On my '97 Explorer with 160K miles (just bought), while checking fluids, the power steering fluid is red & looks like tranny fluid. I've heard of people using ATF instead of power steering fluid since it is usually cheaper. However when checking the rear wiper fluid resevior (after buying the truck already) I found a bottle of power steering stop leak shoved in the compartment. The power steering doesn't seem to be acting up & is nice and quit. Should I have the fluid flushed, refill & see what happens or keep like is til something happens? There is no sign of leakage right now.
I don't recall what color Ford's power steering fluid is, but for a Honda it's a clear light amber color (at least when new).
I would grab a turkey baster and several pints of fresh Ford P/S fluid and start an exchange process (suck out what you can, top off with new fluid, drive for a day, repeat 4+ times)
Red color is okay, but check the smell.
If it smells like Dexron, you don't want it in there.
No its not Dextron. I was just a little low on my power steering fluid today (not much), but i decided to go ahead & fill it up using the bottle of fluid that i found in the truck, which is power steering stabilizer with stop leak, and i noticed it is red, the same color as whats in the resevoir, so its that stablizer w/ stop leak is whats in the power steering resevoir & not tranny fluid. it just happened to be that its red in color & looks like tranny fluid.
