Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: REM's VW question re-posted; slipping VW transmission
    22,762
    Originally Posted by REM :
    "I have a 2003 Passat GLS with the 1.8T engine and an A/T. Lately the A/T is acting up. When I slow to a stop, the engine stumbles and then catches itself. It's very similar to what happens when you have a manual trans and wait too long to let out the clutch when you're slowing to a stop. Also, I've observed some slipping in various situations such as downshifting or sudden acceleration. When it downshifts, it sometimes bangs into the lower gear. The car has only 74,000 miles and has had pretty gentle use.
    Would it make sense to first try flushing and replacing the fluid and strainer. VW, I believe, says the fluid doesn't need to be changed. It's there for life, they say. I'm not sure I buy that.
    What should it cost for a flush, filter replacement, and pan cleaning? I called the local VW dealer and asked them about this and they acted like there was something wrong with me for asking this.
    Any other ideas? Thank you."
    Hi REM,
    In most cars equipped with automatic transmissions, it's routine service to periodically drain the fluid and replace the filter - because filters do get clogged over time with the small particles that wear off internal friction clutches and so on - and because the fluid gets contaminated and/or its additive package loses potency, etc.
    I'm surprised to learn that VW consider it unnecessary to ever change either the fluid or the filter - and that the dealer's treating you like you're crazy for asking about it. Maybe VW has developed a transmission that does not wear internally and thus its internal filters never get clogged? (In which case, why even have a filter at all?) And I have never heard of any oil or hydraulic fluid that never deteriorates.
    Have you?
    Given 70,000-plus miles without a change of either the fluid or the filter, I would not be surprised to find trouble such as you describe. Automatic transmissions (as you probably know) transmit engine power hydraulically, through a torque converter and valve body. The valve body has many small passages in it. Even a very small bit of debris lodged in one of these passages can affect the transmission's functions significantly. Varnishes can make internal valves/accumulators, etc. sticky - which results in weird shift quality and so on.
    I hope it is not permanent damage and would recommend as a first step, that the old fluid and filter be changed.
    Bottom line, changing out the fluid/filter is not going to hurt anything, is almost certainly necessary (given the mileage) and may just fix your problem. Be sure to use the exact type of fluid recommended by VW, though - and filter, too. Some brands of cars are very sensitive to the type of fluid used and use of the wrong type brand can lead to premature and very expensive failures. etc.
    I would look at this as routine maintenance, no matter what VW or the dealer tells you.
    Now, if the problem persists, there may be a bad sensor (modern automatics are electronically governed) or some other external issue. A good repair shop (not necessarily your VW dealer) ought to be able to track that down if necessary. But changing the transmission's fluid/filter is essential (in my opinion) at this mileage, regardless of other possible problems.
    Minneapolis
    1,429
    If you do drop the pan - keep the pieces (hopefully not) that are in the pan. A good transmission guy can look at the pieces in the pan - and maybe tell you the condition of your tranny - or what is failing.
    Junior Member
    Oct 2009
    27
    Thanks for that reply Eric. Yes, believe it or not, VW claims they have a sealed system for life. I've heard others comment that what VW is not telling you is that "life" means 60k - 90k miles if you follow their guidelines. Recommended factory service is just to check the levels and top off if necessary at 40k intervals. Pretty unbelievable, if you ask me.
    Do I need to actually do a "flush" where they run fresh fluid through the lines until the new fluid comes out the other end? Or is a drain and replace, together with a filter change and pan cleaning enough? What should this cost?
    Any opinions about AAMCO or Lee Myles?
    22,762
    Quote Originally Posted by REM View Post
    No problem!
    And yes, I agree with you that VW's definition of "life" is absurd. It's asking for premature (and expensive) transmission problems, in my opinion.
    A flush is better than just draining the pan as the flush will remove all the old fluid and replace it with fresh fluid while just draining the pan will only remove about 1/2 of the total volume.
    The main thing to worry about is that whomever you get to do the service knows what they are doing - and that they use only the fluid listed by VW (as well as the correct filter).
    Use of the wrong type of fluid can lead to rapid failure and will also kill your warranty (if that's still in effect).
    AAMCO and so on are franchised/chain stores; some are better than others. Before you take your car there, check with the local Better Business Bureau to see whether that shop has an unusual number of complaints; also ask friends and people you trust for recommendations. You probably know someone who knows a "good shop."
    Keep us posted - I'm hoping the flush/fill/filter will correct the problem you've got...
    My 2002 Ford Explorer also has a 'sealed for life' transmission... and no dipstick.
