Enter Dr. Zhivago
69
8463
They don’t just want us out of our cars, they also want us out of our homes, too. Out of everything – that is individually owned – in favor of collectively allowed to use. That latter being a pretty good working definition of communism.
Who are they?
Everyone knows. They are the people who comprise the leadership cadre of the World Economic Forum – a body whom no one elected but which wields tremendous power over every elected government in the world, somehow.
The WEF is headed by Klaus Schwab, who was once the protege of a Canadian communist by the name of Maurice Strong, who was very active in the early days of the “environmental” movement – which communists used to revive communism, which had been discredited under its own name. By giving it a new name – and replacing the proletariat with endangered animals first, leading to “climate change” lately – it has very successfully re-introduced the communist regime of poverty for the masses and power for the elites, without the masses beginning to understand that this is the end goal of the WEF’s mantra that we will own nothing – and they will be very happy about it.
Strong knew that this would never sell if plainly stated. At least, not before the masses were sufficiently re-oriented such that they felt guilty about owning things such as private cars and private homes. Then they could be persuaded to give them up – for the greater good. Once they do, it’s done – and they will never get them back. They will then be “happy” to get whatever the World Controllers allow them, which won’t be much.
Bretibart carried a news item about the “Great Reset” – as the WEF styles it – currently under way.  The article describes a WEF “paper” – i.e., a call for an order to be issued by the governments under the sway of the WEF – that “calls” (the prequel to ordering) for communal sharing of vehicles – as well as other things besides. All of this us not owning – and them being very happy about it, as they will control everything. It is necessary, you see, for the sake of the “environment.”
Our enserfment will address the “climate crisis” – which is very much of a piece with the “crisis” of the unvaccinated – by reducing demand for fossil fuels and precious metals, the latter being demanded more of for the sake of more electric cars, which the WEF’ers insisted were also necessary but merely the replacement for our gas-engined cars, not the vehicle for ending our private ownership of cars.
Except of course that’s just exactly what they are meant to do – and now you can see it, if you are willing to look at it. All of a sudden, there is “concern” – not about “carbon dioxide,” although that is coming, too, should it become necessary – but rather about the precious metals that are an essential building block of EV battery packs. It is unacceptable – to the WEF – that a quantity of them sufficient to provide for enough EV battery packs to power a replacement fleet of EVs be extracted and processed . . . on account of the “environment.”
The same “environment” the WEF’ers insisted required mass-adoption of electric cars.
The cars the masses will – per the WEF’s “paper” – have to give up owning, too. Also for the sake of  . . . the “environment.”
Which is to say – though they do not say it – for their sake.
Instead, “car sharing platforms” will “seize the opportunity to offer vehicles where pay per hour is used.” If the WEF World Controllers deign to allow you to use them, at all. Which power they will have once you no longer own what was once your car, now their collective “transportation as a service” – the term used by the ascendant “mobility” companies that will control your mobility via owning it.
As well as what’s left of your finances – after the financialization of everything, also part of the Great Reset. The term can best de described as just what the WEF seeks, which is enserfment, first to debt – via the vitiation of ownership in favor of serial renting – and then to them, by dint of us not owning anything.
This will eventually include your private home, too – which is just as “wasteful” and “bad for the environment” as your private car. So many others could be using both – instead of just you owning them. Manipulation of the envy and stupidity of the Have Nots  will be used to “seize the opportunity” to take them from the Haves, in order for the leadership cadre of the WEF to have everything.
As it was in the old Soviet Union, where everything was Soviet state property – and those who controlled the Soviet state thereby controlled and thus effectively owned everything.
“A design process that focuses on fulfilling the underlying need instead of designing for product purchasing is fundamental to this transition,” reads the WEF’s “paper.” It goes on to say that “This is the mindset needed to redesign cities to reduce private vehicles and other usages.
Emphasis added.
It’s diabolically brilliant, even if it’s nothing new – just rebranded and re-marketed. With an important difference that just may be its undoing.
The communists of the past could use as their excuse the plight of the working classes in industrial societies, which was real (to the extent that some had little while others had much more) while “climate change” is a computer-generated, media-enhanced fraud.
Very much as the “pandemic” was – and both furthering the same goal.
Ironically, the end state of the Great Reset, should it be accomplished, will be exactly the one the communists of the past used as their excuse, i.e., the masses will have little – none, according to the WEF’s coda – while the few will have everything.
Private cars – and jets – as well as “dachas,” as in the old Soviet Union.
That is key to understanding – and rejecting – the evil that is the Great Reset. Just the same as understanding that the “pandemic” was not about “stopping the spread” of a disease but rather about enshrining the sickness that is  . . . communism. That is to say, authoritarian collectivism, which is the way to understanding what “communism” – and the other “isms” are at bottom.
The authoritarian rule of a self-chosen few over the collective. The latter being told they are in charge – “the people,” “democracy” – even though they are on charge of nothing because they are not allowed to own anything. For the “good of society.” For the sake of “public health.” Because it is “necessary,” for the sake of the “environment”  . . . to stop “climate change.”
And that is the end goal and true meaning of the WEF’s coda which, once understood, can be fought – without feeling any guilt.
The “climate” is not “changing” – unnaturally or catastrophically, much less on account of our “emissions” of carbon dioxide, an asserted fatuity on par with the assertions about “masking” and standing six feet apart. The “environment” isn’t in danger.
But we sure as hell are.
69 COMMENTS
  1. When at the Como Zoo in the Twin Cities in Minnesota many moons ago, I was standing in front of the orangutan’s cage, he was behind bars.
    In front of the bars was a glass front. I couldn’t figure out why there was glass in addition to the prison bars. As I stood there observing the orangutan, a good-sized glob of spittle was right in front of my face hanging on the glass enclosure.
    Good times.
    Another orangutan story tells of a grunt in Vietnam while out on patrol one day gave an orangutan a portion of his lunch. Went on for three days.
