Thread: The Road Rage Defuser (Or How To Avoid Being A Clover)
    22,731
    Road rage is a function of Cloverism - inept, oblivious and passive-aggressive "driving."
    Do your part to keep creeping Cloverism in check by avoiding these common examples of Clover-ish conduct behind the wheel:*
    * Left lane hogging -
    Driver's ed courses used to hammer home the point that the left lane was for faster-moving traffic - and passing. If you weren't passing another vehicle or travelling at least as fast as the cars behind you - you were taught to yield and move over to the right as soon as you safely could.
    Unfortunately, many drivers - the Clovers out there - no longer yield to faster-moving traffic. Clovers believe it is their right to stay in the left lane indefinitely, no matter how many cars are stacked up behind them - so long as they are "doing the speed limit."
    But failing to yield and let faster-moving cars get by is not unlike putting an aerosol can in the microwave. An explosion is imminent. Tensions rise; other drivers get more and more frustrated. Some tailgate; others try to pass on the right, which isn't ideal but may be the only way to get around the Clover.**This serves no one's interests - including the Clover. While the Clover may be in the right, legally speaking, as far as not exceeding the posted limit is concerned - he always *forgets (being a Clover) that failure to yield and obstructing the flow of traffic are just as illegal as "speeding" - and arguably much more unsafe.*
    Use your rearview mirror. If someone wants to get by you, let them do so. It's no skin off your nose.
    Moving right and yielding to faster-moving traffic is the polite - and right - thing to do.
    * No cruise control passing -
    Related to the problem of left lane hogging is the cruise-control pass. The typical scenario is a two-lane secondary road where a car in the left lane is attempting to pass a car in the right lane. But instead of accelerating to rapidly overtake the other car, then moving back into the right lane, the Clover inches forward at a glacial pace - his cruise control set on 60 as he tries to pass a driver doing 57.
    Meanwhile, everyone else gets stuck behind this rolling roadblock.
    If you want to pass, signal your intent, then move left and speed up sufficiently to get past the other car quickly - even if that means turning off the cruise control and pressing down on the gas pedal.
    After executing the pass, signal and move back into the right-hand lane.*
    Congratulations! You're no longer a Clover!
    * King of the Road Syndrome -
    It's extremely inconsiderate to be trundling all by yourself down a two-lane road, see a car up ahead at a side street clearly waiting to make a right-hand turn into traffic - and refuse to slide over to the left lane in order to give the other driver room to enter the road. A related phenomenon is the Clover who refuses to use his signal - making you sit there at an intersection until Regal He either turns in or passes you by.
    When you see another driver trying to get onto the road, help him out and make room if you can. Move over to the left. And use your turn signal if you intend to make a turn. It's the nice (and safe) thing to do.
    * The stop-merge -
    When entering a freeway using a merge lane, don't stop and then pull out into fast-moving traffic. The whole purpose of the merge lane is to give vehicles entering a highway an opportunity to speed up to match the flow of traffic, then safely merge with it. If you stop or slow to a crawl, then pull into traffic that's going 20, 30 even 40 miles-per-hour faster, you are asking to be rear-ended. Not only do you create a dangerous situation for yourself, you force other drivers behind you to attempt the same high-speed merge from a standing start.
    This is a signature Cloverism. Avoid doing it!*
    * Blinded by the light -
    Some Clovers like to see where they're going - even if no one else can see a thing. They won't turn off their brights for oncoming traffic - temporarily blinding those other drivers. For a moment or two, they can't tell where they're going - not a good thing at 45 mph on a winding two-lane with narrow shoulders. So, be considerate - and safe: Turn the brights off when other vehicles are approaching, or when you are bearing down on a car up ahead.
    * Captain Tailgate -
    When you walk down the street, you don't walk an inch behind other pedestrians; even Clovers on foot usually leave enough room to avoid trampling the guy ahead. The same applies to driving. Following too closely means you probably won't have enough time and space to avoid slamming into the car ahead's rear end in the event he brakes suddenly. And if that happens, it'll be your fault, too - ticket-wise and higher insurance-wise. Rightly so. Clovers deserve to pay through the nose.*
    Beyond the safety issue, it is also highly aggressive to "ride someone's bumper." And leaving aside basic decency, even if you're Mike Tyson, there's always the chance the guy in the other car will be bigger, badder, or just plain meaner than you are.
    You never know what you might be messing with.
    Chicago vicinity
    549
    Now I'm no clove but last night coming home from work I was in the middle of a blizzard of epic proportions. Yeah third biggest snow fall in Chicago history. It was death on wheels. Anyway anything in my humble opinion over 20 mph was dangerous. I was the leader of the pack on my usual route home a windy normal 45 mph drive on a normal summer day was very treacherous yesterday and extremely slick.
    A jamock was tailing me all over my ass. I was going 30 mph but the problem was there were snow drifts in my path and I wasn't too keen on straddling the double yellows line because a car may pop up and be doing the same. I guess I felt like a clover but really wanted to beat the piss out of the guy tailing me. I was wondering am I a clover or just being too cautious by keeping it around 20 mph.
    Well the jag fuck turned left at the next exit and there was no other car behind. With his brights and inches from my bumper I thought I was a slow poke. God sometimes I just hate people sorry to say.
    Senior Member Mithrandir's Avatar
    Oct 2010
    256
    Post
    Quote Originally Posted by Adam View Post
    I would consider you driving for the conditions. The guy riding your bumper was a fool in my opinion. When the weather is bad, I try to drive safely for the conditions. If someone is in front of me I try to give them enough space in case they spin out or get stuck.
    Sincerely,
    Anthony
    'Many are my names in many countries,' he said. 'Mithrandir among the Elves, Tharkûn to the Drarves; Olórin I was in my youth in the West that is forgotten, in the South Incánus, in the North Gandalf; to the East I go not.' Faramir
    What nobler employment, or more valuable to the state, than that of the man who instructs the rising generation? Cicero (106BC-43BC)
    Do not meddle in the affairs of Win32, for it is subtle, and quick to anger. -D. Martinez
  1. Clover Rage.
    By BrentP in forum The Daily Clover
    Last Post: 03-16-2012, 09:09 PM
  2. ROAD RAGE
    By gail in forum Fight Traffic Tickets/Driving Issues
    Last Post: 11-08-2007, 04:21 PM
  3. Road Rage
    Last Post: 03-16-2007, 01:34 PM
  4. Since road rage is a bad thing...
    Last Post: 03-02-2007, 05:46 PM
  5. Road rage strategies
    Last Post: 12-10-2006, 07:50 AM
