2025 Buick Enclave
12
3947
Here’s an interesting fact: The biggest Buick you can buy today comes with the smallest, strongest engine Buick ever put in its biggest model.
That model being the 2025 Enclave – which is nearly as long an old Electra 225 from the ’70s but isn’t a sedan and does not come with a 455 cubic inch (7.5 liter) V8.
The Enclave is a full-size/three-row crossover that’s related to the Chevy Traverse and the GMC Acadia. It’s a little nicer – and pricier – than those two, in keeping with its being a Buick and thus just shy of a Cadillac in GM’s prestige/pricing hierarchy.
It also no longer comes standard with a 3.6 liter V6 engine – as it did last year. That engine has been retired in favor of a much smaller (2.5) liter turbocharged four cylinder engine that makes 18 more horsepower (and much more torque).
Prices start at $45,000 for the Preferred trim, which is front-wheel drive. AWD can be added as an a la carte option for $2,000.
There are also Sport Touring ($47,000) and top-of-the-line Avenir ($58,000) trims, both of which also come standard with front-wheel-drive with AWD available optionally for $2,0000.
Though technically not-quite a luxury brand, this Buick can be compared with other three-row crossovers offered by luxury brands such as Audi’s Q7 and Acura’s MDX because it is similarly laid out and equipped while being much less pricey.
What’s New For 2025
The Enclave gets a major makeover for the new model (and calendar) year, including a restyled body and interior with a massive (30 inch) curved LCD touchscreen as its centerpiece – as well as a new standard engine.
GM’s SuperCruise self-driving feature is also now available.
New turbo four makes more power – and uses a little less gas – than previously standard V6.
This crossover’s standard 5,000 lb. tow rating is among the highest you’ll find shy of an SUV.
Larger, stronger – and roomier – than much costlier three-row luxury-brand crossovers such as the Audi Q7 ($60,500 to start) and Acura MDX ($51,200 to start).
Standard four lacks the prestige of a six (which is still standard in the MDX).
Buick lacks the prestige of Audi and Acura.
A plethora of “driver assistance technology” is standard – meaning you can’t skip all this “assistance.”
The Enclave formerly came standard with what used to be expected in a large crossover – a V6 – because you used to need at least a V6 to adequately propel a vehicle like this, which seats seven in three rows and weighs 4,537 lbs. before any of those seven people climb aboard.
For reference, a ’70s-era Buick Electra, which could seat six in two rows (because it had three-across bench seats) weighed about the same – and it came standard with a huge V8. Because how else were you going to move all that weight adequately?
Of course, V8s use a lot of gas to move all that weight – and that is one reason why big V8s are all-but-gone (exceptions include a few big SUVs and the big trucks they’re based on). A relatively big V6 also uses a relatively large amount of gas  . . .  relative to a small four. And that’s why the Enclave’s new engine is a 2.5 liter four – goosed by a turbo – in lieu of the previously standard 3.6 liter V6.
It doesn’t use that much less gas, though.
The EPA says the front-drive version will go 20 miles-per-gallon in stop-and-go “city” driving and 27 miles-per-gallon on the highway. That’s a little farther than the V6-powered ’24 Enclave could go  – 18 city, 26 highway – but it’s not a big enough difference to understand why the V6 was ditched in favor of the four. The main reason being gas “emissions” – of carbon dioxide. Here the four offers a significant compliance advantage vs. the V6 because when not under boost, the smaller four is not “emitting” as much CO2, because there is less gas filling its fewer smaller cylinders. When it  is under boost, of course, the volume of gas “emitted” increases – but that doesn’t matter insofar as compliance, which is what’s driving all this engine downsizing.
There’s also an upside – for the buyer – in that when it is under boost, the Enclave’s new turbo four makes more power than the old V6. Horsepower is up to 328 (from 310 previously) and torque is way up (to 326 ft.-lbs. vs 266 ft.-lbs. previously).
This is much more standard horsepower (and torque) than comes standard in the Audi Q7 (which comes standard with a smaller 2.0 liter four that only makes 261 horsepower) and also vs. the Acura MDX, which still comes standard with a 3.5 liter V6 but one that only makes 290 horsepower.
The Buick also out-pulls them both, with a standard 5,000 maximum tow rating, which is sufficient to handle a medium-small RV. The Audi is rated to pull 4,400 lbs. and the Acura just 3,500 lbs.
As mentioned up above, the Enclave is based on a FWD, car-type layout that’s similar to the way the Q7 and MDX are laid out. AWD is available optionally in all trims (it’s standard in the Q7 and optional in the MDX).
A new eight speed automatic transmission replaces the nine speed automatic that was previously paired with the V6 – probably because the new turbo four is a lower-RPM engine than previous V6, meaning it doesn’t need as many upshifts to keep the engine in the sweet spot of the powerband.
