Results 1 to 13 of 13
Thread: Stuck in Park, 99 Jeep
    688
    This morning, my 1997 Jeep Grand Cherokee <5.2L> (left out over night in 15 degrees F / -10C) could not get out of park. The button on the left side of the transmission selector would not press in.
    I started the engine and warmed up the inside for 15 minutes or so with the heater, as I assume the engine will help warm up things under the hood a bit.
    After more than an hour of trying to move the gear selector, I gave up and took a different vehicle to go to a restaurant for lunch and do other stuff. Shut the Jeep Engine off.
    Around two hours latter, I get home and back to the Jeep. Now, the shiftier works perfectly and I am able to drive it again.
    Any ideas on what caused this problem? Anybody here know how this stuff works? Is it all mechanical or is it electrical too?
    It's normal for the brake pedal having to be pressed in to be able to shift out of park. I checked the brake lights when it was NOT working and the brake lights worked normally (I checked this in case it works electrical from the brake).
    But another unusual thing was when it was still stuck in park, I could fully steer the car from full left to full right and and back with the ignition key completely out. The steering lock wasn't working.
    So how does this stuff work? No problem now, but I know it can happen again at any time, perhaps from the cold.
    -Don- Reno, NV
    3,490
    Hi, Don.
    The release button is part of a combination safety system. I think it comprises a solenoid, some wiring and a cable, and works in conjunction with the brake servo.
    My guess is that the cable was wet/damp and froze up - not surprising outside at -15 F. Running the engine and leaving it for a while let enough warmth seep through to free the cable off.
    Just a wild guess, but I have been known to be right sometimes.
    688
    Hi, Don.
    Yeah, I think there is a relay involved. It might even be part of the switch assembly on the gear selector itself. I figure the relay (or whatever it uses) can be quite small, as I assume it deals with fairly low current just to lock a switch.
    Anyway, it has not happened again, not even after the very next very cold night.
    BTW, it was +15F, not -15F. And it did NOT work after warming the engine, at least not right after, up to 30 minutes or so, when I shut off the ignition, gave up and went to lunch. But a couple of hours later, when I got back, everything was back to normal, as if it never happened, yet it was still quite cold outside.
    Anyway, I have been driving this Jeep a lot and no more such problems. If it happens again, I will look under the gear selector cover and see how it works. I figure at worse case, I can release the switch with 12 volts or at least figure out what keeps the switch locked in the tranny selector.
    -Don- Reno, NV
    3,490
    Oops! +15 F/-10 C, my bad.
    What I was guessing was that, over time, the residual warmth from the engine run was enough to free off whatever was sticking.
    688
    Yeah, that was kinda my guess too. The extra couple of hours was all that was needed. Still has not happened again, and I have been riding this 97 Jeep every day.
    I got my Jeeps mixed up in the title, I own both a 97 Jeep Grand Cherokee Laredo (5.2L) and a 99 Jeep Grand Cherokee Laredo (4.7L).
    It was really the 97 Jeep that had the problem.
    -Don- Reno, NV
    2,194
    -Don- Reno, NV
    The park setting has to be released by a relay and your foot on the brake pedal. that was a response to Fords problems on unintended reverse at times in the early 70's. I would say either your ignition switch or the key lock on the steering column (they are separate but work together) is getting worn out.
    The lockout can be defeated but it's a pain. there is often a small hole you can stick a pin into to release it. However, I had a 2000 Cherokee (the smaller one) with a similar problem and if you turn the ignition key far enough to release the steering lock, but NOT far enough to turn the systems on, you can slip the shifter to neutral and start it there. Contrariwise, you can turn the ignition almost but not quite to the OFF position and get the same result. you'll feel a little notchiness in there and can go by that.
    688
    Does it use the same brake swich for the brake lights?
    Where is the pin hole located? Is it in the gear selector?
    When I had the problem, I played around with the ignition switch as I had my foot on the brake pedal--all to no avail.
    -Don- Reno, NV
    2,194
    I don't remember exactly where the small hole is. I just turn the ignition key far enough to unlock the steering column but not far enough to turn power on. I put my foot on the brake to keep it from rolling away. Move the shifter to neutral and start it.
    3,490
    In case it happens again, is this any help, Don?
    If a malfunction occurs and the shift lever cannot be moved out of the PARK position, you can use the following procedure to temporarily move the shift lever: 1. Firmly apply the parking brake.
    2. Turn the engine OFF.
    3. Remove the rubber liner from the cupholder (located next to the shifter on the center console).
    4. Using a screwdriver or similar tool, carefully remove the shift lever override access cover, located on the bottom of the cupholder.
    Shift Lever Override Access Cover
    5. Press and maintain firm pressure on the brake pedal.
    6. Using the screwdriver or similar tool, press and hold the shift lock lever down.
    7. Move the shift lever to the NEUTRAL position.
    8. The vehicle may then be started in NEUTRAL.
    9. Reinstall the shift lever override access cover and install the rubber liner into the cupholder.
    688
    Thanks for the info., but it never happened again. Also, it has not been that cold since then in Reno. Besides, I drove that vehicle back here to sunny warm CA where the winters are often warmer than the summer (summer fog is common here).
    I will probably have to wait until next December to see if I still have the problem. If I stay in Reno and don't come back here to escape the cold!
    -Don- SSF, CA
    Wahiawa
    587
    Speaking of shift lever, my 2009 Toyota Camry's shift lever configuration is remarkably similar as your vehicle , Don. Almost every time I start the car, sometimes I really have a hard time shifting it out of park even on a warm day. I suppose it is made that way with all cars to prevent it from accidentally shifting out of gear? Maybe ?
    3,490
    It is usually necessary to apply the footbrake firmly in order to release the shift lever from 'Park'. The release mechanism, is operated
    via the footbrake and a relay in most cases. My Mazda needs quite a hard pressure on the brake to shift from 'Park'.
    Wahiawa
    587
    via the footbrake and a relay in most cases<
    Is that right? Didn't know that.
    Learn something new, each day !!
