Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Air Conditioning
  1. #21
    3,421
    Quick suggestion, Don. Whip the rad out and, if you cannot see where the leak is from, get a shop to pressure test it. At least then you will know whether or not it is the rad and you will know how many rows your rad has.
  2. #22
    663
    I've started the job already. I have it at my other home here in Reno (15 miles north of here) where I have more room to work on it. I started late with a hot engine so I have a little ways to go to remove the radiator. If I get up there tomorrow, I should be able to get the radiator out. Regardless if I find a leak or not, it will get a new radiator. I think this one has been in there since 1997!
    -Don- Reno, NV
  3. #23
    663
    I completed the job at my other Reno home. It did have evidence of leaking near the center bottom half of the radiator on the front side that faces the A/C condenser, where I cannot see it while mounted in the vehicle.
    They had a new Jeep radiator in stock at the local auto parts store (O' Reiley's Auto Parts) where I also get a 10% discount for once serving in the military. The radiator removed and purchased was a single core. It only cost about $105.00.
    I drove the Jeep 15 miles with the A/C on to bring it back to this house. It didn't leak a drop.
    The hoses and such were very easy to remove because they have only been on for about a year. Around a year ago, I replaced the water pump, thermostat, and heater hoses so this time, I only replaced the radiator and coolant and nothing else.
    -Don- Reno, NV
  4. #24
    3,421
    Sighs of relief all round then, Don.
