2025 VW Jetta GLI
28
5827
Remember when what was once commonly referred to as a standard – that is, a manual – transmission – was  . . . commonly standard? And automatics were generally optional, with the exception of luxury brand (and “loaded”) vehicles?
Fast-forward to the present. It isn’t easy to find a manual transmission as an option – in anything. Even the Corvette is automatic-only now.
But if you still prefer to shift for yourself, there’s one car that still comes standard with a manual and the really unusual thing about is that it’s a sedan.
The Jetta GLI is the high-performance version of VW’s Jetta sedan. The latter comes standard with a 1.5 liter four cylinder engine that makes 158 horsepower and only with an automatic transmission. The GLI comes standard with a larger – and much stronger – 2.0 liter engine and a standard manual transmission. A performance-calibrated seven speed (DSG) automatic is available as a no-cost option.
The price for a Jetta GLI equipped with either transmission is $32,715.
All GLIs are front-wheel-drive.
There are slim pickings when it comes to rivals. They include the Hyundai Elantra N – which comes standard with a manual and a stronger engine and significantly lower fuel economy  as well as a higher MSRP ($34,250 to start) and the Honda Civic Si, which comes also standard with a manual and a smaller MSRP ($29,950) but also a smaller engine and less power.
And without an available automatic, if you prefer not to shift for yourself.
What’s New For 2025
The GLI gets new-look front and rear clips as well as a standard glass-faced 8 inch LCD touchscreen. Also, the previously optional Autobahn package – which bundles a limited slip axle, sharper steering, upgraded brakes, an adaptive suspension with driver-selectable modes plus luxury amenities such as a panorama sunroof, heated leather seats and a heated steering wheel – is now standard.
The downside – if you’re on a budget – is that the ’25 GLI is now several thousand dollars more expensive than it was last year – when you could get the GLI’s essentials (the high-performance engine, the manual transmission) without all the extras for $28,085. That low entry price point gave the 2024 GLI a big competitive advantage over the stronger but much pricier Elantra N.
It was also more competitive with the Civic Si – which is now the only one of the three you can still buy for less than $30k.
Standard manual transmission is something that’s getting hard-to-find even in performance  cars
A sleeper. It’s speedy – but doesn’t look it.
Though technically a compact-sized sedan, the Jetta GLI has about as much room inside – especially in the rear – as many mid-sized sedans.
Autobahn equipment is nice to have – if you can afford it. If you can’t, then you cannot afford the GLI anymore.
Elantra N is now only a little bit more expensive – and a lot more powerful.
Glass-faced touchscreen is sensitive to inadvertent touching.
The GLI comes standard with a turbocharged 2.0 liter four cylinder engine that produces a maximum of 228 horsepower and 258 ft.-lbs. of torque. It is basically the same engine that powers the VW GTI – which is the hotted-up version of the VW Golf five-door hatchback. In the latter, the output of the 2.0 liter engine is a little higher (241 hp) but both VWs can get to 60 in about 6 seconds – or even sooner.
The word are italicized to highlight something interesting about these VWs, which is that they are quicker when equipped with the available seven speed automatic.
So equipped, the Jetta GLI can make the 0-60 run in about 5.6 seconds. With the six speed manual, it takes about six seconds – a significant difference in quickness that can be attributed to the automatic’s ability to shift quicker than the manual can be shifted by most humans. The automated manual’s got dual-clutch internals (that’s why it’s called an automated manual) that allow for lightning quick up (and down) shifts that only a few human drivers could replicate consistently.
On the other hand, the manual is arguably more fun – about which more follows.
Also interestingly – the manual-equipped GLI touts the highest gas mileage: 26 city, 36 highway vs. 25 city, 35 highway for the DSG-equipped version. It is interesting because it’s unusual in that most manual-equipped iterations of a given car usually tout lower gas mileage and that is one of the main reasons why manual-equipped cars – including even sporty cars – are becoming harder-and-harder-to find.
Not so much because potential buyers are turned off by the slightly lower (typically) gas mileage numbers but rather because the manufacturer is punished – by the government – for selling vehicles that get lower rather than higher mileage. Even a 2-3 MPG difference matters a lot when it comes to compliance with federal Corporate Average Fuel Economy (CAFE) mandatory minimums and automatics have the great advantage of being programmable – to perform best on tests – while manuals only perform as well as the human doing the shifting.
Also interesting is that the VW’s mileage – with either transmission – is significantly higher than the Elantra N’s with either of its available transmissions. The manual-equipped version rates just 21 city, 29 highway. This is understandable given the Elantra N’s stronger (276 horsepower) engine. But it does mean the Hyundai’s both more expensive to drive – and to buy.
The Civic Si beats them both, with class-highest gas mileage: 30 city, 38 highway (with the manual six speed.
