Results 1 to 4 of 4
Thread: Buzzing sound
    Buzzing sound
    I was working with loose connection at the headlamp on my '76 Chevy. To check, I pulled out the headlight switch on the dashboard (the engine was off, incidentally) and I hear a buzzing sound. Can anyone explain why it buzzes?
    Larry T
    2,139
    Re: Buzzing sound
    Larry T
    Probably you have a headlight on buzzer and when you were fiddling with the wires, it started working again. My old '77 Chrysler had the same thing and it only worked part time.
    Re: Buzzing sound
    Quote Originally Posted by grouch
    Larry T
    Do you mean to say it's normal for the lighting system to buzz when you turn on the headlights?
    Re: Buzzing sound
    "Do you mean to say it's normal for the lighting system to buzz when you turn on the headlights?"
    Only when the ignition is OFF.
    It's to remind you to shut off your headlights when you turn off your ignition. For an example, a lot of people turn on their headlights on rainy days. Then they stop later, it's sunny and clear and very easy to forget to turn off the headlights. In bright sunlight, most people will not notice and will return to a vehicle with a dead battery. The buzzer prevents this.
    It should NOT buzz when the ignition is on (regardless if engine is running).
    But if you have a damaged ignition lock or ignition switch . . . .
  1. Ah, the sound of a V-8 Pacer!
    By Eric in forum Piece of sheet cars
    Last Post: 09-19-2010, 07:00 AM
  2. Ah, the sound of global warming!
    Last Post: 02-11-2008, 02:50 PM
  3. Here's how an engine should sound!
    Last Post: 10-19-2007, 11:28 AM
  4. Sound of an old Kaw H2
    Last Post: 06-28-2007, 11:41 AM
  5. What's That Beeping Sound????
    Last Post: 02-28-2007, 10:12 PM
