Thread: Yamaha FZ1 Fazer in Greece, up to 277kph.
    3,416
    The sheer performance of some of the modern 'All Rounder' bikes is, compared with a few years ago, quite astounding. Anyone wanting high performance, without the (long distance) discomfort of a modern crotch-rocket, might well consider something like the Yahama FZ1 Fazer shown in the clip below.
    http://uk.youtube.com/view_play_list?p=C3C6419EDF06FA73
    Engine
    Type 998cc liquid-cooled inline 4-cylinder; DOHC, 20 valves
    Bore x Stroke 77 x 53.6mm
    Compression Ratio 11.5:1
    Carburetion Fuel injection
    Ignition Digital TCI
    Transmission 6-speed w/multi-plate clutch
    Final Drive O-ring chain
    Chassis
    Suspension/Front 43mm fork; fully adjustable, 5.1-in travel
    Suspension/Rear Single shock; adjustable preload and rebound damping, 5.1-in travel
    Brakes/Front Dual 320mm floating discs w/4-piston calipers
    Brakes/Rear 245mm disc w/single-piston caliper
    Tires/Front 120/70-ZR17
    Tires/Rear 190/50-ZR17
    Dimensions
    Length 84.3 in
    Width 30.3 in
    Height 47.4 in
    Seat Height 32.1 in
    Wheelbase 57.5 in
    Rake (Caster Angle) 25.0
    Trail 4.3 in
    Fuel Capacity 4.75 gal
    Oil Capacity (with oil filter change) 3.8 L
    Dry Weight 439 lb
    22,732
    Re: Yamaha FZ1 Fazer in Greece, up to 277kph.
    "The sheer performance of some of the modern 'All Rounder' bikes is, compared with a few years ago, quite astounding. Anyone wanting high performance, without the (long distance) discomfort of a modern crotch-rocket, might well consider something like the Yahama FZ1 Fazer shown in the clip below."
    It is amazing, isn't it?
    My '76 Kz900 (essentially a Z1900 - which was the first large cc "superbike," as you know and the quickest/fastest thing on wheels in the mid 1970s) was only capable of 12 second quarter miles and topped out at around 134 mph.
    By today's standards, the Kz is slow.
    Virtually any 1,000 bike today can do at least an 11 second quarter - with top end close to 150 mph. Supersports are in the 9s - with top speed over 170 mph....
    This is one occasion where I will say hooray! for progress!
  1. Greece
    By chiph in forum Survival/Economic Collapse
    Last Post: 06-17-2011, 04:08 PM
  2. Greece's troubles and the US... a taste of what's coming?
    Last Post: 05-14-2010, 07:49 AM
  3. Will America go the way of Greece?
    Last Post: 05-10-2010, 05:51 AM
  4. 2009 Yamaha YZF-R1.
    By Ken in forum On Two Wheels
    Last Post: 11-01-2008, 10:11 AM
  5. '07 Yamaha R1 specs
    Last Post: 12-05-2006, 09:05 AM
