Thread: Lucas electrics.
    2,185
    Lucas electrics.
    I've had the pleasu.....um experience of working on British cars before. Mostly MG's. Lot's of cleaning and dielectric grease makes them work, sort of. In that vein, I found this.
    ELECTRICAL THEORY BY JOSEPH LUCAS
    Positive ground depends on proper circuit functioning, which is the transmission of negative ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work. We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing.
    For example, if one places a copper bar across the terminals of a battery, prodigious quantities of smoke are liberated and the battery shortly ceases to function. In addition, if one observes smoke escaping from an electrical component such as a Lucas voltage regulator, it will also be observed that the component no longer functions. The logic is elementary and inescapable!
    The function of the wiring harness is to conduct the smoke from one device to another. When the wiring springs a leak and lets all the smoke out of the system, nothing works afterward.
    Starter motors were considered unsuitable for British motorcycles for some time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
    It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, hydraulic forks and disk brake systems leak fluid, British tires leak air and British Intelligence leaks national defense secrets.
    Therefore, it follows that British electrical systems must leak smoke. Once again, the logic is clear and inescapable.
    In conclusion, the basic concept of transmission of electrical energy in the form of smoke provides a logical explanation of the mysteries of electrical components especially British units manufactured by Joseph Lucas, Ltd.
    And remember: "A gentleman does not motor about after dark."
    Joseph Lucas "The Prince of Darkness"
    1842-1903
    A few Lucas quips:
    The Lucas motto: "Get home before dark."
    Lucas is the patent holder for the short circuit.
    Lucas - Inventor of the first intermittent wiper.
    Lucas - Inventor of the self-dimming headlamp. The three-position Lucas switch--DIM, FLICKER and OFF. The other three switch settings--SMOKE, SMOLDER and IGNITE.
    The Original Anti-Theft Device - Lucas Electrics.
    If Lucas made guns, wars would not start
    Back in the '70s, Lucas decided to diversify its product line and began manufacturing vacuum cleaners. It was the only product they offered which did not suck.
    3,488
    Quote Originally Posted by Grouch
    "It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, hydraulic forks and disk brake systems leak fluid, British tires leak air and British Intelligence leaks national defense secrets."
    But surely you appreciate that British 'bikes, vans, trucks and cars were specifically
    designed to leak as a customer/user aid. Once your vehicle, no matter what type,
    stopped 'dripping' then, in the case of engine oil, one knew it was time to top up.
    In the case of shocks it was time to replace them, brake systems it was time to top-up
    etc, etc.. One never needed to refer to an owners manual. And was it not Lucas who
    invented
    the 'Blue smoke diagnostic system' in order to overcome the problems caused
    by wire and plastic manufacturers who could not produce impervious products. The
    German, American and Japanese manufacturers are still - from my experience - using
    invisible smoke, at least I have never seen any.
    In the case of the British Intelligence leaks these were (and still are) quite deliberate -
    as our intelligence was invariably wrong this was a carefully planned exercise in
    spreading false information. Thus our enemies and the public in general were, and
    still remain, confused.
    We may be an eccentric nation but there is always method in our madness (or is it
    madness in our methods?)
