Results 1 to 7 of 7
Thread: Retro-review: Ford Maverick, 1970-'75
    22,817
    There is an interesting species of near muscle car that came into being and briefly existed for a handful of years, beginning in the early 1970s - just as the high tide of the real muscle car was receding. These were cars that did not come with high-powered V-8s from the factory. But which did come with V-8s that could very easily be made high-powered. The rest was already covered. They had the necessary foundations: rear-wheel-drive layout, sporty two-door styling. And they often had advantages many of the factory muscle cars of the '60s did not, including low curb weight - and a low price tag.
    They were "do-it-yourself muscle cars" - just add horsepower.
    One of these was the Grabber version of Ford's Maverick. It existed for five short years, from 1970 through 1975. It was supposed to be merely an appearance package, but soon came to be more than that. The package appeared about halfway through the Maverick's first full year in production in Dec. 1970 and included:
    * Five Grabbber-specific colors: Brite Yellow, Grabber Yellow, Grabber Green, Grabber Blue and Thanks Vermillion (later color choices would include Freudian Gilt, Anti-Establishment Mint, Original Cinnamon and Hulla Blue).
    * Special "Grabber" side stripes and decals, blacked-out grille and rear valance panel, dual sport mirrors.
    * Trunk mounted spoiler.
    * Chrome drip moldings and door frames.
    * "Dual dome" hood with dummy scoops (1970-72 models).
    * Bench or bucket seats, trimmed in either Ruffino vinyl or Manston cloth (1972).
    * 14 inch wheels with special trim rings.
    This was in addition to neat Maverick features such as the "flipper type" rear vent windows, which could be opened outward to draw air into the car. "Select Aire" AC could be ordered, but the car's effective ventilation system made this unnecessary.
    Standard under the Grabber's dual-dome scooped hood was the base Maverick's 105 hp 170 CID straight six, with two larger (200 and 250 CID) sixes available as step-up options. But buyers in search of a muscle car in the rough checked off the option box for the 302 V-8, which, became available shortly after the Maverick's launch.
    It was not a Boss 302 - or even a four barrel 302 - but it was a V-8 and even better, it was a 302 V-8. The same basic V-8 that had made big power in other Ford vehicles and which only required a dusting with various factory and aftermarket performance parts to rise from its slumber. It had the potential to be a screamer - especially in a car that only weighed 2,786 lbs. - a flyweight even by early '70s standards. (For some perspective, the "compact" 1970 Chevy Nova SS weighed about 3,200 lbs.)
    The little V-8 was factory rated at 210 hp (SAE gross) in 1970 - or about 100 hp less than the output of a healthy 302. Part of the reason for the modest output was the extremely mild camshaft - a stick designed to deliver good low-speed torque for A to B driving. It was further choked-down by its economy-intended two-barrel carburetor and a very restrictive single exhaust system. Restrictive, not because of catalytic converters - these would not be an issue until 1975 - but rather because the super-tight packaging of the Maverick did not allow for factory dual exhausts or even a decent-diameter single exhaust system.
    The Grabber's 302 left the factory constipated - but this proved to be a blessing in disguise.
    As far as the government - and insurance companies - were concerned, this was an economy car. Not a performance car. It could, therefore, slip under the radar. It was cheap to buy - and even more important, it was cheap to insure - unlike an out-of-the-closet muscle car. And once the keys were in your hands - and the car in your garage . . . . A weekend and a few hundred bucks later could - and often did - transform the 302 into a ferocious performer. And no one except you - and those you smacked down on the street - would ever be the wiser.
    Even without changing cams, simply swapping out the stock two-barrel intake and carb for a four-barrel intake and carb, diddling the ignition timing to more performance-favorable calibrations - and installing what was known back in the day as a "bang plate" (shift kit) in the three-speed automatic (most of these cars came through with automatics) really woke the thing up. I can vouch for this personally, having helped so modify a '73 Grabber this way. We also managed to install a proper dual exhaust system - it takes some work, but it is doable - and changed out the economy-minded ring and pinion for a more aggressive set. The effect of these tweaks was like jumper cables on your nipples in January. The otherwise stock 302 - never opened up, with its factory low-performance camshaft in place - easily barked the tires on both the 1-2 upshift and the 2-3 upshift at WOT.
