Thread: Can your gas tank freeze in the winter?
    Should I keep my gas tank full in the winter, so it does not freeze?
    Pure unleaded freezes at around minus 150F, Dom so you should be OK. On a bike or car it pays to keep the tank topped up to avoid rust if the vehicle is laid up for any length of time. Obviously any water in the gas will freeze at its normal freezing point.
    2,186
    Yes, but not so it doesn't freeze. Alcohol absorbs water so since most gasoline sold today is either 5% or 10% alcohol, you probably don't have much if any water in your tank. A half tank of fuel will collect moisture from the atmosphere and eventually your performance will suffer. Also, if everyplace is closed due to heavy snow, you have a full tank and can last out the storm. Get stuck and you have enough fuel to keep yourself warm until you can get out.
    If you're really worried about it, you can get a bottle of Heet which is alcohol and will absorb moisture. Any alcohol will work but NOT rubbing alcohol as it has water added and can't absorb anymore.
  1. Tank Sheets
    By bikerlbf406 in forum Classic Car Corner
    Last Post: 01-25-2010, 09:12 AM
  2. Dehydrated .vs. Freeze dried food
    By Eric in forum Survival/Economic Collapse
    Last Post: 12-31-2009, 12:31 PM
  3. Gas Tank Cleaner
    By dom in forum On Two Wheels
    Last Post: 04-13-2009, 10:45 PM
  4. one-third of a tank.... $37!
    Last Post: 05-15-2008, 08:54 AM
  5. Marge's tank
    Last Post: 11-18-2007, 06:39 AM
