Thread: Forum mods?
    D_E_Davis
    Forum mods?
    I'd like to see the following changes:
    1. I'd like the "unread posts" and the "new replies" links to be added at the bottom of the page as well as leaving them at the top. On many long threads I must page up quite a bit just to reach these links.
    2. I'd like the "unread posts" flags to remain set until I actually read them. As it is now, when I must leave with some posts unread on my next visit no "unreads" show.
    22,769
    Re: Forum mods?
    I'll see what Martie says; she's the "tech" side of things here!
    1,072
    Re: Forum mods?
    The flags do remain set. The problem is that from the menu page you can only list unread posts since your last visit. If you read all of those & click on 'Show unread posts since last visit' you will then get a message 'No posts found. Show all unread posts?'.Click on that & all your unread posts will be listed. It's not ideal, as you must read all the posts on the 'since last visit' list to be able to list all unread posts; using the 'mark read' option on the 'since last visit' list appears to clear 'unread' flags globally.
    It shouldn't be too difficult to add 'show all unread posts' to the opening menu - most forum software allows that.
  1. Forum Rules
    By Mase in forum Secession Talk
    Last Post: 12-03-2008, 10:42 AM
  2. subtle 3G Camaro mods:
    By misterdecibel in forum Car Care & Repair
    Last Post: 06-27-2008, 03:12 PM
  3. What's with the time on this forum?
    Last Post: 11-10-2006, 08:09 PM
  4. forum use
    Last Post: 11-10-2006, 02:56 AM
  5. Old forum has closed
    Last Post: 09-18-2006, 07:40 AM
