Thread: Difference between brake fluids
    I always see the Dot 3 and Dot 4 fluid on the racks and Walmart when I am shopping. I think all of my vehicles take Dot 3, but what is the difference between the two? If I was in a pinch would I be able to substitute one for the other?
    688
    Yes and no.
    You can mix Dot 3 with Dot 4, or even use 100% Dot 4 for what's designed for Dot 3, but never mix either with Dot 5.
    But it is not be a good idea to mix Dot 3 with Dot 4 or use Dot 3 when the brake system is designed for Dot 4.
    Dot 4 has a slightly higher boiling point than Dot 3 and therefore should not be used or mixed if the vehicle is designed for Dot 4.
  1. Replies: 9
    Last Post: 11-19-2010, 10:44 PM
  2. difference between engines
    Last Post: 01-30-2010, 08:49 PM
  3. Replies: 8
    Last Post: 10-26-2009, 07:33 PM
  4. 4x4 or AWD - and what's the difference?
    Last Post: 04-02-2009, 08:52 AM
  5. Cheap auto fluids & junky oil filters, etc.
    Last Post: 02-10-2007, 11:26 AM