The increased power of the Enclave’s new smaller engine is readily apparent, especially in stop-and-go driving. The increased torque – which is what gets a vehicle moving from rest – being responsible for that. Put in plainer terms, you get more response with less apparent effort. Last year, it was necessary to floor it to get moving quickly. Now halfway-to-the-floor will do the same – with less revving (and shifting).
But the absence of the six is also apparent – because you can hear what’s no longer there. When pressed, the turbo four sounds small, because of course it is. Four cylinder engines are by no means bad engines. But they do sound like four cylinder engines and the sound is a little incongruent with the size of this Buick.
On the other hand, it is much quicker (zero to 60 takes about 6.7 seconds) than a ’70s Buick dreadnought such as the Electra, which had an engine nearly three times as large. that had twice as many cylinders.
Power, then, is not the problem. Nor performance.
Perception may be.
Buick wants to be regarded as a luxury-vehicle brand but four cylinder engines in luxury priced vehicles are kind of like paying ribeye money to get a really good hamburger. Not that there’s anything wrong with a really good hamburger. Then again, Audi is certainly regarded as a luxury brand and most of its offerings come standard with fours that are smaller and less powerful than this Buick’s four.
There are two things that could be done to address the perception problem, though. One being to augment the sound of the four – as many other manufacturers are already doing. But there’s a cheesy feel to that sound. How about some authentic turbo whistle instead? It doesn’t need to be loud – just noticeable when the engine is under boost, as when the accelerator pedal has bee floored. That sound is both real and impressive. It could make up for the sound of the six that’s no longer there.
Being a Buick, the Enclave’s ride is tuned to be softer than the “sportier” (firmer) feel you get in luxury-sport crossovers such as the Q7 and the MDX. This being a plus, if you enjoy feeling the road less on your way to work and back.
You will read other reviews of this model that fault the Enclave for not being as adept-feeling during high-speed cornering. But that is like expecting a milkshake to help you lose weight. If you want high-speed cornering adroitness, why would you be shopping a Buick?
The Enclave is Buick’s largest current offering – and it’s now larger than it was last year.
The outgoing model was 204.8 inches long; the new model is 207.6 inches long. That is not quite as long as the largest (and longest) Buicks of the past, such as the Electra 225 of the ’70s – but it’s not a lot less, either.
It is also not a little bit longer than both the Audi Q7 (199.3 inches) and the Acura MDX (198.4 inches). Those two being closer to mid-sized than full-sized. The difference is most apparent when you sit in the third rows of all three of these models. The Buick’s third row has legroom sufficient to allow adults to sit back there rather than just kids.
You also get class-most cargo space: 22.9 cubic feet behind the Enclave’s third row and 97.5 cubic feet with the third and second rows stowed. The Q7 has just 14.2 cubic feet of space behind its third row and only 69.6 cubic feet of total available space. The MDX is closer, with 18.1 cubic feet of space behind its third row and 95 cubic feet total.
But it still costs $5,200 more to start than the Buick does. You pay more to get less, in other words.
Something else you get (also for less) is a truly massive curved glass, trapezoidal LCD touchscreen that encompasses both the main instrument cluster and the interface for the vehicle’s infotainment systems. It looks much less afterthoughty than the Pop Tart-looking tablets that perch on top of the center stacks of many other crossovers.
On the upside, it does look less afterthoughty.
It’s a cleaner, more integrated look. On the downside, it’s a smartphone-emulating interface that effectively requires looking at the touchscreen to be certain you’re tapping the right icon. While knobs and switches and buttons may look very 20th century, no one has yet improved upon the superior functionality of these interfaces, which can be operated by feel without needing to look.
A very good 12 speaker Bose stereo is standard; in some of the others, a very good stereo is an extra-cost option. If you want a system that’s better than very good, the top-of-the-line Avenir comes standard with a 16 speaker system.
Avenir trims also come standard with enormous (22 inch) wheels, which are more for looks than the usual sharper/quicker steering feel that one gets with tall wheels shod with short sidewall tires. Other trims come standard with 20 inch wheels but if you want the look of the ’22s, they’re available optionally.
Don’t, by the way, be fooled by the Sport Touring trim. It’s meant to look sportier – but it’s still as soft and quiet-riding as the other trims.
While the Enclave does come standard with a 5,000 lb. max tow rating, to pull that much without voiding your warranty, you’ll need to spring for the $650 Trailering Package, which bundles heavy-duty cooling with a trailer hitch and Buick’s Hitch Guidance closed-circuit back-up camera system.