But that’s the only transmission you can get with this model.
The GLI carries on the tradition that began some 40 years ago – when VW first offered a hotted-up version of the Rabbit (which became the Golf) called GTI, riffing on the famous Pontiac GTO (which riffed on the Ferrari GTO). The idea – in  both cases – was to take a grocery getter and make it capable of getting the groceries a lot faster. Thus making the getting of groceries a lot more fun.
The standard manual transmission is a key element. It is hard to not harp on that enough because it is that important. Automatics take away from the interactivity of driving, which is part of the fun even in a car that isn’t hotted-up.
Economy cars used to be at least entertaining to drive because they used to always come standard with a manual. Playing with the stick and clutch gave you something to do. They felt faster, too.
Now they are all as boring to drive as riding an escalator. Push the gas pedal down and it goes – and that’s pretty much all there is to do.
it is not fundamentally different in an automatic-equipped performance car. It goes faster – but in the way of a faster-moving escalator. You just stand there – or sit there – and are moved from A to B. Quickness of movement can be fun but it becomes less so when that’s all there is to it.
In a car like the Jetta GLI – with the manual – there is much more to it. As anyone knows who already drives stick. It’s not just the shifting for yourself  – the deciding when to shift and how forcefully – but also the syncopation of the footwork, which is a kind of dance and one that can be elegant when done skillfully. And – the important thing – it is you doing the dancing, which is a very different thing than watching it being done by a machine controlled by a computer.
Cars are so over-controlled now that having this kind of control over a car is almost like getting yard time when in prison. You feel the exhilaration that comes from not being confined. You can walk this way – or that way. Faster – or slower. This is freedom – and it’s what you experience when you work the Jetta GLI’s shifter.
And pedals.
Turn off the traction control and you can skitter the tires, too – which you can’t do in an AWD performance car such as the Subaru WRX. The latter touts superior grip – which is incontestably true. But unless you’re actually racing – and every tenth of a second counts – it’s still more fun, arguably, to skitter the tires and leave a little rubber on the road and some smoke in your wake.
There is one thing, however, that takes away from the fun. As in literally. Because there is something fun that’s missing. That thing being a manual emergency brake. A handle you can pull up to lock the rear wheels – on purpose – in order to spin the car around or make 90 degree power-sliding turns. That kind of fun has been eliminated via the replacement of the pull-up emergency brake lever with an electric parking brake button.
VW did this, no doubt, not to stifle the fun but to save some money. It costs less to plug-in electronics as a car is assembled than to have a worker install cables and make fine adjustments.
But there’s still fun enough to make up for the loss.
The Jetta GLI looks pretty much like a Jetta – and that’s a good thing. It’s tasteful but not attention-drawing, which is very good if you like driving the way a GLI was meant to be driven. It is one of the finest sleepers out there – now that the Toyota Camry (which was the greatest of the bunch) is no longer available with the V6 that made it quicker – and faster – than a ’60s-era GTO.
It’s also something else.
Though classified as a compact sedan, the Jetta’s a mid-sized sedan on the inside. It has 41.1 inches of legroom for the driver and front seat passenger and 37.4 inches of rearseat legroom – as well as a 14.1 cubic foot trunk. Compare those stats with the 2025 Camry – which is 193.5 inches long (vs. 186.9 inches long for the VW). It has 42.1 inches of front seat legroom and 38 inches of backseat legroom – a distinction without much difference. The mid-sized Camry’s 15.1 cubic feet of trunk space is only slightly greater, too. But the difference in footprint is big enough to make a noticeable difference when trying to park curbside.
As mentioned, the Jetta GLI is now offered in just the one (loaded) Autobahn trim, which in addition to the performance equipment (upgraded brakes, adaptive suspension, etc.) bundles heated and ventilated leather sport buckets, LED headlights, ambient interior lighting and a very good Beats premium audio system. These combine to make the GLI a kind of budget-performance alternative to the Audi A4 – which is a cousin of sorts as VW is to Audi what Toyota is to Lexus. The A4 is similar in size (187.5 inches) and shape but has a much less roomy back seat (35.7 inches) and a smaller (12 cubic feet) trunk. It does come standard with a more powerful 2.0 liter engine (paired with a hybrid system) and AWD is standard – but so is a base price of $44,100.
And that won’t get you a manual transmission – which isn’t available with the A4.
The updated 2025 GLI comes standard with a glass faced 8 inch touchscreen that looks higher-end than the usual plasticky pop-tart thing erupting from the top of the dashboard. There are also manual tuning and volume knobs built into it, which allows adjustment without tapping/swiping. But it’s also easy to inadvertently touch the screen while turning the knob, which can cause the system to make changes you didn’t want – such as switching from satellite radio to FM.