    After the third day of sharing lunch with the orangutan, the orangutan wanted all of the grunt’s lunch. The soldier refused, which then the orangutan promptly slapped the snot out him and took all of his lunch.
    True story.
    Imagine you providing lunch for the orangutan every single day to prevent being slapped silly, the orangutan won’t care if you are always left hungry. You’ll be conditioned like a Pavlov dog.
    Everything you have to us belong. You’ll be happy to have nothing.
    That is what the elitist slobs have planned for you.
    The starving will continue until the hunger is satisfied.
    “Who shit my pants?” asked Klaus the Schwab, totally confused, dazed into complete oblivion. Newsflash, Klaus: You’re gonna die one day yourself.
    Good luck to ya!
    • Hi Letme.
      To ask the question is to answer it. Hasbara are the very least of it. I’ve always found it interesting that certain types will assume the answer is always what they expect. Perhaps there are others, also moving pieces around in the shadows? Perhaps the reference was to one of them? Its not always the worlds self professed victims who are the focus.
    • Hi let me,
      I’ve spent most of my adult life critiquing collectivism. I do not see how one can take a principled stand in defense of every individual’s presumptive worth – and innocence of having caused harm, absent specific evidence that he has caused it – while adopting a collectivist attitude toward individuals that presumes lack of worth and harmfulness. Certain individuals are bad people. Hold them each accountable, certainly. But I will not condemn any person absent specific reason that justifies it – in that particular person’s case.
  2. The big news out west is the HISTORIC! low level of Lake Mead. Remember that Hoover Dam isn’t even 100 years old. It was built in the 1930s, a time of extreme drought. It was completed early and under budget, which history teachers usually attribute to the wonderful workforce. But what about the snowpack and precipitation during those years? We read that the data used for water allocation under the Colorado River Compact was skewed higher than average. Did the stream gauges report average, above average or below average snowpack and runoff during construction? A high runoff would have slowed construction in springtime and early summer, which is prime construction time in the Nevada desert.
    If I were a “fake news” journalist I might write up an article comparing historic flows over the last 100+ years. Maybe we’re having the 100 year drought? Maybe there’s more to this global warming stuff than being reported. No one is asking questions of the Bureau of Reclimation. The media is happy to just accept that it’s global warming and that’s all. No mention of the years of increased flows for no reason other than “river health,” no mention of the millions of dollars in revenue from power generation that would be lost if more water was held back. No mention of the loss of business from (typically conservative/redneck) boating and fishing activity on the lake.
  3. I found a couple of very interesting videos and channels lately. Thought I’d share if anyone is interested and has the time.
    Green New Deal – The Math doesn’t Work:
    https://youtu.be/UghHef_XJ-U
    Alexander Mercouris (from The Duran) on current geopolitical events. His channel and The Duran channel are very good. This one in particular addresses the energy crisis surrounding the current developments in the Ukraine war:
    https://rumble.com/v1d8xi9-russia-prepares-big-offensive-putin-talks-to-mbs-ridicules-eu-on-gas-eu-scr.html
    If you don’t have a lot of time, skip past the actual war update (about halfway) to the discussion about European energy and the US involvement with the developing crisis. It’s very enlightening IMO.
  4. Your article points out the root of the problem… guilt. Not in the sense of “found to have committed a crime” but in the sense that you mention, i.e., feeling bad about yourself in any number of ways.
    That what you’re doing is wrong or bad. That what you are or are doing, isn’t good enough, valuable enough or worthy enough. That what you want to do with your life is inherently wrong or destructive or harmful to others.
    People need to develop a “guilt detector”. Proudly and boldly proclaim that, for example, the “common good” is not your responsibility. The condition of the “environment” or “climate” or the earth itself is not on you.
    Until people can identify and defeat guilt, they’ll always be a victim of it. It’s a huge topic and very few people are (apparently) giving this subtle manipulation tactic the treatment it deserves, i.e., complete rejection.
    • THAT, was a very good observation, EM.
      I hope others pick up on that & expand it so… the average guy, or girl, on-the-street can understand it.
  5. Bravo, Eric:
    Another great piece. Here’s the most important part which needs to be repeated over and over and over again:
    “The “climate” is not “changing” – unnaturally or catastrophically, much less on account of our “emissions” of carbon dioxide, an asserted fatuity on par with the assertions about “masking” and standing six feet apart. The “environment” isn’t in danger.”
    • Even if the climate is changing, it isn’t the problem of individuals living their lives the way they want to. The earth is surely going to exist, with plenty of life, well beyond the existence of humans. The idea that we are going to save it is preposterous, foolish and arrogant.
      Nature will find a way, no matter what. Whether that way includes humans for long or not, is another story. What people are really saying but too embarrassed to admit, is that we are trying to save ourselves from our own destruction.
      Even in the event of nuclear holocaust, eventually, the grass and the roaches and other bugs and bacteria and all manner of living things will continue and evolve.
      We aren’t trying to live more in alignment with nature. We’re trying to grow cotton in the desert (for example). The idiots living in the hottest desert in the country are blaming everything but their idiotic premise that it somehow makes sense to do so.
      Humans have set about making steaming, smoking, concrete covered, piles of shit (aka cities) the preferred approach. And then bitterly complain about that somehow not being the garden of Eden. It must be the fault of Trump supporters that their paradise (e.g., the slums of Philadelphia or Los Angeles, etc) aren’t quite as beautiful as they would otherwise be.
      From where I’m sitting, this whole thing does — with no sarcasm intended — appear to be the absolute lunatic ravings of semi-intelligent and fully-insane people en masse.
      They don’t want to go pitch a teepee in the woods and live in nature. Rather they want their steaming piles of shit to be beautiful and, when they’re not, it’s everyone else’s fault.
  6. Where Central Banks Have Issued Digital Currencies
    The advent of CBDCs could also mean that money and economic participation will become privileges, not rights. Digital trade could be tied to a social credit system, much like the one that exists in communist China.