Also available is GM’s SuperCruise self-driving system ($3,730) which is similar to the AutoPilot system available in Teslas and other luxury-brand vehicles that have self-driving capability.
Maybe smaller can be better – even in something that’s pretty big.
12 COMMENTS
  1. Hard to find buyers of new autos when the plethora of cars for sale websites sell cars from four thousand to five thousand dollars and you know that the car is going to be a better choice than anything new as long as it is good shape. You can buy two of them and save many thousands.
    After reading about the latest edition of the Buick Enclave, you think about a V-6 engine in one of the things and go from there.
    A 2005 Buick LeSabre is going to enter the far recesses of your cerebellum. 3800 reasons to buy one of the old ones.
    Out with the new, in with the old.
    Just who in the hell do these car corporations think they are?
    They’re not going to do much of anything if they don’t straighten up and fly right. They might as well quit before it all falls down.
    Pride goeth before fall. Gonna be their fault, when the gov tells you what to do, tell those guys to go get drunk.
    David Buick would walk into the corporate offices at GM and fire them all.
    David Buick would fire Donald Trump.
    It has to stop, the wars first.
    • Heck yes, I’d replace my Toyota “Buick” (Avalon) with another given its V6 & 6-speed tranny.
      Rather than buy anything turbo-charged or with a 10, 11, or 12-speed tranny.
  2. it’s a smartphone-emulating interface that effectively requires looking at the touchscreen to be certain you’re tapping the right icon.
    On January 1, Colorado LEOs will begin ticketing drivers with cell phones in their hands as a secondary offense. So if you’re speeding and the cop sees you holding a cell phone, you’ll get an extra $75 charge on your ticket.
    “To get a citation, a law enforcement officer must see the driver using a cellphone in a manner that causes the driver to be ‘careless and imprudently.'”
    What happens when you’re driving a rental Buick and are fumbling around looking for the HVAC adjustments? Or trying to figure out how to mute the stereo while looking for an address? I say rental because you’ll probably develop some sort of muscle memory after a few weeks of driving it, but if you’re only in it for a few days probably not.
  3. Friend of mine’s dad had a ’92 Roadmaster with the tbi 5.7.
    For zero reason than the LT1 becoming standard power in ’94, he convinced his father to trade in the ’92 for a brand new ’95.
    Old man didn’t really care and was like “yeah, this new one has a lot more pull.”
    Thankfully when my buddy would borrow and return it, his dad wasn’t checking the tread depth on the rear tires.
    Those days of building amazing RoadBlasters – or even the dead-nuts reliable SI/SII 3800 LeSabres – are too far in the rear view now.
  4. What draws me to this more than other look alikes?
    Sure, cheaper than the comparables Eric mentioned, but what draws me to them?
    Large vehicles with small engines seems cheap. Like watching a Broadway play sitting on the floor.
  5. As you’ve pointed out countless times Eric, they now all look the same. Same angry, overwrought face. All “Angry birds.” How in the hell does that look make anyone think Buick?
  6. ‘a massive (30 inch) curved LCD touchscreen as its centerpiece’ — eric
    Sha-ZAY-um! That’s like finding your Florida dream house, pre-equipped with a whole phalanx of plastic pink flamingos in the front yard. Sahara of the Bozart, as ol’ H. L. Mencken used to say.
    When it comes to tow ratings, I figured they were making this stuff up — whatever they could get away with. But I am relieved to learn that an SAE standard governs these ratings:
    ‘The Davis Dam test requires the vehicle to climb the grade on Route 68 between Bullhead City and Golden Valley, Arizona, a climb of 3,500 ft in 11 miles, starting at 100 °F, with the air-conditioning on full.’
    https://en.wikipedia.org/wiki/SAE_J2807#
    I’ll never be your beast of burden
    My back is broad but it’s a-hurting
    All I want is for EeeVee Mary to leave
    I’ve walked for miles, my feet are hurting
    All I want is for EeeVee Mary to heave
    — Rolling Stones, Beast of Burden
  7. I remember my grandparents being so proud when they got a Buick in the late 70s. That’s the extent of my experience with Buick. Is it still all the rage in Chyyyyyna?
    • When we were kids, my white-shoe bankster uncle Tom gave us a ride in his mid-Fifties Buick Roadmaster.
      To my nine-year-old eyes, the big flat floor space between the front and back seats appeared to be about five feet wide, with a surprisingly small transmission hump. This walk-in closet sized expanse made our full-size Chevy station wagon seem cramped by comparison.
      Does heaven have vintage cars? I’m envisioning uncle Tom at the wheel of his Roadmaster, chauffeurring Tall Paul Volcker ’round them elysian fields in that huge back seat, as Paul avails himself of another fine seegar and blows a big smoke ring out the hand-cranked window.
