Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Change motorcycle tire
  1. #21
    2,133
    Got the tire mounted, balanced, and new valve stem done for $27 at a mom an pop spot on a back road in the middle of nowhere!
    I always try to patronize local shops. I don't like to buy off the internet if I can avoid it. If you don't do business with the local shop, they'll close up and you'll pay top dollar at a big shop that may not give a darn. Mom and pop do. There's a shop like that about a mile from my house. He does good work and in some cases better than the bigger shops. I had a (now former) Kawasaki dealership fix the one electrical fault my Concours had under warranty and while they were at it, change the coolant. They quoted me $40 to change the coolant. When I picked it up, I was charged $60 to change the coolant and they didn't even fill it up. It help 3.8 quarts and I had to add 1.5 quarts to fill it. They also charged me $60 to change a fuse. The fuse kept blowing which is why it went to the dealer. It was under warranty and they didn't even try to fix it. I finally tracked the problem to a bad connection on the headlight plug. Once I found it, it took about 15 minutes to fix it. I made it a point to mention this on the Concours mailing list. Kawasaki also is on there. That gouging cost the dealership a LOT of business. I had planned to buy a $600 riding jacket with body armor. I didn't. They also had a smaller bike I was looking at for around town, I didn't buy that either. They lost their dealership about a year later.
  2. #22
    Yeah..
    I will keep a mom and pop alive any chance I get.
    You know, I could not get one spot to mount my tire anywhere!
    NOT ONE..
  3. #23
    Senior Member J. ZIMM's Avatar
    Mar 2008
    THE HIGH DESERT, OREGON
    371
    How accurate is the balancing?
    I like the idea, too - but (for sport bikes that see very high speeds, especially) I definitely want my tires balanced precisely....
    For high speeds, you want a Dynamic Balancing job on your tires. What he is showing is a Static balance. That's OK for normal around town riding. Dynamic takes the side to side or shimmy out of the tire/wheel assembly. The same thing on a passenger tire. I use to have a machine that would do MO-MO tires and vehicle tires Dynamically.
  4. #24
    663
    Some good tire wrenches maybe around $40.
    Wouldn't this make the job a lot easier?
  1. New tire time?
    By RebelKnightCSA in forum Car Care & Repair
    Last Post: 02-06-2012, 09:53 AM
  2. Motorcycle Tire change
    By dom in forum On Two Wheels
    Last Post: 08-22-2011, 03:21 PM
  3. Tire Gages
    Last Post: 05-02-2011, 05:48 AM
  4. Replies: 11
    Last Post: 12-10-2010, 06:23 PM
  5. Tire psi?
    Last Post: 06-20-2007, 11:19 AM
