons of prestige, though that’s also a legitimate reason when you’re spending more than $50,000 on a vehicle.
There’s no turbo to cook – and the GX’s V8 engine isn’t under the kind of pressure that turbo-boosted engines are under to haul two tons of brick-shaped SUV down the road. One of the reasons the GX is revered by the people who own them is its long-term durability, which is partially a function of that easygoing V8 it comes standard with.
Another reason, probably, is that it comes standard with a six speed automatic rather than an automatic with eight or even nine speeds, as its Mercedes and Land Rover rivals come standard with. More parts – and more shifting – often correlates with an eventual need for more fixing.
The GX may be “old” but that’s just the point.
It also pulls – up to 6,500 pounds. This is not as much as the Discovery is rated to pull -even with its four cylinder turbo’d engine – but the body-on-frame construction of the Lexus is more suited to pull. Once again we have the twelve-year track record of GX’s pulling without breaking. Will unibodied and four-cylinder-turbo’d models like the Disco still be pulling twelve years hence?
Want to take the chance?
Having a massive steel frame underneath you has a certain feel that having a body welded-together does not. A pleasant heaviness that’s desirable in a vehicle like this. A confidence-inspiring feeling, when you look underneath a vehicle like this – and see a heavy steel beam perimeter and know it’s not going to bend if you put a floor jack under it or get hung up off-road – and which is much less likely to need welding if you get hit, on road.
With a body that’s bolted to the frame, many exterior body panels can be unbolted and replaced – without welding. And a heavy steel frame is probably going to endure longer – especially against structural rust – than a welded-together (and thinner gauge metal) body and frame.
I will definitely be easier – and cost less – to fix.
Body-on-frame construction used to be standard in most American cars – before government regulations pertaining to fuel efficiency did to them what the asteroid did to the dinosaurs.  After that happened, many Americans retreated to SUVs – which at first were built the way American cars once were, with their bodies bolted to a separate steel frame and a V8 usually standard, under the hood.
Now they’re going away, too. For exactly the same reasons.
The GX’s V8 isn’t the most powerful engine in the class. The Disco’s turbo’d-boosted four makes nearly as much power – and its available turbo’d six makes a lot more (355 hp). But neither sound like or have the feel of a V8. There’s not much sound at all, in fact – probably because outfits like Land Rover (and Benz) know that a four sounds kind of disappointing in a vehicle like this – and so they devote a lot of effort to muffling the sounds it does make. Or supplementing the sounds with artificial sounds – through the stereo – to make you feel as though your $50k-plus bought you more than a four.
And be glad you only have six . . . gears, that is.
The GX’s transmission has no more of those than it needs, so it’s not shifting as much as transmissions that have eight and nine speeds – which constantly seek the highest of their multiple overdrive gears, so as to eke out a little more “efficiency.”
You feel the GX’s gears shift – in a good way, again – whereas the feel (and sound) of all that extraneous up-and-down shifting in the others has to be suppressed, such that it’s often hard to tell when or even if they’re shifting. You feel more in touch with what’s going on in the GX – which is a good feeling.
The steering, on the other hand, lacks feel.
It is very light, which makes it easy to steer this rig – but not as precisely. As you drive it, you get adjusted to making the little course corrections which are often necessary. It feels a lot like driving a big American sled from back-in-the-day.
But – once again – that’s by no means a bad feeling, at all.
This mid-sized Lexus comes standard with three rows, which has its pros and its cons. The obvious pro is the presence of that extra row – and the capacity for seven people. The less obvious con is how little cargo room there is because that third row – just 11.6 cubic feet, which is comparable to the cargo capacity of a Mazda Miata roadster. But the Mazda has only two seats – and you can’t fold them to make more cargo room.