    Want access to your checking and savings accounts? Better not say anything critical of the establishment, or you could be reported by a neighbor or stranger by cell phone app and have your money disappear in seconds. The onus will then be on you to prove that you are “loyal” and get access back. You are guilty until proven innocent. Maybe you don’t want to take the next untested mRNA vaccine for the next dubious pandemic threat? You’ll have little choice if your ability to function economically is controlled digitally.
    This is the world we are facing if we allow central banks to fully digitize money and trade. It is a nightmare environment of complete authoritarianism. The public at large is mostly unaware of the incredible danger inherent in CBDCs and they must be educated before the current crisis grows so large that they can no longer focus on anything other than their own problems.
    from zh comments:
    Social media and media in general is the anti christ..
    Your cell phone is the vessel
    And cbdc is the mark of the beast
    How about throwing out some solutions or potential solutions that could be investigated?
    1. Precious metals, land, barter
    2. Trusts, LLC’s and other corporate structures
    3. decentralized Digital currencies [?]
    Theres a few worth considering. Certainly better than sitting around waiting be enslaved.
    https://www.zerohedge.com/crypto/where-central-banks-have-issued-digital-currencies
  7. A few years ago GW Bush used drones to “smoke ’em out”, he said we had to kill Islamic terrorists in the Middle East for hating our freedoms.
    Well – who really hates our freedoms? Some mullahs who have no influence in Amerika, or the WEF communists who are stealing elections and setting anti-freedom policies that take away our choices.
    The precedent has been set, it is legal to kill terrorists with drones. Well … what are we waiting for?
    Thus all WEF members, who are terrorizing us, should be immediately droned, maybe get them all in one shot while they all gathered up in Davos.
    I am dead serious, anyone who pushes this climate nonsense is a terrorist against our prosperity and values of freedom. But you see we have a problem of perception, no one in the west will say we should kill Klaus Schwab – who is a real Dr. Evil, but all will say we should kill some towel heads in some unimportant middle east desert shit hole.
    The problem is Amerikans are brainwashed and do not understand who the real enemy is, and even if you explain it to them directly, the emotional bias is against the Muslims and not the real terrorists in Davos, New York Times, Tel Aviv, London, and Washington D.C.
    This is the real problem, and when I blogged I used to write again and again and again the last people on earth who will find out that Israel did 911 are Amerikan Christians, because they will deny reality because of their religious beliefs. Megachurch pastor John Hagee says you can’t be in heaven with God unless you love Israel. So that guy is also a terrorist because he is protecting terrorists with religious mumbo jumbo.
  8. “WEF’ers”
    How appropriate. World Economic F’ers.
    Now the Dutch Parliament is declaring nitrogen to be the enemy.
    https://www.fas.usda.gov/data/netherlands-dutch-parliament-approves-law-reduce-nitrogen-emissions
    Heck, 78% of the atmosphere is nitrogen. And they are bound and determined to stop it. These people are Crazy Evil. It’s about time we recognized the true evil among us.
    The good news is that all these World Domination types always fail. Why? Hubris always precedes the fall and this will be no different.
  9. On an episode of the David Knight Show a while back he mentioned a movie from 1981 called “Early Warning” which does everything but say “WEF” but they called it the “One World Foundation”. It’s available free on YouTube. If this continues as it has been the last few years I suspect that at some point we will all be like Sri Llanka and that’s when things will get really interesting.
  10. Good article, Eric.
    The good news is the WEF will never succeed in what they hope to accomplish. The bad news is Americans may have very little left for someone to take. Our assets could be pretty worthless.
    Rumor has it that Russia and China plan to announce a joint global currency in the next 90 days. If this occurs expect many nations to back it: Saudi Arabia, India, Iran, possibly Brazil, etc.
    If this occurs the US economy will crash. We are no longer a nation of producers. Other countries buy nothing from us because we no longer manufacture anything. We have stupid inept government leaders whose only goal seems to be destroying this country. We have created too many enemies.
    Globalization is not sustainable. Too many want to be in charge and not everyone has the same goals. The Rockefeller Foundation’s Scenarios for the Future of Technology and International Development have provided a guideline on what is going to happen and the end result. Many who read the playbook have a tendency to focus on the Lockstep scenario. I urge everyone to read the fourth and final scenario: Smart Scramble. I believe this is how the globalization of today catapults and ultimately solves itself. Don’t focus on 2030, we are going back to 1830.
    • Hi RG, re: joint global currency
      If it happens, my guess is this is the stuff wars are made of, and the US is in such bad shape which will be made significantly worse with that.
      I read something that theorized that our psychopaths’ could/want to take on china causse we are significantly up-military than them right now and they don’t care if they take out a percentage of us as long as their degrading power stays on top. The unknowns is if russia will join china against us, then it’s probably all over.
      My theory is that russia/putin seems to be doing many (not all) things like our founding fathers did. certainly china is not. so if this disaster ww3 happens, how do we make sure that putin runs us and not china? crazy shit I know.
      The good news is I don’t stay up at night worrying about it. Worrying is a waste of time. I’m enjoying the summer the best I can, and I am. My wife and I are setting up to enjoy ourselves as much as possible, and we are.
      • Hi Chris,
        You are right. We can’t live our lives around “what ifs”. My only hope is that a large portion of the world does not trust China and therefore are apprehensive with this new currency. China MUST issue a new currency since the yuan is in trouble. Russia hates the West (can’t say I blame them) and will happily consider all options that will take the USSA and Europe down a few pegs. I am a little surprised by India and Brazil backing the new BRICS, but right now the USSA is weak, so I don’t know if it more self-preservation with these countries or they we were blinded by a fake friendship.
        I think the Bully of the World is about to get her day of reckoning. Honestly, the best thing for us would be to shut down the borders completely and begin manufacturing at home. Isolate ourselves from the rest of the world for a while until we regain our competitive edge. Let the rest of the globe take care of themselves for a change.
