Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: 2010 VW Golf
    22,741
    2010 VW Golf
    It's easy to like the VW Golf.
    On the one hand, it's an economy car - with an available turbo-diesel engine that can return more than 40 mpg on the highway.
    On the other hand, it's powerful and quick - with a standard 170 hp gas-burning engine that still manages to get 30 mpg on the highway.
    No one else offers anything quite like it, which goes a long way toward explaining it popularity despite its slightly higher price relative to competitors.
    The Golf is VW's entry-level model. It's a compact, front-wheel-drive sedan/coupe available with either gasoline or diesel engines. Prices start at $17,620 for the base 2.5 coupe and top out at $23,860 for a TDI (diesel) sedan.
    The 2010 model is essentially all new, with updated exterior and interior, features and equipment - including the optionally available TDI diesel engine.
    Athletic performance/superior handling - even from base model.
    Almost-hybrid fuel efficiency with optional TDI diesel - without the complexity or hassles of owning a hybrid, including down-the-road issues with the batteries.
    Feels solid as the rock of Gibraltar.
    Can be equipped with luxury-level amenities, including hard drive music storage and Bluetooth wireless.
    Available as a coupe (the Mazda3 isn't).
    Available as a sedan (the Mini Cooper isn't).
    Fairly pricey to start - and can get downright expensive if you add some of the available options.
    Superb, high-economy TDI diesel engine currently only offered in higher-trim/more expensive version.
    Base model interior materials can be a bit bleak-looking. Exterior styling a bit bland compared with Mazda3 and Mini Cooper.
    VW has had some issues with quality control.
    Two engines are available in the golf. Standard is a 2.5 liter, 170 hp gas engine teamed with either a five-speed manual or a six-speed automatic.
    This engine is quite powerful for the class. Compare it, for example, with the Mazda3's standard engine (2.0 liters, 148 hp). To get equivalent power/performance (2.5 liters, 167 hp) you have to step up to the more expensive Mazda3 s, which starts at $19,040 - or about $1,400 more than the base model Golf. The base model Mini Cooper, meanwhile, comes standard with just a 1.6 liter, 118 hp engine (for $18,800) while the optional Mini S with turbocharged 1.6 liter engine (172 hp) produces virtually the same power as the Golf's standard engine but costs a lot more ($22,300).
    The VW's 2.5 liter engine is also quite economical. EPA rates the Golf equipped with this engine and five-speed manual transmission at 22 city, 30 highway. The base Mazda3 (with smaller, less powerful 2.0 liter engine) does only slightly better: 25 city, 33 highway. The flyweight Mini is cuter than your high school girlfriend and beats them both with an exceptionally thrifty 28 city, 37 highway - but its acceleration (0-60 in about 8.5-8.7 seconds) is borderline Prius-like.
    The Golf, meanwhile, is significantly quicker than the base Mini or the base model Mazda3: 0-60 in about 7.7-7.8 seconds with the five-speed manual.
    But the Golf has another really strong selling point neither of its rivals can answer and that is the optional 2.0 liter turbocharged, direct injection (TDI) diesel engine. It produces V-6 levels of torque output (236 lbs.-ft., almost all of it available in the lower RPM range where most everyday driving is done) and can deliver 42 MPGs on the highway - by far the best mileage you'll get in anything short of a gas-electric hybrid (or a motorcycle).
    The TDI engine has the additional attraction of being inherently more durable than gas-burning engines. A diesel engine, assuming proper care, can be expected to run reliable for many hundreds of thousands of miles - which means your total ownership costs could end up being much lower, since you may not need another new car for the next 15-20 years.
    Maybe 25 or 30.
    The TDI Golf comes with a six-speed manual (standard) or (optional) a six-speed dual-clutch automatic (DSG). The DSG version is the one that gets best-case mileage of 42 highway (and 30 city) but manual versions still achieve a very impressive 41 highway (and the same 30 mpgs in city-type driving).