    There is instead a small standpipe, vented through the bottom of the pan.
    So far, so good...
    In my limited experience with ATs other than that one, a system flush that does _not_ include removing the pan does more harm than good, because there are _always_ a few chips in the pan, and the high velocity of the flush can move them to a place where they can do harm. They could rest in the bottom of the pan indefinitely and do no harm. Damage from 'professional flushes' may have driven the manufacturers to invent 'sealed for life', in my opinion.
    Pulling the pan and replacing the filter and whatever comes out may help. If you do it yourself, strain the effluent and keep the chips and a sample of the fluid, so you can show it to a good transmission guy, assuming you can find one.
    Before doing any of that, I'd closely inspect the wire harness for damage, and look for rot in any attached vacuum lines. (I'm not sure there _are_ any on a VW; it used to be the standard way to communicate engine load to a hydraulically controlled transmission, and the hose or the vacuum diaphragm used to be the first thing to fail, and the cheapest thing to fix.)
    669
    No problem!
    But leaks probably won't be one of them. Often a new fresh tranny fluid change will cause leaks from cleaning out crud from the flaky gaskets that was holding the tranny fluid in.
    Some people never change tranny fluid or filters and get well more than 150K miles life out of them. And often those who maintain them better don't get any more miles out of them. They sometimes only get more leaks.
    I very rarely bother with a tranny fluid change in any of my vehicles, unless I notice something wrong, such as the burnt toast smell of the tranny fluid or it not looking as it should.
    -Don- (back home in SSF, CA)
    Junior Member
    Oct 2009
    27
    Eric,
    I just heard from a transmission expert that while the flush & filter change is important maintenance, once slipping and other problems appear, the flush & filter change rarely help.
    Any further thoughts?
    22,762
    Eric,
    Well, I'm hoping for the best, but unfortunately yes, the guy you spoke with is more than likely right. Slipping is usually a bad sign. It could, however, be a maladjusted throttle valve cable or some other issue. Let's keep our fingers crossed.
    Meanwhile, changing out the fluid and filter is not going to hurt, should not cost much and in any case needs to be done given the mileage, etc.
    Mike had a good point, too - the pan should be dropped first (before the flush) so that any debris in the pan can be removed and inspected.
    Junior Member
    Oct 2009
    27
    Absolutely. It seems insane to flush the system with all the crap sitting in the pan to just go and circulate and get trapped in the valve body or other places. The only "right" way to do this it appears is to drop the pan, power flush, change the filter, thoroughly clean the pan, inspect the particles, replace the pan and top it off.
    If my tranny needs a rebuild, I may just trade the car in. Do you know what a rebuild (or swap with a rebuilt) cost? The car's only worth about $7,000.
    Minneapolis
    1,429
    The problem is that you may not be able to sell the car, without paying the cost of replacing the transmission. I would guess a rebuild would be $2500. If you could swap it with a used one, might be a better way to go, and keep driving the car.
    22,762
    You've got a real Catch 22 situation there if the tranny needs rebuilding/replacing. The cost is probably going to be in the neighborhood of $2,000 for a new/rebuilt unit (parts and labor). But your car will be worth the same after it's fixed (no increase in value, or not much). On the other hand, if you try to sell it with an obviously failing transmission, you won't get much for it. You'll lose about what it would cost to have it fixed, probably.
    But let's not get ahead of ourselves just yet. First thing to do is drop the pan and have a look. If you don't find pieces of debris (just some light gray/gritty stuff - which is normal wear and tear) you may not have a major problem. Replace the filter/fluid and see how it drives. If the problem is still there, I'd suspect some electrical/sensor-related issue that may be a fairly easy and cheap fix.
    Keep us posted!
    Be cautious about doing a flush -- sometimes the internal filter gets damaged due to overpressure.
    I would recommend two drain & fills, with you driving about 100 city miles between them.
    Junior Member
    Oct 2009
    27
    Can you do a flush with the filter removed? (Something tells me "no") Does it matter if the filter gets damaged since you're changing it anyway?
    Two drains and fills are an interesting idea. You'll still have some dirty fluid in there, but not a lot. It will be about 75% new, 25% old, assuming that only half the fluid in the box comes out when you drain.
    22,762
    I agree with Chip. I would be overcautious and do this job myself in the following way:
    Raise the car, drop the pan/drain the fluid - clean the pan/remove filter. Install new filter, top off transmission with fresh fluid. With the front wheels raised and the car properly chocked/supported, etc., start the car and put the transmission in each range. Run the transmission briefly in each range. Stop the engine, let it cool, then drop the pan/drain the fluid again. Check the filter and replace if need be. Refill and then drive the car.
