Results 1 to 7 of 7
Thread: trip odometer
    Dec 2006
    Granite City, Illinois
    360
    trip odometer
    Heres another question about my car as I just noticed it was not working, however have no clue about what could cause it to stop working. I haven't reset my trip odometer in probably a little over a month. I just refuelled my tank today & reset the odometer while doing so. It reset to all zero's like it should haved, however is not working now. I have no clue how to even figure out what could be wrong with it as I have never done any work at all on gauges. The speedometer, odometer & all other gauges work, so its not a big deal, just something I'd like to fix if I can figure out what is wrong with it & if I could fix it myself.
    Re: trip odometer
    Have you pushed the buttons a couple of extra times?
    OK, that's the extent of my expertise!
    22,971
    Re: trip odometer
    Quote Originally Posted by bikerlbf406
    It's been awhile since I messed with one - but if it's mechanical, it may just be worn/loose damaged plastic gears. The real problem you may face is getting to it (you may have to partially disassemble the dash to get to the instrument cluster) and then dealing with any "odometer tamper-proofing" that was built into it to prevent anyone fiddiling with the digits. If you have a shop manual, it should have the info/instructions, etc.
    2,072
    Re: trip odometer
    That generally works for me too. Sometimes the button just sticks a bit
    Rex
    Re: trip odometer
    Yeah, I'm assuming it has some effect of "disengaging" the gears, maybe, so it can reset, and they don't fully re-engage?
    As I said, speedometers are a black art, as far as I'm concerned.
    Dec 2006
    360
    Re: trip odometer
    I appreciate all of the replies & I decided to push the button a couple more times just to see if it would start working although it reset the very first time. After pushing 2 or 3 times it did start working again. Thanks for the help.
    Re: trip odometer
    Yes!!!! I'm a mechanical genius!!!
    Or something...
  1. This summer trip
    By CharlieCLU in forum On Two Wheels
    Last Post: 03-31-2012, 08:58 PM
  2. Suss out odometer fraud
    By Eric in forum How-To
    Last Post: 07-24-2010, 11:47 PM
  3. Day Two, Backbone trip
    By Oldfrtbkr in forum On Two Wheels
    Last Post: 04-29-2010, 10:47 PM
  4. Day three, Backbone trip
    Last Post: 04-28-2010, 09:11 PM
  5. Took a little Trip
    By Mase in forum Motor Mouth
    Last Post: 10-29-2009, 06:48 PM