    The TDI-equipped Golf isn't as quick as the 2.5 liter Golf, but it's 0-60 time of about 8.6 seconds is still almost exactly the same as the less fuel-efficient Mini Cooper and Mazda3 with 2.0 liter engine.
    All Golfs are front-wheel-drive.
    DRIVING IMPRESSIONS
    From an enthusiast driver's perspective, the Golf is a real pleasure to drive. It is quick enough to be sporty and has plenty of reserve power to execute fast passing/merging maneuvers comfortably and without straining. It has quick steering response, too - and will corner with athletic poise at pretty high speeds.
    But from a normal, everyday driver's point of view, it is also comfortable and smooth. The ride is firm, but not stiff (it is stiff - and bouncy - in the Mini Cooper and to a lesser extent, the Mazda3). Though the Golf is a small car, it feels extremely solid - a characteristic trait of German-built cars. Even cruising along at close to 90 mph, there is minimal road/tire/wind noise transmitted into the cabin and the car seems completely at ease and ready to go much faster (which of course it is designed to do, given Germany's high-speed Autobahns). At legal U.S. speeds, the Golf feels understressed - like a powerful bodybuilder just warming up.
    TDI versions launch with forcefullness, too. If you want, you can even squeal the tires. Few 40-plus mpg cars can do that. It is also quiet - whether idling in traffic or running 75 on the highway.
    I could find no fault with either of the Golf's available engines, both of which manage to be strong performers as well as very fuel-efficient. The transmission choices are also top-drawer. Manual enthusiasts will like that both engines can be teamed with a stick-shift, while going automatic involves no compromises of either performance/driving fun - or economy (DSG-equipped Golfs get the best mileage).
    As mentioned above, the Golf's two bodystyles (hatchback coupe and four-door sedan) gives it a selling advantage over its two chief rivals, the Mini Cooper (no sedan version) and Mazda3 (no coupe). It's also nice that both versions have about the same interior space (more on this follows below).
    The interior of the base Golf comes off as a little on the Spartan side in terms of initial impressions but the car is well-equipped as it sits with AC and most power options (windows, lock, cruise control) plus a very decent eight-speaker stereo with MP3 player. The bland-looking materials (dash cover/door panels, etc.) are however substantial-looking and panel fitment is superior.
    Though you might expect the TDI version to be low-budget/economy-oriented it actually has more standard stuff than the base Golf - including 17 inch alloy rims, a premium audio system with touchscreen interface, Bluetooth wireless, fog lights - and a firmer-riding, sport-tuned suspension.
    You can further dress out your Golf with leather, heated seats, GPS (bundled with music storage hard drive) Xenon HID headlights, a sunroof and other stuff - but be aware that some of these options are expensive and if you're not careful you can end up with a Golf that's pushing $30k.
    Space-wise, the Golf (both versions) has more front-seat headroom (39.3 inches) than either the Mini (38.8 inches) or the Mazda3 (38.9 inches) and virtually the same front-seat legroom as the Mini (41.2 inches vs. 41.4 inches.) The Mazda3 has significantly more front seat legroom (42 inches) but the Golf beats the Mazda on rear-seat headroom (38.5 inches vs. 37.5 inches), while the Mazda has a bit more rear-seat legroom (36.2 inches vs. 35.6). The bottom line is that it will depend on your body type as far as which car feels roomier in the back.
    The big point, though, is that the VW has useable back seats.
    The Mini, on the other hand, doesn't.
    While the Mini has surprisingly generous room for front seat occupants its rear seats are Adult Unfriendly (just 29.9 inches of legroom) which severely limits its practicality relative to the VW (or the Mazda).
    The VW's trunk/cargo capacity is 12.4 cubic feet - better than the Mazda3 (11.8 cubic feet) and vastly better than the Mini (5.7 cubic feet). Although to be fair the Mini has the most potential cargo room, 24 cubic feet - but that's with the second row seats down and the Mini transporting no more than two people.
