Originally Posted by
Eric
In the case of oil, there are multiple standards; some oils don't meet the higher ones.
I bet the same applies to the other fluids. Dexron automatic fluid, for example, has gone through a number of "updates" over the years - with newer transmissions requiring the latest formulation (Dexron III - or whatever it is now), and so on.
Some automakers have their own recommended brand(s) - or specifically require that whatever fluids are used meet a specified rating, else you risk voiding your warranty, etc.
The thing to do is find out what service specification/standard/rating applies (or is recommended for use in your vehicle) and if the product you are thinking of using meets the standard, etc. it should be fine to use it.