    • Hey RG we still produce a whole lot of stuff. We’re the world’s grocery store. We are the leading arms dealers, aircraft manufacturer, engineers and designers. For how much longer remains to be seen…
      • Hi RK,
        The problem is we are importing more than we are exporting. Our trade deficit is about $860 billion dollars. Per my comment to Chris above. We need to take care of ourselves and let the rest of the world learn to walk instead of the USSA (and our money) constantly toting them around.
        • There is no trade deficit. We make things in China because people don’t want to pay $1,000 for a laptop. I don’t support US manufacturing if it will drag down share prices for no reason other than it’s somehow patriotic.
          • Hi BD
            Actually there is a huge trade deficit. The real question is what are the implications? On the surface, if the rest of the world is willing to send us goods and services in exchange for the Empires fiat, why complain? But once one gets below the surface, and examines the unseen, matters aren’t quite so simple and rosy.
            First, we have gone from being a nation of producers, to a nation of paper pushers. There are three main reasons. One, government (at all levels) and its nearly endless regulations, rules and taxes. Two, the central banks (and its banking cartel) manipulation of the economy (interest rates, and base/broad money). Three, the political class sold out to the globalists.
            Each of those has serious implications individually. Collectively, they have hollowed out the Empires manufacturing base (which is a legitimate national security issue). Undermined the US dollar, and its stability. And exposed those in power to foreign manipulation against the interests of the country and its people. This has resulted in the systemic instability that we see all around us.
            Free enterprise capitalism is an ideal. It is a goal that should be the lodestone of peoples activities. What we have is anything but free enterprise capitalism. What we have is crony capitalism at best, and out right fascism at worst.
            But that is to be expected, when short sighted people, with no principles are allowed to rule.
    • Hi RG.
      I’ve spent most of my life dealing with think tanks and academics. Which is why I’m not overly impressed with them. Especially the ones well known to the general public. They all have various weaknesses and obvious biases. Think tanks in particular are prone to several. One of the worst is that their conclusions almost always support the agenda of those funding them. Isn’t it odd how that happens?…
      That’s also one of the reasons the Gangs (governments) “intelligence” groups no matter how well funded, always seem to be behind the curve, and tend to miss major developments.
      The fact of the matter is, that the politicians do not reward being told the truth. Hence, they are told what they want to hear, rather than what they need to know. (it tends to be better
      for ones career.)
      Are you familiar with whats known as Putts Law? It deals with technical organizations in general. In brief its this;
      Putt’s Law: “Technology is dominated by two types of people, those who understand what they do not manage and those who manage what they do not understand.”
      Putt’s Corollary: “Every technical hierarchy, in time, develops a competence inversion.” with incompetence being “flushed out of the lower levels” of a technocratic hierarchy, ensuring that technically competent people remain directly in charge of the actual technology while those without technical competence move into management.
      Now, couple that with Diversity hires, and you get the waking nightmare that we are living in today.
      Don’t even get me started on models. Computer modeling has been all the rage for a long, long time. Good accurate modeling is rare, VERY time consuming and expensive. It is also very easy to do badly or wrong. There is an OLD expression dealing with this: GIGO. Garbage In Garbage Out.
      One of the best ways to look at a model is a series of assumptions. Especially in multi variant systems. The more complex the system, the more time and insight must be used in assigning its elements properly. Keeping in mind that ONE wrong assumption or missing element can send the results off into fantasy land.
      One example of that is the IPCC 8.5. It was originally intended as a sanity check. In other words, if your results are in that range you had better check your model. Instead the zealots and cultists seized on it as likely, and the rest is history.
      In short, don’t take these groups overly seriously. Its fine to keep track of them. One should always know what an enemy is up to, and what their focus is. But keep reality in mind. Emergent systems can’t be accurately modeled. That means that many of their plans are not only going to fail, but fail chaotically. Which provides those opposed to them opportunities.
      You may find this video of interest. This woman spent 32 years in analysis for the Company. She has many useful insights, but some glaring blind spots. It is those blind spots that explain their various intelligence failures.
      https://www.youtube.com/watch?v=kNv2PlqmsAc&ab_channel=SANSDigitalForensicsandIncidentResponse
      • HI BJ,
        I agree with your thoughts on think tanks and academia. People are going to use the data to push their own narrative. Even individuals are guilty of doing it. Anything that is in agreement with our thoughts and opinions must be right. 🙂
        The Rockefeller Foundation I view a little bit differently. Let’s be honest, they are in charge. They regulate the money supply through their control of global banking institutions. Their influence is worldwide, and the scenarios created by their pamphlet are too coincidental. They also never seem to appear on any “Richest People List”. Why not? It isn’t the people in the forefront that worry me, only those behind the scenes that hold the puppet strings.
        • Hi RG.
          Why not? I suspect we both know the answer to that question. Much of this tracks back to the Dynasty. As for the R foundation, they aren’t in charge. Its those who helped establish the various houses over the last few centuries who rule from the shadows. But they are not the only ones moving pieces around in the shadows.
          This is a very deep and twisting rabbit hole, and I’d not recommend diving down it for most people. Its far too easy to end up like Alex Jones. The man has a brilliant mind, but his perceptions and value judgements are questionable. Thank you for taking the time to respond.
      • BWUBWD.
        Took a green hornworm off the green tomatoes, recently, & put it in the green green grass o’ home. Chaos averted. For the tomatoes. The grass was cut the next day. Prolly no meta for that hornworm.
        Butterfly Wing Up Butterfly Wing Down … gimme a competent alcoholic jokers wildcard, any day:
        https://www.youtube.com/watch?v=_nhxm5QEbYI&t=174s
        Hey, copilot, that official authority wasn’t what you thought, was it?:
        https://www.youtube.com/watch?v=kr5jSg58Hf4
        • Hi Ozy
          Another Dayo in the Banana Republic. Day light gone and me want to go home.
          Dat damn tally man be napping in da shade again. Who knows what evil lurks?
