Thread: Sticky throttle linkage
    Member
    Wahiawa, HI
    44
    A funny thing happened to me today. I started the car as usual. I usually let the engine warm up about minute and a half or so.By that time I should be able to open the choke by tapping the gas pedal, right, ? BUT according to the vacuum gauge needle the choke valve was still closed so I let it warm up about couple of minutes more. Tapping the gas pedal still showed the needle in the same position so I just went on my way but the way the car was going, the choke was still "closed". I stopped on the side of the road, removed the air cleaner and noticed the choke valve in the "open" position. Obviously the throttle linkage were sticking so when I got home I used my WD40 on the linkages, and will test it in the morning with a cold engine. OR IS THERE SOMETHING ELSE I HAVE TO CONTEND WITH??
    Larry
    22,740
    Quote Originally Posted by Larry Adachi View Post
    Larry
    You have a Rochester Quadrajet 4-barrel (if memory serves). The choke mechanism is controlled by a heat coil; there is also a "choke unloader" - also on the passenger side of the carb. It looks like a small vacuum canister with a metal rod/linkage.
    The choke mechanism requires periodic cleaning/adjustment as it sometimes gets sticky. Rather than WD-40 (which is for displacing moisture/protecting against rust, mainly) get a can of spray carb cleaner and thoroughly spray the exterior of the carb. You can do this with the carb on the engine; just remove the air cleaner assembly. Do this with the engine cold, incidentally - and put a clean rag on top of the carb's butterflies to prevent gunk from getting inside the carb. Your job here is to clean the exterior parts - especially the carb's linkages. Work the throttle arm/choke parts as you spray. Let the carb dry.
    Now, start the car from cold and see whether the problem is still there. The choke should engage (cold engine) with a light tap on the gas pedal/throttle linkage. The engine should start immediately - and settle into "fast idle," around 1,500 RPM or so. Another light tap on the gas pedal should cause the idle speed to drop a few hundred RPM. The choke should release after not much longer - a minute or two unless it is really cold outside. (The exact specifications for idle speed, etc. should be on a sticker on the radiator shroud. If not, you can get them in a Chilton's or Haynes manual.)
    If the choke's not operating correctly - hard starting, stays on too long, incorrect idle speed, etc. - adjusting it is pretty basic and I think you could handle it. No special tools are needed. Just a good manual (Haynes or Chilton).
    PS: Have you checked/changed the filter in the past two years? People often forget this and the Q-Jet is very sensitive to clogged/restricted filters. The filter is located in the carb body, right where the metal fuel line screws into the carb.
  1. Major backorder on throttle body?????
    By martie in forum Advice/Questions/Tips
    Last Post: 07-31-2009, 11:06 PM