The Jetta GLI is one of just a small handful of sedans you still get to drive – as opposed to being driven.
28 COMMENTS
  1. “That kind of fun has been eliminated via the replacement of the pull-up emergency brake lever with an electric parking brake button.”
    Lame. Even my old Peugeot had a brake lever, which made for some great slides on dirt roads.
  2. Lately there seem to be sounds from Washington, D.C. suggesting that many of the emissions rules will be rolled back or eliminated. If that occurs, might we see a resurgence of offerings of manual transmissions on a far broader range of cars, as well as a redeployment of simpler (fewer speed) automatic transmissions — and perhaps far fewer or no CVTs? And maybe some lower prices to reflect the removal of some of the unnecessary complexities? I gather there is also talk of some of the car import restrictions possibly being removed.
  3. Re: E-emergency brake.
    Just another thing that won’t work in 10+/- years in the rust belt. Granted even the manual handbrakes with a cable would freeze/rust up too, but pretty easy to replace. Now with the e-brake, you’ll switch it on, and it won’t come off, or stuck. Big repair.
    Just another e-device outside in the elements, and why I personally won’t own a car older than 10 yrs old in the rust belt.
    We were just driving before the ‘storm! OMG!’, and they were dropping amazing amounts of salt on the interstate about 6hrs before the ‘storm!’. The salt was turning to dust, and we were driving in a salt fog. not kidding. My poor cars ‘everything’ being coated in this corrosive stuff everywhere.
  4. So many nice cars out there. I wish I had Jay Leno’s garage. Unfortunately I only have a two and a half car garage. Itz dangerous to park a car outside in my area. Itz not just garage space but itz also state and local licensing plus insurance. Life and socializing is getting expensive. And along with the de-valuation of the currency pretty soon America will have many, many millionaires. Soon it will be time to reset the currency by getting rid of some of the zeroes.
  5. After Loper-Bright. The car companies need to grow same sack and refuse to comply.
    Had VW had any actual men in charge during the governments diesel scam they could have spent a tiny fraction of what it cost them to throw themselves at the mercy of a court who doesn’t believe in mercy.
    • So true. I’m pretty annoyed at VW for not having the balls to just tell everyone to piss if, that the electric vehicle thing is a scam and the VWTDI motor one of the best motors on earth. Fuel economy was unbelievable and it was fun to drive (I always drive a manual one). No way were those small diesels ever putting out enough emissions to hurt anyone ever.
  6. We have a 2016 GLI, the first year after Volkswagen got caught “cheating”.
    I drove from Nashville to Austin on two tanks of gas in the Jetta.
    After filling up outside Little Rock, once I got back on the highway, the range indicator showed that I would make it home with 30 miles to spare.
    When I arrived in Austin, the range indicator showed I had 70 miles left.
  7. The thing about a Manual Handbrake is not locking the rear wheels or swinging the rear of the car around, it’s being able to use it to sit at a traffic light without your foot on the brake and irritating the driver in back of you. Also, on a hill, it allows you to smoothly drive away. Replacing rear pads is easier and cheaper as well.
    I had an Audi A3 with an Electric Handbrake (with Hill Holder) and never could get the knack of effortlessly driving away while headed upward on a hill. I had the car one year and the Handbrake was one of the main reasons I got rid of it.
    • ‘it’s being able to use [the manual handbrake] to sit at a traffic light without your foot on the brake and irritating the driver in back of you.’ — Doug
      Precisely. A manual handbrake in the center console is a simple, functional, intuitive design. Frequently I use it for hill holding. Releasing the handbrake while engaging the clutch is about as difficult as learning to walk and chew gum at the same time.
      But the ‘cell phone on wheels’ design philosophy is that physical coordination should not be required — indeed, is a nuisance; everything should be automated. Fundamentally this is un-ergonomic. Humans enjoy tasks that can be executed by muscle memory after learning them. Arts, crafts, dancing, shooting, sports: that’s why we do them.
      Taking these manual functions away from us is a malicious assault on our well-being and quality of life. The drones who design all these soulless electronics lack any insight into the emotional connection between a driver and a vehicle that requires modest manual skills to operate. I feel no more affinity to their chip-controlled appliances than I do to a fresh dog turd deposited on the sidewalk.
      • In the year 5555
        Your arms hangin’ limp at your sides
        Your legs got nothin’ to do
        Some machine’s doin’ that for you
        — Zager & Evans, In the Year 2525
        They don’t get it.
        • In the year 1955
          While you could still be alive
          You could drive your car near and far
          Now all you can do is drive to the bar
          All your car will do for you
          It’s not up to you
          In the year 2024 it’s all car jive
          You’re lucky to be alive
          The Zen of Zager and Evans and all apologies.
          Elon controls every Tesla, not you or anyone else.