          Meta a day keeps the bots at play. No Such Agenda is nose to nose with Meta muci! Who knows wHo wins in the End?
          The grass is always greenEr over the septIc tank. Or was that MIC? Both are full of it.
          Butter files just do it for effect. Just ignore them. Other wise they might fly off the hockey stick. Kaos takes its toll. please have exact ChangE.
          Copilot Wi Tu Lo? No authority like Lo authority. Just ask Sum Ting Wong.
  11. There’s a book titled ‘Homo the Sap: Permanent War’ written by Lorne T. Morgan. More talked about than read.
    Another book by Marsten Bates titled ‘Gluttons and Libertines’ is an eye-opener.
    According to Marsten, anyone who claims to be expert in food or sex is to be considered crackpot. If you include climate change, Al Gore is just another kook.
    Klouse is one for the books. Stealth enemy action is where it’s at for Klouse.
    Bill Gates’ brain is in dunce mode much worse than Bidet’s.
    Nobody wants to hear one word when he speaks with his forked tongue. Get lost, you bum.
    In heaven, there is no beer.
  12. The Democrat-Marxism lie always unravel on them sometimes right at the wrong time. The vaccines that don’t immunize, a disease that its origin coincides with a BSL-3 laboratory doing experiments on the same disease, policies that cause shortages, etc. Global warming is a hoax, and they know it.
    However, the last (2) pillars to remove in order to fully change a society: the relative ability to acquire individual prosperity, and the 2nd Amendment. Bite-me and his Democrat-Marxist handlers are destroying our economy via the destruction and inflation of the dollar and are working towards a food crisis. Then they will justify taking guns away. Gun ownership is a big problem for them, but they are clever. It is this last point of chaos, will be their goal. During this chaos, the police will not be your friend, they will be the dis-armory wing of the Democrat-Marxist.
    Solzhenitsyn wrote in the Gulag Archipelago how they lamented in the camps that if even a small resistance at each and every apartment was waged with clubs and bats when the NVKD came, the cowardly NVKD would have run and eventually their organization would have collapsed. But it didn’t happen because people hoped the NVKD weren’t coming for them then didn’t want to get involved.
    We all better resolve ourselves to get involved and be prepared.
    • Hans,
      Indeed, “gun ownership is a big problem” for any tyrant. It’s much harder to load the “deplorables” on the train to the re-education camp if they are shooting at you. Which is why all tyrants always attempt to disarm the people. The pitiful part is, it usually works. Let us insist it does not this time.
    • Hi HG
      Exactly right…..
      Resistance is Respected – Weakness is Despised
      There is nothing leftist/globalist/communists/nwo respect more than strength. There is nothing they despise more than weakness. Those people who think that they can calm the situation by bowing to the elite nobility/nwo/who/wef .0001% cabal, washing their feet, or brushing, or kissing their boots, not only figuratively, but literally, have no idea that all they are doing is greatly aggravating the situation and encouraging the elite nobility//nwo/un/ccp/wef cabal to demand far, far more.
      Kennedy cv19 speech:
      The pandemic is a crisis of convenience for the elite who are dictating these policies. It gives them the ability to obliterate the middle class, to destroy the institutions of democracy, to shift all of our wealth to a handful of billionaires [while] impoverishing the rest of us.
      ATTENTION: And the only thing between them and our children is this crowd that has come to Berlin….(the Berlin protest)
      Thank you all very much for fighting. See ‘Robert F. Kennedy Jr. Speaks at Berlin Rally for Freedom and Peace’.
      The history of much of human existence since the Neolithic Revolution 12,000 years ago can be written simply: the endless struggle by those who are oppressed and enslaved against the insane elite that oppresses, enslaves and kills them.
      Unless we succeed completely in defeating this coup the very essence of what it means to be human will be taken from us.
      And one consequence of this coup will be human extinction in the near term, by one or more of four possible paths: nuclear war, the collapse of biodiversity, the deployment of 5G. or (the demon shots?)……. mass starvation, controlling the food supply….
      nuclear war….maybe he was on to something ………
      our own obedience, our own cooperation that will condemn us all to the fate being orchestrated by the global elite nobility.
      The entirety of human history is one of the few controlling the many because the many acquiesce to the few
      If you thought that the rule of law would protect you from government overreach, it might be a good time to review your belief. The law is simply another tool in the elite’s armory against you and it is being used with devastating impact right now
      say to the police opposite: ‘You have children, you have grandchildren. And you are enforcing the fascism which your own children and grandchildren will have to live with. Join us, for goodness sake and stop serving the psychopaths.
      and this……..
      the dissenting and disenfranchised will find themselves branded as “terr//orists”, gathered up into the box cars, and shipped away to be disappeared by the millions.
      Clean, efficient, cheap elimination, sustainable and always environmentally friendly. And it will be at that point, in these cramped box cars, within these hot and stinking quarters during that collective silence where time is suspended between repeating clanks of iron on iron and the hypnotic rhythm of the carriage roll, it is here where “of the people” will ponder upon why they did not wake up, why they did not wise up, and why they did not rise up.
      And so these thoughts go, box car after box car, train after train, day after day. And as the trains slow into the camps, “of the People” will finally experience the epiphany of just how few individuals there were who ruled over the world, but will also discover too late just how few bullets would have fixed things early, how little blood need be shed to derail this Road to Zero.
      We Are About To See One Of The Greatest Human Die Offs Of All Time * Merritt Palevsky Zelenko * NWO
      https://brandnewtube.com/watch/we-are-about-to-see-one-of-the-greatest-human-die-offs-of-all-time-merritt-palevsky-zelenko-nwo_gf2j7ehb8um4mdh.html
      • There is nothing leftist/globalist/communists/nwo respect more than strength. There is nothing they despise more than weakness.
        the globalist communists despise the weak pukes that bow to wearing masks, injections, lockdowns, etc.
        the globalist communists respect the strong people that wouldn’t bow to wearing masks, injections, lockdowns, social distancing, etc.
