Results 1 to 15 of 15
Thread: GM cost-cutting
    GM cost-cutting
    GM is famous for the cost-cutting that made their cars so crappy in the 80's and 90's.
    What I was thinking today was that GM wasn't wrong in cost-cutting. Every business needs to do that.
    What they did wrong was cut costs in the wrong place -- in the product itself. From an accounting standpoint, it makes perfect sense -- building the vehicles are a variable cost, so in order to see a larger 'savings', you cut the costs there rather than in your fixed expenses.
    What they should have done is cut costs in the fixed portion -- the overhead of all those layers of management & bureaucracy. But there wasn't anyone at the top to enforce a dictate...
    4,934
    Re: GM cost-cutting
    It's hard to remove a lot of layers of management... after all, most management is dedicated to making itself indispensable.
    What is even more depressing is that there are uni grads in management who actually believe customer surveys and 'scientifically-proven' drivel. And if their Dad has 'connections'.... excuse me or I will launch into a tirade!
    2,191
    Re: GM cost-cutting
    We have an engineer at work who went to college. I was rather mystified when he named the first gate you come to as "Gate 0", put a truck scake in without a drain or sump pump so it won't work in rainy weather, put a drain at the top of a rise in the pavement and recess it so that lift trucks got stuck every time and put a 4 inch pipe to drain a 40 acre field. Then it occured to me. He went to Ringling Brothers Clown College.
    I'm not very popular at work as I told him that, in front of the company division vice president. Fortunately, I'm very good at my job and have pulled their bottoms out of an expensive jam several times.
    22,997
    Re: GM cost-cutting
    In GM's defense,part of the problem they're dealing with is legal/contractual - and very hard to do much about. I'm speaking specifically of the commitments/obligations to the dealer network, which makes it very difficult for GM to do some much-needed pruning of its brand structure (for openers).It is crazy to have 6-7 full-line divisions (each with 6-8 separate models or more) when you have 25 percent of the market.....
    Re: GM cost-cutting
    Then how'd they manage to axe Oldsmobile?
    22,997
    Re: GM cost-cutting
    It was no easy thing; and they had to buy out a bunch of dealers - huge bucks involved there. But it was a little easier with Olds because that division really had slipped into obvious irrelevance. Buick and Pontiac still sell some cars - though arguably, there's not much reason anymore for these badge-engineered divisions, either.
    Re: GM cost-cutting
    Consolodate Buick/Pontiac into a single division. I bet a majority of their dealers already sell both brands anyway.
    3,614
    Re: GM cost-cutting
    The solution is combine BPC and call it the X car.
    22,997
    Re: GM cost-cutting
    But what would the resultant entity be called? Which models would be cashiered?
    If I were in charge, I'd shuffle the entire structure of GM. There should be three divisions - at most.
    4,934
    Re: GM cost-cutting
    GM looks a bit like the British motor industry did in the 1960s.
    Austin, Morris, Wolseley, Riley, MG, ... where are they now?
    Re: GM cost-cutting
    That's a pretty good comparison, Rob.
    Hopefully, when GM 'rationalizes' their production, they don't end up with being another BMC.
    3,614
    Re: GM cost-cutting
    GM may not be around long enough to rationalize much of anything. A share of stock has lost some 68% in value in the past year.
    http://www.bloomberg.com/apps/quote?ticker=GM:US
    Re: GM cost-cutting
    Buick/Pontiac. They'd have some cars with Buick nameplates and some with Pontiac badges, depending on market position. Pontiac for performance and entry-level models, Buick for bigger sedans and people haulers.
    4,934
    Re: GM cost-cutting
    Actually my 2001 LS1 (70k miles) is showing less durability than my 1957 Jaguar did. Piston-slap, serpentine belt, now the valve lifters are very noisy on startup and for about a mile... in spite of excellent modern SJ oil and regular servicing and ordinary driving...
    Mind you, they make Jaguars in India now don't they? I think I'll stick with the 1950s British tech stuff. Rose-tinted glasses and all.
    Re: GM cost-cutting
    The CFO may be in India, but I don't think they're moving the factories or engineering facilities.
  1. Corner-cutting Clover
    By chiph in forum The Daily Clover
    Last Post: 02-19-2011, 08:22 PM
  2. 58 in a 65 will cost you $80
    By dom in forum Fight Traffic Tickets/Driving Issues
    Last Post: 07-25-2009, 04:14 AM
  3. GM cutting another 10,000 jobs
    Last Post: 02-10-2009, 10:41 AM
  4. Chrysler cutting deals on 2009 hybrids
    Last Post: 06-20-2008, 04:35 AM
  5. Why does car insurance cost so much?
    Last Post: 06-12-2008, 06:45 AM
