Results 1 to 10 of 10
Thread: On the subject of retreaded truck tires...
    here's an article about a move by a state senator in Florida.
    http://www.landlinemag.com/todays_ne.../013007_05.htm
    First, he needs to be educated about retreads. Then, he needs to do something useful, like maybe an alarm on each tire that's underinflated?
    By the way, most trucks with the new super wide singles have such a system.
    D_E_Davis
    Re: On the subject of retreaded truck tires...
    Provided, that is, if he's capable of comprehanding that education.
    Well, at least he was realistic enough to recognize that his bill has virtually no chance of becoming law.
    2,072
    Another bloody polie! Hell I hope that message doesn't get down here. Retreads in my experience are as good a a new tyre, unless the original casing has been damaged. I think early retreads did come apart, but systems improved.
    Truckies here would revolt I am sure if similar laws were propsed in OZ
    Rex
    MikeHalloran
    He said his intent was to open a dialogue. I'm not sure what venue would be appropriate, but maybe a dialogue would be a good thing.
    I have no idea if they were retreads or not, but I see a fair amount of detritus from failed truck tires on Florida highways, mostly intact or nearly intact treads not showing obvious wear.
    Maybe it's the heat, or the high average speeds, or the projectiles in the road.
    I've averaged more than one puncture per year for 29 years in FL, against a total of not more than five in Northern states in a similar period before that. Maybe we should sweep the roads regularly.
    D_E_Davis
    For me it's difficult to determine if a hunk of rubber debris is from a truck tire or from a passenger/SUV tire, when I'm flying by at freeway speeds. I know the automatic conclusion is that it came from a truck, but others challenge that view. I can say that those treads thrown off are almost always caused by underinflation, with a subsequent heat buildup to destruction.
    The problem is that the debate has already been held, and the results are in. Truck tires, whether retreads or virgin treads, fail due to heat, almost always caused by underinflation.
    As I said earlier, here's one hint. If you see wires sticking out of the piece of tread on the road, it wasn't a retread failure.
    Underinflation is the big problem, and most large companies have a program in place to check and correct inflation problems on a regular basis.
    MikeHalloran
    The radius makes it clear the treads are not from Minis.
    So, the large outfits have programs in place. I wonder about the low- buck one- truck outfits?
    We've got scales at the borders, and special DOT cops roaming the roads, and if I understand correctly truckers are required to have tire gages in their possession. Do they need an incentive to use them?
    D_E_Davis
    Think in-state. Local moving vans, dump trucks, local delivery - none of these are regulated or watched like the interstate trucks.
    2,072
    I tend to check my motorbike tyres every 10 days, my 4WD about 3 weeks
    Rex
  1. We're all subject to a social contract
    By doncoo in forum What happened to our liberty?
    Last Post: 02-28-2012, 04:17 PM
  2. A few question on the subject of religion....
    Last Post: 04-08-2008, 06:48 AM
  3. Replies: 9
    Last Post: 12-22-2007, 03:22 PM
  4. Off the Subject -- Church is not all Boring
    By ColleenC2 in forum Motor Mouth
    Last Post: 05-12-2007, 10:02 PM
  5. Entirely off the subject of cars...
    Last Post: 04-26-2007, 09:03 PM