    • Hans, et al,
      Here’s the relevant quote….BTW, totally worth reading the entire three volumes…it was very influential for me in the 70s…..
      “And how we burned in the camps later, thinking: What would things have been like if every Security operative, when he went out at night to make an arrest, had been uncertain whether he would return alive and had to say good-bye to his family? Or if, during periods of mass arrests, as for example in Leningrad, when they arrested a quarter of the entire city, people had not simply sat there in their lairs, paling with terror at every bang of the downstairs door and at every step on the staircase, but had understood they had nothing left to lose and had boldly set up in the downstairs hall an ambush of half a dozen people with axes, hammers, pokers, or whatever else was at hand?… The Organs would very quickly have suffered a shortage of officers and transport and, notwithstanding all of Stalin’s thirst, the cursed machine would have ground to a halt! If…if…We didn’t love freedom enough. And even more – we had no awareness of the real situation…. We purely and simply deserved everything that happened afterward.”
      • Giuseppe,
        Thank you for posting the actual quote from Solzhenitsyn.
        I often thought after what may happen in the next few years, we will all wish January 6th was a real insurrection and we re-establishment of a constitutional republic. We’ll see what happens and pray to God for our country and founding principles.
  13. The entire WEF agenda is being set by a myth of climate change, that man is causing uncontrollable temperature increase by CO2 emissions. That is laughably insane as CO2 is a trace gas and man made CO2 is only 0.117% of anthropogenic warming.
    https://globalwarminglie.wordpress.com/2010/03/27/anthropocentric-co2-is-only-0-117/
    0.117% rounded off to the nearest integer is zero – and is so small it can not be measured.
    In fact after years of study I have come to the conclusion that CO2 has no effect whatsoever on climate, and realized that the agenda is pure political power mongering and not based on any science at all.
    Think about it, a trace gas can not control the thermodynamics of a planet. All you have to do to prove this is go to Canada in the winter, and it is just as cold as it ever has been, regardless of CO2 levels. So this idea that earth is going to change into some dinosaur era hot house, where palm trees grow in Minneapolis, is ludicrous.
    Bottom line? No matter how much people “believe” the reality is that CO2 is not a temperature driver, CO2 has never forced temperature on earth. This is the record in ice core samples, ice ages start at high CO2, and end at low CO2. At no time in earth’s 4.6 billion year history has CO2 ever controlled temperatures.
    But this climate change by CO2 is a potent belief caused by a agenda driven media – which has induced a coma in the sheeple’s minds and thus the disaster of market tampering will continue until we wake up owning nothing – having been asset stripped by Klaus Schwab and company.
    Rich people own the media and are using it to wage war on us. And we saw this directly with the Covid death jab – so now we can see climate change is just like Covid – a false narrative being used to harm us.
    • Hi YJ
      you are right…..
      CO2 bs = insanity. another nutcase theory for low iq leftist morons
      This professor completely dismantles the climate change lie, worth watching, these leftists pushing this climate change bs are the biggest liars in history.
      Climate change just like bat germ bs is purely political and religious, based on fake science. Climate change, the new GAIA cult religion, like it’s brother covid, a big favorite of the communist, reset, one world government, satanic cult freaks,
      Don’t lose sight of the fact that the whole scam is being used to hide a financial crime, they looted the place.
      No pension money left = need depopulation now.
      https://www.youtube.com/watch?v=CA1zUW4uOSw
    • You know, even if CO2 does affect the climate, and worldwide temps increase by a couple degrees, so what? First, what is the “perfect” temperature for earth? 64 degrees? 77 degrees? 87 degrees? I dunno, and neither does anyone else. Second, look at the benefits of warmer temperatures. Longer growing season, less snow, meaning less salt damaging roads, water sources, etc. Also means a lesser amount of fossil fuels used for heating. Warmer temperatures and higher amounts of CO2 also produce greater crop yields. The world is provably greener today than it has been in a long time. And what is the biggest killer, cold temps or hot? Well Stanford University did a very thorough study and found that twice as many people die from extreme cold than from extreme heat. Bottom line to me is, wherever you live, whatever time of year it is, take whatever today’s temperature is and add two or even three degrees and then ask yourself, so what?
      • Warmer temperatures don’t mean less snow in the northern hemisphere and higher elevations. It means more snow. Perfect snow weather is 30-35 degrees for high moisture content snow. Warmer temps = more moisture in the air. That’s a good thing for high elevation desert areas like Wyoming, Idaho, Utah and Western Montana.
        Just from my observation over the past 30 years that I have paid attention to weather in Idaho, I’ve noticed the milder winters are always wetter. Colder is virtually always dryer.
      • Hi Floriduh,
        Exactly. No one knows. And no one has proved any harm will come from the alleged 1 degree – or 3 degree average increase. They keep asserting that the East Coast will drown under a rising sea. But where’s the beef? It hasn’t done so. They just say so – all the while buying and building mansions by the sea…
      • Hi Nova Saint
        You need to be careful of that. Its not all of the small hat tribe that’s involved in these schemes and scams. Its mainly the Dynasty and their tools. I’ve known a lot of them over the decades. Most are just people. The same as anyone else. Many have natural talents for business and banking. Also keep in mind that Rothbard, one of the main founders of modern libertarianism was a member of the small hat tribe. Judge them by their actions, not their tribe.
  14. Forever wars, forever covid, forever climate crisis, foreve……………………………………………………………………………………….
    It would be funny if there weren’t so many idiots that believed it. This fall and winter we will see the vaccinated lining up for boosters after they see images of death. No matter that the jab didn’t work in the first place. The whole point is to scare the cattle. They will be spooked. Beware the spooked herd.