    A nice touch in the Golf are the standard eight-way manual-adjust seats, which can be ratcheted up and down to accommodate shorter or taller drivers and which really improves the day-to-day usability of the car.
    My only gripe is that VW doesn't offer the excellent TDI diesel in a "basic" version of the Golf - perhaps even without power windows - which would lighten it up as well as lower its cost. An $18k TDI Golf capable of 44 mpg on the highway would be incredibly appealing.
    There are pros and cons here. On the one hand, the Golf - especially the TDI-equipped version - is one of the most economical cars you can buy in terms of everyday fuel economy as well as potential down-the-road longevity. On the other hand, the VW's base price of $17,260 is fairly steep relative to other economy-type but still-sporty cars you might buy, including the $15,295 (to start) Mazda3.
    Also, VW has had a somewhat spotty record in recent years as far as minor gremlins such as problems with electrical systems. The New Beetle, in particular.
    That said, the 2010 Golf is an all-new model and VW has hopefully worked out whatever issues plagued some its earlier models.
    And to be fair, the Mini has had its own issues with quality/reliability, too.
    Warranty-wise, the Golf comes with a standard three year/36,000 basic and five year/60,000 mile powertrain warranty. Mazda offers exactly the same coverage on the Mazda3 and Mini offers a bit more basic coverage, with a four-year/50,000 mile standard warranty (but a less substantial four-year/50,000 mile policy on the powertrain).
    The only extra-cost safety feature is back seat side-impact airbags (for the sedan; they're not available in the coupe). Both coupes and sedans come standard with ABS, traction and stability control, front seat side-impact air bags and first and second row head/curtain air bags.
    The Golf costs a bit more than other entry-level sporty-economy cars but it offers superior power/peformance and (in TDI versions) simply outstanding fuel efficiency, which washes away much of the difference in up-front expenses.
    If you can afford to spend the extra grand or three necessary to get into one, you'll be much happier when you're driving one.
    Chicago vicinity
    549
    That's a sharp looking car and in my opinion perfect for today's world.
    Something I don't understand. Why make the diesel the most expensive, they should offer it as either a base (whatever that is these days), or as a higher end model. And now with the diesel being so damn fast (compared to before), they should offer the GTI suspension in the TDI.
    22,741
    Very good point.
    At least they should offer the TDI in a base trim, perhaps even without power windows and locks - which would lighten it up as well as lower the price.
    I think an $18k, 44 mpg highway Golf TDI would be exceptional.
    In Germany, the engine choice is independent of the trim level (to a great degree).
    The lack of choice in the USA is solely the result of VWoA's marketing team.
    We always get less options than the home-market buyers do. It's always been that way (unless you ordered a gray market car).
    I've had no reliability or QC issues with my 2007 GTI, after three years.
    The 2010 Golf isn't "all-new", it's a facelift of the MkV model with some engineering tweeks.
    Is the base Golf available with a slushbox, or is the expensive DSG the only automatic?
    22,741
    Just DSG - which is a big ticket option.
    It was a $1.7K upcharge when I was shopping in 2007, that's gonna lose VW a lot of regular joe customers. VW's loss is Mazda and Honda's gain...
    22,741
    Yep.
    If we were talking about a $30k car, ok - another $1,700 for a state-of-the-art transmission is within reason. But the Golf? It's competing with cars in the mid-high teens, like the Mazda3. Not only is the cost of the DSG unrealistic for the segment, it's way high in proportion to the cost of the car it goes in.
    My opinion: VW makes some excellent cars but it is pricing itself out of the market. It is trying to become another Audi (or BMW) but people just aren't going to pay Audi and BMW money for a VW.
    Besides, why even try? VW was hugely successful when its cars were both great to drive/own as well as great buys....
    On the other hand, a slushbox is an $800 dollar upcharge even on a Civic DX - $16.3K for a manual DX 4-door, $17.1K for a DX auto.