    Before you start this job, I recommend buying a drain plug kit from a place like Summit Racing or JEGS. (Assuming your VW's pan does not have a drain plug already, of course!) This will make future service a lot less messy and a whole lot easier. Installing the plug is extremely simple; anyone who can operate a drill can do it.
    If you prefer not to do this yourself, find a shop that will do it for you, as per the above. Don't let them talk you into the power flush thing unless they have first removed the pan/cleaned it and removed/replaced the filter.
    If you find a lot of debris (pieces of shredded metal, etc.) and not just some fine particle sludge, the tranny is probably toast and replacing the fluid/filter is probably not going to do much for you.
    Junior Member
    Oct 2009
    27
    Eric,
    I'm bringing it into the local AAMCO on Thursday. I spoke on the phone to the mgr there, and they seem to do things the right way. He said if there's evidence of an internal problem, he would NOT flush the tranny, because that would make things worse. He said if there is an internal problem, flushing or even a fluid change is a waste of money. But he also said there's a 50-50 chance that it just might be an electric/electronic problem.
    And I forgot to mention. My Ck Engine light has been on for awhile. It was related to one code for a bad thermostat that I haven't yet changed. But for all I know, a couple of more codes could have popped up too. The light doesn't get brighter when more codes pop up.
    22,762
    Eric,
    Excellent!
    I'm hoping it turns out to be an electronic fault of some kind. 70,000 miles is way to early for a transmission to fail unless it's been seriously abused or just happens to be a poorly built/weak unit to begin with.
    I haven't heard of widespread premature problems with VW automatics (anyone else?) so with luck, you'll be back in business for the cost of a fill n' flush or a minor service/replacement of some sensor, etc.
    Eric,
    I remember way back when I had a Mercury Cougar, the transmission had extreme difficulty shifting. It would start in second and would not go into overdrive. It turned out to be a Throttle Position Sensor. The sensor was replaced and that solved the problem.
    Sounds to me that your tranny has multiple issues.
    1) the stumbling when slowing down sounds like a sticking torque converter lockup switch
    2) the slipping could be worn clutch discs, or incomplete engagement because of stuck valves from debris, or just some bad solenoids or wire connections in there.
    3) all this stuff easily could be some messed up electrics, or an internally filthy tranny.
    I can't believe VW says not to change the fluid for the life of the tranny. That is insane!
    22,762
    "I can't believe VW says not to change the fluid for the life of the tranny. That is insane!"
    I can. Reason? Marketing. Why, just look at our fine cars! They never need routine service!
    Which sounds good up front, which is all that matters (apparently).
    Down the road, though, it's a different story.
    VW is not the only sinner here. See also:
    Lifetime coolant
    100,000 mile spark plugs
    Etc.
    Junior Member
    Oct 2009
    27
    Excellent!
    I had the car in to AAMCO. They told me the car is showing Codes 17114 / PO 0730. They said fluid level is good, and color is starting to turn. Surprisingly, they stated that they didn't get a code for a bad thermostat that was showing up consistently for the last several months, and the thermostat problem is still there. They said the problem is definitely internal damage, and the tranny will have to be removed disassembled and inspected. Cost = $1,172.50, but that doesn't include any repairs, which he said could be anywhere from $2,000 to $5,000. (If the repairs are done, the $1,172 is credited against the cost).
    They also said that the tranny was stuck in 3rd gear during the test drive and all the indicator lights came on. This is something I NEVER observed. There was a lot of high pressure sales tactics and warning me that I could get stranded without warning. They also didn't have any written printout to give me claiming that it's all on the computer and can't print out. Frankly, I was skeptical of their diagnosis.
    I've been reading up on Code 17114 and it appears that it's a generic code that doesn't really pinpoint the problem. How do I even know if the car generated those codes? Does the VAG-COM print out a report?
    Time for a second opinion, I think.
    Any other thoughts?
  1. Replies: 5
    Last Post: 11-18-2010, 09:24 AM
  2. Slipping floor mats and sticking gas pedals
    Last Post: 03-23-2010, 04:02 AM
  3. VW Transmission Slipping
    By REM in forum Car Care & Repair
    Last Post: 10-03-2009, 07:07 AM
  4. Posted Without Comment....
    By Mase in forum Secession Talk
    Last Post: 12-17-2008, 06:52 PM
  5. I see my car is posted...
    Last Post: 11-17-2006, 07:45 AM
