Thread: Loud squeaking from brakes
    Hearing a loud squeaking from brakes at low speeds.
    Sounds like it's coming from the front.
    Pad wear indicator?
    My friction material is worn out?
    If you're lucky, it's a pad 'squealer', and it's time to change the pads.
    If you're not so lucky, the squealer is long gone, the pad backing is rubbing on a rotor, and it's time to change the pads and the rotors.
    Either way, it's definitely time to pull some wheels and visually inspect the brakes.
    2,183
    Sounds like your brakes are down to the wear indicator. You're probably due for pads.
  1. How to bleed brakes
    By Eric in forum How-To
    Last Post: 11-22-2010, 08:54 AM
  2. Loud Stereos a Moving Violation
    By swamprat in forum Fight Traffic Tickets/Driving Issues
    Last Post: 12-21-2009, 06:51 AM
  3. Breaks vs. Brakes
    Last Post: 10-31-2009, 07:41 PM
  4. No brakes!!!
    Last Post: 04-21-2009, 07:30 AM
  5. Upgrade those front brakes - the PFM way.
    By Ken in forum On Two Wheels
    Last Post: 08-01-2008, 12:53 PM