    $17.0K vs $17.8K for Mazda3 sedan too. I didn't realize slushboxes were so expensive.
    So the VW is still expensive, but not quite so wildly out of line.
    22,741
    True!
    It's easy to spend close to $20k on an "economy" car with a few options.
    Personally, I think it's demented.
    One of the few new economy cars I would personally consider buying is the Nissan Versa 1.6. Under $10k, out the door.
    That's "economical."
    And it does just fine as a transportation appliance. Which is all most people really need anyhow.
    The VW and Mazda, etc. are indeed "sportier." Well - so what?
    The truth is we can't drive them anywhere near their capability more than every once in a while without guaranteeing we'll get crucified by a traffic cop. And even if you take the cops out of the equation, for most people, in most places, the density of traffic makes "sporty" driving a physical impossibility anyhow. You get to go as fast as the car ahead (or the traffic all around you). Which, usually, is not very fast!
    Finally, most people are not "sporty" (let alone high performance) in either their abilities or their inclinations. They may have an image of themselves as such - which is what sells cars - but in practice, very few people I see ever drive with any real gusto. And that includes the ones sitting behind the wheels of much more powerful/capable cars than a Golf or Mazda3. They "go with the flow" and poke along with everyone else.
    So why in the world do they spend close to $20k on an "economy" car? So they can look and feel they way they want to look and feel. It has next to nothing to do with substance.
    That, in a nutshell, is the Truth About Cars!
    1,071
    I first visited the US in 1978 & have made half-a-dozen more trips since then. A conundrum I still haven't found the answer to is why Americans demand so much power to drive so slowly!
    22,741
    For the same reason that a Yuppie couple with (at most) two kids will buy a 5,000 sq. ft. McMansion....
    For show.
    To make a statement.
    So that people will think they're cool.
    Or rich.
    Americans are so bamboozled by advertising and the related urge to conform to whatever the current standard of "in" might be that they will fall all over themselves to spend money they don't have on things they don't really need.
    It's fairly sad, actually.
    But then, I counteract this tendency to sympathy by remembering how annoying it is to be stuck behind some Breeder in her 400 hp S-moo-vee doing two or three miles per hour over the (under-posted) speed limit....
    1,071
    What annoys me is the slow crawl away from traffic lights. . . in the country that invented drag racing!
    22,741
    There's that, too!
    It's commonplace to be stuck behind two "sport sedans" - one in the left, the other in the right lane, both matching one another's (slow) speed - preventing you from getting around either.
    They'd be fine driving Yugos.
    True!
    What are you some kind of Communist? We're revoking your Libertarian card.
    Not everyone who buys a small car does it for "economy". Some people, myself included, just prefer having something smaller and lighter. I'll make no apologies for the electric windows and leather seats in my GTI. I didn't buy a $26.9K (sticker) compact because I went looking for an economy car and got nickeled and dimed to death, I bought it because I thought it was the best "performance" car I could find within my budget.
    BTW, the automatic transmission is a $1K upcharge on the Nissan Versa.
    And the 1.6 is only available in the ugly Sedan body style, if you want the hatch you have to step up to the 1.8 S trim level.
    22,741
    I'm not saying people should be forced to do anything.
    I am merely observing that many people buy cars based on marketing and image rather than actual need - and that I think it's silly for a hausfrau to putter around suburbia in a 300 hp "crossover" or S-moo-Vee.
  1. 2011 VW Golf
    Last Post: 10-12-2010, 09:43 AM
  2. 2010 vw gti
    Last Post: 06-22-2010, 04:37 PM
  3. 2010 ... or 10,000 BC?
    Last Post: 01-25-2010, 06:40 AM
  4. VW reveals new Euro Golf, including diesel versions
    Last Post: 08-11-2008, 07:44 AM
  5. VW Golf to get 7-speed DSG
    Last Post: 02-06-2008, 09:03 AM
