Results 1 to 8 of 8
Thread: Jaguar XK head
    Jaguar XK head
    A question for Rob -
    On another forum, a member said he made the mistake of setting the head from an XK motor on a flat surface (I assume his workbench), implying this was a bad thing to do.
    Can you tell me why?
    Because I'm thinking the bottom of the head need to be flat to get a good seal with the gasket against the cylinder casting. And that the valves probably aren't sticking out the bottom of the head, as they're usually recessed to get a good combustion chamber.
    23,030
    Re: Jaguar XK head
    How would setting a head on a workbench cause damage? Even if the head is aluminum, unless you beat on it or something, what would cause damage to what is essentially a big hunk of alloy? I have left the alloy head of my motorcycle sitting on my workbench - didn't seem to cause any trouble...
    Re: Jaguar XK head
    That's what I'm wondering.
    Perhaps it easily warps if it's not 100% flat ???
    23,030
    Re: Jaguar XK head
    Maybe if there was a 100 pounds of deadweight placed on top of it!
    Re: Jaguar XK head
    The guy in the other forum said the valves stick out the bottom just a little bit, and the weight of it is enough to bend the stems just a teensy weensy bit, to where they won't work freely any more.
    MikeHalloran
    Re: Jaguar XK head
    I think the valve axes are not parallel to the cylinder axes, and the valve stems are delicate.
    Other interesting failure mechanisms chronicled here:
    http://www.jag-lovers.org/xk-lovers/...sion_zero.html
    23,030
    Re: Jaguar XK head
    Ah. I guess then so long as you lay it on its side you're ok?
    Re: Jaguar XK head
    Interesting reading, Mike.
    Who knew the things would be so fragile?
  1. Don't let road head happen to you
    By dBrong in forum Video clips
    Last Post: 08-27-2010, 09:05 AM
  2. GM looking for new head of GMC & Buick
    By chiph in forum Automotive News
    Last Post: 12-24-2009, 03:45 PM
  3. Drop-Head?
    By Mase in forum Classic Car Corner
    Last Post: 06-28-2009, 11:33 PM
  4. About to head out...
    Last Post: 11-22-2007, 08:03 AM
  5. Head installed!
    Last Post: 08-03-2006, 04:44 PM
