Results 1 to 15 of 15
Thread: How to use K-Y Jelly (for car repair)
    2,133
    When I ran a salvage yard, I found a case of K-Y Jelly in the trunk of one. No telling what someone used that much for. However, I found that if you're putting rubber bushings into an old car (in this case, a 1970 Malibu) you can spray some water on the metal part, smear a little jelly on the rubber part, and it will generally go right in. Make sure to keep your hands dry though as you get them wet and then grab the jellied up part, it can sail a long ways under benches and such.
    Senior Member J. ZIMM's Avatar
    Mar 2008
    THE HIGH DESERT, OREGON
    371
    I've aways kept a Jar of Vaseline on my tool box for installing rubber parts, on battery terminals, and to help keep parts in place during installations. Before I got married, I use to keep a small jar in the car...hehehe
    2,133
    Quote Originally Posted by J. ZIMM View Post
    Never use vasoline (petroleum jelly) on anything rubber. The oil in it will soften the rubber and eventually rot it. Trust me on this. I've seen rubber parts such as weather stripping get spongey from the use of oil on it.
    Senior Member Mase's Avatar
    840
    KY is specifically formulated to NOT degrade rubber, and if you think about it, that makes sense.
    I use Vaseline on all my electrical connections.
    Mar 2008
    371
    Thats where the term "I got her all oiled up for ya" came from....hehehe
    Ha, yeah I've never had one "oiled up" electrical connection ever give me a problem with connectivity, or corrosion.
    2,133
    I used it for years but dielectric grease with a silicone base is better. I got a Jaguar once at the salvage yard and the owner was just tired of fooling with the "Prince of Darkness" Lucas electrics. I cleaned all the aluminum connectors and put dielectric grease on them and drove the car for a couple of years with no problems what ever.
    I like the dielectric stuff too, but they don't sell it in huge containers like the generic Vaseline at Walmart! HA
    2,133
    A little goes a long way. That said, instead of the little tube I usually get, I found a huge honkin' tube next to it at AutoZone. I even fixed the wondow motors on my lady friends car with that stuff. The little plastic bearings broke and I couldn't find replacements so I put little ball bearings in it. The dielectric grease held them in place while I put the gear assembly back together.
    Aight dammit..
    I'm going to get some dielectric grease today and a tube of KY!
    You guys have me sold! LOL
    How about that other stuff..
    The stuff for sore muscles..
    What's it called again?
    2,133
    Aight dammit..
    When I played Rugby, I used Ben Gay. It's a good linament but also a good equalizer. Get into a scrum and someone foul you, you can take care of business. Just rub a bit on the forehead of the other guy who fouled you. A few minutes later, sweat will take it into their eyes. You really don't want that in your eyes. A little trick I learned playing football.
    Ha Grouch you messed up my joke.
    22,731
    Dirty pool!
    Brings back some great memories...
    Junior Member
    Nov 2012
    5
    This method over many years and recommend that you do not assume the trouble is a certain part, as a problem in one area will often show up as a symptom somewhere else. An example is carb malfunctions are often incorrectly assumed to be governor problems.
  1. Avoiding repair rip-offs
    Last Post: 03-10-2010, 07:29 AM
  2. 1928 Car Repair Mailer.
    By Jim Rose in forum Classic Car Corner
    Last Post: 01-20-2010, 12:15 PM
  3. Car Care & Repair
    Last Post: 05-10-2009, 05:46 PM
  4. Checking out repair shops
    Last Post: 12-20-2008, 09:55 AM
  5. Right to Repair
    By swamprat in forum Car Care & Repair
    Last Post: 09-29-2007, 01:52 PM