    Remember, this car only weighed about 2,800 pounds.
    A new (2013) Mustang GT weighs 3,622 lbs. - 800 pounds more.
    A new Mustang GT also costs $30,750 - vs. $1,995 for the base 1970 Maverick, plus another $194 for the Grabber package. Add the V-8 and you were maybe up to $2,500 or so in early 1970s dollars - about $14,000 in 2013 dollars. Imagine being able to buy a RWD car with a V-8 engine for that kind of money. Not used.
    Brand-new.
    This was part of the Maverick's genius. It was incredibly affordable, yet it wasn't a bottom feeding basic transpo unit like many of its competitors, especially those from Japan. You could get a V-8, after all. You could also get AC. And in addition to the Grabber package, there were almost as many a la carte options for individualization of each car as the 1964 Mustang had offered. In fact, the man responsible for the '64 Mustang was trying to recreate history by reviving the same basic idea - fun, affordable, personal - behind the '64 Mustang. In 1969, then-Ford Vice President Lee Iaccoca told Time magazine: "You dumb foot draggers you in Detroit what took you so long to know imports were going to hit a million? Now the market is damn well defined, and you know what the market says? 'Give me a hell of a good buy for two grand, will you? ' "
    Thus was born Ford's answer to the imports - among them, VW's hot-selling Beetle.
    But like the four-cylinder econo-boxes from Japan, the four-cylinder-only Beetle could never even dream of being a muscle car, while the Maverick - in Grabber trim - could be one with just a little bit of work, most of it backyard mechanic doable with basic hand tools.
    There were only two really significant issues with the Maverick, from the standpoint of high-performance. First, there was no limited slip differential option - and the most aggressive factory gearing was 3.08 (most Grabbers came through with a burnout-unfriendly 2.79 ring and pinion). Second, while a manual transmission was available, it was only a three-speed manual. If you wanted a factory four-speed car, you had to move up to a Mustang.
    And there were incidentals - such as the absence of a factory-available tachometer or "rally" gauge cluster. You got a speedo, fuel gauge and a few idiot lights.
    Even so, the Grabber was still a low-bucks way to get into a brand-new RWD/V-8 performance car - or at least, a RWD car with a V-8 that could be made into a performance car. Even by 1974, with inflation eating away at everything - by causing the prices of everything to rise - the Maverick's base price was still just $2,591. With the Grabber equipment, the V-8 and AC, the out-the-door price was in the neighborhood of $3,400 - just under $16k today.
    Not everyone could afford a GTO - or a Mustang. As much then - as now. Cars like the Maverick Grabber gave buyers who wanted something more than an import econo-box but which was still priced about the same a real alternative. Something they could work with.
    In 1973, the Maverick lost its dual-dome scooped hood - but since the scoops had never been functional anyhow, there was no loss in performance. What did hurt the Grabber's performance was creeping curb weight - up to 2,957 lbs. by '75. The additional beef was seen as well as felt. The 1970 model's aesthetically appropriate thin-line bumpers (available with twin vertical bumperettes) were replaced - also in '73 - with a set of massive-in-comparison "energy absorbing" bumpers easily three times their size.
    And, their weight.
    All the cars of the period were similarly afflicted - and if you wanted to identify the moment in time when external forces (the government and insurance mafia) were consolidating their death grip on the American car industry - the moment at which these forces and not consumers would determine what kinds of cars would be allowed on the market - it was the dread year 1973. "Unilock" seatbelt buzzers and ignition interlocks were mandatory standard equipment - and catalytic converters were less than 24 months down the road. The buzzers would go away for awhile - then return to afflict all new cars to this very day. Catalytic converters, of course, never went away. We just got more of them (most new cars have at least two and many have four or more).
