I've mentioned the Anti-Corrosion product ACF-50 a couple of times on this forum. For those who wanted to know a bit more about its properties here is a bit more information.
ACF-50 (Anti-Corrosion Formula) was originally designed to protect aircraft from existing and new corrosion and is now available to motorcyclists. Aviation products have to meet rigorously high standards and ACF-50 not only meets these but has been awarded Aviation approvals - MIL-SPEC 81309 types II and III which means it is 'approved for ferrous and non-ferrous metals, electrical systems and electronic components'. The US Navy carried out tests using ACF-50 on the jets on their Aircraft Carriers. They found that ACF-50 so significantly reduced the corrosion they had previously experienced they now use ACF-50 all the time! It works in that type of harsh environment so imagine how well it's going to protect your bike! When applied ACF-50 forms an 'Active' ultra-thin clear film that will kill any existing corrosion cells and will protect your bike against new corrosion forming. On areas such as switches or under the tank and seat, one application will last up to 12 months. Other more exposed areas will need topping up more regularly. ACF-50 has the ability to 'chemically neutralise road salt' and water will bead on contact and literally bounce off. Ideal for the bike that is used all year round in all weathers, a superb service spray as ACF-50 is also a lubricant and penetrant (without loosening structural attachments) and if you put your bike away for the winter, applying ACF-50 will ensure that moisture will not be allowed to cause any damage! Untreated moisture will creep into cracks and will not freely evaporate - ACF-50 actively ejects moisture from these areas.
The Facts
Kills existing corrosion and prevents new
'ACTIVE' for up to 12 months
Excellent lubricant and penetrant
Approved for use on electrics and engines
Easily applied non-drying, ultra thin, clear film
Very economical
Contains no wax, silicon, Teflon or water
How to Use
ACF-50 is 95% product, hence virtually no propellant. Keep the tin in a warm environment, shake very well before use and remember a little ACF-50 goes a long way, so keep a rag handy to soak up any excess - then use the rag to help spread the product. ACF-50 has strong capillary action so will creep into all the areas that moisture can, 'actively' pushing out moisture and replacing it with protection. Go cautiously when applying to callipers to ENSURE YOU KEEP IT OFF THE BRAKES. Use ACF-50 anywhere, except the brakes, on your bike including the engine and exhaust (will smoke on first start and burn off down pipes but still slows down corrosion process). Safe on paintwork, most rubbers and brings up black plastic trim a treat. ACF-50 contains no water and is approved for electrics so spray directly into electrical joints and components where it will prevent corrosion induced failures and high resistance joints. Works well at stopping dirt, mud and salt from sticking. You can come back from a winter ride with the bike 'white with salt' - a quick wash off and it's gone with the bike still protected. Areas not in direct contact with the elements ie tank/seat areas, electrics require treating approx once a year. Other exposed areas re-apply as necessary. You can tell the product is still 'Active; as water will bead on contact...having no water content and not being water soluble ACF-50 only dissipates by being 'sacrificial' whilst stopping existing or new corrosion so just re-treat as required.
Remember, ACF-50 protects jets on US aircraft carriers! If it works for these jets in these conditions, think how well it's going to work for your bike!
