Thread: cranks, no start, no code
    MikeHalloran
    I am embarrassed to admit that I've been chasing this problem for two solid weeks. I thought I'd post the results on the chance someone else might save some time.
    Vehicle: 2002 Ford Explorer EB 4.6LV8
    Symptom: Sudden incidence, cranks fine, doesn't start, doesn't set any codes
    Inspected and tested, no problem found: fuel tank, fuel pump, fuel filter, crank position sensor, fuel pressure, MAP sensor.
    Problem found: Black goo blocking Idle Air Control solenoid valve. The valve is supposed to be open a little bit all the time, and opens farther as the ecu pulses it for more idle air. The engine was getting _no_ air, so it wouldn't start.
    Symptom allowing diagnosis: It _would_ start if the throttle was held half open during cranking; it just wouldn't idle. It's been years since I've owned a carbureted car, so I didn't even try opening the throttle until today.
    Corrective action: Filled the valve interior with Brakleen and cycled the solenoid with 12V a few dozen times. After the first cycle, the Brakleen started draining out, so I kept flushing until it came out clean, and reinstalled the same valve. Luck was with me; the gasket remained intact, so I didn't even have to replace that.
    Re: cranks, no start, no code
    Thanks, I wish more people would post their weird hard to find car problems here after they have been repaired. Now I know if I can't start a car, try pressing half way down on the gas pedal, something I have not tried in years. I no longer own any 4 wheel vehicles without FI and like you, it would take me a while to even think about trying such.
    22,948
    Good stuff; I'm glad it turned out well - and thanks for posting both the symptoms and your diagnostic approach in detail. I am betting there are others here who can benefit from this kind of info!
    Good find.
    IAC valves are expensive, too.
  1. Check Engine Light on (code P0432)
    By bikerlbf406 in forum Car Care & Repair
    Last Post: 08-30-2011, 08:20 PM
  2. They start 'em early...
    By Eric in forum The Maggots...
    Last Post: 09-13-2010, 11:20 AM
  3. Doomed from the start?
    By Eric in forum What happened to our liberty?
    Last Post: 02-25-2010, 05:40 AM
  4. Gas Prices By Zip Code
    By Jim Rose in forum Motor Mouth
    Last Post: 01-03-2008, 07:56 AM
  5. A helmet's just a good start!
    Last Post: 08-07-2006, 02:48 PM