    • Hi Ancap
      Same as it ever was. No amount of sound reasoning or facts will reach most of these Cultists. They make up about 30% of any given population. Focus instead on the roughly 40% who are in the go along to get along group. That’s the function of Meme Warfare. Its meant to provide jarring disconnects spiced with humor. Also keep in mind that roughly 30% of a given population knows this is all nonsense. But only roughly 10% of that will resist openly. Others will monkey wrench the system from behind the scenes. If you are interested in how this breaks down, look into mass formation psychosis.
      https://unherd.com/thepost/mass-formation-psychosis-gets-a-warning-from-google/
      • Hi BJ,
        I do concentrate on the go along to get along group. That’s what must be done to fix anything. They need to be awakened from their slumber and realize that they need to stop giving in to the bullshit. The problem with the go along to get along types is that they are cowards. When it seems okay to follow the lead of the bold, they will. But as soon as it seems too risky, they’ll stand by and watch the bold get hauled off to the gulag. They are just as quick to do the wrong thing as the right thing.
        That’s why I say beware the spooked herd. Knowing about and dealing with cattle, I realize that all is not lost with the spooked herd, but they must be handled differently and with awareness than when they aren’t spooked.
        The positive thing with this is that they aren’t guaranteed to do the bidding of the elitists any more than doing the right thing. The powers that be must also beware.
  15. Never underestimate the power of envy and the “free shit army”, the Dr. Zhivago analogy is spot on. I’ll always remember the scene where he comes back to his family home and finds it infested with peasants and some self-important commissar scolding him for having so much room. If the time comes that the PTB tries to pull that on me I’ll burn it to the ground first.
    Side note: saw an article (trial balloon?) that the Dems might bring Shrillary out of her coffin to run instead of senile Joe in 2024. As Dave Barry says, you can’t make this up.
    • Hi Mike
      wef/nwo/un/who/.0001% reset
      the plan is to steal, confiscate everything.
      satan claus (klaus schwab) wef says you will own nothing and be happier
      thanks to blackface, biden and all the wef infested governments in all the G7….. same agenda, and the whole wef/ccp/nwo controlled government this is where you are headed within months, soon you are totally screwed:
      NOTE: from a poster at another blog:
      I was talking this morning to a former Vietnamese guy I see at work occasionally.
      His father was a successful engineer in Vietnam under the French and US regimes…..then the communists took over.
      He vividly remembers the day they were visited by the local cadre and his father, mother and all his brothers and sisters were ordered to stand against a wall in their own home as the man read off a statement seizing everything for “the people”.
      Next a lady walked around the house tagging everything of value with colored tape.
      (this is coming everywhere real soon)….
      To be taken later in the week.
      His father was eventually imprisoned and shot…
      He….hates …the….communists.
      He went back once to Vietnam and vows to never visit again, never to invest there….etc.
      I asked him what he thought of Trudeau and his “Universal Basic Income”…..
      He’s glared at me, “He’s an idiot and will ruin this country!”
  16. ‘enshrining the sickness that is communism. That is to say, authoritarian collectivism.’ — eric
    Ape News catapults the J6 gaslighting on behalf of the authoritarian collectivists:
    WASHINGTON (AP) — To understand how Donald Trump’s desperation and lies became a potent danger to democracy, consider the ginger mints.
    Such vehement partisan cant from leftist stenographers is what passes for mainstream [sic] ‘journalism.’
    These are the same folks who ceaselessly lectured us throughout 2016 about ‘inevitable Hillary,’ our locked-in next president.
    Now, as their fraudulent non-player character “Biden” – sore beset with cancer and covid – crashes and burns, these malevolent scribblers are machine-gunning the public with their impotent ideological fury like a mall shooter on SSRIs.
    How low can they go? How many menticidal victims can these nihilistic communist tailgunners claim?
    Smash the media.
  17. Another good article. Eric, I encourage you and your readers to add Manhattan Contrarian to their list of daily reads. He doesn’t post every day, two or three times a week. Always very good articles that actually go along with your articles.
  18. On one hand owning nothing could be very liberating, as opposed to the things you own owning you. When its monkey hammered home by a small tribe intent on owning everything, thats when it becomes no bueno.
    • Hi Norman
      Careful about being too specific about who our real enemy is. Their useful idiots and tools tend to come out of the wood work. After all they are The Chosen…
  19. The entire WEF program is founded upon bald faced lies. The greatest danger to any people is their government that claims authority to kill you if you don’t obey. It matters little if there even is “climate change”, if you are dead. Which is exactly what you might likely be if you resist their insanity. My long standing lack of belief in any organized religion aside, I become increasingly convinced there may be demons among us. This goes beyond simple psychosis or megalomania. Such evil is hard to otherwise explain.
    • Good observation, John. I’m beginning to think that psychopaths are nothing more than demons incarnate–spirits from hell disguised as humans. Disturbingly, that’s the group running the world today.
      • Hi Jim
        Lot of truth in that……..
        elite nobility/un/wef/ccp/.0001% satanist/nazi theocracy
        Psychopathic members of an occult satanic death cult running the planet, planning your horrible future. a satanic cult that believe in eugenics, slavery,pedophilia, transhumanism and fake science.
        wef runs the new bankster/nwo/wef/ccp/.0001% one world government being put in place worldwide right now, this will be your new government. the bat germ hoax is a cover, excuse, trap, to put it in place. an occult satanic death cult run by fanatics.
        some wef history
        the World Economic Forum was co-founded by Maurice Strong, who was the main promoter of the climate change movement.
        the much more exclusive World Forum of 300 which was created by Maurice Strong in 1982 and was co-founded with Klaus Schwab as his assistant.
        Prince Charles hired Schwab to run the WEF.
        Great Reset” Schwab’s son is married to a Chinese woman. The Schwabs are China lovers. The “build back better” part of the great reset agenda intends to turn the west in to China.
        The Origins of the World Economic Forum Go Back to the Third Reich nazis.
        schwab runs the wef his family was connected to the nazis in germany.
        World Forum leaves a blind spot to the alien agenda in the the creation of the plan, the blind spot also leaves out Dr Muller, creator of the UNESCO programs and the Common Core education system.