    Simple, affordable cars were on the way out. Simple, affordable RWD cars with V-8 engines were soon to be rendered extinct forever.
    Ford discontinued the Grabber package after the '75 model year. The Maverick would live on for another two years. During these final two seasons, Ford gamely tried to keep the idea alive. A Stallion package that offered many of the erstwhile Grabber features appeared - very briefly - in 1976. It also had a sporty exterior/interior - and could be ordered with the 302 V-8 as well as Lacy Spoke aluminum wheels - which had never been available with the Grabber. But by '77, the gig was up. Maverick was cancelled - and both the Grabber and the Stallion were automotive history.
    The Maverick Grabber and Stallion (as well as their Mercury Comet equivalents) and a number of other almost muscle cars built during the early-mid 1970s like the Oldsmobile Rallye 350, the "Heavy Chevy" Chevelle, the Buick Apollo, the Dodge Aspen R/T, etc., are today perhaps the only not-yet-mined repositories of affordable old-school RWD/V-8 performance.
    Cars of a type that will probably never be made again.
    You can still pick up a nice one for under $5,000 or so.
    Good luck finding a factory-built muscle car - that still runs or with a body not Swiss-cheesed by rust - for anything near that.
    Nearly four decades after the last one left the line, the Grabber's appeal continues to increase. As they were when they were new, these cars are a performance bargain - and potential wolves in sheep's clothing.
    Throw it in the Woods?
    Gad, I had forgotten about the Maverick. I remember the name. I even remember the ads with those silly names for colors. But I can't remember having an opinion about them. For some reason they didn't register. Even looking at pictures now, they don't ring any kind of bell. Odd, because I remember the Pinto, which was not a car that generated fond feelings.
    1,073
    Click on the second photo in the third row from the top here:
    http://www.classictouringcars.com/gallery.html
    Yes, the leading car is a Maverick Grabber!
    2,178
    My dad had two. When he was semi-retired, he delivered papers. I was still in school and remember him waking me up at 3 in the morning. We lived next to the old Wabash-Erie canal and his car was down in it. He had a 1973 and a 1974. The '73 was one of the cars that liked to pop into reverse. While dad did like to take a nip now and then, he was sober going out on his route. I pulled him out in my pickup and took him around on his route. Just a wonderful thing for a teenager on a Saturday morning. The second one never popped into gear. I do know the Nixon era speedometer only read 80 mph and would keep going past it and come around.
    Senior Member BrentP's Avatar
    Jun 2011
    123
    Maverick speedometers didn't get the 85mph Claybrook treatment until '76, maybe '77.
    I had a '75, it went to about 110, I think my '73 goes to 120.
    My friend Frank's Comet was real nice, but changing the spark plugs required every plug wrench, adapter, and extension that I owned at the time, plus an open end wrench to turn the plug wrench on the right bank.
    When the oil pump died, I told him to have it towed. His trusted mechanic told him to just drive it in. ... over a mountain. Frank bought a crank. I didn't help him work on his car anymore.
    Friend's gf had one, mid 70's, not souped up. My memories/impressions of the car were: cheap, ugly, and worst of all the suspension and handling were like a Radio Flyer (or Little Red Wagon.) Not as bad as a Datsun B210 maybe, but close. I've never understood the US focus on straight line performance. Though I suppose a drag race is a thrill, street or track, I always loved cars that could handle a road, not just sprint in a straight line for a few seconds. Probably had something to do with me heading uphill to Yosemite whenever I had the chance. Early 90's I was shopping for a cheap used car, answered an ad for a Ford Pinto - thing had a V8 in it, would burn rubber without trying or intending to, and the heavier engine threw off the balance & made braking and handling worse than a normal Pinto. Seemed inherently unsafe, not what I needed anyway so it was an easy & immediate pass on that one.