          Watch Whislindiesel’s Cybertruck vs Ford F-150 test #2, hilarious.
          10 million threatened lost souls in every Los Angeles greater metropolitan metropolis doesn’t look all that good.
          If any finger-pointing needs to be done, point one at Bibi, a culprit no matter where he is.
          Thou shalt not kill, one of those commandments, abide by it.
          Screw your commandments says rat-eared Bibi.
          The genius Johnathon Goldratt says to attack anti-Semites, the Untermenschen that they are.
          Los Angeles must have been a prime target, me thinks.
          The Jews can kill anybody they want, Palestinians don’t care, it is more sport than revenge now to kill Jews.
          Screw your rights says the dumbass Arnold.
          Rights? You want rights? You don’t need no stinking rights!
          Burn them down.
          It is the worst of the worst.
          Dresden 2.0
  8. Eric, the ID Buzz is a quintessential sleeper, for a minivan. It is stupid fast, very planted, and very “green” for the tree-huggers.
    Unfortunately, it is extremely expensive (60-70 grand) & impractical, as a pure electric device. As a hybrid, either diesel or gas, however, it would be a truly realistic ride option to haul people and stuff.
    Just my two bits…the short trip I had last summer in one was a complete blast of a carnival ride, and the two liters of German beer certainly helped!!
    • I still have a blast driving our 1987 VW van. Good thing too, can’t afford the new one and what about those lithium batteries . . .
  9. Today I read the last sentence and worked to the beginning paragraph. It’s a lot of words. A dream car as they say.
    The Green Dream is over, especially in Los Angeles.
    The EV dream is kaput. Doesn’t hold any water, the EV cult is all wet, all bunkum and bosh.
    Fire in LA has created apocalyptic conditions which are going to result in an exodus. Gotta find new digs.
    We gotta get out of this place – The Animals
    Los Angelinos will need a car, theirs are gone.
    Ship the GLI’s to LA. The market is going be hot there.
    • The market is going to be hot. Fix a typo now and then.
      An EV with nowhere to charge it is going to make everything a chore.
      Your house is ashes, no electricity, no shelter, no food, no clothing, you are wearing what you have, no place to go, you are now displaced.
      It all makes you feel bad for them, no matter how much they don’t have anymore. Even if they have millions to spend, it is all bad. Empathy, word of the day.
      I digress.
      An ICE vehicle with four wheels with gas in the tank will be a no-brainer to have, if you are making good decisions.
      Fire Shock! Post-traumatic Stress Disorder, Stockholm Syndrome all over again, have some sympathy for those in charge, now Los Angeles Syndrome. Robbed of everything, not by malicious intent, just plain stupidity.
      Not doing the job they were hired to do, first mission is fire prevention, nothing else.
      There is an excuse for ignorance, but not for stupidity.
      Make it a Tequila Sunrise, you’ll feel better.
  10. Great review Eric
    Love the GLI as well, remember getting a solo test drive 13yrs ago in a manual and getting a call back for an interview, little car inadvertently led to me getting hired, I just wish I was in a position to buy one then.
    Glad unlike the GTI, you can still row your gears here. Hopefully things change course coming up, GTI needs a stick again and they gotta cancel this EV only crap now that Orange Man’s back dismantling their crap
  11. Great review. I would absolutely drive this one!
    I have a soft spot for all things Jetta. My wife drove a 2010 Wolfsburg manual for years until we gave it to the kid, who drove it a bunch more years until he got his Taco. Absolutely bulletproof and surprisingly fun to drive. Decent fit and finish, too.
    Nice that they skipped the hybrid, too.
    Thanks, Eric!
      • Current body style is nice too. I like it almost as much as my mk4 Jetta wagon. With the TDI longevity, I don’t need a new car but would certainly consider this GLI Jetta if I were in the market.
        • H Jetta,
          I agree! I really wish, though, VW still offered a TDI/manual iteration. I drove several when they were available and they were incredible. Fun to drive (immense low end torque) and extremely long legs, too.
    • Had a B7 A4, FBO and stuff, solid and reliable. Miss it, but also enjoying my Bronco, always wonder how its doing though.
      Deja Vu all over again with these VAG’s
  12. Back in 2010 VW engineers, knowing that the Jetta for the 2011 model year was going to cut corners in suspension and drivetrain, came out with the TDI Cup Edition. This was a seriously souped up Jetta TDI with bigger brakes, tighter suspension and oversized tires. It was also a sleeper, except maybe for the “cup edition” graphics on the side.
    I wonder what VW’s accounting department has in mind for next year?
    • Hopefully with Orange Man and Orangism spreading throughout the global, this EV craze will be staked like a vampire.
      Feel when people overthrow these installed leaders, a lot of things will improve and there’ll be a massive course correction
