Results 1 to 5 of 5
Thread: Confusion replacing 02 Sensor
    Minneapolis
    1,429
    I got the CEL and found P0030 (O2 sensor) on my 2005 Volvo XC90 T6, 46,000 miles.
    I can get to the sensor from the engine compartment. However the wires disappear after the first 12" of wire. It would be a bitch to find where they go - there's hoses / pipes / etc, can't see, can't get your hand in there.
    Question #1 - The Volvo OEM part is really expensive, the Bosch is $150, and some generic's can be had for $40. What is the difference? Should I just splice in a cheapie?
    Question #2 - It seems the easiest to cut the wires and splice the new sensor, rather than get under the car and find where the 02 sensor plugs in. What do you think of this?
    Answer #1 - Depends, do you want to do it more than once? (DON'T GET THE CHEAPIE, but the Bosch may be okay -- honestly I don't know)
    Answer #2 - Do your best not to cut wires, but if that's the way it is you have to.
    22,731
    I don't know about cutting the wires - but I agree with Dom 100 percent about the "cheapie" - forget it!
    Bosch makes a ton of OEM stuff so their replacement part is probably just fine. It may even be the OEM part!
    1,071
    OE on a Volvo will almost certainly be Bosch, so there's no point in paying extra for a fancy Volvo box. I wouldn't buy a generic - they are cheap for a reason! If you want good quality (arguably better than Bosch) at a lower price try NTK (made by NGK); I don't know how they compare in the US, but in the UK they sell for around 70% the price of a Bosch sensor.
    Minneapolis
    1,429
    Thanks you guy's - I'm gonna go with the Bosch for $150.
    Still have the problem of locating were it connects. With the turbo piping, brake lines, hoses, it is not possible to trace the wire.
    The Hennepin county library system has AllData - and even there - there is no info as to where to locate the connector - or what one has to remove in order to get at it!
  1. replacing exhaust
    By bikerlbf406 in forum On Two Wheels
    Last Post: 03-27-2011, 01:45 AM
  2. o2 sensor
    By pearly8 in forum Car Care & Repair
    Last Post: 10-20-2010, 03:25 AM
  3. P0030 - Bank 1 Sen 1 O2 Sensor - Volvo
    By dBrong in forum Car Care & Repair
    Last Post: 12-07-2009, 08:16 PM
  4. Tire pressure confusion?
    By misterdecibel in forum Car Care & Repair
    Last Post: 04-28-2009, 07:09 AM
  5. Replacing a paid-for car?
    Last Post: 01-05-2009, 10:10 PM
