Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Power Steering Fluid
    Seeking some expert advice on refilling steering pump.
    Chilton repair says to use Dexron automatic trans fluid to cars 1976 and earlier (GM cars). Can I use regular fluid. (Don ?) My '76 Chevy is about 3/8 inch low. Checked it "cold". Will any bad reaction result in using other than ATF?
    D_E_Davis
    Re: Power Steering Fluid
    The safest thing is to use what GM recommends. Mixing different fluids sometimes is OK, sometimes not. Considering the relative cost of the Dexron against repair of the steering pump, I'd get the Dexron.
    I thought they used power steering fluid, not ATF???
    22,995
    I agree with Dennis; stick with what your owner's manual recommends.
    D_E_Davis
    That used to be the case but it appears that many makers have switched to ATF in the pump also.
    That would not be the case for a '76 Chevy though, would it?
    "Chilton repair says to use Dexron automatic trans fluid to cars 1976 and earlier (GM cars)."
    I've always used "power steering fluid" in all my 1970 GM vehicles. I don't recall any of the older vehicles asking for ATF in the power steering pump.
    quote]
    [/quote]
    I don't recollect what I put in the pump previously so I took samples from both pump and trans dipsticks and wiped them on white paper towel. Pump oil is yellowish and trans oil is pinkish so that gives us a clue. I might as well replace it with new ATF. Is there a drain plug or must I suction it out? I may sop it out with some clean rags and absorbent paper, what do you think?
    I would go with what the manufacturer recommends.
    Lots of people get into trouble with Hondas by putting 'better' fluids in the transmissions and differentials (RedLine, ATF, etc) instead of the recomended fluids. They usually end up with expensive repairs.
    To change out the power steering fluid, I would use a clean turkey baster to siphon out as much of the old fluid as you can, top it off with new, and then go for a short drive (or just move the wheel from lock to lock a few times). I'd then repeat the process twice more, which should result in a reasonable amount of new fluid getting into the bowels of the system, and little or no air.
    Got me a qt of NAPA ATF Dexron III ,also a baster to suck out and also to fill the pump which will give me control so as not to overfill it. I hope NAPA brand is good enough? If not I can return it for a refund.
    NAPA brand is pretty much always at least "good enough". Most of the time their stuff is top notch. Especially oil filters and batteries.
    "I'd then repeat the process twice more, which should result in a reasonable amount of new fluid getting into the bowels of the system, and little or no air."
    What are the symptoms of getting air in the power steering fluid or pump lines? I have replaced power steering pumps and never had a problem.
    [quote
    [/quote]
    Yeah I was also wondering about how air gets into the power steering fluid. I can see that happening in the hydraulic brake lines but steering???
    22,995
    There is a bleeding process you're generally supposed to follow; usually there are instructions with the new pump...
    "There is a bleeding process you're generally supposed to follow; usually there are instructions with the new pump..."
    There were no such instructions when I replaced the PS pump in my 97 Jeep GC. And there were no problems.
    But what is supposed to be the possible symptoms of air in the PS lines?
    22,995
    I think since the system is "open" (any air can bleed out into the reservoir, which though capped isn't pressure sealed, etc.) the problem takes care of itself through normal operation. I have bled/flushed PS pumps by disconnecting the low pressure line and putting the open end into a catch bucket while topping off the reservoir with fresh fluid as the system operates.
    I would expect any air bubbles in the system to manifest in either intermittent jerkiness or loss of PS assist....
    Like Eric said.
    But the bubbles will eventually work themselves out. It's just that if you do a change (and get air in the system), and then immediately go driving, having the unexpected loss of PS assistance can be, uhhh, unexpected.
    "But the bubbles will eventually work themselves out."
    Perhaps by the time one backs out of the garage, if not sooner!
    I never noticed such a problem and I have disconnected or replaced several PS pumps.
    2,191
    The pump will growl and make weird noises. Possibly some jerking to it too. Just move the wheels back and forth a couple of times and the air will pass through the system. It will then bubble up to the top and disappear. Leave it in and it can cause some problems with excessice wear due to lack of lubrication. Air bubbles don't lubricate.
    Eric,
    Do you happen to know the capacity of fluid in the PS pump?
  1. GM power steering recall
    Last Post: 03-02-2010, 08:31 AM
  2. power steering problems
    By Bear in forum Car Care & Repair
    Last Post: 06-26-2009, 10:22 PM
  3. power steering shutters/shaking
    Last Post: 02-25-2009, 12:26 PM
  4. power steering fluid flush?
    Last Post: 02-25-2009, 12:20 PM
  5. Trans Fluid Question
    By swamprat in forum Car Care & Repair
    Last Post: 02-24-2009, 05:34 PM