If you fold-forward the GX’s third row, the available cargo space expands to 64.7 cubic feet. It’s not quite as much total cargo space as newer-design rivals such as the Disco and Benz offer (74.3 and 74.9 cubic feet, respectively – but as with the MPG stats, it’s close enough that it doesn’t make much difference. In fact, the Disco has even less space with all its seats up – just 9.1 cubic feet. The Benz GLE boasts 33.3 cubic feet – but that’s only if you skip the third row, which Mercedes charges extra for.
The differences that count vs. its primary rivals are the GX’s non-digital dash and its easier to use controls, almost all of which are of the knob and button and wheel type as opposed to the tap and swipe type.
LCD dashboards are very trendy right now. But will they look tacky five years from now? How “hip” and “cool” does the cellphone you owned five years ago seem now? The GX’s tastefully traditional analog gauges are apt to age more gracefully – and unlikely to ever just go dark – as LCD screens are prone to doing, eventually.
The stereo can be tuned by hand – rather than finger. Rotate the knob – and there you are. You don’t have to “scroll” through a “menu” to change the temperature or fan speed, either. Even the gear selector has a firmly connected feel. There is an LCD touchscreen – it being 2022 and all – but you don’t need to use it for regularly necessary adjustments, such as adjusting the stereo or dialing up warmer or colder.
It’s all very pleasantly retro – like being able to board an airplane without having to get your prostate checked.
Be hipped:
This year is likely to be the last year for the GX460 as currently constituted. It is likely to be reconstituted – without a V8 and possibly without body-on-frame construction.
Lexus, like every car maker, is under enormous regulatory pressure to nix the V8 and has already done that in all  of its other models, including the LS sedan, which used to come standard with a V8 – and the LX600 (based on the Toyota LandCruiser) which used to come with one too – and now comes only with a turbo’d six.
So this may be the last year to get one of these magnificent dinosaurs with zero miles on the clock and a new-vehicle warranty.
The GX460 is like $2 gas – a pleasant memory – except it still exists.
For a little while longer.
17 COMMENTS
  1. Eric, thank you for the great review. I have a 2004 GX 470, closing in on 300,000 miles now. Bought one for each of my kids-both are also well over 200,000 miles. Incredibly reliable vehicle-paint and interior still looks great on all vehicles also.
    • Thanks, Mike!
      It’s my pleasure to tout excellent vehicles – and the GX is one of the most. It is a legacy of the era when Toyota (Lexus) over-built vehicles, so as to make them ultra-reliable and long-lived and thus a counterpoint to the competition they were working hard to pull customers from – and did. Rightly so.
      I’d hang on to yours forever.
      PS: My mom got a new RX300 back in ’98 on my recommend. My sister has it now. The thing looks like it’s maybe eight years old and still drives like new.
  2. ‘Jurassic Park was all about resurrecting the dinosaurs – but wouldn’t it be better to just keep them from going extinct in the first place?’ — eric
    The GX460’s curb weight is about 5,200 lbs, on a wheelbase of a mere 110 inches — rather short compared to full-size sedans which once ran 120 inches or so, back in the days when Chevy Impalas sported billowing yards of sheet metal, with vast rear-thrusting trunks.
    A 1990 GMC Suburban, on a much longer 129.5″ wheelbase, weighed a comparatively petite 5,000 lbs.
    Automotive obesity: like human obesity, it’s a government-augmented pathology.
    Fat women, fat cars: they just don’t float muh boat.
    • Morning, Jim –
      “Automotive obesity: like human obesity, it’s a government-augmented pathology.”
      Absolutely. And yet, I like this fatty. It’s one of the last of the real-deal SUVs,, even if it’s carrying a lot of government-mandated extra. It drives beautifully and – as people who own them will tell you – they are tough as anvils and just go and go, seemingly forever.
  3. On the subject of vehicle models sticking around longer. You would think the automakers would want that, in order to profit more on the investment. Be better for buyers too, as parts would be more plentiful as there would be more of them.
