Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Tire psi?
    Tire psi?
    In my 1999 Dodge Ram 1500 (5.2L) pickup truck, I checked the tire PSI today. The sticker on the driverr side door jam says fill to 41 PSI. I hear we are supposed to go by this sticker and not what it says on the tire.
    But what about when the max pressure on all four tires say "35 PSI maximun", but the sticker on the vehicle says 41 PSI is the normal PSI? That's the case with this truck! This is the first I have seen a higher PSI on the sticker than the max shown on the tires.
    So should it be 35 or 41 PSI?
    Re: Tire psi?
    Are the tires on it the original tires, or identical thereto? If not, did you check that the size was identical, including any "LT" size code?
    22,994
    Re: Tire psi?
    Are the tires you have OE? Or OE spec? It doesn't sound like they are. I'd be careful about over-inflating the tires - and would not exceed the stated max recommended psi listed on the tire sidewall.
    Re: Tire psi?
    I'd also be careful about carrying any heavy loads until you can verify this.
    Re: Tire psi?
    It's pouring down rain here (again), or I'd go out and check on my F150. It has the original LT tires on it, and I don't remember the recommendations on it. I know I check them and go to the full allowable pressure when I carry a capacity load.
    Re: Tire psi?
    "Are the tires on it the original tires, or identical thereto?"
    The sticker says the tires should be P225/75R16XL.
    All four tires are P245/75R16.
    MikeHalloran
    Re: Tire psi?
    Use the pressure marked on the tire.
    The originals must have been replaced with tires that can't take quite as much pressure.
    Re: Tire psi?
    "Use the pressure marked on the tire."
    That's what I figured. But I didn't check what the tires said until after I filled them all to 41. I will remove a few PSI before I use the truck.
    BTW, is the "P245" mean my tires are thicker than stock?
    BTW, this pickup truck has a habit of fishtailing in snow, but they are all AT tires. Is there anything else practical that can help in the snow? By any chance would thinner stock tires be better in snow ?
    Or is this rather normal for longer pickups (quad door cab) in the snow? We try not to drive it in the snow anymore after a few near accidents and sliding off the road more than once. All four brakes seem to be okay, but this happens when braking. It does have ABS, but there doesn't seem to be any indication that it is really working. I cannot hear the brakes "click" in the snow as I can with my Jeep. We usually drive the 4WD Jeep in the snow, but once in a great while, we need a truck to move something or whatever.
    Re: Tire psi?
    Wider. The value is in millimeters.
    Too wide or too narrow, and they won't fit the wheel rim.
    Re: Tire psi?
    That was what I meant. Wider, not "thicker".
    Thanks for the info.
    Re: Tire psi?
    -Don-[/color]
    Pickups are usually pretty lousy in snow, due to their weight being concentrated in the front. It SHOULD have Positraction, but may not. That helps, but it's not a cure-all.
    The wider tires could make handling a little worse on the highway, because the tires are made for a little wider rim, so the sidewalls are flexing. The lower pressure will contribute to that. LT (or XL) tires have stiffer sidewalls, usually.
    In other words, someone did you no favor by putting car tires on that truck.
    MikeHalloran
    Re: Tire psi?
    Narrower tires with aggressive tread would be less awful in snow.
    A few hundred pounds of sand, cement, tools, whatever, in the bed would help more.
    Re: Tire psi?
    I have driven pickups in the snow, and I've always gotten where I'm going...but I can't say it was fun.
    1,073
    Re: Tire psi?
    Have you checked the load rating on the tyres? I don't know what 'XL' signifies, but I suspect it could mean 'extra load' or something similar. The fact that the tyres are marked with a lower maximum pressure than the truck manufacturer specifies leads me to believe that you may have tyres which are not load-rated high enough for the vehicle weight.
    I'd inflate to the maximum pressure marked on the tyre, but as this is well below the vehicle manufacturer's recommended pressure it could have an adverse effect on handling.
    I think the best thing you can do is contact the tyre manufacturer & ask if these tyres are suitable for your truck; if they are suitable they should also be able to give advice on the correct pressure to run them at.
    Re: Tire psi?
    I often hear about the disadvantages of wider tires. Poorer MPG. not as good in snow, etc.
    But what are the advantages, if any, of wider tires?
    Re: Tire psi?
    More bling.
    And, theoretically, more traction on pavement.
    Re: Tire psi?
    "More bling"
    WTF (excuse my army talk) is "bling"?
    22,994
    Re: Tire psi?
    "More bling"
    It's a "hip hop" rap culture term; it refers to gaudy equipment like add-on chrome, oversized wheels, etc. Think Caddy Escalade with 21 inch wheels and thug rap booming on the stereo...
    Re: Tire psi?
    My age is showing again--along with the fact of having no kids. ;D
    22,994
    Re: Tire psi?
    Don't worry about it - you are not missing out on anything.
    Rap - and rap "culture" - is perhaps the most loathsome, noxious development of the past 20 years.
    Even worse than the cell phone!
  1. New tire time?
    By RebelKnightCSA in forum Car Care & Repair
    Last Post: 02-06-2012, 09:53 AM
  2. Tire Opinion
    By dBrong in forum Advice/Questions/Tips
    Last Post: 08-18-2011, 11:24 AM
  3. Tire Gages
    Last Post: 05-02-2011, 05:48 AM
  4. Touring Tire
    By dom in forum On Two Wheels
    Last Post: 03-20-2010, 07:47 AM
  5. Tire Safety
    By Jim Rose in forum Car Care & Repair
    Last Post: 12-06-2008, 04:02 PM
