Results 1 to 4 of 4
Thread: Dashboard GEN light
    Dashboard GEN light
    A strange thing happened to my '76 Chevy this afternoon. I moved it out to clean the garage floor, let it warm up enough to prevent condensation in the engine, and left it out in the sun for about a couple of hours, leaving the key in the ignition.
    I restarted it to go shopping and the GEN light came on, I revved the engine a few times but it stayed on, so turning the engine off then restarting it and the light goes out. Any ideas on this minor phenomenon? I thought the alternator went on the blink!
    Larry
    I restarted it to go shopping and the GEN light came on, I revved the engine a few times but it stayed on, so turning the engine off then restarting it and the light goes out. Any ideas on this minor phenomenon? I thought the alternator went on the blink!Larry
    I am going to guess an ignition switch intermittent contact. It does NOT seem to be a problem with the alternator itself.
    But with intermittents, almost anything is possible.
    -Don- SF, CA
    -Don- SF, CA
    Well,I should hope it's not the alternator itself which is little over two years old. Larry
    23,032
    Larry
    I agree with Don. Also, check the back of the alternator. On GM cars of that era, the little nut securing the main "hot" wire sometimes works itself a little loose. Follow the red wire to the back of the alternator. If the nut is loose, hand tighten it with a small wrench. Caution: If this repair is necessary, first disconnect the battery to avoid grounding/sparks via the wrench completing the contact between the "+" side of the system and the "-" ground (engine).
  1. The Ticking Time Bomb in Your Dashboard
    Last Post: 02-26-2012, 07:50 PM
  2. Red light Clover
    By dom in forum The Daily Clover
    Last Post: 01-14-2011, 07:35 PM
  3. This should light your fire-----
    Last Post: 03-08-2008, 02:58 AM
  4. How a dashboard ought to look!
    Last Post: 12-28-2007, 01:24 PM
  5. Red-light Cameras
    By gail in forum Fight Traffic Tickets/Driving Issues
    Last Post: 09-15-2007, 08:58 AM