    Chrysler must make good money on Chargers, 300’s and Challengers. The last facelift (which wasn’t even a huge one) was 2015. Almost 8 years ago. Toyota must love the GX460 as it hasn’t even had a facelift at all (as far as I know). Just keep building them until they stop selling. Probably people on their second or third one even. They all still look good, they all have aged well. Why change something that works, and works well?
    • Hi Rich,
      In re why the “dinosaurs” are being retired: The next round of regulations – including the 50 MPG “standard” pushed by Biden – will render them too costly to manufacture and sell at a profit. Also – in the case of Dodge – Sergio is gone and the new dude is Woke. All in on the “green”…
  4. Hey Eric – always thought this was based on the Land Cruiser (which I think has now been discontinued in all western markets). Didnt lexus also do a version based on the land cruiser, and is that still around, or has it also gone the way of the dinosaur ?
  5. “It’s all very pleasantly retro – like being able to board an airplane without having to get your prostate checked.” _Eric
    I had to laugh when I read that part. One reason perhaps the auto makers love turbo/ direct injection with 10 speeds and cvts is that they won’t have to worry about people driving them 15 years later and not having any interest in a new one as their old car still looks and drives OK if well maintained and kept away from salt. Of course it wouldn’t bother me to use an antique for a daily driver. I remember when you could get a new key cut for under 10 bucks and for most of my cars you still can.
    • I like the old analog cars…..
      I have a 1988 Porsche 924S Le Mans, 5 speed, it came with the M030 track suspension, more powerful euro spec engine and some other performance upgrades, it has only one computer for the fuel injection. I really like this car, it has naturally aspirated 2.5 lt. four cylinder, which has a great sound and a flat torque curve right to redline, it is possibly the best balanced, best handling sports car ever built (it is a front engine rear transaxle design for perfect balance), at 56 mph it gets 42 mpg, on a narrow winding road it is hard to follow, it is perfectly stable and planted at high speed (unlike the 911 that wanders around at high speed). It is built like a tank, but has the precision and build quality of a swiss watch, very high quality and has Porsche engineering (the best engineers in the world), so is a joy to drive. The original purchase price converted to today’s dollar, it is a $90,000 car, it wasn’t cheap when new. Buy one they are going up in value, new cars depreciate.
      The result of a recent auction in Europe for a 1988 Porsche 924S Le Mans
      25,000 – 30,000 EUR Results with costs Result: 23,400 EUR = $26,200 U.S. = $33,284 can $
      1988 Porsche 924 S Le Mans
      Serial number WPOZZZ92ZJN400231
      Rare limited edition Le Mans
      Technical inspection of less than six months
      French registration card
      In 1988 Porsche this limited series named after their 12th victory at the 24H of Le Mans. 980 units were produced between July and September 1987 equipped with a 160hp engine. The serial manufacturer option is numbered M755
      another auction result
      1988 Porsche 924 S le Mans
      VIN:
      WP0ZZZ92ZJN400443
      Status
      £21,375 ($29,453 U.S.) ($37,000 can $) SOLD · Mar 27, 2021
      Location
      Warwick, GBR
      Odometer
      122,543 miles
      https://silverstoneauctions.com/sa073-lot-261-1988-porsche-924-s-le-mans
  6. I bought an 2003 GX 470 a few years back. At the time I never thought it would be my wife’s favorite vehicle–right in the top 5 for me.
    It had 178,000 on it when I got it. My wife has run it up to 210,000. Best 6,000 I’ve spent on a rig. I’ve seriously considered getting one with 100,000 miles or so. I’d keep the old one and my wife could run the other around.
    The greatness of these beasts is hard to overstate.
  7. I actually really like this SUV. I owned the RX330 for seven years, albeit much smaller than the GX, Lexus builds solid vehicles. My RX330 made it to 217k before I traded her in. Plus, I like dinosaurs so this is really up my alley…now if I can locate one.
  8. We went from new models having more options to less, in terms of big engines, transmissions, 4×4.
    I guess that’s progress in the automotive world today.
    Sad to see another one about to bite the dust.