        Muller and Strong created of the United Nations University at Mt Rasur where they communicate with a demon called Rasur,
        Maurice Strong was creator of Agenda 21 along with his buddies Prince Phillip and Charles and Ted Turner. Someone said Turner put up the georgia guidestones that says the population should be 500 million only. Persons will be coerced through lies, drugs, fear, and pain to surrender themselves, their egos to the collective consciousness.
        The blind spot leaves out the involvement of Nazi German Vril psychics who were involved
        at the Maurice Strong Baca Grande hippie commune where Laurence Rockefeller say’s he met the Devil just prior to presenting the plans to the first World Forum in 1982 in Vail Colorado.
        We don’t associate Eugenics with David Rockefeller, like we do with Hitler, but it was actually the Rockefeller Foundation that first did the research,
        their groundbreaking 1930 work on Eugenics, an idea that became so popular in Europe Hitler monetized it domestically to justify global domination.
        Beginning in 1930 the Rockefeller Foundation provided financial support to the Kaiser Wilhelm Institute of Anthropology, Human Heredity, and Eugenics, which later inspired and conducted eugenics experiments in the Third Reich.
        Rockefeller got his monopoly on drugs, and Big Pharma and Rockefeller Medicine were born – and has only grown bigger and more terrible since, now routinely bribing doctors to prescribe their toxic and side effect-laden pills, not to mention their autism-causing va…cc,,,,,in es
        The nazis adopted it and promoted it. “The infection theories (germ theory) were only established as a global dogma through the concrete policies and eugenics of the Third Reich nazis. Before 1933, scientists dared to contradict this gerrm theory; after 1933, these critical scientists were silenced.”
        now we have the allopathic germ theory nazi medicine used exclusively worldwide and big pharma is the most profitable business on the planet, thanks to pasteur, rockefeller and flexner.
        the modern monetary system is based on keynesian beliefs.
        Keynes is heralded as the guiding light of the New Deal (and, as such defended by modern “Green New Dealers” and Great Reset technocrats wishing to impose a top-down system of governance onto the world),
        This will be seen clearly in 1) his devotion to the theories of Thomas Malthus, 2) his promotion of eugenics as a science of racial purification and population control, and 3) his general devotion to World Government as a leading member of the Fabian Society. The fabians bringing communism to all western countries.
        Depopulation: The provable reality was that Indian famines were coordinated tools of population control by the Malthusian elite of the British establishment who considered “war, famine and disease” as the gifts nature gave the strong to manage the weak.
        read again: “disease” as the gifts nature gave the strong to manage the weak. now the great reset wants to use poisonous inj…ec,,,,ti ons for depopulation.
        Thomas Malthus (a British East India Company economist) stated in his famous 1799 Essay on Population:
        “The power of population is so superior to the power in the earth to produce subsistence for man, that premature death must in some shape or other visit the human race.” gates wants to use in…jec,,,,,ti ons.
        “We should facilitate, instead of foolishly and vainly endeavoring to impede, the operations of nature in producing this mortality; and if we dread the too frequent visitation of the horrid form of famine, we should sedulously encourage the other forms of destruction, which we compel nature to use. In our towns we should make the streets narrower, crowd more people into the houses, and court the return of the plague.” today: herding the useless eaters into large cities.
        In his May 2, 1914 lecture Population, Keynes argued that government should “mould law and custom deliberately to bring about that density of population which there ought to be” and that “there would be more happiness in the world if the population of it were to be diminished.”
        now the gates led nwo/ccp/wef globalists are saying after great depopulation reset you will own nothing and be happier.
        Hit…ler himself was not only a devout eugenicist (whose racial purification policies emerged through the funding of the Rockefeller, Carnegie Foundations as well as British establishment), but was also a devout Malthusian saying:
        “The day will certainly come when the whole of mankind will be forced to check the augmentation of the human species, because there will be no further possibility of adjusting the productivity of the soil to the perpetual increase in the population.”
        now gates is saying the same thing, dep op…ul,,ation is good.
        After the war, eugenics-promoting organizations and think tanks changed their names while continuing their work, morphing into new forms by the 1960s such as the
        NOTE :environmental movement, transhumanist movement, including the pharmaceutical/healthcare sector. now we have the wef pushing this with the great reset.
        bat germ religion/climate change/depopulation agenda………it sounds a bit like The church of euthanasia: The church of euthanasia “devoted to restoring the balance between Humans and the remaining species on Earth. “Save the Planet, Kill Yourself”
        the climate change/global warming hoax is an excuse for a cull. the satanists will do it with their cull of useless eaters, they already warned you of the dep..op,,ul ation agenda, there was silence, that is implied consent, the cull progresses.
        Get this: the two top psychos that are administrators for the banksters, gates and soros, have no education, they are morons.
        The psychos running the planet: Mt Rasur where they communicate with a demon called Rasur.
        the pope is part of this cult.
        The government/church/medical system is just a huge occult satanic death cult now
    • Hi John
      The new olympians, the guardians, that is what the globalist/satanist/one world government/wef/un/nwo trash call themselves, the new gods.
      The control group at the top of the world pyramid of power are satanists, they are deep into the occult, this is very dangerous, you will end up possessed with demons.
      These monsters think/say they are the new gods, a long time ago there was a warning about an antichrist taking over, the antichrist is multiple as in antichrists, there is 3000 monsters at the top controlling this reset, they are the antichrists, replacing a good god, with satan.
      politicians are controlled by this control group at the top, they are satanists, the politicians are now possessed
      the government/church/medical system is now one huge globalist/communist/satanic occult cult
      need to hire this priest
      a priest in rome said if these elite nobility/wef/ccp/.0001% globalist demons had been around in the middle ages, they would have been hanged, he says they would have been immediately seen as evil demons. today we are blinder, dumber. these leaders are deep into satanism they are all possessed, should be turned over to that priest to deal with.
      https://www.zerohedge.com/news/2022-04-08/video-its-time-consider-possibility-western-leaders-are-literal-demons
