Thread: Dead battery
    Dead battery
    I had the battery in my new-to-me Honda Ridgeline die over the weekend. Always awkward, it was especially so because I was away in Raleigh, going to visit friends.
    What did it was I drove over a speed-bump in the Costco parking lot. The VSA warning triangle flashed (ok, I was going a little fast and the wheels might have slipped a bit..), but when I came out the truck refused to unlock with the remote, much less start.
    I suspect the bump had knocked one or more of the worn-out lead plates inside the battery loose, leaving their cells able to produce their normal voltage, but not produce enough current to actually run anything.
    Being Costco, I knew they sold batteries, so I hiked down to aisle 127 to pick one up. Uh-oh. The battery in the truck was a group 24F, but they were saying their replacement was a group 35. Yes, it was 12 volts and had 550 CCA, but it was physically the wrong size and would have slopped around in the battery tray.
    http://www.rtpnet.org/teaa/bcigroup.html
    So I called up a friend and he came over and gave me a ride to a local auto-parts store. $94 later and I was back in business.
    The battery was the OEM from Honda, and was 3-1/4 years old, so it was right at the minimum length of time I would expect a factory battery to last, especially given all the electronics on the new cars that draw current.
    PS. Helps to have had a 10mm wrench in the car.
    22,995
    You were lucky to have it die on you near a store (and a friend)!
    I forget where the battery is located in the Ridgeline; was it was it easy to access/remove?
    It's under the hood by the driver's headlight, so not hard at all. Just the usual awkwardness of lifting a heavy object up and over the fender, twice!
  1. Car Battery
    Last Post: 11-13-2011, 10:13 AM
  2. Battery recommendations
    By dBrong in forum Advice/Questions/Tips
    Last Post: 09-20-2011, 11:11 AM
  3. Battery Health
    By Andrew B. in forum Motor Mouth
    Last Post: 05-17-2011, 09:58 AM
  4. Replies: 6
    Last Post: 11-08-2009, 08:56 PM
  5. Replies: 0
    Last Post: 10-21-2009, 08:05 AM
