Thread: Signs your transmission is going.
    Exclamation Signs your transmission is going.
    What are some common signs your transmission is about to break?
    3,487
    Depends which part of the transmission, Dom.
    Gearbox - Jumps out of gear when driving, usually when increasing load. Grinding or rumbling noises when a bearing is failing. Inability or difficuly in selecting a gear when the selector forks are worn. General noise emanating from the gearbox area.
    Clutch - Usually slipping when the pressure plates/friction plates are losing their grip. Slip level increases with load. Rattle from a worn, bearing type, pressure release bearing.
    Propshaft/driveshaft, usually vibration when the universal joints are starting to fail, rattling, machinegun like rattle, mainly on turns, when the Constant Velocity Joints (CVJs) are on their way out.
    Differential, usually a loud whine, varying with load, when the worm/bevel gear/associated bearings are worn.
    Just a few for starters, Dom
  1. Replies: 5
    Last Post: 11-18-2010, 08:24 AM
  2. REM's VW question re-posted; slipping VW transmission
    Last Post: 11-01-2009, 04:55 AM
  3. VW Transmission Slipping
    By REM in forum Car Care & Repair
    Last Post: 10-03-2009, 06:07 AM
  4. Transmission types explained
    Last Post: 10-28-2006, 10:22 PM
  5. STOP signs VS YIELD signs and BEYOND
    By gail in forum Fight Traffic Tickets/Driving Issues
    Last Post: 08-13-2006, 10:24 PM
